Is there a way to boost internet Speed?
Post new topic   Reply to topic
Solved Is there a way to boost internet Speed?
Post by CrisisCore on Sat May 03, 2008 2:12 pm
I am been experiencing Slow internet access during weekends and holidays but it is different during Weekdays. So is there a way to boost the speed?
CrisisCore
Posts Posts : 12
Joined Joined : 2008-05-03
OS OS : Singapore
Points Points : 31380
Solved Re: Is there a way to boost internet Speed?
Post by Digitalocksmith on Sun May 04, 2008 5:38 am
Without upgrading your ISP plan, there are 2 methods you could try to see if they help at all.....and there free!
Firstly, you could use 'Open DNS'. They allow you to go through their DNS servers and many have reported a noticeable increase in speed.
They have configuration pages for your OS or hardware router.
http://www.opendns.com/
Secondly, If you’re on Windows, install 'FastCache'.
AnalogX FastCache is a caching DNS server that runs on your local machine and handles any DNS request that your computer makes, from Internet Explorer to your favorite FTP client. Once a query is made, FastCache will override the normal timeout for the item with one that you specify, so instead of saving a query for a couple of seconds, it can save it for a couple of days. Now every time you ask for it again while it's in the cache, it gives it to you instantly.
http://www.analogx.com/CONTENTS/download/network/fc.htm
Good Luck!
Digitalocksmith
Posts Posts : 626
Joined Joined : 2007-12-22
Points Points : 48914
Post by Doctor Inferno on Sun May 04, 2008 10:19 am
Cool, I didn't actually thought there were such things. By the way you could tweak your internet speed if you are using firefox by doing the following:
in the address bar type in about:config >> in the filter bar type in pipe under network.http.pipelining >> right click toogle >> under network.http.pipelining.maxrequests >> right click >> Modify and change the value to 30.
This makes firefox use 30 connections instead of just 4. making your surfing speed slightly faster.
Post by Digitalocksmith on Sun May 04, 2008 11:05 am
Nice Doc, but firefox seems to slow for me!
My IE7 runs like Lewis Hamiltons McLaren.....damn fast, hehe! Shocking Whoa
Sorry, i'm being silly now.....i'll get back in my box!
Digitalocksmith
Posts Posts : 626
Post by Mr.Waulrus on Mon May 05, 2008 10:06 am
Thanks for the post!
I just combined everything you guys posted and... WOW!!!
Mr.Waulrus
Posts Posts : 35
Joined Joined : 2008-05-02
OS OS : Next to the computer.
Points Points : 31390
Post by xdyeo on Mon Jun 09, 2008 12:49 pm
Oh so you can make it faster like this
Last edited by xdyeo on Mon Jun 09, 2008 1:36 pm; edited 1 time in total (Reason for editing : know how to increase speed of internet.)
xdyeo
Posts Posts : 62
Joined Joined : 2008-04-09
Points Points : 31671
Post by Leet. on Sun Aug 24, 2008 4:52 pm
Zomg i tried the above methods too and it worked like ooHlalalLALAL!
Leet.
Posts Posts : 13
Joined Joined : 2008-08-24
Points Points : 30250
Post by venus89 on Tue Oct 08, 2013 4:22 am
@CrisisCore wrote:I am been experiencing Slow internet access during weekends and holidays but it is different during Weekdays. So is there a way to boost the speed?
A slow Internet connection could be caused by any number of reasons. It may be connection or traffic problem.
To increase your Internet speed you can follow these tips given below:
1.clear cookies from our browser
2.Delete unwanted files.
3. PC Optimization:
It is important to clean your PC regularly. It means a normal maintenance tasks such as, cleaning the disks, registry repairs and Disk Derangement
4. If you are using a DSL connection over your landline, make sure that you have high-quality filters in place to get optimum signal speed.
5.Upgrade your modem
6.Use Updated Web Browser
After, completing this steps, you can check our internet speed from this site ScanMySpeed.com
venus89
Posts Posts : 22
Joined Joined : 2013-02-08
OS OS : windows 7
Points Points : 14099
