Antivirus System Pro
Post by Bassman13 on 11th September 2009, 2:13 am
This link just poped up on my computer and I keep getting windows security alert message for antivirus and to click to scan computer. It is blocking me from system restore and my AVG antivirus has not removed it and deverts me to porn sites. Can you help me clean this from my computer.
Tommy
Bassman13
Posts Posts : 4
Joined Joined : 2009-09-11
Points Points : 26459
Re: Antivirus System Pro
Post by Dr Jay on 11th September 2009, 3:52 am
Hi
Let's try to get this with one punch... Bring it on
Please open Notepad and copy and paste these instructions in to it, then save it to your Desktop - or Print them. You will not be able to be online on Step 2 of this post. If you paste them, in Notepad, do not minimize Notepad, or close it.
STEP 1
  • Once the program has loaded select "Perform Full Scan", then click Scan.
  • Copy and paste the entire report in your next reply. (This will be report # 1) Close the log.
STEP 2
((((((( Running Malwarebytes in Expert Mode ))))))))
Please leave Malwarebytes open, do not minimize it.
Start Task Manager (Ctrl+Alt+Del or Ctrl+Shift+Esc) - click the Processes tab.
Select the following processes (if they exist), and click End Process:
explorer.exe
iexplore.exe (all instances)
Then, leave Task manager open, as is, or minimize it if it is in the way. If it is hard to access later, press Ctrl+Alt+Delete again.
Then...
Go to Malwarebytes, and select Perform Quick Scan, and click Scan. Follow instructions like above. After it is done, it will launch a log. Close the log.
Then, go to Task Manager, click File > New Task. In the box, enter explorer.exe, and press OK. Your Desktop shall launch, and restart the computer.
As long as you saved those logs to a location you can remember, open those logs in Notepad. The first log generated, then paste the second log after that.
If you have any problems, please post questions back here.
Posts Posts : 13743
Points Points : 302211
