phone and router compatabilty problems
Page 1 of 1
- vinceNovice
OS : XP
Rubies : 3374
I have a Thomson gateway 585v7, and a siemens c474ip dect phone, a sipgate.co.uk account, the phone keeps dropping the router and if you call at that point its just a dead line.
Sipgate recommended forwarding ports 5004, 5060 and 5062 and disabling the stun server. But this is proving to be quite difficult with this router, I have a fixed IP and am on adsl2+ .
Can anyone help or point me in the right direction.
Vince
Vince
- XenosIntermediate
OS : Windows 7
Rubies : 3639
I believe this link will give you an idea on how to port forward on that specific router.
http://forum.portforward.com/YaBB.cgi?num=1235285461
it's hard for me to give you direct steps as every router is different
Main System Spec: Intel Quad Q9550 (OC to 3.4Ghz), Gigabyte Ga-ep45-ud3l, 4gb kingston hyperX @ 1066mhz, Corsair tx 650, Nvidia 8600GT.
- vinceNovice
OS : XP
Rubies : 3374
Thanks, have joined that forum and can post in 24 hours, do you think I should disable upnp and re enable the stun server in the phone, I have seen some posts that say this.
- vinceNovice
OS : XP
Rubies : 3374
Sipgate contacted me and said to try witout the port forwading. However it doesnt work, and I get an error code now. ip code 404.
Any ideas
Any ideas
- vinceNovice
OS : XP
Rubies : 3374
bump
Similar topics
Page 1 of 1
