Computer Won't Start - Big Problem
Solved Computer Won't Start - Big Problem
Post by Tech on Mon Sep 14, 2009 9:43 pm
After a series of problems with my computer running Windows Vista 32 bit, I decided to erase EVERYTHING and reset the whole computer. It wouldn't turn on, or do anything. So I used my Vista Install disk, deleted everything on the harddrive, and re-installed vista. Worked fine for a few hours. Then randomly shut down. So I tried turning it on, it said Windows Failed to start (I've been getting this error for months) and let me ethier do Safe mode, or Start windows normally. Both just make the computer shut down.
More info will be given as needed.
Any ideas? Thanks!
Tech
OS : Vista
# Likes : 0
Solved Re: Computer Won't Start - Big Problem
Post by Dr Jay on Tue Sep 15, 2009 4:10 am
Hi
Seems like a memory problem.
Please read the following: set up Memtest, then download Memtest86+ from here.
I think booting from this disk and doing a memory test might get you on the right track. If bad memory, replace the memory, and the system should work.
OS : Windows 10 Home & Pro
# Likes : 10
Post by Tech on Fri Sep 18, 2009 6:36 pm
It's testing right now, What else do I need to do... ex what does the test mean/do?
Tech
OS : Vista
# Likes : 0
Post by Dr Jay on Fri Sep 18, 2009 8:19 pm
See if it detects memory errors.
# Likes : 10
Solved I am having the same prob Help
Post by cassandra82 on Mon Sep 21, 2009 9:01 pm
I am having the same problem and the memory test says everything is ok.What do i do now?
cassandra82
OS : vista
# Likes : 0
Post by skilldegree on Mon Sep 21, 2009 10:55 pm
This could also be the signs of a failing power supply, or your CPU overheating.
You should be able to monitor your temps in the bios, you could also try swapping out your PSU
skilldegree
OS : Win7 x64 Ultimate
# Likes : 0
