antivirus system pro
Post by aliboots on 11th September 2009, 11:09 pm
Please can you tell me how to get rid of this infection?
aliboots
Joined Joined : 2009-09-11
OS OS : vista
Points Points : 26473
Re: antivirus system pro
Post by Dr Jay on 11th September 2009, 11:13 pm
Hi
  • Copy the content of the following quotebox into the main textfield:
    :filefind
    scecli.dll
    netlogon.dll
    eventlog.dll
Please post the following logs in your next reply:
-Malwarebytes log
-SystemLook log
Posts Posts : 14310
Points Points : 302971
Post by crazzycatman on 12th September 2009, 12:06 am
Moderated Message:Comment removed. Please do not post in another member's topic. If you need help, please read [You must be registered and logged in to see this link.] over and [You must be registered and logged in to see this link.] to open a new topic.
crazzycatman
Posts Posts : 32
Points Points : 26734
Post by crazzycatman on 12th September 2009, 12:07 am
crazzycatman
Posts Posts : 32
Post by crazzycatman on 12th September 2009, 11:21 am
crazzycatman
Posts Posts : 32
