Help, finding the right firewall for me
Solved Help, finding the right firewall for me
Post by HannesM on 17th September 2009, 5:19 pm
Hello Smile
I need some help finding the "right" firewall for my usage Goofy. I need a firewall that is free and can create "rules" such as these ones: Some Comodo "rules" (if you scroll down a bit you will find "Rule A", "Rule B" and so on)
Obviously I can pick the comodo-firewall, but are there any alternatives? Can you create "rules", such as the ones in the link, in for example Zone Alarm, Online Armour or Outpost? If yes, which of these firewalls do you prefer?
HannesM
Posts Posts : 75
Joined Joined : 2009-03-24
Points Points : 28427
Solved Re: Help, finding the right firewall for me
Post by Doctor Inferno on 18th September 2009, 1:14 am
I would get Outpost if it were me. I've never heard much of Online Armour, Outpost is lighter on the system than Zone Alarm.
Post by HannesM on 18th September 2009, 8:42 am
"Action: Allow
Protocol: IP
Direction: Out
Source Address: Zone
Destination Address: Any
Ip Details > IP Protocol: Any"
Ok, so in outpost you can create rules, such as the one above?
HannesM
Posts Posts : 75
Post by Doctor Inferno on 18th September 2009, 12:54 pm
Outpost Pro is able to do that, so the free version should also have the ability to add those rules.
Post by HannesM on 21st September 2009, 2:55 pm
Oh, thanks for the help Smile. Outpost it is then Smile
HannesM
Posts Posts : 75
