Battery Problem
Battery Problem
Post by zrawrxd on 19th September 2009, 10:00 pm
Battery Problem
I am using a laptop and I don't know how to make it always charge.
How do I make it always charge?
And my other laptop is always at 0% and never charges, the only way for that laptop to run is with the charger plugged in, but its never charging.
zrawrxd
Posts Posts : 107
Joined Joined : 2008-12-21
OS OS : Window XP [Labtop] / Windows Vista [Labtop]
Points Points : 29368
Re: Battery Problem
Post by Safan on 19th September 2009, 10:08 pm
I moved your other post to hardware but since you made this post, the other one is not needed (but I don't have powers to move it, so another mod will have to trash it)
Anyway, I think the battery is faulty and I believe there is no real solution to fix it. I have a laptop with the same problem, and cannot run without a wire, but got nowhere to buy a new one.
Posts Posts : 3292
Points Points : 40873
Re: Battery Problem
Post by zrawrxd on 19th September 2009, 10:27 pm
@Safan wrote:Hello,
So I have to always have the charger plugged in?
Edit: I went to google and got this:
-Gone to support.dell.com and downloaded the newest BIOS then restarted.
-Got latest windows updates, restarted.
-Turned off took out battery, held down power button for ten slow seconds, put battery in, started it up.
-Unplugged, shut down computer, left battery out for ten minutes, put in battery, turned on.
How do I tell what my BIOS verison is?
zrawrxd
Posts Posts : 107
Re: Battery Problem
Post by Safan on 19th September 2009, 10:40 pm
When you boot. The first screen will say Dell
The BIOS versions should be the number underneath the logo image.
Or you could go to "system information" from the "system tools" located in
"accessories" of the "all programs" menu.
You can also find it using Vista / Windows 7 start menu search by typing in system information
Posts Posts : 3292
Re: Battery Problem
Post by zrawrxd on 19th September 2009, 11:30 pm
Ok none of those worked.
So I guess I will have to always have my charger plugged in.
zrawrxd
Posts Posts : 107
Re: Battery Problem
Post by Xenos on 19th September 2009, 11:41 pm
Hello...
A long time ago I had a samsung laptop and it did the same thing.
At the time I didn't know half as much about computers as I do now, so the laptop ended up in the bin.
so unfortunatly I don't have a solution to fix this.
But have you tried a different battery to see if that's the problem?
Also try cleaning the contacts on both the battery and the laptop .
Main System Spec: Intel Quad Q9550 (OC to 3.4Ghz), Gigabyte Ga-ep45-ud3l, 4gb kingston hyperX @ 1066mhz, Corsair tx 650, Nvidia 8600GT.
Xenos
Posts Posts : 180
Joined Joined : 2009-08-09
Points Points : 27234
Re: Battery Problem
Post by zrawrxd on 19th September 2009, 11:45 pm
@Xenos wrote:try cleaning the contacts on both the battery and the laptop .
Contacts?
I think i saw somewhere that Dell was using downgraded batteries, Is there a way to upgrade the batteries?
zrawrxd
Posts Posts : 107
Re: Battery Problem
Post by Xenos on 20th September 2009, 7:16 am
the metal contacts where the battery connects to the laptop, sometimes you may not have access to the contacts on the battery.
sorry not sure about updating the battery
you could also check the DC Voltage is Good.
Check the voltage at the output
of your AC adapter with a DC voltmeter, right on the barrel connector that
gets plugged into the laptop. The rule of thumb for acceptable readings on
power adapter output is usually a 5% variation either way of the faceplate
voltage, and in terms of charging a battery, a high reading is better than
a low reading.
Xenos
Posts Posts : 180
