Problem with Firefox and flash
Solved Problem with Firefox and flash
Post by Oneiros on 17th September 2009, 1:10 am
Hello guys,
Everytime I try to run a flash app with Firefox, it uses up to 60% of my processor and it goes extremely slow. I'm running firefox 3.5.3
Thanks in advance!
Oneiros
Posts Posts : 3
Joined Joined : 2009-08-12
OS OS : Windows XP/SP2
Points Points : 26775
Solved Re: Problem with Firefox and flash
Post by Dr Jay on 17th September 2009, 3:17 am
Hi
What version of Flash are you running?
(How to check: right-click on a Flash object and click About Adobe Flash Player)
Posts Posts : 14310
Points Points : 302971
Post by Oneiros on 17th September 2009, 11:08 am
Hi
I have 10.0.32.18 installed.
Oneiros
Posts Posts : 3
Post by Dr Jay on 18th September 2009, 12:47 am
Hi again
Let's try this workaround.
Right click on Flash object and click Settings. Uncheck "Enable Hardware Acceleration". If this fails to solve it, then I recommend to uninstall Adobe Flash ActiveX/Plugin from Add or Remove Programs (Control Panel > Add or Remove Programs). Then, restart the computer. Lastly, download and install the latest from Adobe.com.
Review my feedback, if any questions, please ask.
Posts Posts : 14310
Post by Oneiros on 18th September 2009, 2:20 am
It seems that it solved the problem.
Thanks a lot!
Oneiros
Posts Posts : 3
Post by Dr Jay on 18th September 2009, 2:29 am
You are welcome! Awesome (sparkly)
Posts Posts : 14310
