Need help removing Critical_warning screensaver
Post by KailiWeil on 24th September 2009, 10:10 pm
Hi-
I have all of thse random boxes popping up saying I have been infected and need to install a antivirus software etc.
When I went to my desktop properties something called crtitical_warning is showing up. I cannot remove it or change
it to anything else. Can you please help me?
KailiWeil
Posts Posts : 3
Joined Joined : 2009-09-24
Points Points : 26325
Re: Need help removing Critical_warning screensaver
Post by Belahzur on 24th September 2009, 11:58 pm
Points Points : 245091
Post by KailiWeil on 28th September 2009, 3:42 am
Scan saved at 9:41:09 PM, on 9/27/2009
C:\Program Files\Intel\Wireless\Bin\EvtEng.exe
C:\Program Files\Intel\Wireless\Bin\S24EvMon.exe
C:\Program Files\Intel\Wireless\Bin\ZcfgSvc.exe
C:\PROGRA~1\Intel\Wireless\Bin\1XConfig.exe
C:\PROGRA~1\COMMON~1\AOL\ACS\AOLacsd.exe
C:\Program Files\TOSHIBA\ConfigFree\CFSvcs.exe
C:\WINDOWS\system32\DVDRAMSV.exe
c:\PROGRA~1\COMMON~1\mcafee\mna\mcnasvc.exe
C:\Program Files\Intel\Wireless\Bin\RegSrvc.exe
c:\Toshiba\IVP\swupdate\swupdtmr.exe
C:\WINDOWS\system32\igfxtray.exe
C:\WINDOWS\system32\hkcmd.exe
C:\Program Files\Intel\Wireless\Bin\ifrmewrk.exe
C:\Program Files\ltmoh\Ltmoh.exe
C:\WINDOWS\AGRSMMSG.exe
C:\Program Files\Apoint2K\Apoint.exe
C:\Program Files\TOSHIBA\TouchPad\TPTray.exe
C:\Program Files\TOSHIBA\Accessibility\FnKeyHook.exe
C:\WINDOWS\system32\TCtrlIOHook.exe
C:\Program Files\TOSHIBA\TOSHIBA Controls\TFncKy.exe
C:\Program Files\TOSHIBA\E-KEY\CeEKey.exe
C:\WINDOWS\system32\TPSMain.exe
C:\Program Files\TOSHIBA\Touch and Launch\PadExe.exe
C:\WINDOWS\system32\ZoomingHook.exe
C:\Program Files\TOSHIBA\TOSHIBA Zooming Utility\SmoothView.exe
C:\Program Files\Toshiba\Tvs\TvsTray.exe
C:\Program Files\TOSHIBA\ConfigFree\NDSTray.exe
C:\Program Files\TOSHIBA\ConfigFree\CFSServ.exe
C:\Program Files\QuickTime\qttask.exe
C:\Program Files\Common Files\AOL\1149775359\ee\AOLSoftware.exe
C:\Program Files\Common Files\AOL\ACS\AOLDial.exe
C:\WINDOWS\system32\winupdate.exe
C:\Program Files\TOSHIBA\TOSCDSPD\toscdspd.exe
C:\WINDOWS\system32\TPSBattM.exe
C:\Program Files\Apoint2K\Apntex.exe
C:\WINDOWS\system32\RAMASST.exe
c:\program files\common files\aol\1149775359\ee\services\antiSpywareApp\ver2_0_32_1\AOLSP Scheduler.exe
c:\program files\common files\aol\1149775359\ee\aolsoftware.exe
C:\Program Files\AdvancedVirusRemover\PAVRM.exe
C:\WINDOWS\SoftwareDistribution\Download\66b1d8e81a20b4b541ab3e558f2fd638\update\update.exe
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch =
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 5.0\Reader\ActiveX\AcroIEHelper.ocx
O2 - BHO: DriveLetterAccess - {5CA3D70E-1895-11CF-8E15-001234567890} - C:\WINDOWS\system32\dla\tfswshx.dll
O2 - BHO: scriptproxy - {7DB2D5A0-7241-4E79-B68D-6309F01C5231} - C:\Program Files\McAfee\VirusScan\scriptsn.dll
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.2.4204.1700\swg.dll
O4 - HKLM\..\Run: [reƖ] C:\Program Files\Intel\Wireless\Bin\ifrmewrk.exe /tf Intel PROSet/Wireless
O4 - HKLM\..\Run: [LtMoh] C:\Program Files\ltmoh\Ltmoh.exe
O4 - HKLM\..\Run: [AGRSMMSG] AGRSMMSG.exe
O4 - HKLM\..\Run: [Apoint] C:\Program Files\Apoint2K\Apoint.exe
O4 - HKLM\..\Run: [TPNF] C:\Program Files\TOSHIBA\TouchPad\TPTray.exe
O4 - HKLM\..\Run: [TOSHIBA Accessibility] C:\Program Files\TOSHIBA\Accessibility\FnKeyHook.exe
O4 - HKLM\..\Run: [TCtryIOHook] TCtrlIOHook.exe
O4 - HKLM\..\Run: [TFncKy] TFncKy.exe
O4 - HKLM\..\Run: [CeEKEY] C:\Program Files\TOSHIBA\E-KEY\CeEKey.exe
O4 - HKLM\..\Run: [TPSMain] TPSMain.exe
O4 - HKLM\..\Run: [SVPWUTIL] C:\Program Files\Toshiba\Windows Utilities\SVPWUTIL.exe SVPwUTIL
O4 - HKLM\..\Run: [PadTouch] C:\Program Files\TOSHIBA\Touch and Launch\PadExe.exe
O4 - HKLM\..\Run: [ZoomingHook] ZoomingHook.exe
O4 - HKLM\..\Run: [SmoothView] C:\Program Files\TOSHIBA\TOSHIBA Zooming Utility\SmoothView.exe
O4 - HKLM\..\Run: [HWSetup] C:\Program Files\TOSHIBA\TOSHIBA Applet\HWSetup.exe hwSetUP
O4 - HKLM\..\Run: [Tvs] C:\Program Files\Toshiba\Tvs\TvsTray.exe
O4 - HKLM\..\Run: [NDSTray.exe] NDSTray.exe
O4 - HKLM\..\Run: [Pinger] c:\toshiba\ivp\ism\pinger.exe /run
O4 - HKLM\..\Run: [Notebook Maximizer] C:\Program Files\Notebook Maximizer\maximizer_startup.exe
O4 - HKLM\..\Run: [CFSServ.exe] CFSServ.exe -NoClient
O4 - HKLM\..\Run: [Pure Networks Port Magic] "C:\PROGRA~1\PURENE~1\PORTMA~1\PortAOL.exe" -Run
O4 - HKLM\..\Run: [HostManager] C:\Program Files\Common Files\AOL\1149775359\ee\AOLSoftware.exe
O4 - HKLM\..\Run: [AOLDialer] C:\Program Files\Common Files\AOL\ACS\AOLDial.exe
O4 - HKLM\..\Run: [winupdate.exe] C:\WINDOWS\system32\winupdate.exe
O4 - HKCU\..\Run: [TOSCDSPD] C:\Program Files\TOSHIBA\TOSCDSPD\toscdspd.exe
O4 - HKCU\..\Run: [Advanced Virus Remover] C:\Program Files\AdvancedVirusRemover\PAVRM.exe
O4 - Global Startup: RAMASST.lnk = C:\WINDOWS\system32\RAMASST.exe
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_01\bin\npjpi150_01.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_01\bin\npjpi150_01.dll
O9 - Extra button: Real.com - {CD67F990-D8E9-11d2-98FE-00C0F0318AFE} - C:\WINDOWS\system32\Shdocvw.dll
O10 - Unknown file in Winsock LSP: c:\windows\system32\winhelper.dll
O14 - IERESET.INF: START_PAGE_URL=http://www.toshibadirect.com/dpdstart
O23 - Service: AOL Connectivity Service (AOL ACS) - America Online, Inc. - C:\PROGRA~1\COMMON~1\AOL\ACS\AOLacsd.exe
O23 - Service: ConfigFree Service (CFSvcs) - TOSHIBA CORPORATION - C:\Program Files\TOSHIBA\ConfigFree\CFSvcs.exe
O23 - Service: DVD-RAM_Service - Matsushita Electric Industrial Co., Ltd. - C:\WINDOWS\system32\DVDRAMSV.exe
O23 - Service: EvtEng - Intel Corporation - C:\Program Files\Intel\Wireless\Bin\EvtEng.exe
O23 - Service: MBackMonitor - McAfee - C:\Program Files\McAfee\MBK\MBackMonitor.exe
O23 - Service: RegSrvc - Intel Corporation - C:\Program Files\Intel\Wireless\Bin\RegSrvc.exe
O23 - Service: Spectrum24 Event Monitor (S24EventMonitor) - Intel Corporation - C:\Program Files\Intel\Wireless\Bin\S24EvMon.exe
O23 - Service: Swupdtmr - Unknown owner - c:\Toshiba\IVP\swupdate\swupdtmr.exe
End of file - 10064 bytes
KailiWeil
Posts Posts : 3
Post by Belahzur on 28th September 2009, 6:18 pm
Post by KailiWeil on 2nd October 2009, 3:11 am
Database version: 2890
10/1/2009 9:11:03 PM
mbam-log-2009-10-01 (21-11-03).txt
Objects scanned: 93038
Time elapsed: 6 minute(s), 32 second(s)
Memory Processes Infected: 1
Registry Keys Infected: 2
Registry Values Infected: 5
Registry Data Items Infected: 9
Folders Infected: 4
Files Infected: 3
C:\WINDOWS\system32\winupdate.exe (Trojan.FakeAlert) -> Unloaded process successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{a77d3539-581d-450c-9e44-a84c415a6172} (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\AVR (Rogue.AdvancedVirusRemover) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\winupdate.exe (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\advanced virus remover (Rogue.AdvancedVirusRemover) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\Environment\avapp (Rogue.PersonalAntiVirus) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\Environment\avuninst (Rogue.PersonalAntiVirus) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\Desktop\General\wallpaper (Hijack.Wallpaper) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\ActiveDesktop\NoChangingWallpaper (Hijack.DisplayProperties) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer\NoActiveDesktopChanges (Hijack.DisplayProperties) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer\NoSetActiveDesktop (Hijack.DisplayProperties) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\activedesktop\NoChangingWallpaper (Hijack.DisplayProperties) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer\NoActiveDesktopChanges (Hijack.DisplayProperties) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer\NoSetActiveDesktop (Hijack.DisplayProperties) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System\DisableTaskMgr (Hijack.TaskManager) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
C:\Program Files\Common Files\Uninstall\PersonalAV (Rogue.PersonalAntiVirus) -> Quarantined and deleted successfully.
C:\Program Files\AdvancedVirusRemover (Rogue.AdvancedVirusRemover) -> Quarantined and deleted successfully.
C:\Program Files\PersonalAV (Rogue.PersonalAntiVirus) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Start Menu\PersonalAV (Rogue.PersonalAntiVirus) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\winupdate.exe (Trojan.FakeAlert) -> Quarantined and deleted successfully.
C:\Program Files\AdvancedVirusRemover\PAVRM.exe (Rogue.AdvancedVirusRemover) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\winhelper.dll (Trojan.FakeAlert) -> Quarantined and deleted successfully.
KailiWeil
Posts Posts : 3
Post by Belahzur on 3rd October 2009, 11:48 pm
  • Copy and paste DDS.txt back here, I don't need to see attach.txt just yet.
