Police Pro on Desktop - Removal Help Requested
Post by Kalysia on 9th September 2009, 2:09 am
Hello, there,
A week or so ago, our desktop computer became infected with Police Pro. It locked us out of our programs, and our Google searches were being directed to other search sites. After deleting the infected files, and changing the value of the explore.exe file, everything seemed to be working fine.
This afternoon, as I got on Google and performed a search, Police Pro popped back up, again. We have not had a problem with it for the last several days, but, now, I am forced to use the task manager to activate the explorer.exe file every time that I turn on the computer. I am at a complete loss for what to do to remove this program from our computer. Any and all help is greatly appreciated.
Kalysia
Posts Posts : 3
Joined Joined : 2009-09-09
Points Points : 26477
Re: Police Pro on Desktop - Removal Help Requested
Post by Dr Jay on 9th September 2009, 5:54 am
Hi
Posts Posts : 13810
Points Points : 302437
Post by Dr Jay on 14th September 2009, 10:14 pm
Due to lack of response, this topic is now closed.
If you need the topic reopened, PM an administrator or moderator.
Posts Posts : 13810
