Dealing with 4 bit graphics, please help.
Solved Dealing with 4 bit graphics, please help.
Post by Relorium on Tue Sep 15, 2009 10:58 pm
Yesterday when I was using my computer, everything was fine. It had just finished downloading some updates for Windows and I decided to shut it down and go to bed. This morning I booted it up to find that I now have 4 bit graphics. I'm guessing that my out of date driver doesn't work with the new updates. The only problem is that I cannot find the correct driver ANYWHERE. They don't even have it listed on the website. I'm using a Toshiba Satellite A45-S121 with Windows XP SP2. I need the latest driver for the following chip type: Intel(R) 82852/82855 GM/GME Graphics Controller
I downloaded this from some website: Intel® Graphics Media Accelerator Driver for Windows* XP (exe)
But when I tried to install it, it said that it couldn't be installed on my computer and to contact the computer's manufacturer.
Relorium
OS : Windows XP SP2
Solved Re: Dealing with 4 bit graphics, please help.
Post by Relorium on Wed Sep 16, 2009 12:26 am
I've fixed the problem myself. I can't believe that given the amount of views this post received and the simple solution of the problem no one posted a single reply. This reputable website was absolutely no help at all. I won't be using it again.
Relorium
OS : Windows XP SP2
