Antivirus System PRO - gone but browsers won't work
Post by alannati on 9th September 2009, 1:56 am
I recently got Antivirus System PRO and went through the steps on this site for removing it with Malwarebyte. It worked well and the program and pop-ups are gone, but neither IE or Firefox will connect to the net. Firefox opens a blank page and IE "cannot display the webpage"
I installed HijackThis and got the following report:
Scan saved at 6:35:40 PM, on 9/8/2009
C:\Program Files\Intel\Wireless\Bin\EvtEng.exe
C:\Program Files\Intel\Wireless\Bin\S24EvMon.exe
C:\Program Files\Intel\Wireless\Bin\WLKeeper.exe
C:\Program Files\Intel\Wireless\Bin\ZcfgSvc.exe
C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe
C:\Program Files\Dell\NICCONFIGSVC\NICCONFIGSVC.exe
C:\Program Files\Intel\Wireless\Bin\RegSrvc.exe
C:\PROGRA~1\AVG\AVG8\avgemc.exe
C:\PROGRA~1\AVG\AVG8\avgrsx.exe
C:\Program Files\AVG\AVG8\avgcsrvx.exe
C:\PROGRA~1\Intel\Wireless\Bin\1XConfig.exe
C:\WINDOWS\system32\hkcmd.exe
C:\Program Files\Dell\Media Experience\PCMService.exe
C:\Program Files\HP\hpcoretech\hpcmpmgr.exe
C:\WINDOWS\system32\spool\drivers\w32x86\3\hpztsb10.exe
C:\Program Files\Hewlett-Packard\HP Software Update\HPWuSchd2.exe
C:\Program Files\Adobe\Acrobat 8.0\Acrobat\Acrotray.exe
C:\PROGRA~1\AVG\AVG8\avgtray.exe
C:\Program Files\DAEMON Tools Lite\daemon.exe
C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe
C:\WINDOWS\system32\cmd.exe
R3 - URLSearchHook: AVG Security Toolbar BHO - {A3BC75A2-1F87-4686-AA43-5347D756017C} - C:\Program Files\AVG\AVG8\Toolbar\IEToolbar.dll
R3 - URLSearchHook: (no name) - *{CFBFAE00-17A6-11D0-99CB-00C04FD64497} - (no file)
O1 - Hosts: ::1 localhost
O1 - Hosts: 91.212.127.221 viruskill2009.microsoft.com
O1 - Hosts: 91.212.127.221 viruskill2009.com
O1 - Hosts: 91.212.127.221 [You must be registered and logged in to see this link.]
O2 - BHO: WormRadar.com IESiteBlocker.NavFilter - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - C:\Program Files\AVG\AVG8\avgssie.dll
O2 - BHO: Java(tm) Plug-In SSV Helper - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre6\bin\ssv.dll
O2 - BHO: Adobe PDF Conversion Toolbar Helper - {AE7CD045-E861-484f-8273-0445EE161910} - C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll
O3 - Toolbar: (no name) - {BA52B914-B692-46c4-B683-905236F6F655} - (no file)
O3 - Toolbar: Adobe PDF - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll
O3 - Toolbar: AVG Security Toolbar - {CCC7A320-B3CA-4199-B1A6-9F516DD69829} - C:\Program Files\AVG\AVG8\Toolbar\IEToolbar.dll
O4 - HKLM\..\Run: [PCMService] "C:\Program Files\Dell\Media Experience\PCMService.exe"
O4 - HKLM\..\Run: [HP Component Manager] "C:\Program Files\HP\hpcoretech\hpcmpmgr.exe"
O4 - HKLM\..\Run: [HPDJ Taskbar Utility] C:\WINDOWS\system32\spool\drivers\w32x86\3\hpztsb10.exe
O4 - HKLM\..\Run: [HP Software Update] "C:\Program Files\Hewlett-Packard\HP Software Update\HPWuSchd2.exe"
O4 - HKLM\..\Run: [Acrobat Assistant 8.0] "C:\Program Files\Adobe\Acrobat 8.0\Acrobat\Acrotray.exe"
O4 - HKLM\..\Run: [AVG8_TRAY] C:\PROGRA~1\AVG\AVG8\avgtray.exe
O4 - HKCU\..\Run: [DAEMON Tools Lite] "C:\Program Files\DAEMON Tools Lite\daemon.exe" -autorun
O8 - Extra context menu item: Append to existing PDF - [You must be registered and logged in to see this link.] Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: Convert link target to Adobe PDF - [You must be registered and logged in to see this link.] Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
O8 - Extra context menu item: Convert link target to existing PDF - [You must be registered and logged in to see this link.] Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: Convert selected links to Adobe PDF - [You must be registered and logged in to see this link.] Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIECaptureSelLinks.html
O8 - Extra context menu item: Convert selected links to existing PDF - [You must be registered and logged in to see this link.] Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIEAppendSelLinks.html
O8 - Extra context menu item: Convert selection to Adobe PDF - [You must be registered and logged in to see this link.] Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
O8 - Extra context menu item: Convert selection to existing PDF - [You must be registered and logged in to see this link.] Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: Convert to Adobe PDF - [You must be registered and logged in to see this link.] Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
O9 - Extra button: Real.com - {CD67F990-D8E9-11d2-98FE-00C0F0318AFE} - C:\WINDOWS\system32\Shdocvw.dll
O9 - Extra button: MUSICMATCH MX Web Player - {d81ca86b-ef63-42af-bee3-4502d9a03c2d} - [You must be registered and logged in to see this link.] (file missing)
O10 - Broken Internet access because of LSP provider 'c:\windows\system32\lsp.dll' missing
O18 - Protocol: linkscanner - {F274614C-63F8-47D5-A4D1-FBDDE494F8D1} - C:\Program Files\AVG\AVG8\avgpp.dll
O20 - Winlogon Notify: avgrsstarter - C:\WINDOWS\SYSTEM32\avgrsstx.dll
O23 - Service: AVG Free8 E-mail Scanner (avg8emc) - AVG Technologies CZ, s.r.o. - C:\PROGRA~1\AVG\AVG8\avgemc.exe
O23 - Service: AVG Free8 WatchDog (avg8wd) - AVG Technologies CZ, s.r.o. - C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe
O23 - Service: ##Id_String1.6844F930_1628_4223_B5CC_5BB94B879762## (Bonjour Service) - Apple Computer, Inc. - C:\Program Files\Bonjour\mDNSResponder.exe
O23 - Service: EvtEng - Intel Corporation - C:\Program Files\Intel\Wireless\Bin\EvtEng.exe
O23 - Service: FLEXnet Licensing Service - Macrovision Europe Ltd. - C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe
O23 - Service: Google Updater Service (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
O23 - Service: NICCONFIGSVC - Dell Inc. - C:\Program Files\Dell\NICCONFIGSVC\NICCONFIGSVC.exe
O23 - Service: RegSrvc - Intel Corporation - C:\Program Files\Intel\Wireless\Bin\RegSrvc.exe
O23 - Service: Spectrum24 Event Monitor (S24EventMonitor) - Intel Corporation - C:\Program Files\Intel\Wireless\Bin\S24EvMon.exe
O23 - Service: WLANKEEPER - Intel® Corporation - C:\Program Files\Intel\Wireless\Bin\WLKeeper.exe
End of file - 8667 bytes
alannati
Posts Posts : 3
Joined Joined : 2009-09-09
Points Points : 26485
Re: Antivirus System PRO - gone but browsers won't work
Post by Dr Jay on 9th September 2009, 5:52 am
Hi
You may have to transfer this from a computer that is connected to the Internet, to the infected computer - then run it.
  1. Please download LSPFix from [You must be registered and logged in to see this link.].
  2. Run the LSPFix.exe that you have just finished downloading.
  3. Check the I know what I'm doing box.
  4. In the Keep box you should see one or more instances of XXXXX.dll.
  5. Select every instance of XXXXX.dll and move each one to the Remove box by clicking the >> button.
  6. When you are done click Finish>>.
Posts Posts : 14309
Points Points : 302960
Post by alannati on 11th September 2009, 6:03 pm
I did that and now IE and Firefox seem to work, but the computer will not connect to a wireless network. I have tried to connect to two different ones. It recognizes the network, but cant acquire the network address. It wont even show the network icons in the system tray until I open the Network Connections window from the start menu.
alannati
Posts Posts : 3
Post by Dr Jay on 11th September 2009, 8:13 pm
Please reboot to Safe Mode with Networking (tap the F8 key just before Windows starts to load and select the Safe Mode with Networking option from the menu). See if the connection is operational.
Posts Posts : 14309
Post by alannati on 12th September 2009, 7:51 am
OK, so I entered safe mode with networking and it still could not connect to a network. I ran MBAM and got the following report:
Malwarebytes' Anti-Malware 1.40
Database version: 2551
Windows 5.1.2600 Service Pack 3 (Safe Mode)
9/11/2009 5:10:32 PM
mbam-log-2009-09-11 (17-10-32).txt
Scan type: Full Scan (C:\|)
Objects scanned: 193648
Time elapsed: 28 minute(s), 53 second(s)
alannati
Posts Posts : 3
Post by Dr Jay on 12th September 2009, 8:24 am
Hi
From a computer that is connected to the Internet, please download the below tool, and transfer it on to the infected machine. Work in Safe Mode.
ComboFix
Please download ComboFix from [You must be registered and logged in to see this link.] or [You must be registered and logged in to see this link.]
* IMPORTANT !!! Save ComboFix.exe to your Desktop
  • Disable your AntiVirus and AntiSpyware applications, usually via a right click on the System Tray icon. They may otherwise interfere with our tools. Note: If you are having difficulty properly disabling your protective
    programs, or are unsure as to what programs need to be disabled, please refer to the information available through this link : [You must be registered and logged in to see this link.]
  • Double click on ComboFix.exe & follow the prompts.
  • As part of it's process, ComboFix will check to see if the Microsoft Windows Recovery Console is installed.
Since you are not connected to the Internet on the infected machine, then the Recovery Console cannot be downloaded and installed. Optionally, before you start the scan, install it from a Windows XP disc.
When finished, it shall produce a log for you. Please include the C:\ComboFix.txt in your next reply.
Do not mouse-click Combofix's window while it is running. That may cause it to stall.
Posts Posts : 14309
