System Security AND Police Pro
Solved System Security AND Police Pro
Post by LaxRef93 on 9th September 2009, 11:52 pm
Hi.. my wife's XP computer has been hit by both System Security 2009 and Police Pro. It is not letting me run any .exe files, so I am not able to run Maleware Bites program. I can however get on to an IE window. Any help would be greatly appreciated. Thanks!
LaxRef93
Posts Posts : 13
Joined Joined : 2009-09-09
Points Points : 26485
Solved Re: System Security AND Police Pro
Post by Dr Jay on 10th September 2009, 1:35 am
Hi
Please download ComboFix from [You must be registered and logged in to see this link.] or [You must be registered and logged in to see this link.]
* IMPORTANT !!! Save ComboFix.exe to your Desktop
  • Disable your AntiVirus and AntiSpyware applications, usually via a right click on the System Tray icon. They may otherwise interfere with our tools. Note: If you are having difficulty properly disabling your protective
    programs, or are unsure as to what programs need to be disabled, please refer to the information available through this link : [You must be registered and logged in to see this link.]
  • Double click on ComboFix.exe & follow the prompts.
  • Follow the prompts to allow ComboFix to download and install the Microsoft Windows Recovery Console, and when prompted, agree to the End-User License Agreement to install the Microsoft Windows Recovery Console.
When finished, it shall produce a log for you. Please include the C:\ComboFix.txt in your next reply.
Do not mouse-click Combofix's window while it is running. That may cause it to stall.
Posts Posts : 13810
Points Points : 302437
Post by LaxRef93 on 10th September 2009, 1:57 am
This virus won't let me run any .exe files, so when I double click on ComboFix.exe, all I get is an error message that says: "Error (and then gives the path)"
LaxRef93
Posts Posts : 13
Post by Dr Jay on 10th September 2009, 2:05 am
Hi
Please rename combofix.exe to cmf.com
Then, try to run it as instructed above.
Thanks.
Posts Posts : 13810
Post by LaxRef93 on 10th September 2009, 10:15 am
Here is the log. It ran almost all night. What are my next steps (BTW, the computer seems to be working 100% better already)?
ComboFix 09-09-09.04 - UPSAIR 09/09/2009 22:34.1.2 - NTFSx86
Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.502.253 [GMT -4:00]
Running from: c:\documents and settings\Administrator\Desktop\cmf.com
AV: Trend Micro Internet Security Pro *On-access scanning enabled* (Updated) {7D2296BC-32CC-4519-917E-52E652474AF5}
FW: Trend Micro Personal Firewall *enabled* {3E790E9E-6A5D-4303-A7F9-185EC20F3EB6}
WARNING -THIS MACHINE DOES NOT HAVE THE RECOVERY CONSOLE INSTALLED !!
c:\documents and settings\All Users\Application Data\95091246.ini
c:\documents and settings\UPSAIR\Application Data\wiaserva.log
C:\test.txt
c:\windows\braviax.exe
c:\windows\Installer\8efc279.msp
c:\windows\ppp3.dat
c:\windows\ppp4.dat
c:\windows\system32\~.exe
c:\windows\system32\41.exe
c:\windows\system32\AVR09.exe
c:\windows\system32\bennuar.old
c:\windows\system32\braviax.exe
c:\windows\system32\critical_warning.html
c:\windows\system32\dddesot.dll
c:\windows\system32\desote.exe
c:\windows\system32\dllcache\beep.sys
c:\windows\system32\drivers\hjgruiybexrros.sys
c:\windows\system32\hjgruicqjnqygx.dll
c:\windows\system32\hjgruienbjoeuf.dll
c:\windows\system32\hjgruimrrtjxdq.dll
c:\windows\system32\hjgruipsmpktit.dat
c:\windows\system32\hjgruirkhoglvd.dat
c:\windows\system32\kdfinj.dll
c:\windows\system32\sonhelp.htm
c:\windows\system32\sysnet.dat
c:\windows\system32\winhelper.dll
c:\windows\system32\winupdate.exe
c:\windows\wpd99.drv
Infected copy of c:\windows\system32\drivers\beep.sys was found and disinfected
Restored copy from - c:\i386\beep.sys
Infected copy of c:\windows\system32\eventlog.dll was found and disinfected
Restored copy from - c:\windows\ServicePackFiles\i386\eventlog.dll
-------\Service_hjgruimylyxmyv
-------\Legacy_hjgruimylyxmyv
((((((((((((((((((((((((( Files Created from 2009-08-10 to 2009-09-10 )))))))))))))))))))))))))))))))
2009-09-10 02:20 . 2009-09-10 02:20 104400 ----a-w- c:\documents and settings\Administrator\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
2009-09-09 23:24 . 2009-09-09 23:24 -------- d-----w- c:\documents and settings\Administrator\Application Data\Uniblue
2009-09-08 02:42 . 2009-09-08 02:42 -------- d-----w- c:\documents and settings\Administrator\Local Settings\Application Data\KodakGallery
2009-09-08 02:42 . 2009-09-08 02:42 -------- d-----w- c:\documents and settings\Administrator\Application Data\Skinux
2009-09-07 14:46 . 2009-09-07 14:46 163840 ----a-w- c:\windows\svchasts.exe
2009-08-22 20:27 . 2009-08-22 20:27 -------- d-----w- c:\documents and settings\All Users\Application Data\Google Updater
2009-09-10 02:26 . 2004-08-11 22:00 56320 ----a-w- c:\windows\system32\eventlog.dll
2009-09-09 23:27 . 2009-05-25 18:40 -------- d---a-w- c:\documents and settings\All Users\Application Data\TEMP
2009-09-07 12:25 . 2009-08-10 20:08 664 ----a-w- c:\windows\system32\d3d9caps.dat
2009-07-21 01:39 . 2006-09-13 12:51 -------- d--h--w- c:\program files\InstallShield Installation Information
2009-07-12 18:09 . 2008-12-31 03:15 77824 ----a-w- c:\windows\system32\kdfapi.dll
2009-07-12 18:09 . 2008-12-31 03:15 192512 ----a-w- c:\windows\system32\kdfvmgr.exe
2009-07-12 18:09 . 2008-12-31 03:14 387288 ----a-w- c:\windows\system32\kdfmgr.exe
2009-07-12 15:08 . 2008-12-31 03:14 53248 ----a-w- c:\windows\system32\Kdfhok.dll
"swg"="c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2007-08-08 68856]
"OE"="c:\program files\Trend Micro\Internet Security\TMAS_OE\TMAS_OEMon.exe" [2008-12-31 497008]
"Uniblue RegistryBooster 2009"="c:\program files\Uniblue\RegistryBooster\RegistryBooster.exe" [2008-08-26 2019624]
"igfxtray"="c:\windows\system32\igfxtray.exe" [2005-09-20 94208]
"igfxhkcmd"="c:\windows\system32\hkcmd.exe" [2005-09-20 77824]
"igfxpers"="c:\windows\system32\igfxpers.exe" [2005-09-20 114688]
"SoundMAXPnP"="c:\program files\Analog Devices\Core\smax4pnp.exe" [2004-10-15 1404928]
"Adobe Reader Speed Launcher"="c:\program files\Adobe\Reader 8.0\Reader\Reader_sl.exe" [2008-01-12 39792]
"AppleSyncNotifier"="c:\program files\Common Files\Apple\Mobile Device Support\bin\AppleSyncNotifier.exe" [2009-03-06 177472]
"ArcSoft Connection Service"="c:\program files\Common Files\ArcSoft\Connection Service\Bin\ACDaemon.exe" [2009-07-10 195072]
"UfSeAgnt.exe"="c:\program files\Trend Micro\Internet Security\UfSeAgnt.exe" [2009-04-01 995528]
"QuickTime Task"="c:\program files\QuickTime\qttask.exe" [2009-01-05 413696]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2009-03-13 342312]
"SunJavaUpdateSched"="c:\program files\Java\jre6\bin\jusched.exe" [2009-03-09 148888]
Digital Line Detect.lnk - c:\program files\Digital Line Detect\DLG.exe [2006-9-13 24576]
Kodak EasyShare software.lnk - c:\program files\Kodak\Kodak EasyShare software\bin\EasyShare.exe [2008-10-30 282624]
Windows Search.lnk - c:\program files\Windows Desktop Search\WindowsSearch.exe [2008-5-26 123904]
[HKEY_CURRENT_USER\software\microsoft\windows\currentversion\policies\explorer]
"NoSimpleStartMenu"= 1 (0x1)
[HKEY_USERS\.default\software\microsoft\windows\currentversion\policies\explorer]
"NoSetActiveDesktop"= 1 (0x1)
"NoActiveDesktopChanges"= 1 (0x1)
"{56F9679E-7826-4C84-81F3-532071A8BCC5}"= "c:\program files\Windows Desktop Search\MSNLNamespaceMgr.dll" [2009-05-25 304128]
[HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\TrendAntiVirus]
[HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\TrendFirewall]
"EnableFirewall"= 0 (0x0)
"c:\\WINDOWS\\system32\\msiexec.exe"=
"c:\\Program Files\\Kodak\\Kodak EasyShare software\\bin\\EasyShare.exe"=
R0 PCTCore;PCTools KDS;c:\windows\system32\drivers\PCTCore.sys [5/25/2009 2:40 PM 130936]
R2 ASFIPmon;Broadcom ASF IP Monitor;c:\program files\Broadcom\ASFIPMon\AsfIpMon.exe [3/8/2005 8:46 PM 61440]
R2 Security Activity Dashboard Service;Security Activity Dashboard Service;c:\program files\Trend Micro\TrendSecure\SecurityActivityDashboard\tmarsvc.exe [12/30/2008 8:36 PM 181584]
R2 tmpreflt;tmpreflt;c:\windows\system32\drivers\tmpreflt.sys [12/30/2008 8:29 PM 36368]
R2 WUSB300NSvc;WUSB300NSvc;c:\program files\Linksys\WUSB300N\WLService.exe [12/27/2007 8:45 PM 53307]
R3 tmcfw;Trend Micro Common Firewall Service;c:\windows\system32\drivers\TM_CFW.sys [12/30/2008 8:29 PM 335376]
S2 tmevtmgr;tmevtmgr;c:\windows\system32\drivers\tmevtmgr.sys [10/18/2007 10:04 AM 50192]
S2 TmPfw;Trend Micro Personal Firewall;c:\program files\Trend Micro\Internet Security\TmPfw.exe [12/30/2008 8:34 PM 497008]
S2 TmProxy;Trend Micro Proxy Service;c:\program files\Trend Micro\Internet Security\TmProxy.exe [12/30/2008 8:35 PM 677128]
S3 sdAuxService;PC Tools Auxiliary Service;c:\program files\Spyware Doctor\pctsAuxs.exe [5/25/2009 2:40 PM 348752]
2009-07-13 c:\windows\Tasks\AppleSoftwareUpdate.job
- c:\program files\Apple Software Update\SoftwareUpdate.exe [2008-07-30 16:34]
Trusted Zone: foxnews.com\www
Trusted Zone: microsoft.com\*.update
Trusted Zone: microsoft.com\update
Trusted Zone: windowsupdate.com\download
FF - ProfilePath - c:\documents and settings\UPSAIR\Application Data\Mozilla\Firefox\Profiles\56j0aow5.default\
FF - component: c:\program files\Trend Micro\TrendSecure\TISProToolbar\FirefoxExtension\components\FFTMUFEHelper.dll
FF - component: c:\program files\Trend Micro\TrendSecure\TISProToolbar\FirefoxExtension\components\FFToolbarComm.dll
FF - plugin: c:\documents and settings\UPSAIR\Application Data\Mozilla\Firefox\Profiles\56j0aow5.default\extensions\moveplayer@movenetworks.com\platform\WINNT_x86-msvc\plugins\npmnqmp071101000055.dll
FF - plugin: c:\program files\Mozilla Firefox\plugins\npImgCtl.dll
FF - plugin: c:\program files\Virtual Earth 3D\npVE3D.dll
---- FIREFOX POLICIES ----
FF - user.js: dom.disable_open_during_load - false // Popupblocker control handled by McAfee Privacy Service
Rootkit scan 2009-09-10 05:27
- - - - - - - > 'explorer.exe'(392)
c:\windows\system32\mshtml.dll
c:\program files\Common Files\ArcSoft\Connection Service\Bin\ACService.exe
c:\windows\system32\searchindexer.exe
c:\program files\Linksys\WUSB300N\WUSB300N.exe
c:\program files\Trend Micro\TrendSecure\TISProToolbar\ProToolbarUpdate.exe
c:\windows\system32\searchprotocolhost.exe
c:\program files\Java\jre6\bin\jucheck.exe
c:\windows\system32\searchfilterhost.exe
Completion time: 2009-09-10 5:37 - machine was rebooted
ComboFix-quarantined-files.txt 2009-09-10 09:37
Pre-Run: 44,539,146,240 bytes free
Post-Run: 45,310,435,328 bytes free
197 --- E O F --- 2009-07-05 07:02
LaxRef93
Posts Posts : 13
Post by Dr Jay on 10th September 2009, 3:16 pm
Hi
1. Close any open browsers.
File::
Save this as CFScript.txt, in the same location as ComboFix.exe
Refering to the picture above, drag CFScript into ComboFix.exe
When finished, it shall produce a log for you at C:\ComboFix.txt which I will require in your next reply.
Combofix should never take more that 20 minutes including the reboot if malware is detected.
If it does, open Task Manager then Processes tab (press ctrl, alt and del at the same time) and end any processes of findstr, find, sed or swreg, then combofix should continue.
If that happened we want to know, and also what process you had to end.
In your next reply, please include the ComboFix log, and the Malwarebytes log. Also, please tell me how your computer is running.
Posts Posts : 13810
Post by LaxRef93 on 10th September 2009, 4:46 pm
When I dragged the script onto ComboFix, it says there is an updated version of ComboFix, and asking if I want to install that. Should I?
LaxRef93
Posts Posts : 13
Post by Dr Jay on 10th September 2009, 5:47 pm
Hi
Go ahead. Smile
Posts Posts : 13810
Post by LaxRef93 on 10th September 2009, 8:11 pm
Here are the logs you wanted posted. First one is ComboFix, second one is Malewarebytes. The ComboFix only took like 15-20 minutes this time, so that's good. So far, the computer is running good. Is there anything else you would like me to do to further fix the problem?
Thanks.
ComboFix 09-09-09.09 - UPSAIR 09/10/2009 14:24.2.2 - NTFSx86
Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.502.39 [GMT -4:00]
Running from: c:\documents and settings\UPSAIR\Desktop\cmf.com
Command switches used :: c:\docume~1\UPSAIR\Desktop\CFScript.txt
AV: Trend Micro Internet Security Pro *On-access scanning disabled* (Updated) {7D2296BC-32CC-4519-917E-52E652474AF5}
FW: Trend Micro Personal Firewall *disabled* {3E790E9E-6A5D-4303-A7F9-185EC20F3EB6}
FILE ::
"c:\windows\svchasts.exe"
C:\test.txt
2009-09-10 16:14 . 2009-09-10 16:14 -------- d-----w- c:\documents and settings\Emma\Application Data\Skinux
2009-09-10 16:12 . 2009-09-10 16:12 -------- d-----w- c:\documents and settings\Emma\Local Settings\Application Data\Identities
2009-09-10 16:12 . 2009-09-10 16:12 -------- d-----w- c:\documents and settings\Emma\Local Settings\Application Data\ArcSoft
2009-09-10 16:12 . 2009-09-10 16:12 -------- d-----w- c:\documents and settings\Emma\Application Data\Windows Desktop Search
2009-09-10 16:11 . 2009-09-10 16:11 -------- d-----w- c:\documents and settings\Emma\Application Data\ArcSoft
2009-09-10 16:43 . 2008-12-31 03:15 77824 ----a-w- c:\windows\system32\kdfapi.dll
2009-09-10 16:43 . 2008-12-31 03:15 192512 ----a-w- c:\windows\system32\kdfvmgr.exe
2009-09-10 16:43 . 2008-12-31 03:14 53248 ----a-w- c:\windows\system32\Kdfhok.dll
2009-09-10 16:43 . 2008-12-31 03:14 387288 ----a-w- c:\windows\system32\kdfmgr.exe
2009-09-10 16:23 . 2007-12-11 22:29 -------- d-----w- c:\documents and settings\All Users\Application Data\Microsoft Help
2009-09-10 02:26 . 2004-08-11 22:00 56320 ------w- c:\windows\system32\eventlog.dll
2009-06-16 14:36 . 2004-08-11 22:00 119808 ----a-w- c:\windows\system32\t2embed.dll
2009-06-16 14:36 . 2004-08-11 22:00 81920 ----a-w- c:\windows\system32\fontsub.dll
+ 2009-06-16 14:36 . 2009-06-16 14:36 81920 c:\windows\system32\dllcache\fontsub.dll
- 2007-12-11 22:41 . 2009-06-14 07:01 35088 c:\windows\Installer\{91120000-0031-0000-0000-0000000FF1CE}\oisicon.exe
+ 2007-12-11 22:41 . 2009-09-10 16:23 35088 c:\windows\Installer\{91120000-0031-0000-0000-0000000FF1CE}\oisicon.exe
- 2007-12-11 22:41 . 2009-06-14 07:01 18704 c:\windows\Installer\{91120000-0031-0000-0000-0000000FF1CE}\mspicons.exe
+ 2007-12-11 22:41 . 2009-09-10 16:23 18704 c:\windows\Installer\{91120000-0031-0000-0000-0000000FF1CE}\mspicons.exe
- 2007-12-11 22:41 . 2009-06-14 07:01 20240 c:\windows\Installer\{91120000-0031-0000-0000-0000000FF1CE}\cagicon.exe
+ 2007-12-11 22:41 . 2009-09-10 16:23 20240 c:\windows\Installer\{91120000-0031-0000-0000-0000000FF1CE}\cagicon.exe
+ 2009-01-07 01:31 . 2009-01-07 01:31 48512 c:\windows\Installer\$PatchCache$\Managed\00002119130000000000000000F01FEC\12.0.6425\PUBTRAP.DLL
+ 2009-09-10 16:22 . 2008-07-08 13:02 26488 c:\windows\$hf_mig$\KB971633\update\spcustom.dll
+ 2009-09-10 16:22 . 2008-07-08 13:02 17272 c:\windows\$hf_mig$\KB971633\spmsg.dll
+ 2009-09-10 16:16 . 2008-07-08 13:02 26488 c:\windows\$hf_mig$\KB961371\update\spcustom.dll
+ 2009-09-10 16:16 . 2008-07-08 13:02 17272 c:\windows\$hf_mig$\KB961371\spmsg.dll
+ 2009-06-16 14:43 . 2009-06-16 14:43 81920 c:\windows\$hf_mig$\KB961371\SP3QFE\fontsub.dll
+ 2009-06-16 14:36 . 2009-06-16 14:36 119808 c:\windows\system32\dllcache\t2embed.dll
+ 2007-12-11 22:41 . 2009-09-10 16:23 888080 c:\windows\Installer\{91120000-0031-0000-0000-0000000FF1CE}\wordicon.exe
- 2007-12-11 22:41 . 2009-06-14 07:01 888080 c:\windows\Installer\{91120000-0031-0000-0000-0000000FF1CE}\wordicon.exe
+ 2007-12-11 22:41 . 2009-09-10 16:23 272648 c:\windows\Installer\{91120000-0031-0000-0000-0000000FF1CE}\pubs.exe
- 2007-12-11 22:41 . 2009-06-14 07:01 272648 c:\windows\Installer\{91120000-0031-0000-0000-0000000FF1CE}\pubs.exe
- 2007-12-11 22:41 . 2009-06-14 07:01 922384 c:\windows\Installer\{91120000-0031-0000-0000-0000000FF1CE}\pptico.exe
+ 2007-12-11 22:41 . 2009-09-10 16:23 922384 c:\windows\Installer\{91120000-0031-0000-0000-0000000FF1CE}\pptico.exe
+ 2007-12-11 22:41 . 2009-09-10 16:23 845584 c:\windows\Installer\{91120000-0031-0000-0000-0000000FF1CE}\outicon.exe
- 2007-12-11 22:41 . 2009-06-14 07:01 845584 c:\windows\Installer\{91120000-0031-0000-0000-0000000FF1CE}\outicon.exe
- 2007-12-11 22:41 . 2009-06-14 07:01 217864 c:\windows\Installer\{91120000-0031-0000-0000-0000000FF1CE}\misc.exe
+ 2007-12-11 22:41 . 2009-09-10 16:23 217864 c:\windows\Installer\{91120000-0031-0000-0000-0000000FF1CE}\misc.exe
+ 2009-03-06 07:41 . 2009-03-06 07:41 589704 c:\windows\Installer\$PatchCache$\Managed\00002119130000000000000000F01FEC\12.0.6425\PUBCONV.DLL
+ 2009-01-08 14:59 . 2009-01-08 14:59 624520 c:\windows\Installer\$PatchCache$\Managed\00002119130000000000000000F01FEC\12.0.6425\PTXT9.DLL
+ 2008-10-25 10:21 . 2008-10-25 10:21 136072 c:\windows\Installer\$PatchCache$\Managed\00002119130000000000000000F01FEC\12.0.6425\PRTF9.DLL
+ 2008-11-04 04:04 . 2008-11-04 04:04 498072 c:\windows\Installer\$PatchCache$\Managed\00002119130000000000000000F01FEC\12.0.6425\MORPH9.DLL
+ 2009-09-10 16:22 . 2008-07-09 07:38 382840 c:\windows\$hf_mig$\KB971633\update\updspapi.dll
+ 2009-09-10 16:22 . 2008-07-09 07:38 755576 c:\windows\$hf_mig$\KB971633\update\update.exe
+ 2009-09-10 16:22 . 2008-07-08 13:02 231288 c:\windows\$hf_mig$\KB971633\spuninst.exe
+ 2009-09-10 16:16 . 2009-05-26 11:40 382840 c:\windows\$hf_mig$\KB961371\update\updspapi.dll
+ 2009-09-10 16:16 . 2009-05-26 11:40 755576 c:\windows\$hf_mig$\KB961371\update\update.exe
+ 2009-09-10 16:16 . 2008-07-08 13:02 231288 c:\windows\$hf_mig$\KB961371\spuninst.exe
+ 2009-06-16 14:43 . 2009-06-16 14:43 119808 c:\windows\$hf_mig$\KB961371\SP3QFE\t2embed.dll
+ 2004-08-11 22:00 . 2009-06-03 19:09 1291264 c:\windows\system32\quartz.dll
+ 2008-05-07 05:12 . 2009-06-03 19:09 1291264 c:\windows\system32\dllcache\quartz.dll
+ 2009-05-26 22:54 . 2009-05-26 22:54 4192768 c:\windows\Installer\b8a52.msp
+ 2009-07-02 20:23 . 2009-07-02 20:23 5027328 c:\windows\Installer\b8a3a.msp
- 2007-12-11 22:41 . 2009-06-14 07:01 1172240 c:\windows\Installer\{91120000-0031-0000-0000-0000000FF1CE}\xlicons.exe
+ 2007-12-11 22:41 . 2009-09-10 16:23 1172240 c:\windows\Installer\{91120000-0031-0000-0000-0000000FF1CE}\xlicons.exe
+ 2007-12-11 22:41 . 2009-09-10 16:23 1165584 c:\windows\Installer\{91120000-0031-0000-0000-0000000FF1CE}\accicons.exe
- 2007-12-11 22:41 . 2009-06-14 07:01 1165584 c:\windows\Installer\{91120000-0031-0000-0000-0000000FF1CE}\accicons.exe
+ 2009-03-06 07:41 . 2009-03-06 07:41 9589096 c:\windows\Installer\$PatchCache$\Managed\00002119130000000000000000F01FEC\12.0.6425\MSPUB.EXE
+ 2009-06-03 19:12 . 2009-06-03 19:12 1291264 c:\windows\$hf_mig$\KB971633\SP3QFE\quartz.dll
+ 2006-10-17 13:40 . 2009-07-07 15:10 24539592 c:\windows\system32\MRT.exe
Rootkit scan 2009-09-10 14:34
Completion time: 2009-09-10 14:37
ComboFix-quarantined-files.txt 2009-09-10 18:37
ComboFix2.txt 2009-09-10 09:37
Pre-Run: 45,009,371,136 bytes free
Post-Run: 45,003,481,088 bytes free
multi(0)disk(0)rdisk(0)partition(2)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
201 --- E O F --- 2009-09-10 16:23
Malwarebytes' Anti-Malware 1.40
Database version: 2773
9/10/2009 4:02:34 PM
mbam-log-2009-09-10 (16-02-34).txt
Scan type: Full Scan (C:\|)
Objects scanned: 184890
Time elapsed: 58 minute(s), 48 second(s)
Registry Keys Infected: 1
Files Infected: 7
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Win Police Pro (Rogue.WindowsPolicePro) -> Quarantined and deleted successfully.
C:\Qoobox\Quarantine\C\WINDOWS\svchasts.exe.vir (Trojan.FakeAlert) -> Quarantined and deleted successfully.
C:\Qoobox\Quarantine\C\WINDOWS\system32\hjgruicqjnqygx.dll.vir (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Qoobox\Quarantine\C\WINDOWS\system32\desote.exe.vir (Trojan.Dropper) -> Quarantined and deleted successfully.
C:\Qoobox\Quarantine\C\WINDOWS\system32\winhelper.dll.vir (Trojan.FakeAlert) -> Quarantined and deleted successfully.
C:\Qoobox\Quarantine\C\WINDOWS\system32\winupdate.exe.vir (Rogue.AdvancedVirusRemover) -> Quarantined and deleted successfully.
C:\System Volume Information\_restore{46DE8921-1D39-44D2-A9E9-64119261F211}\RP990\A0085998.dll (Trojan.Sirefef) -> Quarantined and deleted successfully.
C:\System Volume Information\_restore{46DE8921-1D39-44D2-A9E9-64119261F211}\RP991\A0086286.exe (Trojan.FakeAlert) -> Quarantined and deleted successfully.
LaxRef93
Posts Posts : 13
Post by Dr Jay on 11th September 2009, 1:44 am
Hi
Go to start > run and copy and paste next command in the field:
ComboFix /u
Make sure there's a space between Combofix and /
Then hit enter.
This will uninstall Combofix, delete its related folders and files, reset your clock settings, hide file extensions, hide the system/hidden files and resets System Restore.
Please download F-Secure's Blacklight from [You must be registered and logged in to see this link.]
  • Save it to your Desktop
  • Double-click blbeta.exe then accept the agreement.
  • click > scan then > next,
  • You'll see a list of all items found.
  • Don't choose for rename yet! I want to see the log first, because legit items can also be present there...
  • There must be also a log on your desktop with the name fsbl.xxxxxxx.log (the xxxxxxx stand for numbers)
  • Post the contents of the log in your next reply.
Posts Posts : 13810
Post by LaxRef93 on 12th September 2009, 12:42 am
Hi.. f-secure reported no hidden items found. Do I still hit next?
Here is the log:
09/11/09 19:18:00 [Info]: BlackLight Engine 2.2.1092 initialized
09/11/09 19:18:00 [Info]: OS: 5.1 build 2600 (Service Pack 3)
09/11/09 19:18:00 [Note]: 7019 4
09/11/09 19:18:00 [Note]: 7005 0
09/11/09 19:18:16 [Note]: 7006 0
09/11/09 19:18:16 [Note]: 7011 1660
09/11/09 19:18:16 [Note]: 7035 0
09/11/09 19:18:16 [Note]: 7026 0
09/11/09 19:18:20 [Note]: FSRAW library version 1.7.1024
LaxRef93
Posts Posts : 13
Post by Dr Jay on 12th September 2009, 2:19 am
Hi
Hit next and let the program exit. I do not think that is a full log. Are you sure you got that from the log on the Desktop?
Please re-open Malwarebytes, click the Update tab, and click Check for Updates. Then, click the Scanner tab, select Perform Quick Scan, and press Scan. Post the log in your next reply, and please tell me how your computer is running.
Posts Posts : 13810
Post by LaxRef93 on 12th September 2009, 3:02 am
I double checked, and that is all that was on the log file on my desktop. However, the link you provided for blacklight only went to an information page. I had to navigate [You must be registered and logged in to see this link.] to find it. Do you want me to do anything differently with this tool?
What is the next step? Computer seems to be running ok.. some things seem to run a little slow, but not bad.
Here is the log from running Malewarebytes again:
Database version: 2782
9/11/2009 10:46:12 PM
mbam-log-2009-09-11 (22-46-12).txt
Objects scanned: 121621
Time elapsed: 9 minute(s), 23 second(s)
LaxRef93
Posts Posts : 13
Post by Dr Jay on 12th September 2009, 3:15 am
Hi
  • Click Run Scan and let the program run uninterrupted.
    :filefind
    scecli.dll
    netlogon.dll
    eventlog.dll
In your next reply, please include the OTL log, and the SystemLook log.
Posts Posts : 13810
Post by LaxRef93 on 12th September 2009, 12:25 pm
Hi
The OldTimer link appears to be broken.
LaxRef93
Posts Posts : 13
Post by Dr Jay on 12th September 2009, 5:42 pm
Hi
Not broken from here. Goofy
Try again. You may be blocked to download it.
If you cannot access it, then please do the following:
  • It will install to C:\Program Files\Trend Micro\HijackThis\HijackThis.exe
  • After installing, you should get the user agreement, press accept and HijackThis will run.
  • Select Do a system scan and save a log file. This will open a notepad file of everything HijackThis found, copy and paste it back here.
Posts Posts : 13810
Post by LaxRef93 on 14th September 2009, 11:05 pm
Here is the Hijack This log:
Scan saved at 7:04:32 PM, on 9/14/2009
C:\Program Files\Trend Micro\BM\TMBMSRV.exe
C:\Program Files\Common Files\ArcSoft\Connection Service\Bin\ACService.exe
C:\Program Files\Broadcom\ASFIPMon\AsfIpMon.exe
C:\Program Files\Trend Micro\TrendSecure\SecurityActivityDashboard\tmarsvc.exe
C:\Program Files\Trend Micro\Internet Security\SfCtlCom.exe
C:\Program Files\Trend Micro\Internet Security\TmPfw.exe
C:\Program Files\Trend Micro\Internet Security\TmProxy.exe
C:\Program Files\Trend Micro\Internet Security\UfSeAgnt.exe
C:\WINDOWS\system32\SearchIndexer.exe
C:\Program Files\Linksys\WUSB300N\WLService.exe
C:\Program Files\Linksys\WUSB300N\WUSB300N.exe
C:\WINDOWS\system32\hkcmd.exe
C:\Program Files\Analog Devices\Core\smax4pnp.exe
C:\Program Files\Common Files\ArcSoft\Connection Service\Bin\ACDaemon.exe
C:\Program Files\Trend Micro\TrendSecure\TISProToolbar\ProToolbarUpdate.exe
C:\Program Files\Trend Micro\Internet Security\TMAS_OE\TMAS_OEMon.exe
C:\Program Files\Uniblue\RegistryBooster\RegistryBooster.exe
C:\Program Files\Digital Line Detect\DLG.exe
C:\Program Files\Kodak\Kodak EasyShare software\bin\EasyShare.exe
C:\Program Files\Windows Desktop Search\WindowsSearch.exe
C:\WINDOWS\system32\SearchProtocolHost.exe
C:\Program Files\Trend Micro\TrendSecure\TSCFCommander.exe
C:\Program Files\Trend Micro\TrendSecure\TISProToolbar\PlatformDependent\ProToolbarComm.exe
C:\Program Files\Trend Micro\TrendSecure\TSCFPlatformCOMSvr.exe
C:\WINDOWS\system32\kdfmgr.exe
R1 - HKLM\Software\Microsoft\Internet Explorer\Search,Default_Page_URL = [You must be registered and logged in to see this link.]
O2 - BHO: Trend Micro Toolbar BHO - {43C6D902-A1C5-45c9-91F6-FD9E90337E18} - C:\Program Files\Trend Micro\TrendSecure\TISProToolbar\TSToolbar.dll
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.2.4204.1700\swg.dll
O2 - BHO: Browser Address Error Redirector - {CA6319C0-31B7-401E-A518-A07C3DB8F777} - C:\Program Files\BAE\BAE.dll
O3 - Toolbar: (no name) - {0BF43445-2F28-4351-9252-17FE6E806AA0} - (no file)
O3 - Toolbar: Trend Micro Toolbar - {CCAC5586-44D7-4c43-B64A-F042461A97D2} - C:\Program Files\Trend Micro\TrendSecure\TISProToolbar\TSToolbar.dll
O4 - HKLM\..\Run: [igfxtray] C:\WINDOWS\system32\igfxtray.exe
O4 - HKLM\..\Run: [igfxhkcmd] C:\WINDOWS\system32\hkcmd.exe
O4 - HKLM\..\Run: [igfxpers] C:\WINDOWS\system32\igfxpers.exe
O4 - HKLM\..\Run: [ArcSoft Connection Service] C:\Program Files\Common Files\ArcSoft\Connection Service\Bin\ACDaemon.exe
O4 - HKLM\..\Run: [UfSeAgnt.exe] "C:\Program Files\Trend Micro\Internet Security\UfSeAgnt.exe"
O4 - HKCU\..\Run: [OE] C:\Program Files\Trend Micro\Internet Security\TMAS_OE\TMAS_OEMon.exe
O4 - HKCU\..\Run: [Uniblue RegistryBooster 2009] C:\Program Files\Uniblue\RegistryBooster\RegistryBooster.exe /S
O4 - HKUS\S-1-5-18\..\Run: [OE] C:\Program Files\Trend Micro\Internet Security\TMAS_OE\TMAS_OEMon.exe (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [OE] C:\Program Files\Trend Micro\Internet Security\TMAS_OE\TMAS_OEMon.exe (User 'Default user')
O4 - Global Startup: Digital Line Detect.lnk = ?
O4 - Global Startup: Kodak EasyShare software.lnk = C:\Program Files\Kodak\Kodak EasyShare software\bin\EasyShare.exe
O4 - Global Startup: Windows Search.lnk = C:\Program Files\Windows Desktop Search\WindowsSearch.exe
O16 - DPF: {474F00F5-3853-492C-AC3A-476512BBC336} (UploadListView Class) - [You must be registered and logged in to see this link.]
O16 - DPF: {4ED9DDF0-7479-4BBE-9335-5A1EDB1D8A21} - [You must be registered and logged in to see this link.]
O16 - DPF: {6F750203-1362-4815-A476-88533DE61D0C} (Kodak Gallery Easy Upload Manager Class) - [You must be registered and logged in to see this link.]
O16 - DPF: {8100D56A-5661-482C-BEE8-AFECE305D968} (Facebook Photo Uploader 5 Control) - [You must be registered and logged in to see this link.]
O16 - DPF: {9600F64D-755F-11D4-A47F-0001023E6D5A} (Shutterfly Picture Upload Plugin) - [You must be registered and logged in to see this link.]
O16 - DPF: {B7D07999-2ADB-4AEB-997E-F61CB7B2E2CD} (TSEasyInstallX Control) - [You must be registered and logged in to see this link.]
O16 - DPF: {E06E2E99-0AA1-11D4-ABA6-0060082AA75C} (GpcContainer Class) - [You must be registered and logged in to see this link.]
O18 - Protocol: tmtb - {04EAF3FB-4BAC-4B5A-A37D-A1CF210A5A42} - C:\Program Files\Trend Micro\TrendSecure\TISProToolbar\TSToolbar.dll
O23 - Service: ArcSoft Connect Daemon (ACDaemon) - ArcSoft Inc. - C:\Program Files\Common Files\ArcSoft\Connection Service\Bin\ACService.exe
O23 - Service: Broadcom ASF IP Monitor (ASFIPmon) - Broadcom Corporation - C:\Program Files\Broadcom\ASFIPMon\AsfIpMon.exe
O23 - Service: PC Tools Auxiliary Service (sdAuxService) - PC Tools - C:\Program Files\Spyware Doctor\pctsAuxs.exe
O23 - Service: PC Tools Security Service (sdCoreService) - PC Tools - C:\Program Files\Spyware Doctor\pctsSvc.exe
O23 - Service: Security Activity Dashboard Service - Trend Micro Inc. - C:\Program Files\Trend Micro\TrendSecure\SecurityActivityDashboard\tmarsvc.exe
O23 - Service: Trend Micro Central Control Component (SfCtlCom) - Trend Micro Inc. - C:\Program Files\Trend Micro\Internet Security\SfCtlCom.exe
O23 - Service: Trend Micro Unauthorized Change Prevention Service (TMBMServer) - Trend Micro Inc. - C:\Program Files\Trend Micro\BM\TMBMSRV.exe
O23 - Service: Trend Micro Personal Firewall (TmPfw) - Trend Micro Inc. - C:\Program Files\Trend Micro\Internet Security\TmPfw.exe
O23 - Service: Trend Micro Proxy Service (TmProxy) - Trend Micro Inc. - C:\Program Files\Trend Micro\Internet Security\TmProxy.exe
O23 - Service: WUSB300NSvc - Unknown owner - C:\Program Files\Linksys\WUSB300N\WLService.exe
End of file - 11624 bytes
LaxRef93
Posts Posts : 13
Post by Dr Jay on 14th September 2009, 11:52 pm
Hi
I notice that you have these sites download.windowsupdate.com and foxnews.com in your Trusted Zone. Internet Explorer's security is based upon a set of zones. Each zone has different security in terms of what scripts and applications can be run from a site that is in that zone. There is a security zone called the Trusted Zone. This zone has the lowest security and allows scripts and applications from sites in this zone to run without your knowledge. It is therefore a popular setting for malware sites to use so that future infections can be easily done on your computer without your knowledge as these sites will be in the Trusted Zone.
I strongly recommend remove all entries from the Trusted Zone as they are unnecessary to be there.
To do this, start Internet Explorer > Tools tab > Internet Options (Security tab)
Please download [You must be registered and logged in to see this link.] to your desktop and run it.
  • When the first page comes up select Beginner Mode
  • On the next page select Save a binary .Run file (Recommended) then click Start full scan at the top.
  • At this time Runscanner.exe may request access to the Internet through your firewall please allow it to do so, it will then run for two or three minutes.
  • On completion it will ask for a location to save the file and a name. It will do this for both the .run file and the log file
  • Call the .run file "Select a name" and save it to your desktop. You will see the .run file on your desktop. Paste the results of that in your next reply.
Posts Posts : 13810
Post by LaxRef93 on 15th September 2009, 12:37 am
I removed all entries from Trusted Sites on IE8. Here is the log file from runscanner:
Runscanner logfile
* = signed file
- = file not found
General info
Computer name : JKLEINMANN-DT
Creation time : 9/14/2009 8:08:36 PM
Hosts <> 127.0.0.1 : 0
Hosts file location : %SystemRoot%\System32\drivers\etc
IE version : 8.0.6001.18702
OS : Microsoft Windows XP
OS Build : 2600
OS SP : Service Pack 3
RunScanner Version : 1.8.1.0
User Language : English (United States)
User rights : Administrator
Windows folder : C:\WINDOWS
Running processes
* C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe (Apple Inc.)
* C:\WINDOWS\System32\alg.exe (Microsoft Corporation)
* C:\Program Files\Common Files\ArcSoft\Connection Service\Bin\ACDaemon.exe (ArcSoft Inc.)
* C:\Program Files\Common Files\ArcSoft\Connection Service\Bin\ACService.exe (ArcSoft Inc.)
* C:\Program Files\Bonjour\mDNSResponder.exe (Apple Inc.)
C:\Program Files\Broadcom\ASFIPMon\AsfIpMon.exe (Broadcom Corporation)
* C:\WINDOWS\system32\csrss.exe (Microsoft Corporation)
* C:\WINDOWS\system32\ctfmon.exe (Microsoft Corporation)
C:\Program Files\Digital Line Detect\DLG.exe (BVRP Software)
* C:\WINDOWS\system32\svchost.exe (Microsoft Corporation)
* C:\WINDOWS\System32\svchost.exe (Microsoft Corporation)
* C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe (Google Inc.)
* C:\WINDOWS\system32\hkcmd.exe (Intel Corporation)
* C:\Program Files\Internet Explorer\iexplore.exe (Microsoft Corporation)
* C:\Program Files\iPod\bin\iPodService.exe (Apple Inc.)
* C:\Program Files\iTunes\iTunesHelper.exe (Apple Inc.)
* C:\Program Files\Java\jre6\bin\jusched.exe (Sun Microsystems, Inc.)
* C:\Program Files\Java\jre6\bin\jqs.exe (Sun Microsystems, Inc.)
C:\Program Files\Kodak\Kodak EasyShare software\bin\EasyShare.exe (Eastman Kodak Company)
* C:\WINDOWS\system32\kdfmgr.exe (Bluegem Security)
* C:\WINDOWS\system32\lsass.exe (Microsoft Corporation)
* C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE (Microsoft Corporation)
* C:\Program Files\Trend Micro\Internet Security\SfCtlCom.exe (Trend Micro Inc.)
* C:\Program Files\Trend Micro\BM\TMBMSRV.exe (Trend Micro Inc.)
* C:\WINDOWS\system32\SearchIndexer.exe (Microsoft Corporation)
* C:\WINDOWS\system32\igfxpers.exe (Intel Corporation)
* C:\Documents and Settings\UPSAIR\Desktop\runscanner.exe (Runscanner.net)
* C:\WINDOWS\system32\services.exe (Microsoft Corporation)
* C:\Program Files\Analog Devices\Core\smax4pnp.exe (Analog Devices, Inc.)
* C:\WINDOWS\system32\spoolsv.exe (Microsoft Corporation)
* C:\Program Files\Trend Micro\Internet Security\TMAS_OE\TMAS_OEMon.exe (Trend Micro Inc.)
* C:\Program Files\Trend Micro\Internet Security\TmPfw.exe (Trend Micro Inc.)
* C:\Program Files\Trend Micro\Internet Security\TmProxy.exe (Trend Micro Inc.)
* C:\Program Files\Trend Micro\TrendSecure\SecurityActivityDashboard\tmarsvc.exe (Trend Micro Inc.)
* C:\Program Files\Trend Micro\Internet Security\UfSeAgnt.exe (Trend Micro Inc.)
* C:\Program Files\Trend Micro\TrendSecure\TISProToolbar\ProToolbarUpdate.exe (Trend Micro Inc.)
* C:\Program Files\Trend Micro\TrendSecure\TISProToolbar\PlatformDependent\ProToolbarComm.exe (Trend Micro Inc.)
* C:\Program Files\Trend Micro\TrendSecure\TSCFCommander.exe (Trend Micro Inc.)
* C:\Program Files\Trend Micro\TrendSecure\TSCFPlatformCOMSvr.exe (Trend Micro Inc.)
C:\Program Files\Linksys\WUSB300N\WUSB300N.exe (Linksys)
* C:\Program Files\Uniblue\RegistryBooster\RegistryBooster.exe (Uniblue Software)
* C:\WINDOWS\Explorer.EXE (Microsoft Corporation)
* C:\WINDOWS\system32\winlogon.exe (Microsoft Corporation)
* c:\windows\System32\smss.exe (Microsoft Corporation)
* C:\Program Files\Windows Desktop Search\WindowsSearch.exe (Microsoft Corporation)
* C:\WINDOWS\system32\wuauclt.exe (Microsoft Corporation)
* C:\WINDOWS\system32\wbem\wmiprvse.exe (Microsoft Corporation)
Unrated items
002 * C:\Program Files\Common Files\ArcSoft\Connection Service\Bin\ACDaemon.exe (ArcSoft Inc.)
002 C:\Program Files\QuickTime\qttask.exe (Apple Inc.)
003 * C:\Program Files\Uniblue\RegistryBooster\RegistryBooster.exe (Uniblue Software)
005 C:\Program Files\Digital Line Detect\DLG.exe (BVRP Software)
005 C:\Program Files\Kodak\Kodak EasyShare software\bin\EasyShare.exe (Eastman Kodak Company)
010 * C:\Program Files\Common Files\ArcSoft\Connection Service\Bin\ACService.exe (ArcSoft Connect Daemon)
010 C:\Program Files\Broadcom\ASFIPMon\AsfIpMon.exe (Broadcom ASF IP Monitor)
010 C:\Program Files\Linksys\WUSB300N\WLService.exe (WUSB300NSvc)
011 C:\Program Files\Broadcom\ASFIPMon\BASFND.sys (BASFND)
011 * C:\WINDOWS\System32\Drivers\GEARAspiWDM.sys (GEAR ASPI Filter Driver)
050 C:\Program Files\Windows Desktop Search\MSNLNamespaceMgr.dll (Microsoft Corporation) {56F9679E-7826-4C84-81F3-532071A8BCC5}
052 C:\Program Files\BAE\BAE.dll (Dell Inc.) {CA6319C0-31B7-401E-A518-A07C3DB8F777}
052 C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll (Sun Microsystems, Inc.) {E7E6F031-17CE-4C07-BC86-EABFE594F69C}
061 C:\Program Files\Windows Desktop Search\msnlExt.dll (Microsoft Corporation) {13E7F612-F261-4391-BEA2-39DF4F3FA311}
062 C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\PDFShell.dll (Adobe Systems, Inc.) {F9DB5320-233E-11D1-9F84-707F02C10627}
069 C:\WINDOWS\system32\hptcpmon.dll (Hewlett Packard)
100 Start Page HKCU : [You must be registered and logged in to see this link.]
104 * C:\WINDOWS\Downloaded Program Files\PhotoUploader5.ocx (The Facebook) {0CCA191D-13A6-4E29-B746-314DEE697D83}
104 GUID / CLSID not found {4ED9DDF0-7479-4BBE-9335-5A1EDB1D8A21}
104 C:\WINDOWS\Downloaded Program Files\axofupld.dll (KODAK EASYSHARE Gallery) {6F750203-1362-4815-A476-88533DE61D0C}
104 * C:\WINDOWS\Downloaded Program Files\PhotoUploader55.ocx (The Facebook) {8100D56A-5661-482C-BEE8-AFECE305D968}
104 GUID / CLSID not found {8FFBE65D-2C9C-4669-84BD-5829DC0B603C}
104 * C:\WINDOWS\Downloaded Program Files\sfuploadplugin.ocx (Shutterfly, Inc.) {9600F64D-755F-11D4-A47F-0001023E6D5A}
104 C:\WINDOWS\DOWNLO~1\TSEASY~1.OCX (Trend Micro Inc.) {B7D07999-2ADB-4AEB-997E-F61CB7B2E2CD}
104 GUID / CLSID not found {CAFEEFAC-0015-0000-0006-ABCDEFFEDCBA}
104 * C:\WINDOWS\Downloaded Program Files\ieatgpc.dll (WebEx Communications, Inc) {E06E2E99-0AA1-11D4-ABA6-0060082AA75C}
105 E&xport to Microsoft Excel : [You must be registered and logged in to see this link.]
107 C:\Program Files\Bonjour\mdnsNSP.dll (Apple Inc.)
173 GUID / CLSID not found
221 GUID / CLSID not found
223 * C:\Program Files\Malwarebytes' Anti-Malware\mbamext.dll (Malwarebytes Corporation) {57CE581A-0CB6-4266-9CA0-19364C90A0B3}
225 * C:\Program Files\Malwarebytes' Anti-Malware\mbamext.dll (Malwarebytes Corporation) {57CE581A-0CB6-4266-9CA0-19364C90A0B3}
227 GUID / CLSID not found
231 C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\PDFShell.dll (Adobe Systems, Inc.) PDF Column Info
Missing files
011 C:\WINDOWS\system32\drivers\Abiosdsk.sys
011 C:\WINDOWS\system32\drivers\Atdisk.sys
011 C:\WINDOWS\system32\drivers\bvrp_pci.sys
011 C:\DOCUME~1\UPSAIR\LOCALS~1\Temp\catchme.sys
011 C:\WINDOWS\system32\drivers\Changer.sys
011 C:\WINDOWS\system32\drivers\lbrtfdc.sys
011 c:\windows\system32\Drivers\neokdss.sys
011 C:\WINDOWS\system32\drivers\PCIDump.sys
011 C:\WINDOWS\system32\drivers\PDCOMP.sys
011 C:\WINDOWS\system32\drivers\PDFRAME.sys
011 C:\WINDOWS\system32\drivers\PDRELI.sys
011 C:\WINDOWS\system32\drivers\PDRFRAME.sys
011 C:\WINDOWS\system32\drivers\Simbad.sys
011 C:\WINDOWS\system32\drivers\WDICA.sys
061 deskpan.dll
LaxRef93
Posts Posts : 13
Post by Dr Jay on 15th September 2009, 1:22 am
Hi
Please post the SystemLook log from earlier, as well.
Posts Posts : 13810
Post by LaxRef93 on 15th September 2009, 1:30 am
Here is the log from Security Check. I will try to load SystemLook again.
Results of screen317's Security Check version 0.98.9
Windows XP Service Pack 3
Antivirus/Firewall Check:
Windows Firewall Enabled!
Antivirus up to date!
Spyware Doctor 6.0
HijackThis 2.0.2
Java(TM) 6 Update 15
Adobe Flash Player 10
Adobe Reader 8.1.2
Adobe Reader 8.1.2 Security Update 1 (KB403742)
Process Check:
objlist.exe by Laurent
Trend Micro BM TMBMSRV.exe
Trend Micro TrendSecure SecurityActivityDashboard tmarsvc.exe
Trend Micro Internet Security SfCtlCom.exe
Trend Micro Internet Security TmPfw.exe
Trend Micro Internet Security TmProxy.exe
Trend Micro Internet Security UfSeAgnt.exe
Trend Micro TrendSecure TISProToolbar ProToolbarUpdate.exe
Trend Micro Internet Security TMAS_OE TMAS_OEMon.exe
Trend Micro TrendSecure TSCFCommander.exe
Trend Micro TrendSecure TISProToolbar PlatformDependent\ProToolbarComm.exe
Trend Micro TrendSecure TSCFPlatformCOMSvr.exe
DNS Vulnerability Check:
Unknown. This method cannot test your vulnerability to DNS cache poisoning.
LaxRef93
Posts Posts : 13
Post by LaxRef93 on 15th September 2009, 1:46 am
And here is the log for SystemLook:
SystemLook v1.0 by jpshortstuff (29.08.09)
Log created at 21:33 on 14/09/2009 by UPSAIR (Administrator - Elevation successful)
Searching for "scecli.dll"
C:\i386\scecli.dll --a--- 180224 bytes [07:18 14/10/2006] [10:00 04/08/2004] 0F78E27F563F2AAF74B91A49E2ABF19A
C:\WINDOWS\$NtServicePackUninstall$\scecli.dll -----c 180224 bytes [19:18 31/12/2008] [10:00 04/08/2004] 0F78E27F563F2AAF74B91A49E2ABF19A
C:\WINDOWS\ERDNT\cache\scecli.dll --a--- 181248 bytes [09:35 10/09/2009] [00:12 14/04/2008] A86BB5E61BF3E39B62AB4C7E7085A084
C:\WINDOWS\ServicePackFiles\i386\scecli.dll ------ 181248 bytes [05:29 04/09/2008] [00:12 14/04/2008] A86BB5E61BF3E39B62AB4C7E7085A084
C:\WINDOWS\system32\scecli.dll ------ 181248 bytes [22:00 11/08/2004] [00:12 14/04/2008] A86BB5E61BF3E39B62AB4C7E7085A084
Searching for "netlogon.dll"
C:\i386\netlogon.dll --a--- 407040 bytes [07:17 14/10/2006] [10:00 04/08/2004] 96353FCECBA774BB8DA74A1C6507015A
C:\WINDOWS\$NtServicePackUninstall$\netlogon.dll -----c 407040 bytes [19:18 31/12/2008] [10:00 04/08/2004] 96353FCECBA774BB8DA74A1C6507015A
C:\WINDOWS\ERDNT\cache\netlogon.dll --a--- 407040 bytes [09:35 10/09/2009] [00:12 14/04/2008] 1B7F071C51B77C272875C3A23E1E4550
C:\WINDOWS\ServicePackFiles\i386\netlogon.dll ------ 407040 bytes [05:29 04/09/2008] [00:12 14/04/2008] 1B7F071C51B77C272875C3A23E1E4550
C:\WINDOWS\system32\netlogon.dll ------ 407040 bytes [22:00 11/08/2004] [00:12 14/04/2008] 1B7F071C51B77C272875C3A23E1E4550
Searching for "eventlog.dll"
C:\i386\eventlog.dll --a--- 55808 bytes [07:14 14/10/2006] [10:00 04/08/2004] 82B24CB70E5944E6E34662205A2A5B78
C:\WINDOWS\$NtServicePackUninstall$\eventlog.dll -----c 55808 bytes [19:18 31/12/2008] [10:00 04/08/2004] 82B24CB70E5944E6E34662205A2A5B78
C:\WINDOWS\ERDNT\cache\eventlog.dll --a--- 56320 bytes [09:35 10/09/2009] [02:26 10/09/2009] 6D4FEB43EE538FC5428CC7F0565AA656
C:\WINDOWS\ServicePackFiles\i386\eventlog.dll ------ 56320 bytes [05:27 04/09/2008] [00:11 14/04/2008] 6D4FEB43EE538FC5428CC7F0565AA656
C:\WINDOWS\system32\eventlog.dll ------ 56320 bytes [22:00 11/08/2004] [02:26 10/09/2009] 6D4FEB43EE538FC5428CC7F0565AA656
-=End Of File=-
LaxRef93
Posts Posts : 13
Post by Dr Jay on 15th September 2009, 2:12 am
Hi
Hooray! Your computer is clean.
Adobe Acrobat Reader is out of date.
Please download the newest version from here: [You must be registered and logged in to see this link.]
It's important to remove older versions of Acrobat Reader since it does not do so automatically and old versions still leave you vulnerable.
Go to Start > Control Panel > Software and open Add or Remove Programs.
Search in the list for all previous installed versions of Adobe Acrobat Reader.
Software recommendations
AntiSpyware
  • [You must be registered and logged in to see this link.]
Resident Protection help
Rogue programs help
Securing your computer
If you are interested:
Posts Posts : 13810
Post by LaxRef93 on 15th September 2009, 2:25 am
Thank you very much for all your help! You answered each of my posts most times within an hour, and for that I appreciate it very much. This is a great service, and I'm glad I found it! Thank you again for a job well done!
LaxRef93
Posts Posts : 13
Post by Dr Jay on 15th September 2009, 2:45 am
Since this issue appears to be solved, this topic is now closed and being marked solved.
If you need the topic reopened, PM an administrator, moderator, or staff.
Posts Posts : 13810
