msb.exe malaware removal help
Post by Jenkins on 19th September 2009, 12:57 am
I have been told to post here to get help with removing msb.exe
It has been causing my computer to go on an endless loop of restarting itself (more info here [You must be registered and logged in to see this link.] ) I can't log into the account normally but I can go in safe mode. Right now, I am using the guest account which works fine but I would still like to use the other account because it doesnt ask for my credentials every five freaking minutes. So what should I do now?
Jenkins
Posts Posts : 56
Joined Joined : 2009-03-07
OS OS : Wndows Vista 64 Bit
Points Points : 28496
Re: msb.exe malaware removal help
Post by Dr Jay on 19th September 2009, 1:36 am
Hi
Please do the following and carefully read:
Log on to the account and immediately go to the Start menu, type in CMD and press Enter.
When the shutdown popup comes up, type in the Command Prompt window:
shutdown -a
Keep Command Prompt open and do that again if the shutdown popup comes up. Repeat it as many times as needed simultaneously through this process.
Repeat the above process once, then please post a log in your next reply.
Posts Posts : 13757
Points Points : 302262
Post by Jenkins on 24th September 2009, 12:42 am
it isnt automatically restarting anymore, but i am not sure if the virus is there or not because the account will act very slow and/or freeze constantly. im not sure if this is because of the virus or because i havent used the account in such a long time, so i will do what you said.
by the way, sorry it took me so long to reply
Jenkins
Posts Posts : 56
Post by Dr Jay on 24th September 2009, 1:06 am
No problem. Post when ready. Smile
Posts Posts : 13757
