How to Remove Alpha Antivirus [Removal Guide]
Page 1 of 6 • Share •
Page 1 of 6 • 1, 2, 3, 4, 5, 6
This guide will give you easy instructions on how to remove Alpha Antivirus for free.
What is Alpha Antivirus? (Information)
Alpha Antivirus is a fake security software which uses fraudulent strategies by displaying false or exaggerated security issues on your computer rather than any legitimate ones to coerce you into purchasing their software.
Alpha Antivirus is a new malicious specimen from the same family of fake security software as Personal Antivirus
Alpha Antivirus Screenshot:
Files Associated With Alpha Antivirus:
Click Spoiler to view:
1. Open Task Manager by pressing Ctrl+Shift+Esc.
2. Navigate to the Processes tab.
3. Locate for a process called Alpha.exe and end it's process by click the End Process button at the bottom left hand corner of Task Manager and click Yes.
4. Continue with the instructions listed below to remove Alpha Antivirus completely.
1. Please download this removal tool: Malwarebytes' Anti-Malware.
2. Install Malwarebytes' Anti-Malware by double clicking on mbam-setup
4. Malwarebytes' Anti-Malware will automatically update itself after the installation, click the OK button to close that box and you will now be at the main program Window as shown below.
If you are having problems with the updater, you can use this link to manually update Malwarebytes' Anti-Malware with the latest database. Make sure that Malwarebytes' Anti-Malware is closed before installing the update.
5. Close All opened Windows, Programs, File or Folders.
6. Make sure you are on the Scanner tab. Select Perform quick scan then click the Scan button as shown below.
8. When the scan is finished a message box will appear, click OK to continue.
9. Click Show Results.
11. Click on Remove selected.
12. When removing the files, Malwarebytes' Anti-Malware may require you to restart the computer in order to do a complete removal. If it displays a message stating that it needs to restart, click Yes.
13. After that you can close the Malwarebytes' Anti-Malware window, your computer is now cleaned from the malware infection.
To protect and prevent your computer from experiencing future threats like this, you may want to consider purchasing the Pro version of Malwarebytes' Anti-Malware with real-time protection from this link.
If you are still experiencing problems or difficulties following this guide or require any assistance removing this malware, please post your questions in our Virus, Spyware & Malware Removal forums for free help.
You have to be logged in to post questions. Registration is free. By registering you will be privileged to other resources and to ask questions.
- Spoiler:
- C:\Program Files\Alpha Antivirus
- C:\Program Files\AlphaAV\Alpha Antivirus.exe
- C:\Program Files\AlphaAV\activate.ico
- C:\Program Files\AlphaAV\Explorer.ico
- C:\Program Files\AlphaAV\AlphaAV.exe
- C:\Program Files\AlphaAV\unins000.dat
- C:\Program Files\AlphaAV\uninstall.ico
- C:\Program Files\AlphaAV\working.log
- C:\Program Files\AlphaAV\db
- C:\Program Files\AlphaAV\db\DBInfo.ver
- C:\Program Files\AlphaAV\db\ia080614.db
- C:\Program Files\AlphaAV\db\ia080618x.db
- C:\Program Files\AlphaAV\Languages
- C:\Program Files\AlphaAV\Languages\IAEs.lng
- C:\Program Files\AlphaAV\Languages\IAFr.lng
- C:\Program Files\AlphaAV\Languages\IAGer.lng
- C:\Program Files\AlphaAV\Languages\IAIt.lng
- C:\Program Files\Common Files\Uninstall\AlphaAV
- C:\Documents and Settings\All Users\Start Menu\AlphaAV\Uninstall.lnk
- C:\Documents and Settings\All Users\Start Menu\AlphaAV\Alpha Antivirus
- C:\Documents and Settings\All Users\Start Menu\AlphaAV\Alpha Antivirus Home Page.lnk
- C:\Documents and Settings\All Users\Start Menu\AlphaAV\Alpha Antivirus.lnk
- C:\Documents and Settings\All Users\Start Menu\AlphaAV\Purchase License.lnk
- %UserProfile%\Application Data\Alpha Antivirus
- %UserProfile%\Application Data\AlphaAV\settings.ini
- %UserProfile%\Application Data\AlphaAV\uill.ini
- %UserProfile%\Application Data\AlphaAV\unins000.exe
- %UserProfile%\Application Data\AlphaAV\Uninstall Alpha Antivirus.lnk
- %UserProfile%\Application Data\AlphaAV\db
- %UserProfile%\Application Data\AlphaAV\db\config.cfg
- %UserProfile%\Application Data\AlphaAV\db\Timeout.inf
- %UserProfile%\Application Data\AlphaAV\db\Urls.inf
- %UserProfile%\Application Data\Microsoft\Internet Explorer\Quick Launch\Alpha Antivirus.lnk
- %UserProfile%\Local Settings\Application Data\Microsoft\Windows\log.txt
- %UserProfile%\Local Settings\Application Data\Microsoft\Windows\pguard.ini
- %UserProfile%\Local Settings\Application Data\Microsoft\Windows\services.exe
- %UserProfile%\Local Settings\Application Data\Microsoft\Internet Explorer\iGSh.png
- %UserProfile%\Local Settings\Application Data\Microsoft\Internet Explorer\iMSh.png
- %UserProfile%\Local Settings\Application Data\Microsoft\Internet Explorer\iPSh.png
- %UserProfile%\Local Settings\Application Data\Microsoft\Internet Explorer\iv.exe
- HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\alphaav
- HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Alpha Antivirus
- HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root\LEGACY_ITGRDENGINE
- HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\ITGrdEngine
- HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer “PrS”
- HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run “Alpha Antivirus”
Last edited by Doctor Inferno on Fri 16 Apr 2010, 10:16 pm; edited 17 times in total (Reason for editing : Information Update)
Doctor Inferno- The GeekPolice
Re: How to Remove Alpha Antivirus [Removal Guide]
Thank you so much!! Your removal guide was the only one in the whole internet which worked and removed Alpha Antivirus in about 10 minutes! I registered here just to say thank you, I would also know where to go if I have virus problems again.
Lex4434
Operating System: XP
Awesome! You guys are the BEST! Thank you so much for this this guide on to remove Alpha Antivirus, it worked flawlessly. Imma go buy that Malwarebytes protection.
Jouuuui
Unborn
Operating System: Vista
Thank you so very much for your help. You have no idea how much I appreciate it.
I will definitely recommend your site to others.
Wildfire
Unborn
I tryed doing that but everytime i click abort scan it says no malishious items were detected.. and everytime i turn on the comp..the alpha thing pops up
HELP ME
what do i do to get rid of this thing
please help
HELP ME
please help
nadia1234
Unborn
nadia1234 wrote:I tryed doing that but everytime i click abort scan it says no malishious items were detected.. and everytime i turn on the comp..the alpha thing pops up
HELP ME
please help
Open a new topic here: http://www.geekpolice.net/virus-spyware-malware-removal-f11/
We will help you remove it from there.
Ok, I was doing this on a friends computer... it was all going fine until it revealed 300 odd files, with consent we deleted them/romoved or whatever. It then wanted to reboot the computer, so i did this. Now it wont load to windows again
it gets stuck on the ACER bit on the screen. Wont even load XP. HELP
andrewg112
Unborn
alpha antivirus
your instructions to move alpha antivus worked perfectly!!!Brian
bdlynch
Unborn
Operating System: vista
I created an account here just to say Thank YOU! Your guide worked perfectly.
Rradfgg
Unborn
Just used your guide to get rid of Alpha. Worked great managed to get rid of it within 10 minutes. I will use this site in future for sure.
richardcant26
Unborn
alpha virus
i love you guys!!! thank you for your help in how to remove that ugly alpha virus
i don't know much about computers, but with your help i felt like a pro it was so easy !!!!!!!!!!!!!!!! Lea
lenkalea
Unborn
hi..i also created an account to say thanks...was about to throw the computer out the window due to alpha but you guys saved the day!!!
taz
Unborn
Operating System: xp
Another thanks! My son dumped his computer off to "Mom". After 2 hours I landed on your site and your "removal guide" instructions... saved his computer and more importantly - my sanity! You guys/gals really did save the day.
texaspharmer
Unborn
Operating System: Windows Vista
My labtop has been showing the security tool virus removal programm. I cannot get on the internet. What can I do to get my labtop work normal as before the security tool took it over?
hamnest
Unborn
hamnest wrote:My labtop has been showing the security tool virus removal programm. I cannot get on the internet. What can I do to get my labtop work normal as before the security tool took it over?
Try downloading MBAM on another system, and put it on a flash drive, then transfer it over.
adrenaline
Operating System: Windows XP SP3
Similar topics» Boarding Guide
» Strategical Guide
» FORCE BLADER GUIDE
» Sector And Universe Trader Guide
» Alpha Antivirus, Antivirus System Pro, Security Tool, and Cyber Security continually infecting users.
» Strategical Guide
Page 1 of 6
by
