Explorer.exe Problem!! XP pro
Post by tarzan on Fri Sep 18, 2009 8:57 am
Hi
i have problem with the explrer.exe, i often get the error reporting dialog box...my system's response is very slow now. I want to avoid reinstalling windows .. plz guide
OS XP Pro SP2
tarzan
Posts Posts : 427
Joined Joined : 2008-10-31
OS OS : xp.pro,vista, Windows 7
Points Points : 29998
Re: Explorer.exe Problem!! XP pro
Post by Dr Jay on Fri Sep 18, 2009 6:24 pm
Hi
Please download the latest version of Kaspersky GetSystemInfo (GSI) from here and save it to your Desktop.
  • Please close all other applications running on your system.
  • Please double click GetSystemInfo.exe to open it.
  • Click the Settings button.
  • Set it to Maximum
  • IMPORTANT! Then please click Customize - choose Driver / Ports tab and
  • Uncheck Scan Ports.
  • Click Create Report to run it.
  • It will create a zip folder called GetSystemInfo_XXXXXXXXXXXXXX.zip on your Desktop. Please upload the folder to Kaspersky GSI Parser and click the Submit button.
Posts Posts : 13713
Points Points : 302069
Post by tarzan on Sat Sep 19, 2009 6:04 am
tarzan
Posts Posts : 427
Post by Dr Jay on Sat Sep 19, 2009 7:28 am
Hi
Jotti File Submission:
  • Please go to Jotti's malware scan
  • Copy and paste the following file path into the "File to upload & scan"box on the top of the page:
    • C:\Tally9\tallylicserver.exe
  • Click on the submit button
  • Please post the results in your next reply. (URL)
Posts Posts : 13713
Post by tarzan on Sat Sep 19, 2009 7:35 am
tarzan
Posts Posts : 427
Post by Dr Jay on Sat Sep 19, 2009 7:59 am
Hi
Do you ever run World of Warcraft or Warcraft 3? There have been problems reported that could cause Explorer to get an "Access Violation" whenever the game runs.
How about a memory test.
Please read the following: set up Memtest, then download Memtest86+ from here.
Please let me know of the results.
Posts Posts : 13713
Post by tarzan on Sat Sep 19, 2009 8:06 am
hi.
no i never installed warcraft or any games on this laptop.
by the which file should i download
* Download - Pre-Compiled Bootable ISO (.gz)
* Download - Pre-Compiled Bootable ISO (.zip)
* Download - Pre-Compiled Bootable Binary (.gz)
* Download - Pre-Compiled Bootable Binary (.zip)
* Download - Pre-Compiled EXE file for USB Key (Pure DOS)
* Download - Pre-Compiled package for Floppy (DOS - Win)
tarzan
Posts Posts : 427
Post by Dr Jay on Sat Sep 19, 2009 8:17 am
Hi
One of these two:
Posts Posts : 13713
Post by tarzan on Sat Sep 19, 2009 8:21 am
do i need to burn the iso in the cd...coz my laptop is a miini laptop and does not have a cdrom
tarzan
Posts Posts : 427
Post by Dr Jay on Sat Sep 19, 2009 8:25 am
Hi
Try to get it burned by maybe a friend. I believe you may have a memory issue, so it is important to check it.
Posts Posts : 13713
Post by tarzan on Sat Sep 19, 2009 8:30 am
i dont have a cd rom to read on the laptop...only usb drives
tarzan
Posts Posts : 427
Post by Dr Jay on Sat Sep 19, 2009 6:17 pm
Please Download Speedfan and install it. Once it's installed, run the program and post here the information it shows. The information I want you to post is the stuff that is circled in the example picture I have attached.
Posts Posts : 13713
Post by tarzan on Tue Sep 22, 2009 6:49 am
will revert in 2-3 days as i am away from my laptop. Will update as soon as i am done...thanks!!
tarzan
Posts Posts : 427
