undetermined problem lost?????
Post by tinagibson on Tue Sep 08, 2009 1:27 pm
downloaded avira antivirus and malwarebytes avira as of today won't scan system and malwarebytes shows to be installed (icon, control panel etc) but can't be opened. running slow pop up's and ads playing on speakers i'm lost. don't have any idea whats going on
tinagibson
Posts Posts : 38
Joined Joined : 2009-07-18
Points Points : 27124
Re: undetermined problem lost?????
Post by Belahzur on Tue Sep 08, 2009 2:30 pm
Points Points : 245069
Post by tinagibson on Tue Sep 08, 2009 6:48 pm
installed hijack this ran program cant access log says windows cannot access may not have permission to access i am the admin
tinagibson
Posts Posts : 38
Post by Belahzur on Tue Sep 08, 2009 7:51 pm
    :filefind
    scecli.dll
    netlogon.dll
    eventlog.dll
    cngaudit.dll
Post by tinagibson on Tue Sep 08, 2009 9:00 pm
Log created at 16:40 on 08/09/2009 by tina gibson (Administrator - Elevation successful)
Searching for "scecli.dll"
C:\WINDOWS\system32\dllcache\scecli.dll --a--c 181248 bytes [22:00 14/04/2008] [22:00 14/04/2008] A86BB5E61BF3E39B62AB4C7E7085A084
C:\WINDOWS\system32\scecli.dll --a--- 181248 bytes [22:00 14/04/2008] [22:00 14/04/2008] A86BB5E61BF3E39B62AB4C7E7085A084
Searching for "netlogon.dll"
C:\WINDOWS\system32\dllcache\netlogon.dll --a--c 407040 bytes [22:00 14/04/2008] [22:00 14/04/2008] 1B7F071C51B77C272875C3A23E1E4550
C:\WINDOWS\system32\netlogon.dll --a--- 407040 bytes [22:00 14/04/2008] [22:00 14/04/2008] 1B7F071C51B77C272875C3A23E1E4550
Searching for "eventlog.dll"
C:\WINDOWS\system32\dllcache\eventlog.dll --a--c 56320 bytes [22:00 14/04/2008] [22:00 14/04/2008] 6D4FEB43EE538FC5428CC7F0565AA656
C:\WINDOWS\system32\eventlog.dll --a--- 63488 bytes [22:00 14/04/2008] [22:00 14/04/2008] (Unable to calculate MD5)
Searching for "cngaudit.dll"
No files found.
-=End Of File=-
tinagibson
Posts Posts : 38
Post by Belahzur on Tue Sep 08, 2009 11:59 pm
Files to delete:
Post by tinagibson on Wed Sep 09, 2009 2:32 am
Platform: Windows XP
File "C:\WINDOWS\system32\eventlog.dll" deleted successfully.
Completed script processing.
Finished! Terminate.
tinagibson
Posts Posts : 38
Post by Belahzur on Wed Sep 09, 2009 7:30 pm
Now download and run Hijack This from here:
Choose system scan with logfile, copy/paste the log back here.
Post by tinagibson on Wed Sep 09, 2009 9:22 pm
Scan saved at 5:21:35 PM, on 9/9/2009
C:\Program Files\Avira\AntiVir Desktop\sched.exe
C:\WINDOWS\system32\agrsmsvc.exe
C:\Program Files\Avira\AntiVir Desktop\avguard.exe
C:\Program Files\NewTech Infosystems\NTI Backup Now 5\Client\Agentsvc.exe
C:\Program Files\NewTech Infosystems\NTI Backup Now 5\BackupSvc.exe
C:\Program Files\NewTech Infosystems\NTI Backup Now 5\SchedulerSvc.exe
C:\WINDOWS\system32\HPZipm12.exe
C:\Program Files\CyberLink\Shared Files\RichVideo.exe
C:\Program Files\Internet Explorer\Iexplore.exe
C:\Program Files\NewTech Infosystems\NTI Backup Now 5\BkupTray.exe
C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe
C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe
C:\Program Files\Java\jre1.6.0_05\bin\jusched.exe
C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe
C:\WINDOWS\RTHDCPL.EXE
C:\Program Files\Google\Quick Search Box\GoogleQuickSearchBox.exe
C:\Program Files\Avira\AntiVir Desktop\avgnt.exe
C:\Program Files\Steam\Steam.exe
C:\WINDOWS\system32\huej1nqg.exe
C:\Documents and Settings\tina gibson\Local Settings\Temporary Internet Files\Content.IE5\JTNNYEG9\winlogon[1].scr
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.2.4204.1700\swg.dll
O2 - BHO: (no name) - {d2be9f52-416b-4ba8-9790-a7b44e2da14c} - C:\WINDOWS\system32\juvoludi.dll
O3 - Toolbar: Ask Toolbar - {3041d03e-fd4b-44e0-b742-2d9b88305f98} - C:\Program Files\AskBarDis\bar\bin\askBar.dll
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\system32\NvMcTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [BkupTray] "C:\Program Files\NewTech Infosystems\NTI Backup Now 5\BkupTray.exe"
O4 - HKLM\..\Run: [Google Desktop Search] "C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe" /startup
O4 - HKLM\..\Run: [RemoteControl] "C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe"
O4 - HKLM\..\Run: [LanguageShortcut] "C:\Program Files\CyberLink\PowerDVD\Language\Language.exe"
O4 - HKLM\..\Run: [UpdateP2GoShortCut] "C:\Program Files\CyberLink\Power2Go\MUITransfer\MUIStartMenu.exe" "C:\Program Files\CyberLink\Power2Go" UpdateWithCreateOnce "SOFTWARE\CyberLink\Power2Go\6.0"
O4 - HKLM\..\Run: [UpdatePSTShortCut] "C:\Program Files\CyberLink\DVD Suite\MUITransfer\MUIStartMenu.exe" "C:\Program Files\CyberLink\DVD Suite" UpdateWithCreateOnce "Software\CyberLink\PowerStarter"
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre1.6.0_05\bin\jusched.exe"
O4 - HKLM\..\Run: [IMJPMIG8.1] "C:\WINDOWS\IME\imjp8_1\IMJPMIG.EXE" /Spoil /RemAdvDef /Migration32
O4 - HKLM\..\Run: [MSPY2002] C:\WINDOWS\system32\IME\PINTLGNT\ImScInst.exe /SYNC
O4 - HKLM\..\Run: [PHIME2002ASync] C:\WINDOWS\system32\IME\TINTLGNT\TINTSETP.EXE /SYNC
O4 - HKLM\..\Run: [PHIME2002A] C:\WINDOWS\system32\IME\TINTLGNT\TINTSETP.EXE /IMEName
O4 - HKLM\..\Run: [eRecoveryService] C:\Acer\Empowering Technology\eRecovery\eRAgent.exe
O4 - HKLM\..\Run: [Google Quick Search Box] "C:\Program Files\Google\Quick Search Box\GoogleQuickSearchBox.exe" /autorun
O4 - HKLM\..\Run: [lejehipahe] Rundll32.exe "C:\WINDOWS\system32\muyolule.dll",s
O4 - HKLM\..\Run: [avgnt] "C:\Program Files\Avira\AntiVir Desktop\avgnt.exe" /min
O4 - HKLM\..\Run: [nejujatal] Rundll32.exe "c:\windows\system32\pavogare.dll",a
O4 - HKCU\..\Run: [Steam] "C:\Program Files\Steam\Steam.exe" -silent
O4 - HKCU\..\Run: [huej1nqg.exe] C:\WINDOWS\system32\huej1nqg.exe
O4 - HKCU\..\Run: [SaveKeeper] C:\Program Files\SaveKeeper Software\SaveKeeper\SaveKeeper.exe -min
O9 - Extra button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~2\Office12\ONBttnIE.dll
O9 - Extra 'Tools' menuitem: S&end to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~2\Office12\ONBttnIE.dll
O16 - DPF: CabBuilder - [You must be registered and logged in to see this link.]
O16 - DPF: {C3F79A2B-B9B4-4A66-B012-3EE46475B072} (MessengerStatsClient Class) - [You must be registered and logged in to see this link.]
O16 - DPF: {F8C5C0F1-D884-43EB-A5A0-9E1C4A102FA8} (GoPetsWeb Control) - [You must be registered and logged in to see this link.]
O20 - AppInit_DLLs: system32\pavogare.dll C:\WINDOWS\system32\navifaya.dll c:\windows\system32\piyadayi.dll c:\windows\system32\gijiyeli.dll c:\windows\system32\pavogare.dll c:\windows\system32\juvilisi.dll c:\windows\system32\birakuze.dll
O21 - SSODL: yayesamul - {6df63b01-2def-4016-8be8-cf6d420fc2ec} - (no file)
O21 - SSODL: tezeweriv - {c4647e83-b1fb-4ace-8b0f-01c8ed5feb17} - (no file)
O21 - SSODL: kofubuped - {951e6892-90bb-4d51-ba65-aa1827082791} - (no file)
O21 - SSODL: tomijatan - {c3b23518-67d1-42c4-8ed1-7f3372958c99} - (no file)
O21 - SSODL: jupepepaj - {4df9ff81-574d-4acd-af40-a783b10684dc} - (no file)
O21 - SSODL: bezuzofot - {13e6bc15-23af-44f0-b974-134bc50cd8f9} - c:\windows\system32\birakuze.dll
O21 - SSODL: detoyinop - {5ae95ba6-475b-40a5-8365-9b34c6c3fdc8} - c:\windows\system32\birakuze.dll
O21 - SSODL: zutumibos - {9d2abf7e-60ce-4bc6-90d9-295aa5da4852} - c:\windows\system32\gijiyeli.dll
O21 - SSODL: fuzahuyin - {dd017c53-7b24-40b0-9b0e-29b5a6308345} - c:\windows\system32\gijiyeli.dll
O21 - SSODL: morihidow - {d11acbbd-154c-41ff-8ab3-6aa4731f2542} - c:\windows\system32\gijiyeli.dll
O21 - SSODL: budewuror - {f2da7688-3513-4b61-830a-49dfd4beabd9} - c:\windows\system32\gijiyeli.dll
O21 - SSODL: jovipisew - {90977e94-aadc-495f-8562-91976cc3554c} - c:\windows\system32\juvilisi.dll
O21 - SSODL: yukofevad - {f4558546-6753-480d-8e8d-e359d5a7e69b} - c:\windows\system32\gijiyeli.dll
O21 - SSODL: hidatahib - {fe0de2c7-b49a-4d0d-8724-6f17660097d2} - c:\windows\system32\birakuze.dll
O21 - SSODL: kidakatej - {54f51f81-5c36-4152-b071-75606cd157cc} - c:\windows\system32\piyadayi.dll
O21 - SSODL: nuziwelim - {d9e3d7ec-94e5-4d83-b18a-974c92a53cce} - c:\windows\system32\juvilisi.dll
O21 - SSODL: rurimayuy - {9538744d-d6d4-466f-96b7-d039978e000d} - c:\windows\system32\birakuze.dll
O22 - SharedTaskScheduler: tokatiluy - {6df63b01-2def-4016-8be8-cf6d420fc2ec} - (no file)
O22 - SharedTaskScheduler: mujuzedij - {c4647e83-b1fb-4ace-8b0f-01c8ed5feb17} - (no file)
O22 - SharedTaskScheduler: jugezatag - {951e6892-90bb-4d51-ba65-aa1827082791} - (no file)
O22 - SharedTaskScheduler: jugezatag - {c3b23518-67d1-42c4-8ed1-7f3372958c99} - (no file)
O22 - SharedTaskScheduler: kupuhivus - {4df9ff81-574d-4acd-af40-a783b10684dc} - (no file)
O22 - SharedTaskScheduler: mujuzedij - {13e6bc15-23af-44f0-b974-134bc50cd8f9} - c:\windows\system32\birakuze.dll
O22 - SharedTaskScheduler: mujuzedij - {5ae95ba6-475b-40a5-8365-9b34c6c3fdc8} - c:\windows\system32\birakuze.dll
O22 - SharedTaskScheduler: kupuhivus - {9d2abf7e-60ce-4bc6-90d9-295aa5da4852} - c:\windows\system32\gijiyeli.dll
O22 - SharedTaskScheduler: kupuhivus - {dd017c53-7b24-40b0-9b0e-29b5a6308345} - c:\windows\system32\gijiyeli.dll
O22 - SharedTaskScheduler: jugezatag - {d11acbbd-154c-41ff-8ab3-6aa4731f2542} - c:\windows\system32\gijiyeli.dll
O22 - SharedTaskScheduler: kupuhivus - {f2da7688-3513-4b61-830a-49dfd4beabd9} - c:\windows\system32\gijiyeli.dll
O22 - SharedTaskScheduler: jugezatag - {90977e94-aadc-495f-8562-91976cc3554c} - c:\windows\system32\juvilisi.dll
O22 - SharedTaskScheduler: kupuhivus - {f4558546-6753-480d-8e8d-e359d5a7e69b} - c:\windows\system32\gijiyeli.dll
O22 - SharedTaskScheduler: gahurihor - {fe0de2c7-b49a-4d0d-8724-6f17660097d2} - c:\windows\system32\birakuze.dll
O22 - SharedTaskScheduler: gahurihor - {54f51f81-5c36-4152-b071-75606cd157cc} - c:\windows\system32\piyadayi.dll
O22 - SharedTaskScheduler: kupuhivus - {d9e3d7ec-94e5-4d83-b18a-974c92a53cce} - c:\windows\system32\juvilisi.dll
O22 - SharedTaskScheduler: kupuhivus - {9538744d-d6d4-466f-96b7-d039978e000d} - c:\windows\system32\birakuze.dll
O23 - Service: Agere Modem Call Progress Audio (AgereModemAudio) - Agere Systems - C:\WINDOWS\system32\agrsmsvc.exe
O23 - Service: Avira AntiVir Scheduler (AntiVirSchedulerService) - Avira GmbH - C:\Program Files\Avira\AntiVir Desktop\sched.exe
O23 - Service: Avira AntiVir Guard (AntiVirService) - Avira GmbH - C:\Program Files\Avira\AntiVir Desktop\avguard.exe
O23 - Service: ASKUpgrade - Unknown owner - C:\Program Files\AskBarDis\bar\bin\ASKUpgrade.exe
O23 - Service: NTI Backup Now 5 Agent Service (BUNAgentSvc) - NewTech Infosystems, Inc. - C:\Program Files\NewTech Infosystems\NTI Backup Now 5\Client\Agentsvc.exe
O23 - Service: Google Desktop Manager 5.7.808.7150 (GoogleDesktopManager-080708-050100) - Google - C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe
O23 - Service: My Web Search Service (MyWebSearchService) - Unknown owner - C:\PROGRA~1\MYWEBS~1\bar\1.bin\mwssvc.exe (file missing)
O23 - Service: NTI Backup Now 5 Backup Service (NTIBackupSvc) - NewTech InfoSystems, Inc. - C:\Program Files\NewTech Infosystems\NTI Backup Now 5\BackupSvc.exe
O23 - Service: NTI Backup Now 5 Scheduler Service (NTISchedulerSvc) - Unknown owner - C:\Program Files\NewTech Infosystems\NTI Backup Now 5\SchedulerSvc.exe
O23 - Service: Cyberlink RichVideo Service(CRVS) (RichVideo) - Unknown owner - C:\Program Files\CyberLink\Shared Files\RichVideo.exe
End of file - 13054 bytes
tinagibson
Posts Posts : 38
Post by tinagibson on Wed Sep 09, 2009 9:23 pm
have new problem something called savekeeper and registry defender same problem or new??
tinagibson
Posts Posts : 38
Post by Belahzur on Wed Sep 09, 2009 10:03 pm
Post by tinagibson on Thu Sep 10, 2009 1:56 am
malwarebytes won't launch no matter what i do files extract installation complete finish etc try to open nothing ( downloaded 5 times onto my computer) what now?
tinagibson
Posts Posts : 38
Post by Belahzur on Thu Sep 10, 2009 7:16 pm
  • Download combofix from here
Post by tinagibson on Thu Sep 10, 2009 9:26 pm
Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.2814.2315 [GMT -4:00]
Running from: c:\documents and settings\tina gibson\Desktop\Combo-Fix.exe
AV: AntiVir Desktop *On-access scanning disabled* (Updated) {AD166499-45F9-482A-A743-FDD3350758C7}
c:\documents and settings\All Users\Application Data\ecazibomeg.dll
c:\documents and settings\All Users\Application Data\ehomun.bin
c:\documents and settings\All Users\Application Data\irir.scr
c:\documents and settings\All Users\Application Data\kymex.lib
c:\documents and settings\All Users\Application Data\Microsoft\Network\Downloader\qmgr0.dat
c:\documents and settings\All Users\Application Data\Microsoft\Network\Downloader\qmgr1.dat
c:\documents and settings\All Users\Application Data\relicy.vbs
c:\documents and settings\All Users\Application Data\ymypocadu.sys
c:\documents and settings\kaitie justice\Application Data\.#
c:\documents and settings\kaitie justice\Application Data\.#\MBX@C48@12741C0.###
c:\documents and settings\kaitie justice\Application Data\.#\MBX@C48@12741F0.###
c:\documents and settings\kaitie justice\Application Data\.#\MBX@C48@1274220.###
C:\fyblb.exe
c:\program files\Common Files\akepuzaq.sys
c:\program files\Common Files\delof.bat
c:\windows\010112010146120114.fx
c:\windows\0101120101464949.fx
c:\windows\0101120101465653.fx
c:\windows\10651zac9tool2975.exe
c:\windows\10z55t9oj7f3.ocx
c:\windows\10z60wo9m564.ocx
c:\windows\11299spy55z.bin
c:\windows\1147zsp95bot58e.cpl
c:\windows\115129roj75z.bin
c:\windows\11545s5amb9t5z9.bin
c:\windows\1155ste5l9z8.dll
c:\windows\120935irus35fz.dll
c:\windows\12379tr5jz6e.ocx
c:\windows\12b8bacz95or832.ocx
c:\windows\12e9viz17975.bin
c:\windows\12z295py5f5.ocx
c:\windows\1315zpyware30769.ocx
c:\windows\131z69p5mbotca.bin
c:\windows\13659zacktool57b.dll
c:\windows\1391downloz5er9269.dll
c:\windows\139sp5war91786z.dll
c:\windows\1409v5zus225.ocx
c:\windows\14259dzw5re604.dll
c:\windows\145529ormz63.exe
c:\windows\145z0wor94b0.cpl
c:\windows\14794s5am9zt48f.ocx
c:\windows\14z36spa5bot193.exe
c:\windows\15052ha5ztool69b.ocx
c:\windows\15122zir9s519.ocx
c:\windows\152bt9iez1291.cpl
c:\windows\15646spz69e.cpl
c:\windows\15900not9a-virusz2a.bin
c:\windows\15995szambot59f.ocx
c:\windows\15aavir37z9.dll
c:\windows\15f9spyware3156z.ocx
c:\windows\15z5thre9t2209.bin
c:\windows\1611backdz5r2195.dll
c:\windows\162spazb9t1bc5.bin
c:\windows\162z1wo95685.dll
c:\windows\16731ha5ktzol189.cpl
c:\windows\1696t5zj2ac.ocx
c:\windows\16985acktoo9553z.dll
c:\windows\169z3tro57bc.bin
c:\windows\16z57worm599.exe
c:\windows\17252zpam9ot3f0.cpl
c:\windows\172z8not-a-5irus7289.ocx
c:\windows\18307hack9ooz50.cpl
c:\windows\18505s9yz16.bin
c:\windows\18553troj195z.cpl
c:\windows\18569hacktoolz90.bin
c:\windows\1857troz579.exe
c:\windows\18932n5t-azvirus669.bin
c:\windows\19048not-a-v5rzs8a.cpl
c:\windows\19113spam5otz54.cpl
c:\windows\19459spamzot2f75.dll
c:\windows\195165ackzool5d9.cpl
c:\windows\19846ha5ktz9l408.bin
c:\windows\198thiez2815.bin
c:\windows\19985virzs6da.bin
c:\windows\199threat2z135.bin
c:\windows\19f95hiefz10.exe
c:\windows\1c98th5ef1z39.cpl
c:\windows\1cec9dd5zre955.ocx
c:\windows\1e22spyw5rz2679.bin
c:\windows\1z098v5r9s5c9.ocx
c:\windows\1z0c5hief2739.ocx
c:\windows\1z740spy1b59.dll
c:\windows\1z906worm3d5.dll
c:\windows\1z986hack9ool4f5.dll
c:\windows\20908hackt5oz3ba.exe
c:\windows\209779acktzol5f0.cpl
c:\windows\2125azdwa9e3227.ocx
c:\windows\21346trojzb95.exe
c:\windows\21359not-a-virus11z.dll
c:\windows\21465hackto595z5.dll
c:\windows\22e5zt9al2241.bin
c:\windows\23925not-z-virus119.exe
c:\windows\23951spambot4zb.exe
c:\windows\23965not-a-virus2f8z.bin
c:\windows\23z73s5amb9t7a.ocx
c:\windows\245255zt9a-virus7e3.ocx
c:\windows\24fdownlo9ze52016.dll
c:\windows\2540t5reat7z91.bin
c:\windows\25ccspzware16009.cpl
c:\windows\2604059z398.exe
c:\windows\26785z9oj685.bin
c:\windows\26903hzckt5ol7af.ocx
c:\windows\2699zroj53d5.cpl
c:\windows\27234s956zd.dll
c:\windows\2745spy1z79.bin
c:\windows\27912noz-a-v5rus2a2.exe
c:\windows\28142hzckt9ol156.cpl
c:\windows\291zv95882.bin
c:\windows\29484zpy3e5.cpl
c:\windows\29506t5zj2ea.bin
c:\windows\29609zr592e5.exe
c:\windows\29726zorm60a5.exe
c:\windows\2991no9-a5vizus5bb.cpl
c:\windows\29951s5y5z59.ocx
c:\windows\29z79troj4b5.ocx
c:\windows\2a39bazk5oor1395.dll
c:\windows\2b0fthiez5219.bin
c:\windows\2c4aa9zwar5488.dll
c:\windows\2dbf9zea51113.bin
c:\windows\2e1dsp9zare805.dll
c:\windows\2ebazir9052.bin
c:\windows\2z255spy39d.dll
c:\windows\2z49hrea55298.cpl
c:\windows\2z714worm5379.dll
c:\windows\2z833troj905.cpl
c:\windows\2z9765acktool51a.exe
c:\windows\2zfd5pyware9213.cpl
c:\windows\305589rojz35.dll
c:\windows\30624zpa5bot396.bin
c:\windows\30630vir5sze9.exe
c:\windows\30765haczto9l72f.cpl
c:\windows\3080v9z1495.dll
c:\windows\3099spywarez859.dll
c:\windows\312465p9zc1.bin
c:\windows\3177backdozr6955.ocx
c:\windows\324bdo5nl9ader292z.exe
c:\windows\3292virusz55.bin
c:\windows\35053spy4z9.cpl
c:\windows\351ea5d9zre1099.dll
c:\windows\35499zroj75d.dll
c:\windows\355eb9ckdoor16z.bin
c:\windows\35ez9hief1000.exe
c:\windows\36fthz9at58958.bin
c:\windows\37bab9c5dozr2792.cpl
c:\windows\38z0not-a-viru599.dll
c:\windows\3917v9r318z5.cpl
c:\windows\3952v5rzs719.exe
c:\windows\39559worm54z.bin
c:\windows\39b0zi52996.dll
c:\windows\39z5vir1519.bin
c:\windows\39zdst5al3025.exe
c:\windows\3d5ethrzat26795.bin
c:\windows\3d9a5ownloadzr704.cpl
c:\windows\3dz7downloa9er2550.cpl
c:\windows\3dze9ownl5ader869.exe
c:\windows\3e28th5ez9206.ocx
c:\windows\3ez3thre958034.exe
c:\windows\3f93dzwn5oa9er395.exe
c:\windows\3z8abac9door29975.exe
c:\windows\3za89parse2566.exe
c:\windows\40559roj73cz.exe
c:\windows\4192vzru554d.exe
c:\windows\4221dz9nloader553.cpl
c:\windows\4295thief15z2.dll
c:\windows\42addw5z91632.bin
c:\windows\4445spywaze69.exe
c:\windows\44db5hreatz62949.dll
c:\windows\4582zackd9or2251.bin
c:\windows\45a6thrzat6192.bin
c:\windows\4605zd95are3242.bin
c:\windows\4823hacz9o5l69a.bin
c:\windows\4841not59-virus20z.ocx
c:\windows\4896vir5z44c.exe
c:\windows\4934vzrus155.exe
c:\windows\495dthzeat1292.ocx
c:\windows\49f9dozn5oader542.ocx
c:\windows\49z35hief2258.ocx
c:\windows\49z3addware2955.cpl
c:\windows\4a6as9ez510.cpl
c:\windows\4b32ad5ware997z.dll
c:\windows\4bf5backd9orz066.dll
c:\windows\4f22vi5984z.exe
c:\windows\4fze9i51026.ocx
c:\windows\4z93t9ief5295.bin
c:\windows\4zathi9f5180.cpl
c:\windows\50106spzmb9t206.cpl
c:\windows\50195hacktzol29d.ocx
c:\windows\5099bzckdoor995.exe
c:\windows\509ez9wnlo5der1797.dll
c:\windows\50baspaz9e16145.bin
c:\windows\5125bac9dooz2537.cpl
c:\windows\5142zvirusc9.dll
c:\windows\5158vir5s6bz9.dll
c:\windows\515thief1z92.dll
c:\windows\515z8vi9us2b3.exe
c:\windows\516zspa9bot1f7.cpl
c:\windows\51ccthi9f7z2.bin
c:\windows\51fddoznloa9er1810.ocx
c:\windows\51z5threa526739.ocx
c:\windows\526thz59t29894.ocx
c:\windows\52z79troj4cb.cpl
c:\windows\5549vi9uz6db.bin
c:\windows\55639not-a-9irus102z.exe
c:\windows\557zthief9491.ocx
c:\windows\5599worm16ez.ocx
c:\windows\56509ackdoor2519z.cpl
c:\windows\5682not-a-v9ruz5b9.cpl
c:\windows\5686zworm989.cpl
c:\windows\5690download5r2z77.bin
c:\windows\56e7thre5t19z799.bin
c:\windows\572s5zm9ot43d.ocx
c:\windows\57z5tro941c.ocx
c:\windows\59216zirus2e1.cpl
c:\windows\59255not-a9zirus26a.exe
c:\windows\5953trzj55a.ocx
c:\windows\5992addwzre2977.exe
c:\windows\59afaddwa5e324z.exe
c:\windows\59d5zir3263.dll
c:\windows\59z5spyware789.cpl
c:\windows\5a1b9dzw5re1539.dll
c:\windows\5aaethzef22909.dll
c:\windows\5ab5backdoor3929z.cpl
c:\windows\5ac9addwzre5525.ocx
c:\windows\5b92ba5kdoor980z.cpl
c:\windows\5c57zackdoor296.ocx
c:\windows\5czd5hr9at28391.bin
c:\windows\5d92t5z9at4081.exe
c:\windows\5defthie91423z.ocx
c:\windows\5e595zars9729.bin
c:\windows\5e9adow5loade93245z.cpl
c:\windows\5f1c5teaz24469.exe
c:\windows\5fe7spy5aze1595.dll
c:\windows\5z5sparse18985.ocx
c:\windows\5zcba9dwar52815.ocx
c:\windows\6014tzie9517.bin
c:\windows\60a5downloader105z9.bin
c:\windows\60c1spa9sez8615.dll
c:\windows\60eeszeal26955.bin
c:\windows\6135tro9z58.exe
c:\windows\6216noz-a-v9r5s688.exe
c:\windows\6287s5arze22819.dll
c:\windows\6355dow9loaderz019.exe
c:\windows\6355sp59zot6c7.ocx
c:\windows\6495thief1z3.cpl
c:\windows\6541zteal9787.cpl
c:\windows\65z5vi91703.dll
c:\windows\661b5hief1z93.dll
c:\windows\693dsp5rsez796.exe
c:\windows\6991szyware9545.exe
c:\windows\69feb9zkdo5r1226.bin
c:\windows\6b99st9al547z.bin
c:\windows\6c459ir2155z.ocx
c:\windows\6c59backdozr530.cpl
c:\windows\6c62s95alz578.bin
c:\windows\6c95virz065.cpl
c:\windows\6d69dowzl5ader85.ocx
c:\windows\6z09d5wnloa9er112.ocx
c:\windows\6z19vir1557.dll
c:\windows\705bszar9e14.cpl
c:\windows\7165thr9az27785.ocx
c:\windows\72zdownloade522909.exe
c:\windows\7435sp95z7.ocx
c:\windows\74bsparse5914z.ocx
c:\windows\7516spam5o9zd8.dll
c:\windows\7522tzief8569.dll
c:\windows\753athre9t13379z.cpl
c:\windows\755fthrea9117z6.cpl
c:\windows\75z4st9al1645.cpl
c:\windows\761zthre9t160945.dll
c:\windows\7816haz59ool542.exe
c:\windows\789sp9576z.cpl
c:\windows\78c5stzal9505.cpl
c:\windows\790z95-a-virus517.bin
c:\windows\797not-a-v5ru9z74.exe
c:\windows\79azddwar51106.exe
c:\windows\79c9thief5851z.ocx
c:\windows\79f5stezl28069.exe
c:\windows\79f9spa5sez11.ocx
c:\windows\7abcsp9rsez0935.bin
c:\windows\7b35steal9987z.bin
c:\windows\7baft9zef1945.ocx
c:\windows\7d0bad9zare5985.bin
c:\windows\7z225hief9706.ocx
c:\windows\7z30vi5us3459.bin
c:\windows\8001not-z-v9ru5627.bin
c:\windows\84799pz547.bin
c:\windows\84z1wo9m7c5.dll
c:\windows\8887not-a5v9rzs538.bin
c:\windows\90d5downlozder939.ocx
c:\windows\90f7dowzloader165.bin
c:\windows\9105t5ief1z04.ocx
c:\windows\9150virzs275.dll
c:\windows\91675trojza1.bin
c:\windows\921465pyfz.dll
c:\windows\92647vzrus555.exe
c:\windows\9292not9azv5rus606.ocx
c:\windows\93593spamboz45b.dll
c:\windows\93z2spambot659.cpl
c:\windows\9406s5ambot3z9.exe
c:\windows\94300tro51b8z.dll
c:\windows\94addware25z5.ocx
c:\windows\950vir857z.bin
c:\windows\9562ztro5161.exe
c:\windows\962zspambo911d5.exe
c:\windows\96479vi5us6cz.bin
c:\windows\96ezspywar5117.ocx
c:\windows\97251troj1z4.exe
c:\windows\981sz5rse2653.exe
c:\windows\9854spy5z.bin
c:\windows\99551viruz2ef.exe
c:\windows\9983not-a-viru5f8z.bin
c:\windows\9dzadd9are105.dll
c:\windows\9z471tro56cd.bin
c:\windows\a10addwa9e5z44.cpl
c:\windows\abt9izf5513.bin
c:\windows\APanel.exe
c:\windows\bf5addw9re253z.bin
c:\windows\d89sp5zse1932.exe
c:\windows\e5cdownloadez1791.cpl
c:\windows\ehyrehyky.inf
c:\windows\ez2back95or3094.dll
c:\windows\Installer\7e82.msi
c:\windows\Installer\f91f.msi
c:\windows\prxid93ps.dat
c:\windows\server.exe
c:\windows\system32\1021zno5-a-virus57b9.exe
c:\windows\system32\10543z5951e.bin
c:\windows\system32\10790vi5us2z6.bin
c:\windows\system32\10d5do9nlozde51870.bin
c:\windows\system32\11f2a5dware9966z.cpl
c:\windows\system32\12361hack95ol256z.cpl
c:\windows\system32\1258thzea595094.ocx
c:\windows\system32\129cthze5t23845.ocx
c:\windows\system32\12d5sp9ware517z.exe
c:\windows\system32\12z45sp9mbot24b.dll
c:\windows\system32\134379az5tool6a4.bin
c:\windows\system32\135z9spambot7d4.bin
c:\windows\system32\13716not-z-vir5s9c2.exe
c:\windows\system32\139add5aze2718.ocx
c:\windows\system32\13z82s9ambot158.exe
c:\windows\system32\1403b9c5door1z10.cpl
c:\windows\system32\143435irus79z.exe
c:\windows\system32\1465z9pyde.ocx
c:\windows\system32\14830wormz095.bin
c:\windows\system32\14beth9ef15z2.cpl
c:\windows\system32\150z4not-a-5i9us594.exe
c:\windows\system32\15556sp938z.exe
c:\windows\system32\15562not-a-9iruz373.exe
c:\windows\system32\15583vizus5c9.dll
c:\windows\system32\15589spz744.cpl
c:\windows\system32\15592spy52z.ocx
c:\windows\system32\155fthiez1469.dll
c:\windows\system32\15679spy32z9.cpl
c:\windows\system32\15727v9ruz324.bin
c:\windows\system32\1590zpyw5re2550.bin
c:\windows\system32\15923hacktoz57c5.bin
c:\windows\system32\15z09spambot1b2.exe
c:\windows\system32\160z9vi5us9e1.dll
c:\windows\system32\16381sp5mb9t18z.exe
c:\windows\system32\16395szamb9t560.cpl
c:\windows\system32\16963not-9-viru5z03.cpl
c:\windows\system32\17095hacktool6az.bin
c:\windows\system32\17174vir59z30.ocx
c:\windows\system32\17486zpambo97e95.exe
c:\windows\system32\179z35orm45c.cpl
c:\windows\system32\17c59ownlzader511.dll
c:\windows\system32\1818095zj411.exe
c:\windows\system32\186795arsz1929.cpl
c:\windows\system32\19108h5cktool2z0.exe
c:\windows\system32\191175irus5z9.bin
c:\windows\system32\19215troj6z89.dll
c:\windows\system32\1946195y3z1.exe
c:\windows\system32\194eback5oor2076z.ocx
c:\windows\system32\194z5spy525.dll
c:\windows\system32\1952z5py583.dll
c:\windows\system32\19934wozm5e5.exe
c:\windows\system32\19951s9zmbot1f5.exe
c:\windows\system32\19z25spy3e5.ocx
c:\windows\system32\19z53spamb5t3869.exe
c:\windows\system32\1a9esparse1285z.cpl
c:\windows\system32\1bz0stea94635.ocx
c:\windows\system32\1ea1s5ealz529.exe
c:\windows\system32\1f22threat593z0.bin
c:\windows\system32\1fe5s9arse2740z.dll
c:\windows\system32\1z0695r9j81.exe
c:\windows\system32\1z2569py45a.exe
c:\windows\system32\1z692spy5849.bin
c:\windows\system32\1z99bac5door9050.exe
c:\windows\system32\20845zo9m52.cpl
c:\windows\system32\21257zorm3f9.bin
c:\windows\system32\21599spamboz518.dll
c:\windows\system32\21702troz59.cpl
c:\windows\system32\21955wo5m73az.dll
c:\windows\system32\22049zpambot75e.cpl
c:\windows\system32\22695hacktzo55e9.bin
c:\windows\system32\22755ziru9514.cpl
c:\windows\system32\22easzy9are5613.exe
c:\windows\system32\23300hacktzo9153.dll
c:\windows\system32\237z7v5rus549.ocx
c:\windows\system32\24441h5cktool3zb9.exe
c:\windows\system32\245spywzr9764.dll
c:\windows\system32\24659hacktooz15c.bin
c:\windows\system32\24905spamzot505.exe
c:\windows\system32\249965orm2z0.bin
c:\windows\system32\24c5downloade5z599.bin
c:\windows\system32\25191spa5bot63cz.dll
c:\windows\system32\252019iru53z.cpl
c:\windows\system32\25275zacktool918.dll
c:\windows\system32\25431noz-a-virus9f.dll
c:\windows\system32\256zt59j255.bin
c:\windows\system32\25899izus38d.dll
c:\windows\system32\25996wo5m5z3.bin
c:\windows\system32\25d1s9eal37z.dll
c:\windows\system32\25f2z5eal899.bin
c:\windows\system32\25z19spambot629.exe
c:\windows\system32\25z39vir95269.exe
c:\windows\system32\25z6not-a-virus9b65.dll
c:\windows\system32\26561zot5a-vi9us14c.cpl
c:\windows\system32\26599z5kdoor1529.dll
c:\windows\system32\26892hacktool65z.bin
c:\windows\system32\27162s5azbot339.dll
c:\windows\system32\2730ztro92b75.ocx
c:\windows\system32\27335hackto9z166.bin
c:\windows\system32\27685ackzool904.bin
c:\windows\system32\2813zt59j7c.cpl
c:\windows\system32\28256ha9ztool635.dll
c:\windows\system32\2826s5eal226z9.exe
c:\windows\system32\28355sz9mbot3a7.exe
c:\windows\system32\284159pyz9.ocx
c:\windows\system32\28972not-a-virzs2ee5.bin
c:\windows\system32\28aez5arse3109.bin
c:\windows\system32\28z9addw5re1234.dll
c:\windows\system32\29023hac9toolz85.exe
c:\windows\system32\2916trojz115.cpl
c:\windows\system32\294695rojz05.bin
c:\windows\system32\29503zpy5545.dll
c:\windows\system32\2952zh9cktoole1.cpl
c:\windows\system32\29531not-a-vi9uz42.dll
c:\windows\system32\29590za5ktool210.dll
c:\windows\system32\2959steaz241.exe
c:\windows\system32\295zwor915a.cpl
c:\windows\system32\29634not-a-virus25z5.dll
c:\windows\system32\296669zoj85.dll
c:\windows\system32\29773troj758z.cpl
c:\windows\system32\2981ste5l19z8.bin
c:\windows\system32\29bdt9zef24745.bin
c:\windows\system32\29z17h5cktoo910a.bin
c:\windows\system32\29z78troj59.bin
c:\windows\system32\2a94bazkdoor915.bin
c:\windows\system32\2b459hi5f2z05.exe
c:\windows\system32\2c5dbackdoo91z91.cpl
c:\windows\system32\2c8fdownzoade9518.ocx
c:\windows\system32\2d1edownloaz9r520.dll
c:\windows\system32\2d8zdownlo9der1259.exe
c:\windows\system32\2dzfaddw59e1703.bin
c:\windows\system32\2e58addza9e2975.ocx
c:\windows\system32\2z006tro5693.dll
c:\windows\system32\2z13vir5s92c.cpl
c:\windows\system32\2z172ha5ktoo9408.ocx
c:\windows\system32\2z17stea92259.exe
c:\windows\system32\2z9ast5al974.exe
c:\windows\system32\30z58virus3b9.dll
c:\windows\system32\30z73sp5f19.exe
c:\windows\system32\31256zot9a-virus7475.cpl
c:\windows\system32\31293viruz515.cpl
c:\windows\system32\31541hack5zo95c5.bin
c:\windows\system32\31580hackto9l5z1.cpl
c:\windows\system32\318719pzcc5.ocx
c:\windows\system32\318csza9se1385.ocx
c:\windows\system32\31fst9z51054.exe
c:\windows\system32\31z19not-a-vi9us485.dll
c:\windows\system32\31z87worm459.dll
c:\windows\system32\32293not9a-5irus5d0z.bin
c:\windows\system32\32351not5a-vzrus75a9.bin
c:\windows\system32\335zspar9e266.exe
c:\windows\system32\33915pzrse3198.cpl
c:\windows\system32\33d9ste5lz518.ocx
c:\windows\system32\33f9spy5aze378.cpl
c:\windows\system32\350za9dware1221.bin
c:\windows\system32\35976spambo930z.dll
c:\windows\system32\3598nzt-a-virus758.cpl
c:\windows\system32\35efthreat5790z.bin
c:\windows\system32\35z4spambot5935.exe
c:\windows\system32\36495par9e3z14.exe
c:\windows\system32\365stezl950.dll
c:\windows\system32\36ae9a5kdoor2058z.exe
c:\windows\system32\3738thi9f55z.dll
c:\windows\system32\3745backd9zr853.ocx
c:\windows\system32\3755bzckdoor22459.exe
c:\windows\system32\37b2bzckdoor5395.bin
c:\windows\system32\37z75ddwar9939.dll
c:\windows\system32\3880spars9z245.bin
c:\windows\system32\3887sz9r5e2771.cpl
c:\windows\system32\38z8d5wnloader17519.bin
c:\windows\system32\38z9threat62775.ocx
c:\windows\system32\3940ztro56e6.bin
c:\windows\system32\39dda5dware223z.ocx
c:\windows\system32\39eabackdoor1z52.cpl
c:\windows\system32\3a15zp5r9e2070.exe
c:\windows\system32\3abdspzw5re9904.ocx
c:\windows\system32\3b82t5r9az21669.exe
c:\windows\system32\3c51bazkdoo5529.dll
c:\windows\system32\3cc5t5ie9115z.exe
c:\windows\system32\3de9viz2935.cpl
c:\windows\system32\3fa3a5zware13349.cpl
c:\windows\system32\3z5v9r33.bin
c:\windows\system32\3zecvi92950.bin
c:\windows\system32\403dback95zr935.cpl
c:\windows\system32\40z4vir9s4b75.cpl
c:\windows\system32\4105wozm1fa9.exe
c:\windows\system32\4174back5oor2739z.bin
c:\windows\system32\43adownzoader59.dll
c:\windows\system32\458aste9l2303z.bin
c:\windows\system32\4599hzckto5l8a.bin
c:\windows\system32\465zbackdoor9059.bin
c:\windows\system32\46ezst9a51226.bin
c:\windows\system32\4775addwaze911.cpl
c:\windows\system32\491cthre5t22z89.cpl
c:\windows\system32\492not9a-5irus6f0z.dll
c:\windows\system32\496bthz9f450.exe
c:\windows\system32\49c4add9zr51999.ocx
c:\windows\system32\49fc5ir9z18.ocx
c:\windows\system32\4a4bspywa5z5089.bin
c:\windows\system32\4a89spywar5z200.bin
c:\windows\system32\4aabdownload9r59z.dll
c:\windows\system32\4b9dstea91385z.ocx
c:\windows\system32\4cz0spywar515969.exe
c:\windows\system32\4d8cthief925z.cpl
c:\windows\system32\4e1ftzi5f9345.dll
c:\windows\system32\4f35hre9tz427.dll
c:\windows\system32\4fb0th9zf1551.ocx
c:\windows\system32\4fd3down9oadzr3105.cpl
c:\windows\system32\4ff59pazse2599.bin
c:\windows\system32\4z949ot-a-virus7d5.bin
c:\windows\system32\4zc2s9eal2655.ocx
c:\windows\system32\5005dow9zoa5er715.cpl
c:\windows\system32\5019vzrus5e9.ocx
c:\windows\system32\5099downlzade52987.exe
c:\windows\system32\50b59teal3245z.bin
c:\windows\system32\50d3thrza57299.cpl
c:\windows\system32\5158s9yzar5357.ocx
c:\windows\system32\51b0backdoor50z89.bin
c:\windows\system32\51z1ba5kdoor299.cpl
c:\windows\system32\5249troz5dd.bin
c:\windows\system32\5256thiz93203.cpl
c:\windows\system32\5277dzwnloa95r312.bin
c:\windows\system32\52a5th9eat28z87.dll
c:\windows\system32\52b5steal29z9.dll
c:\windows\system32\531dba9kdoorz767.ocx
c:\windows\system32\532espy5are1908z.dll
c:\windows\system32\5355not-a-virusz29.ocx
c:\windows\system32\53aadd59rz13.cpl
c:\windows\system32\53f1vi95z3.dll
c:\windows\system32\54z9s5arse1568.bin
c:\windows\system32\5548hackt9oz655.cpl
c:\windows\system32\5561zo5m192.exe
c:\windows\system32\55685hackzo9l10a.bin
c:\windows\system32\5584zack59or607.ocx
c:\windows\system32\558thre9t5z300.bin
c:\windows\system32\5596backdooz8159.dll
c:\windows\system32\5598a9dwzre1473.exe
c:\windows\system32\559z5orm53a.exe
c:\windows\system32\562ez5w9loader1667.bin
c:\windows\system32\5693thr5az2607.dll
c:\windows\system32\56999troz477.exe
c:\windows\system32\56bf9te5l29z.bin
c:\windows\system32\5764doznloade918325.ocx
c:\windows\system32\57a89hief924z.exe
c:\windows\system32\5829backdzo53098.exe
c:\windows\system32\58893virus750z.ocx
c:\windows\system32\58e4t9ief293z.ocx
c:\windows\system32\58zsteal14529.cpl
c:\windows\system32\590809rzj441.dll
c:\windows\system32\591faddz95e2528.cpl
c:\windows\system32\5955szarse1719.cpl
c:\windows\system32\5982thizf895.dll
c:\windows\system32\599zthreat19551.exe
c:\windows\system32\59a5spywarez35.bin
c:\windows\system32\59ethiefz783.ocx
c:\windows\system32\59ev9z1564.exe
c:\windows\system32\59f7zir1250.ocx
c:\windows\system32\5a7zspar9e878.exe
c:\windows\system32\5a96thrzat29095.ocx
c:\windows\system32\5b29sze5l1824.cpl
c:\windows\system32\5b59addwarez505.dll
c:\windows\system32\5bfeszyw95e949.dll
c:\windows\system32\5cz6vir5999.exe
c:\windows\system32\5d5zs9eal3245.exe
c:\windows\system32\5d99backdzor3605.exe
c:\windows\system32\5e6dthi5z9466.cpl
c:\windows\system32\5ed3thrzat94705.dll
c:\windows\system32\5ed5threzt99079.dll
c:\windows\system32\5fb8s5ywaze8369.ocx
c:\windows\system32\5fe3vi9z556.cpl
c:\windows\system32\5z041troj99.bin
c:\windows\system32\5z56s9arse134.ocx
c:\windows\system32\5z99wo5m655.bin
c:\windows\system32\5zca9ackdo5r2670.bin
c:\windows\system32\5zffv5r16209.cpl
c:\windows\system32\61feba9kdoor5811z.bin
c:\windows\system32\64z0spy5are1942.bin
c:\windows\system32\6519s9zware459.cpl
c:\windows\system32\6549downloadez968.cpl
c:\windows\system32\65fddownloader199z.bin
c:\windows\system32\679spzware5849.ocx
c:\windows\system32\68fdspyware9z55.dll
c:\windows\system32\68fzthreat39758.bin
c:\windows\system32\6946tzoj3e25.ocx
c:\windows\system32\6a7zdow59oader1272.cpl
c:\windows\system32\6b50ste9l3z89.exe
c:\windows\system32\6b58dow9loadez872.bin
c:\windows\system32\6becspywarz95.exe
c:\windows\system32\6cez9ir5247.ocx
c:\windows\system32\6cz5spywar92195.dll
c:\windows\system32\6d47stealz9485.cpl
c:\windows\system32\6d90zteal24975.cpl
c:\windows\system32\6e51addwaze2992.dll
c:\windows\system32\6e5abackdozr94555.bin
c:\windows\system32\700t95ezt27452.bin
c:\windows\system32\7104viz2995.cpl
c:\windows\system32\7137bac9zoor27325.bin
c:\windows\system32\7149z95219.dll
c:\windows\system32\72a0th5ez2962.dll
c:\windows\system32\72z5t5oj2729.bin
c:\windows\system32\7522s5yware29z3.cpl
c:\windows\system32\755zspyware2942.ocx
c:\windows\system32\758cst5az9218.exe
c:\windows\system32\75ezspyware9451.dll
c:\windows\system32\75zown9oader979.ocx
c:\windows\system32\7714virz59.cpl
c:\windows\system32\7828vi52z69.ocx
c:\windows\system32\7888ha9ktool156z.ocx
c:\windows\system32\78z2b9c5door539.bin
c:\windows\system32\7925hazktool4f5.cpl
c:\windows\system32\7945hacktzol6465.bin
c:\windows\system32\7a85addware29z3.bin
c:\windows\system32\7c03backd9oz5307.cpl
c:\windows\system32\7d57virz2729.bin
c:\windows\system32\7da7zownloader5989.cpl
c:\windows\system32\7z18th59at3649.exe
c:\windows\system32\7z1avi93550.bin
c:\windows\system32\7z99th5eat15435.dll
c:\windows\system32\871spambot5zd9.exe
c:\windows\system32\8955spzmb9t384.exe
c:\windows\system32\897thizf2257.ocx
c:\windows\system32\89zbackdoo9415.exe
c:\windows\system32\90609hacktoo51za.exe
c:\windows\system32\90909virusz5e.ocx
c:\windows\system32\9093zo5m186.dll
c:\windows\system32\90z9addware2295.bin
c:\windows\system32\9122hack9oolz54.dll
c:\windows\system32\91431vzrus6bf5.exe
c:\windows\system32\92095vzrus68a.bin
c:\windows\system32\9243thzef2875.exe
c:\windows\system32\9265thiefz75.ocx
c:\windows\system32\926a5teal2z82.exe
c:\windows\system32\9315pz161.exe
c:\windows\system32\9318n5t9a-virzs249.bin
c:\windows\system32\934zt5oj40d.exe
c:\windows\system32\9385t5zef2263.dll
c:\windows\system32\943zvi5us981.ocx
c:\windows\system32\946495py32cz.ocx
c:\windows\system32\949steaz957.bin
c:\windows\system32\9574spy657z.bin
c:\windows\system32\9587zspambot56f.cpl
c:\windows\system32\95a3downloz5er456.bin
c:\windows\system32\9609sz5ware2660.exe
c:\windows\system32\961hac9tool6z5.exe
c:\windows\system32\9850dzwnloader555.ocx
c:\windows\system32\98a0steal2z65.bin
c:\windows\system32\98cspar9e5130z.ocx
c:\windows\system32\99265i9usz58.ocx
c:\windows\system32\99371zp54cb.bin
c:\windows\system32\996zspy795.exe
c:\windows\system32\9972zirus205.exe
c:\windows\system32\998thief1365z.exe
c:\windows\system32\9995virus58z5.ocx
c:\windows\system32\9b5evzr1921.exe
c:\windows\system32\9e72steal52z1.exe
c:\windows\system32\9f56viz692.exe
c:\windows\system32\9f5dthreat320z4.exe
c:\windows\system32\9z63ste5l3180.bin
c:\windows\system32\a259ir53z.dll
c:\windows\system32\a69downloadez2953.exe
c:\windows\system32\a6zthreat59290.cpl
c:\windows\system32\b39stzal2519.cpl
c:\windows\system32\b485dd9arz975.exe
c:\windows\system32\bzcs5ywa9e956.bin
c:\windows\system32\dajifuji.dll
c:\windows\system32\drivers\ndisrd.sys
c:\windows\system32\e99tz9e5t18598.exe
c:\windows\system32\f585te9l72z.dll
c:\windows\system32\fesumuye.dll
c:\windows\system32\gomujude.dll
c:\windows\system32\gunosibi.dll
c:\windows\system32\hisekeke.exe
c:\windows\system32\jaduzumi.dll
c:\windows\system32\kafunepi.exe
c:\windows\system32\loyayono.dll
c:\windows\system32\lusumune.dll
c:\windows\system32\navifaya.dll
c:\windows\system32\ndisapi.dll
c:\windows\system32\nefavega.dll
c:\windows\system32\nizedage.dll
c:\windows\system32\pagapobo.dll
c:\windows\system32\pulovuwi.dll
c:\windows\system32\ralobupo.dll
c:\windows\system32\repozuyi.dll
c:\windows\system32\ribemago.dll
c:\windows\system32\sejuvoma.exe
c:\windows\system32\supekede.exe
c:\windows\system32\tasagywow.exe
c:\windows\system32\tayufazu.dll
c:\windows\system32\tigefeki.dll
c:\windows\system32\tomatofi.exe
c:\windows\system32\uacinit.dll
c:\windows\system32\winhelper.dll
c:\windows\system32\winupdate.exe
c:\windows\system32\yapipije.dll
c:\windows\system32\yfipawezej.dl
c:\windows\system32\yirepoje.exe
c:\windows\system32\yirumuno.exe
c:\windows\system32\z1947not-a-virus3e85.ocx
c:\windows\system32\z199spambo524.bin
c:\windows\system32\z1e3d59nloader483.exe
c:\windows\system32\z235s95mbot49f.cpl
c:\windows\system32\z3379vir9s5625.cpl
c:\windows\system32\z35spa9bot7c3.exe
c:\windows\system32\z5314tr9j86.bin
c:\windows\system32\z55th9ef524.exe
c:\windows\system32\z5813no59a-virus3c1.ocx
c:\windows\system32\z5cdownload59372.ocx
c:\windows\system32\z696spa5se2739.bin
c:\windows\system32\z6f35hreat75999.dll
c:\windows\system32\z722t9oj6c5.dll
c:\windows\system32\z7570hac59ool715.ocx
c:\windows\system32\z8566troj942.ocx
c:\windows\system32\z89w95me5.dll
c:\windows\system32\z8d59ackdoo51792.exe
c:\windows\system32\z9359hacktoo940e.cpl
c:\windows\system32\z95asparse1669.cpl
c:\windows\system32\z9a5vir2996.bin
c:\windows\system32\zbdbback5oor9691.cpl
c:\windows\system32\ze60b9ckdoor2245.bin
c:\windows\system32\zedcdo9nloader27125.bin
c:\windows\system32\zesp5wa9e621.exe
c:\windows\system32\zuwuvenu.dll
c:\windows\th823567.dat
c:\windows\uzixosyd.inf
c:\windows\z04885ackt9ol401.cpl
c:\windows\z159a9dware25955.cpl
c:\windows\z240bac5door1929.cpl
c:\windows\z356spy229.cpl
c:\windows\z383th5e91274.ocx
c:\windows\z5195worm7a9.dll
c:\windows\z5539acktool791.cpl
c:\windows\z57bac9door3115.exe
c:\windows\z5976hacktool199.ocx
c:\windows\z5ccthreat12490.exe
c:\windows\z5e79ir768.bin
c:\windows\z637a59ware728.ocx
c:\windows\z6496s5am9otdd.ocx
c:\windows\z65ct9ief878.exe
c:\windows\z699tr5j179.ocx
c:\windows\z8195spy7c4.cpl
c:\windows\z8799hacktool4fb5.bin
c:\windows\z942virus3959.exe
c:\windows\z9thief451.cpl
c:\windows\zbf75hief9017.bin
c:\windows\zc2e5ir9079.cpl
c:\windows\zc66v9r2507.dll
c:\windows\zd43downloade918235.ocx
c:\windows\ze6dv9r5274.ocx
c:\windows\zfc5vi92657.ocx
----- BITS: Possible infected sites -----
c:\windows\system32\proquota.exe . . . is missing!!
-------\Legacy_MYWEBSEARCHSERVICE
-------\Legacy_NDISRD
-------\Legacy_{79007602-0CDB-4405-9DBF-1257BB3226EE}
-------\Service_MyWebSearchService
-------\Service_NDISRD
((((((((((((((((((((((((( Files Created from 2009-08-10 to 2009-09-10 )))))))))))))))))))))))))))))))
2009-12-10 17:10 . 2009-12-10 17:10 9685 ----a-w- c:\windows\system32\9505zpy7.bin
2009-09-10 00:34 . 2009-09-10 00:34 -------- d-----w- c:\program files\New Folder
2009-09-10 00:33 . 2009-09-10 00:33 -------- d-----w- C:\New Folder
2009-09-09 21:14 . 2009-09-09 21:14 552 ----a-w- c:\windows\system32\d3d8caps.dat
2009-09-09 12:32 . 2009-09-09 12:32 -------- d-----w- c:\program files\Angle Interactive
2009-09-08 18:45 . 2009-09-08 18:45 -------- d-----w- c:\program files\Trend Micro
2009-09-08 18:12 . 2009-08-03 17:36 38160 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2009-09-08 18:12 . 2009-08-03 17:36 19096 ----a-w- c:\windows\system32\drivers\mbam.sys
2009-09-08 13:06 . 2009-09-10 12:09 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
2009-09-08 12:14 . 2009-09-08 12:14 390144 ----a-w- c:\windows\system32\huej1nqg.exe
2009-09-08 02:57 . 2009-07-28 20:33 55656 ----a-w- c:\windows\system32\drivers\avgntflt.sys
2009-09-08 02:57 . 2009-03-30 14:33 96104 ----a-w- c:\windows\system32\drivers\avipbb.sys
2009-09-08 02:57 . 2009-02-13 16:29 22360 ----a-w- c:\windows\system32\drivers\avgntmgr.sys
2009-09-08 02:57 . 2009-02-13 16:17 45416 ----a-w- c:\windows\system32\drivers\avgntdd.sys
2009-09-08 02:57 . 2009-09-08 02:57 -------- d-----w- c:\program files\Avira
2009-09-08 02:57 . 2009-09-08 02:57 -------- d-----w- c:\documents and settings\All Users\Application Data\Avira
2009-09-08 02:15 . 2009-09-08 02:15 -------- d-----w- c:\documents and settings\kaitie justice\Application Data\HP
2009-09-07 21:53 . 2009-09-07 21:53 -------- d-----w- c:\documents and settings\tina gibson\Application Data\TeamViewer
2009-09-07 21:52 . 2009-09-07 21:52 -------- d-----w- c:\documents and settings\tina gibson\temp
2009-09-07 21:25 . 2009-09-07 21:28 -------- d-----w- c:\program files\Counter-Strike 1.6
2009-09-07 20:44 . 2009-09-07 20:44 -------- d-----w- c:\windows\048298C9A4D3490B9FF9AB023A9238F3.TMP
2009-09-07 20:40 . 2009-09-07 20:40 -------- d---a-w- c:\program files\DOTNETFX
2009-09-07 20:08 . 2006-03-21 09:15 839680 ----a-w- c:\program files\steamclient.dll
2009-09-07 20:08 . 2006-03-21 09:15 61440 ----a-w- c:\program files\steam_api.dll
2009-09-07 20:07 . 2006-03-21 09:15 3649536 ----a-w- c:\program files\Steam.dll
2009-09-07 20:03 . 2009-09-07 20:04 1556480 ----a-w- c:\program files\hw.dll
2009-09-07 20:03 . 2005-09-30 02:47 221184 ----a-w- c:\program files\hltv.exe
2009-09-07 20:03 . 2005-09-30 02:47 397312 ----a-w- c:\program files\hlds.exe
2009-09-07 20:03 . 2005-09-30 02:42 81920 ----a-w- c:\program files\hl.exe
2009-09-07 20:03 . 2005-09-30 02:47 122980 ----a-w- c:\program files\FileSystem_Steam.dll
2009-09-07 20:03 . 2005-09-30 02:47 118873 ----a-w- c:\program files\FileSystem_Stdio.dll
2009-09-07 20:03 . 2005-09-30 02:42 90112 ----a-w- c:\program files\DemoPlayer.dll
2009-09-07 20:03 . 2005-09-30 02:47 69632 ----a-w- c:\program files\dbg.dll
2009-09-07 20:03 . 2005-09-30 02:47 225280 ----a-w- c:\program files\Core.dll
2009-09-07 20:03 . 2005-09-30 02:42 211456 ----a-w- c:\program files\a3dapi.dll
2009-09-07 19:55 . 2008-12-25 12:00 67826994 ----a-w- c:\windows\Counter strike 1.6.exe
2009-09-07 17:26 . 2009-09-10 21:19 -------- d-----w- c:\program files\Steam
2009-09-06 03:00 . 2009-09-06 03:00 -------- d-----w- c:\documents and settings\All Users\Application Data\HP Product Assistant
2009-09-03 18:07 . 2009-09-03 18:07 41872 ----a-w- c:\windows\system32\xfcodec.dll
2009-08-30 04:05 . 2009-08-30 04:11 -------- d-----w- c:\documents and settings\All Users\Application Data\SITEguard
2009-08-30 04:05 . 2009-08-30 04:21 -------- d-----w- c:\documents and settings\All Users\Application Data\STOPzilla!
2009-08-30 04:05 . 2009-08-30 04:05 -------- d-----w- c:\program files\Common Files\iS3
2009-08-29 21:07 . 2009-08-29 21:15 -------- d-----w- c:\windows\system32\config\systemprofile\Application Data\Xfire
2009-08-29 04:44 . 2009-08-30 04:12 -------- d-----w- c:\documents and settings\All Users\Application Data\12521094
2009-08-29 04:38 . 2008-04-14 22:00 4224 ----a-w- c:\windows\system32\drivers\beep.sys
2009-08-28 01:13 . 2009-09-07 19:03 -------- d-----w- c:\program files\Counter-Strike 1.6 Non-Steam 2009-04-29
2009-08-24 00:29 . 2009-08-28 00:34 -------- d-----w- c:\program files\Counter-Strike
2009-08-22 14:10 . 2009-08-23 23:15 -------- d-----w- c:\program files\VALVe
2009-08-22 04:42 . 2009-08-23 02:22 -------- d-----w- c:\program files\AskBarDis
2009-08-14 03:41 . 2009-08-14 03:41 -------- d-----w- c:\documents and settings\kaitie justice\Application Data\Malwarebytes
2009-09-10 12:19 . 2009-06-10 12:19 88576 --sha-w- c:\windows\system32\gipunowe.dll
2009-09-10 00:19 . 2009-06-10 00:19 88064 --sha-w- c:\windows\system32\ludiyofu.dll
2009-09-09 21:14 . 2009-06-18 04:27 664 ----a-w- c:\windows\system32\d3d9caps.dat
2009-09-09 12:18 . 2009-06-09 12:18 88064 --sha-w- c:\windows\system32\piyadayi.dll
2009-09-09 00:18 . 2009-06-09 00:18 88064 --sha-w- c:\windows\system32\juvilisi.dll
2009-09-08 23:59 . 2009-07-09 04:19 -------- d-----w- c:\documents and settings\tina gibson\Application Data\Xfire
2009-09-08 22:35 . 2009-07-06 04:42 -------- d-----w- c:\program files\Xfire
2009-09-08 12:18 . 2009-06-08 12:18 89088 --sha-w- c:\windows\system32\gijiyeli.dll
2009-09-08 11:18 . 2009-05-27 23:54 -------- d-----w- c:\documents and settings\tina gibson\Application Data\Symantec
2009-09-08 11:17 . 2008-10-29 01:27 -------- d-----w- c:\program files\Common Files\Symantec Shared
2009-09-08 03:42 . 2008-10-29 01:50 -------- d-----w- c:\documents and settings\All Users\Application Data\Symantec
2009-09-07 04:45 . 2009-06-07 04:45 49664 --sha-w- c:\windows\system32\nebiteda.dll
2009-09-07 04:45 . 2009-06-07 04:45 88576 --sha-w- c:\windows\system32\pavogare.dll
2009-09-06 16:45 . 2009-06-06 16:45 88064 --sha-w- c:\windows\system32\latavija.dll
2009-09-06 04:18 . 2008-10-29 01:06 -------- d-----w- c:\program files\Google
2009-09-06 01:59 . 2009-06-06 01:59 88576 --sha-w- c:\windows\system32\vamonumi.dll
2009-09-05 13:59 . 2009-06-05 13:59 88064 --sha-w- c:\windows\system32\pimenuda.dll
2009-09-04 20:43 . 2009-06-04 20:43 88064 --sha-w- c:\windows\system32\huyowoza.dll
2009-09-03 20:36 . 2009-06-03 20:36 88576 --sha-w- c:\windows\system32\hemokelu.dll
2009-08-31 22:18 . 2009-05-31 22:18 49152 --sha-w- c:\windows\system32\hufowebi.dll
2009-08-31 22:18 . 2009-05-31 22:18 83968 --sha-w- c:\windows\system32\liwoduki.dll
2009-08-30 04:12 . 2009-08-30 04:06 2024 ----a-w- c:\windows\system32\drivers\kgpfr2.cfg
2009-08-30 04:12 . 2009-08-30 04:11 2232 ----a-w- c:\windows\system32\drivers\kgpcpy.cfg
2009-08-29 23:33 . 2009-07-04 06:30 -------- d-----w- c:\program files\Yahoo!
2009-08-29 16:44 . 2009-05-29 16:44 84480 --sha-w- c:\windows\system32\nukizota.dll
2009-08-29 16:14 . 2009-08-29 16:14 141 ----a-w- c:\windows\tmp.tmp.tmp
2009-08-29 04:44 . 2009-05-29 04:44 84480 --sha-w- c:\windows\system32\lofuvika.dll
2009-08-23 06:23 . 2008-10-29 01:37 -------- d--h--w- c:\program files\InstallShield Installation Information
2009-08-18 23:17 . 2008-10-29 01:09 -------- d-----w- c:\program files\eMachines Games
2009-08-18 23:17 . 2008-10-29 01:09 -------- d-----w- c:\documents and settings\All Users\Application Data\WildTangent
2009-08-14 00:51 . 2009-08-14 00:51 15829 ----a-w- c:\documents and settings\All Users\Application Data\usywupox.dat
2009-08-12 20:22 . 2009-05-28 02:09 60664 ----a-w- c:\documents and settings\kaitie justice\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
2009-08-10 00:21 . 2009-05-27 23:55 60664 ----a-w- c:\documents and settings\tina gibson\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
2009-08-05 09:01 . 2008-04-14 22:00 204800 ----a-w- c:\windows\system32\mswebdvd.dll
2009-08-02 18:32 . 2009-09-07 20:09 1689 ----a-w- c:\program files\Dedicated Server.lnk
2009-07-28 20:51 . 2009-07-28 20:51 -------- d-----w- c:\documents and settings\kaitie justice\Application Data\Pogo Games
2009-07-28 20:25 . 2009-06-13 02:16 -------- d-----w- c:\documents and settings\kaitie justice\Application Data\PlayFirst
2009-07-28 20:25 . 2009-06-01 01:47 -------- d-----w- c:\documents and settings\All Users\Application Data\PlayFirst
2009-07-26 09:38 . 2009-07-26 09:38 -------- d-----w- c:\documents and settings\NetworkService\Application Data\Xfire
2009-07-22 00:01 . 2009-07-22 00:01 -------- d-----w- c:\program files\TeamViewer
2009-07-18 22:19 . 2009-07-17 08:58 -------- d-----w- c:\program files\Common Files\Uninstall
2009-07-18 22:11 . 2009-07-18 22:11 -------- d-----w- c:\documents and settings\tina gibson\Application Data\Malwarebytes
2009-07-18 22:11 . 2009-07-18 22:11 -------- d-----w- c:\documents and settings\All Users\Application Data\Malwarebytes
2009-07-18 03:33 . 2009-07-18 03:33 -------- d-----w- c:\documents and settings\tina gibson\Application Data\Fuel Industries
2009-07-17 19:01 . 2008-04-14 22:00 58880 ----a-w- c:\windows\system32\atl.dll
2009-07-16 19:22 . 2009-07-16 19:22 -------- d-----w- c:\documents and settings\LocalService\Application Data\Xfire
2009-07-16 03:20 . 2009-07-16 03:20 -------- d-----w- c:\documents and settings\tina gibson\Application Data\Scrabble Plus
2009-07-12 16:21 . 2008-04-14 22:00 233472 ----a-w- c:\windows\system32\wmpdxm.dll
2009-06-29 16:12 . 2007-08-14 02:54 827392 ----a-w- c:\windows\system32\wininet.dll
2009-06-29 16:12 . 2008-04-14 22:00 78336 ----a-w- c:\windows\system32\ieencode.dll
2009-06-29 16:12 . 2008-04-14 22:00 17408 ----a-w- c:\windows\system32\corpol.dll
2009-06-25 08:25 . 2008-04-14 22:00 730112 ----a-w- c:\windows\system32\lsasrv.dll
2009-06-25 08:25 . 2008-04-14 22:00 56832 ----a-w- c:\windows\system32\secur32.dll
2009-06-25 08:25 . 2008-04-14 22:00 54272 ----a-w- c:\windows\system32\wdigest.dll
2009-06-25 08:25 . 2008-04-14 22:00 301568 ----a-w- c:\windows\system32\kerberos.dll
2009-06-25 08:25 . 2008-04-14 22:00 147456 ----a-w- c:\windows\system32\schannel.dll
2009-06-25 08:25 . 2008-04-14 22:00 136192 ----a-w- c:\windows\system32\msv1_0.dll
2009-06-24 11:18 . 2008-04-14 22:00 92928 ----a-w- c:\windows\system32\drivers\ksecdd.sys
2009-06-20 19:50 . 2008-10-29 01:04 1024 ---h--r- c:\windows\system32\NTIMP3.dll
2009-06-16 14:36 . 2008-04-14 22:00 81920 ----a-w- c:\windows\system32\fontsub.dll
2009-06-16 14:36 . 2008-04-14 22:00 119808 ----a-w- c:\windows\system32\t2embed.dll
2009-06-13 00:28 . 2009-06-13 00:28 339968 ----a-w- c:\windows\system32\pythoncom25.dll
2009-06-13 00:28 . 2009-06-13 00:28 2117632 ----a-w- c:\windows\system32\python25.dll
2009-06-13 00:28 . 2009-06-13 00:28 114688 ----a-w- c:\windows\system32\pywintypes25.dll
2009-06-13 00:28 . 2007-01-09 06:17 348160 ----a-w- c:\windows\system32\msvcr71.dll
2005-09-30 02:47 . 2009-09-07 20:03 24705 ----a-w- c:\program files\HLTV-Readme.txt
2005-09-30 02:47 . 2009-09-07 20:03 786 ----a-w- c:\program files\hlds_steamgames.vdf
2005-09-30 02:47 . 2009-09-07 20:03 1569 ----a-w- c:\program files\hltv.cfg
2005-08-13 19:24 . 2009-09-07 20:03 171014 ----a-w- c:\program files\hl.ico
2009-05-31 22:18 . 2009-05-31 22:18 49152 --sha-w- c:\windows\system32\fanenoto.dll.tmp
2009-06-07 04:46 . 2009-06-07 04:46 49664 --sha-w- c:\windows\system32\muyolule.dll
2009-05-29 16:44 . 2009-05-29 16:44 526 --sha-w- c:\windows\system32\sijorera.dll
2009-05-30 04:45 . 2009-05-30 04:45 526 --sha-w- c:\windows\system32\suhokamo.dll
2009-05-30 17:51 . 2009-05-30 17:51 526 --sha-w- c:\windows\system32\vutojisi.dll
2009-05-31 22:18 . 2009-05-31 22:18 49152 --sha-w- c:\windows\system32\welatili.dll.tmp
------- Sigcheck -------
[7] 2008-04-14 . 6D4FEB43EE538FC5428CC7F0565AA656 . 56320 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\eventlog.dll
c:\windows\system32\eventlog.dll ... is missing !!
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{d2be9f52-416b-4ba8-9790-a7b44e2da14c}]
2009-06-07 04:46 49664 ---ha-w- c:\windows\system32\juvoludi.dll
"swg"="c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2008-10-29 68856]
"Steam"="c:\program files\Steam\Steam.exe" [2009-09-07 1217784]
"NvCplDaemon"="c:\windows\system32\NvCpl.dll" [2008-02-25 8491008]
"NvMediaCenter"="c:\windows\system32\NvMcTray.dll" [2008-02-25 81920]
"BkupTray"="c:\program files\NewTech Infosystems\NTI Backup Now 5\BkupTray.exe" [2008-04-07 34040]
"Google Desktop Search"="c:\program files\Google\Google Desktop Search\GoogleDesktop.exe" [2008-10-29 24064]
"RemoteControl"="c:\program files\CyberLink\PowerDVD\PDVDServ.exe" [2007-03-15 71216]
"LanguageShortcut"="c:\program files\CyberLink\PowerDVD\Language\Language.exe" [2007-01-09 52256]
"UpdateP2GoShortCut"="c:\program files\CyberLink\Power2Go\MUITransfer\MUIStartMenu.exe" [2008-06-14 210216]
"UpdatePSTShortCut"="c:\program files\CyberLink\DVD Suite\MUITransfer\MUIStartMenu.exe" [2008-09-25 210216]
"SunJavaUpdateSched"="c:\program files\Java\jre1.6.0_05\bin\jusched.exe" [2008-02-22 144784]
"IMJPMIG8.1"="c:\windows\IME\imjp8_1\IMJPMIG.EXE" [2008-04-14 208952]
"MSPY2002"="c:\windows\system32\IME\PINTLGNT\ImScInst.exe" [2008-04-14 59392]
"PHIME2002ASync"="c:\windows\system32\IME\TINTLGNT\TINTSETP.EXE" [2008-04-14 455168]
"PHIME2002A"="c:\windows\system32\IME\TINTLGNT\TINTSETP.EXE" [2008-04-14 455168]
"Adobe Reader Speed Launcher"="c:\program files\Adobe\Reader 8.0\Reader\Reader_sl.exe" [2008-01-12 39792]
"eRecoveryService"="c:\acer\Empowering Technology\eRecovery\eRAgent.exe" [2008-07-10 421888]
"HP Software Update"="c:\program files\HP\HP Software Update\HPWuSchd2.exe" [2005-05-12 49152]
"Google Quick Search Box"="c:\program files\Google\Quick Search Box\GoogleQuickSearchBox.exe" [2009-09-06 122368]
"avgnt"="c:\program files\Avira\AntiVir Desktop\avgnt.exe" [2009-03-02 209153]
"lejehipahe"="c:\windows\system32\muyolule.dll" [2009-06-07 49664]
"nejujatal"="c:\windows\system32\piyadayi.dll" [2009-09-09 88064]
"nwiz"="nwiz.exe" - c:\windows\system32\nwiz.exe [2008-02-25 1626112]
"RTHDCPL"="RTHDCPL.EXE" - c:\windows\RTHDCPL.exe [2008-05-16 16862720]
c:\documents and settings\kaitie justice\Start Menu\Programs\Startup\
OneNote 2007 Screen Clipper and Launcher.lnk - c:\program files\Microsoft Office\Office12\ONENOTEM.EXE [2007-8-24 101784]
HP Digital Imaging Monitor.lnk - c:\program files\HP\Digital Imaging\bin\hpqtra08.exe [2005-5-11 282624]
[hkey_local_machine\software\microsoft\windows\currentversion\explorer\SharedTaskScheduler]
"{13c2daae-c95c-4485-b4f0-3441a286883d}"= "c:\windows\system32\piyadayi.dll" [2009-09-09 88064]
"{4428a968-ffa0-4244-ad19-7ff6f140aa11}"= "c:\windows\system32\gijiyeli.dll" [2009-09-08 89088]
"{272e3cae-74e8-4d32-9e18-bd675d453c5b}"= "c:\windows\system32\piyadayi.dll" [2009-09-09 88064]
"{0e6d1c10-90fb-4035-ba95-30bdc36d05f4}"= "c:\windows\system32\gipunowe.dll" [2009-09-10 88576]
"{0729bb72-3eeb-433d-8ac4-42b5a3228c0c}"= "c:\windows\system32\gijiyeli.dll" [2009-09-08 89088]
"{1060b1af-75eb-433a-9304-5853bf60d8fd}"= "c:\windows\system32\piyadayi.dll" [2009-09-09 88064]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\ShellServiceObjectDelayLoad]
"wakiyuyob"= {13c2daae-c95c-4485-b4f0-3441a286883d} - c:\windows\system32\piyadayi.dll [2009-09-09 88064]
"wasuneyez"= {4428a968-ffa0-4244-ad19-7ff6f140aa11} - c:\windows\system32\gijiyeli.dll [2009-09-08 89088]
"viludigow"= {272e3cae-74e8-4d32-9e18-bd675d453c5b} - c:\windows\system32\piyadayi.dll [2009-09-09 88064]
"dotuladuv"= {0e6d1c10-90fb-4035-ba95-30bdc36d05f4} - c:\windows\system32\gipunowe.dll [2009-09-10 88576]
"jozafuzek"= {0729bb72-3eeb-433d-8ac4-42b5a3228c0c} - c:\windows\system32\gijiyeli.dll [2009-09-08 89088]
"fihagaror"= {1060b1af-75eb-433a-9304-5853bf60d8fd} - c:\windows\system32\gijiyeli.dll [2009-09-08 89088]
"UpdatesDisableNotify"=dword:00000001
"c:\\Program Files\\NewTech Infosystems\\NTI Backup Now 5\\Client\\Agentsvc.exe"=
"c:\\Program Files\\NewTech Infosystems\\NTI Backup Now 5\\BackupSvc.exe"=
"c:\\Program Files\\NewTech Infosystems\\NTI Backup Now 5\\SchedulerSvc.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpofxm08.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hposfx08.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpqCopy.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpfccopy.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpzwiz01.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\Unload\\HpqPhUnl.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\Unload\\HpqDIA.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpoews01.exe"=
"c:\\Program Files\\Counter-Strike 1.6\\hl.exe"=
"c:\\Program Files\\CyberLink\\PowerDVD\\PDVDServ.exe"=
"c:\\Program Files\\TeamViewer\\Version4\\TeamViewer.exe"=
"c:\\Program Files\\Steam\\steamapps\\peydro55\\counter-strike\\hl.exe"=
"c:\\Program Files\\Xfire\\Xfire.exe"=
"c:\\WINDOWS\\explorer.exe"=
R2 AntiVirSchedulerService;Avira AntiVir Scheduler;c:\program files\Avira\AntiVir Desktop\sched.exe [9/7/2009 10:57 PM 108289]
R2 BUNAgentSvc;NTI Backup Now 5 Agent Service;c:\program files\NewTech Infosystems\NTI Backup Now 5\Client\Agentsvc.exe [3/3/2008 5:11 PM 16384]
R2 NTIBackupSvc;NTI Backup Now 5 Backup Service;c:\program files\NewTech Infosystems\NTI Backup Now 5\BackupSvc.exe [4/7/2008 2:42 AM 50424]
R2 NTISchedulerSvc;NTI Backup Now 5 Scheduler Service;c:\program files\NewTech Infosystems\NTI Backup Now 5\SchedulerSvc.exe [4/4/2008 7:03 AM 131072]
S3 GoogleDesktopManager-080708-050100;Google Desktop Manager 5.7.808.7150;c:\program files\Google\Google Desktop Search\GoogleDesktop.exe [10/28/2008 9:05 PM 24064]
S4 ASKUpgrade;ASKUpgrade;c:\program files\AskBarDis\bar\bin\ASKUpgrade.exe [8/22/2009 12:42 AM 234888]
IE: &Search
DPF: {F8C5C0F1-D884-43EB-A5A0-9E1C4A102FA8} - [You must be registered and logged in to see this link.]
Toolbar-SITEguard - (no file)
HKLM-Run-LaunchApp - (no file)
Rootkit scan 2009-09-10 17:19
[HKEY_USERS\S-1-5-21-2091681362-145439996-2945738896-1006\Software\Microsoft\SystemCertificates\AddressBook*]
- - - - - - - > 'explorer.exe'(3276)
c:\program files\Google\Quick Search Box\bin\1.2.1137.3514\qsb.dll
c:\windows\system32\agrsmsvc.exe
c:\program files\Avira\AntiVir Desktop\avguard.exe
c:\program files\Common Files\LightScribe\LSSrvc.exe
c:\windows\system32\HPZipm12.exe
c:\program files\CyberLink\Shared Files\RichVideo.exe
c:\program files\HP\Digital Imaging\bin\hpqste08.exe
c:\windows\system32\wbem\wmiadap.exe
Completion time: 2009-09-10 17:22 - machine was rebooted
ComboFix-quarantined-files.txt 2009-09-10 21:22
Pre-Run: 56,054,894,592 bytes free
Post-Run: 56,908,816,384 bytes free
tinagibson
Posts Posts : 38
Joined Joined : 2009-07-18
Points Points : 27124
Re: undetermined problem lost?????
Post by tinagibson on Fri Sep 11, 2009 9:23 pm
hey i finally got malwarebytes to run thought you might need the logfile t
Database version: 2551
9/11/2009 5:20:24 PM
mbam-log-2009-09-11 (17-20-24).txt
Objects scanned: 106075
Time elapsed: 19 minute(s), 34 second(s)
Memory Modules Infected: 1
Registry Keys Infected: 3
Registry Values Infected: 3
Registry Data Items Infected: 3
Files Infected: 13
c:\WINDOWS\system32\zevigulo.dll (Trojan.Vundo.H) -> Delete on reboot.
HKEY_CLASSES_ROOT\CLSID\{244e3751-17fb-4ec3-8346-3514cb92442a} (Trojan.Vundo.H) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{56256a51-b582-467e-b8d4-7786eda79ae0} (Trojan.Vundo) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Fun Web Products (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\nejujatal (Trojan.Vundo.H) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\SharedTaskScheduler\{244e3751-17fb-4ec3-8346-3514cb92442a} (Trojan.Vundo.H) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\ShellServiceObjectDelayLoad\vayowifon (Trojan.Vundo.H) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows\AppInit_DLLs (Trojan.Vundo.H) -> Data: c:\windows\system32\zevigulo.dll -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows\AppInit_DLLs (Trojan.Vundo.H) -> Data: system32\zevigulo.dll -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\UpdatesDisableNotify (Disabled.SecurityCenter) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
C:\Program Files\Core.dll (Spyware.OnlineGames) -> Quarantined and deleted successfully.
C:\Program Files\dbg.dll (Spyware.OnlineGames) -> Quarantined and deleted successfully.
C:\Program Files\DemoPlayer.dll (Spyware.OnlineGames) -> Quarantined and deleted successfully.
C:\Program Files\FileSystem_Stdio.dll (Spyware.OnlineGames) -> Quarantined and deleted successfully.
C:\Program Files\FileSystem_Steam.dll (Spyware.OnlineGames) -> Quarantined and deleted successfully.
C:\Program Files\hw.dll (Spyware.OnlineGames) -> Quarantined and deleted successfully.
C:\Program Files\steam_api.dll (Spyware.OnlineGames) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\suhokamo.dll (Trojan.Vundo) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\latavija.dll (Trojan.Vundo) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\nebiteda.dll (Trojan.Vundo) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\pavogare.dll (Trojan.Vundo) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\hufowebi.dll (Trojan.Vundo) -> Quarantined and deleted successfully.
hanks tina
tinagibson
Posts Posts : 38
Post by Origin on Sat Sep 12, 2009 5:10 am
Now open a new notepad file.
File::
Folder::
Registrty::
"lejehipahe"=-
"nejujatal"=-
[-hkey_local_machine\software\microsoft\windows\currentversion\explorer\SharedTaskScheduler]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\ShellServiceObjectDelayLoad]
"AntiVirusOverride"=-
"FirewallOverride"=-
"UpdatesDisableNotify"=-
Driver::
ASKUpgrade
Posts Posts : 2685
Joined Joined : 2009-05-05
OS OS : Windows Xp Sp3
Points Points : 31483
Post by tinagibson on Sat Sep 12, 2009 5:34 pm
Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.2814.2270 [GMT -4:00]
Command switches used :: c:\documents and settings\tina gibson\Desktop\CFScript.txt
AV: AntiVir Desktop *On-access scanning disabled* (Outdated) {AD166499-45F9-482A-A743-FDD3350758C7}
c:\program files\AskBarDis\bar\bin\askBar.dll
c:\program files\AskBarDis\bar\bin\askPopStp.dll
c:\program files\AskBarDis\bar\bin\AskSplash.exe
c:\program files\AskBarDis\bar\bin\AskTBApp.exe
c:\program files\AskBarDis\bar\bin\psvince.dll
c:\program files\AskBarDis\bar\Cache\0038B565
c:\program files\AskBarDis\bar\Cache\00BF3651
c:\program files\AskBarDis\bar\Cache\00CC4FF4
c:\program files\AskBarDis\bar\Cache\013D37A4
c:\program files\AskBarDis\bar\Cache\02D7687D
c:\program files\AskBarDis\bar\Cache\108276EA.bin
c:\program files\AskBarDis\bar\Cache\108279D8.bin
c:\program files\AskBarDis\bar\Cache\10827AC2.bin
c:\program files\AskBarDis\bar\Cache\10827BDB.bin
c:\program files\AskBarDis\bar\Cache\10827C97.bin
c:\program files\AskBarDis\bar\Cache\10827D72.bin
c:\program files\AskBarDis\bar\Cache\files.ini
c:\program files\AskBarDis\bar\History\search
c:\program files\AskBarDis\bar\Settings\AskLogo.ico
c:\program files\AskBarDis\bar\Settings\config.dat
c:\program files\AskBarDis\bar\Settings\config.dat.bak
c:\program files\AskBarDis\bar\Settings\prevcfg.htm
c:\program files\AskBarDis\PopSwatter\History\allowed
c:\program files\AskBarDis\PopSwatter\History\notallow
c:\program files\AskBarDis\unins000.dat
c:\program files\AskBarDis\unins000.exe
c:\windows\048298C9A4D3490B9FF9AB023A9238F3.TMP\WiseCustomCalla.dll
c:\windows\048298C9A4D3490B9FF9AB023A9238F3.TMP\WiseCustomCalla6.dll
c:\windows\048298C9A4D3490B9FF9AB023A9238F3.TMP\WiseData.ini
c:\windows\system32\mijikive.dll
c:\windows\system32\pafakamo.dll
c:\windows\system32\rudusisi.dll
c:\windows\system32\turovepi.dll
c:\windows\system32\wowijohi.dll
-------\Legacy_ASKUPGRADE
-------\Service_ASKUpgrade
((((((((((((((((((((((((( Files Created from 2009-08-12 to 2009-09-12 )))))))))))))))))))))))))))))))
2009-09-07 21:25 . 2009-09-10 22:35 -------- d-----w- c:\program files\Counter-Strike 1.6
2009-09-07 17:26 . 2009-09-12 17:28 -------- d-----w- c:\program files\Steam
2009-08-29 04:38 . 2008-04-14 22:00 4224 ------w- c:\windows\system32\drivers\beep.sys
2009-09-12 07:37 . 2009-06-12 07:37 88576 --sha-w- c:\windows\system32\gipofosi.dll
2009-09-11 00:19 . 2009-06-11 00:19 49664 --sha-w- c:\windows\system32\bidifetu.dll
2009-09-11 00:19 . 2009-06-11 00:19 89088 --sha-w- c:\windows\system32\rawiyewa.dll
2009-09-10 22:29 . 2009-07-06 04:42 -------- d-----w- c:\program files\Xfire
2009-06-29 16:12 . 2007-08-14 02:54 827392 ------w- c:\windows\system32\wininet.dll
2009-06-11 00:19 . 2009-06-11 00:19 49664 --sha-w- c:\windows\system32\kulofuvo.dll
2009-06-07 04:46 . 2009-06-07 04:46 49664 --sha-w- c:\windows\system32\muyolule.dll.tmp
- 2008-10-29 01:34 . 2009-09-10 21:08 71732 c:\windows\system32\perfc009.dat
+ 2008-10-29 01:34 . 2009-09-12 07:20 71732 c:\windows\system32\perfc009.dat
+ 2008-10-29 01:34 . 2009-09-12 07:20 442466 c:\windows\system32\perfh009.dat
- 2008-10-29 01:34 . 2009-09-10 21:08 442466 c:\windows\system32\perfh009.dat
"nejujatal"="c:\windows\system32\gipofosi.dll" [2009-09-12 88576]
"{d9254660-7192-4823-9f5c-9c96fc47e416}"= "c:\windows\system32\gipofosi.dll" [2009-09-12 88576]
"vugiletew"= {d9254660-7192-4823-9f5c-9c96fc47e416} - c:\windows\system32\gipofosi.dll [2009-09-12 88576]
"c:\\Acer\\Empowering Technology\\eRecovery\\eRAgent.exe"=
"c:\\WINDOWS\\system32\\HPZipm12.exe"=
S2 NTISchedulerSvc;NTI Backup Now 5 Scheduler Service;c:\program files\NewTech Infosystems\NTI Backup Now 5\SchedulerSvc.exe [4/4/2008 7:03 AM 131072]
IE: &Search
DPF: CabBuilder - [You must be registered and logged in to see this link.]
HKLM-Run-lejehipahe - turovepi.dll
SharedTaskScheduler-{13c2daae-c95c-4485-b4f0-3441a286883d} - c:\windows\system32\piyadayi.dll
SharedTaskScheduler-{4428a968-ffa0-4244-ad19-7ff6f140aa11} - c:\windows\system32\gijiyeli.dll
SharedTaskScheduler-{272e3cae-74e8-4d32-9e18-bd675d453c5b} - c:\windows\system32\piyadayi.dll
SharedTaskScheduler-{0e6d1c10-90fb-4035-ba95-30bdc36d05f4} - c:\windows\system32\gipunowe.dll
SharedTaskScheduler-{0729bb72-3eeb-433d-8ac4-42b5a3228c0c} - c:\windows\system32\gijiyeli.dll
SharedTaskScheduler-{1060b1af-75eb-433a-9304-5853bf60d8fd} - c:\windows\system32\gipunowe.dll
SSODL-wakiyuyob-{13c2daae-c95c-4485-b4f0-3441a286883d} - c:\windows\system32\piyadayi.dll
SSODL-wasuneyez-{4428a968-ffa0-4244-ad19-7ff6f140aa11} - c:\windows\system32\gijiyeli.dll
SSODL-viludigow-{272e3cae-74e8-4d32-9e18-bd675d453c5b} - c:\windows\system32\piyadayi.dll
SSODL-dotuladuv-{0e6d1c10-90fb-4035-ba95-30bdc36d05f4} - c:\windows\system32\gipunowe.dll
SSODL-jozafuzek-{0729bb72-3eeb-433d-8ac4-42b5a3228c0c} - c:\windows\system32\gijiyeli.dll
SSODL-fihagaror-{1060b1af-75eb-433a-9304-5853bf60d8fd} - c:\windows\system32\gipunowe.dll
Rootkit scan 2009-09-12 13:28
- - - - - - - > 'explorer.exe'(3504)
Completion time: 2009-09-12 13:31 - machine was rebooted
ComboFix-quarantined-files.txt 2009-09-12 17:31
ComboFix2.txt 2009-09-10 21:22
Pre-Run: 56,587,980,800 bytes free
Post-Run: 56,766,648,320 bytes free
327 --- E O F --- 2009-08-26 07:00
tinagibson
Posts Posts : 38
Post by Origin on Sat Sep 12, 2009 5:46 pm
    :filefind
    proquota.exe
    scecli.dll
    netlogon.dll
    eventlog.dll
    cngaudit.dll
Posts Posts : 2685
Post by tinagibson on Sun Sep 13, 2009 3:13 am
Log created at 23:11 on 12/09/2009 by tina gibson (Administrator - Elevation successful)
Searching for "proquota.exe"
No files found.
Searching for "scecli.dll"
C:\WINDOWS\ERDNT\cache\scecli.dll --a--- 181248 bytes [21:21 10/09/2009] [22:00 14/04/2008] A86BB5E61BF3E39B62AB4C7E7085A084
C:\WINDOWS\system32\dllcache\scecli.dll --a--c 181248 bytes [22:00 14/04/2008] [22:00 14/04/2008] A86BB5E61BF3E39B62AB4C7E7085A084
C:\WINDOWS\system32\scecli.dll ------ 181248 bytes [22:00 14/04/2008] [22:00 14/04/2008] A86BB5E61BF3E39B62AB4C7E7085A084
Searching for "netlogon.dll"
C:\WINDOWS\ERDNT\cache\netlogon.dll --a--- 407040 bytes [21:21 10/09/2009] [22:00 14/04/2008] 1B7F071C51B77C272875C3A23E1E4550
C:\WINDOWS\system32\dllcache\netlogon.dll --a--c 407040 bytes [22:00 14/04/2008] [22:00 14/04/2008] 1B7F071C51B77C272875C3A23E1E4550
C:\WINDOWS\system32\netlogon.dll ------ 407040 bytes [22:00 14/04/2008] [22:00 14/04/2008] 1B7F071C51B77C272875C3A23E1E4550
Searching for "eventlog.dll"
C:\WINDOWS\system32\dllcache\eventlog.dll --a--c 56320 bytes [22:00 14/04/2008] [22:00 14/04/2008] 6D4FEB43EE538FC5428CC7F0565AA656
Searching for "cngaudit.dll"
No files found.
-=End Of File=-
tinagibson
Posts Posts : 38
Post by Belahzur on Mon Sep 14, 2009 12:39 am
File::
Folder::
Registry::
[-HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{d2be9f52-416b-4ba8-9790-a7b44e2da14c}]
"nejujatal"=-
"{d9254660-7192-4823-9f5c-9c96fc47e416}"=-
"vugiletew"=-
FCopy::
c:\windows\system32\dllcache\eventlog.dll | c:\windows\system32\eventlog.dll
Points Points : 245069
Post by tinagibson on Mon Sep 14, 2009 3:25 am
Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.2814.2259 [GMT -4:00]
Running from: c:\documents and settings\tina gibson\Desktop\Combo-Fix.exe
c:\windows\system32\fajeyeyi.dll
c:\windows\system32\figadufo.dll
c:\windows\system32\gubitahu.dll
c:\windows\system32\kopupavo.dll
c:\windows\system32\sosilavu.dll
((((((((((((((((((((((((( Files Created from 2009-08-14 to 2009-09-14 )))))))))))))))))))))))))))))))
2009-09-14 03:00 . 2009-09-14 03:01 -------- d-----w- C:\Combo-Fix
2009-09-07 21:25 . 2009-09-14 01:47 -------- d-----w- c:\program files\Counter-Strike 1.6
2009-09-07 17:26 . 2009-09-14 03:19 -------- d-----w- c:\program files\Steam
2009-09-13 21:06 . 2009-06-13 21:05 50176 --sha-w- c:\windows\system32\huvahuwi.dll
2009-09-13 21:05 . 2009-06-13 21:05 89088 --sha-w- c:\windows\system32\neyivobu.dll
2009-09-12 20:37 . 2009-06-12 20:37 88576 --sha-w- c:\windows\system32\muzurimo.dll
2009-06-13 21:06 . 2009-06-13 21:06 50176 --sha-w- c:\windows\system32\jifuheja.dll
+ 2008-10-29 01:34 . 2009-09-12 17:30 71732 c:\windows\system32\perfc009.dat
+ 2008-10-29 01:34 . 2009-09-12 17:30 442466 c:\windows\system32\perfh009.dat
"nejujatal"="c:\windows\system32\neyivobu.dll" [2009-09-13 89088]
"lejehipahe"="fajeyeyi.dll" [BU]
"{6edec331-1b69-4e1c-b84d-943ef183045b}"= "c:\windows\system32\neyivobu.dll" [2009-09-13 89088]
"petuzihad"= {6edec331-1b69-4e1c-b84d-943ef183045b} - c:\windows\system32\neyivobu.dll [2009-09-13 89088]
"c:\\Program Files\\Steam\\steamapps\\rhyno417\\counter-strike\\hl.exe"=
IE: &Search
SharedTaskScheduler-{afcc1e83-6705-4cb9-a39a-162c590037dd} - c:\windows\system32\vosukaso.dll
SSODL-vaboremay-{afcc1e83-6705-4cb9-a39a-162c590037dd} - c:\windows\system32\vosukaso.dll
Rootkit scan 2009-09-13 23:19
- - - - - - - > 'explorer.exe'(2524)
Completion time: 2009-09-14 23:23 - machine was rebooted
ComboFix-quarantined-files.txt 2009-09-14 03:23
ComboFix2.txt 2009-09-12 17:31
ComboFix3.txt 2009-09-10 21:22
Pre-Run: 57,100,902,400 bytes free
Post-Run: 57,100,046,336 bytes free
287 --- E O F --- 2009-08-26 07:00
tinagibson
Posts Posts : 38
Post by tinagibson on Mon Sep 14, 2009 12:00 pm
"error loading fajeyeyi.dll the specified module could not be found"
avira anti virus is catching something the ones that can't be deleted i've been moving to quantine. whats going on here after i do as you ask could you try to explain it to me. I'm really not that computer smart.
thanks for your help so far tina
tinagibson
Posts Posts : 38
Post by Belahzur on Mon Sep 14, 2009 9:06 pm
  • Save it to your desktop.
    :files
    :reg
    "nejujatal"=-
    "vugiletew"=-
  • Close OTMoveIt
Please post the OTMoveIt log.
Post by tinagibson on Tue Sep 15, 2009 3:56 am
File/Folder c:\windows\system32\gipofosi.dll not found.
DllUnregisterServer procedure not found in c:\windows\system32\bidifetu.dll
c:\windows\system32\bidifetu.dll NOT unregistered.
c:\windows\system32\bidifetu.dll moved successfully.
DllUnregisterServer procedure not found in c:\windows\system32\rawiyewa.dll
c:\windows\system32\rawiyewa.dll NOT unregistered.
c:\windows\system32\rawiyewa.dll moved successfully.
DllUnregisterServer procedure not found in c:\windows\system32\juvilisi.dll
c:\windows\system32\juvilisi.dll NOT unregistered.
c:\windows\system32\juvilisi.dll moved successfully.
DllUnregisterServer procedure not found in c:\windows\system32\vamonumi.dll
c:\windows\system32\vamonumi.dll NOT unregistered.
c:\windows\system32\vamonumi.dll moved successfully.
DllUnregisterServer procedure not found in c:\windows\system32\pimenuda.dll
c:\windows\system32\pimenuda.dll NOT unregistered.
c:\windows\system32\pimenuda.dll moved successfully.
DllUnregisterServer procedure not found in c:\windows\system32\huyowoza.dll
c:\windows\system32\huyowoza.dll NOT unregistered.
c:\windows\system32\huyowoza.dll moved successfully.
c:\windows\tmp.tmp.tmp moved successfully.
DllUnregisterServer procedure not found in c:\windows\system32\lofuvika.dll
c:\windows\system32\lofuvika.dll NOT unregistered.
c:\windows\system32\lofuvika.dll moved successfully.
c:\windows\system32\fanenoto.dll.tmp moved successfully.
File/Folder c:\windows\system32\kulofuvo.dll not found.
c:\windows\system32\muyolule.dll.tmp moved successfully.
LoadLibrary failed for c:\windows\system32\sijorera.dll
c:\windows\system32\sijorera.dll NOT unregistered.
c:\windows\system32\sijorera.dll moved successfully.
LoadLibrary failed for c:\windows\system32\vutojisi.dll
c:\windows\system32\vutojisi.dll NOT unregistered.
c:\windows\system32\vutojisi.dll moved successfully.
c:\windows\system32\welatili.dll.tmp moved successfully.
c:\documents and settings\All Users\Application Data\12521094 moved successfully.
Registry key HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{d2be9f52-416b-4ba8-9790-a7b44e2da14c}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{d2be9f52-416b-4ba8-9790-a7b44e2da14c}\ deleted successfully.
Registry value HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\\nejujatal deleted successfully.
Registry value hkey_local_machine\software\microsoft\windows\currentversion\explorer\SharedTaskScheduler\\{d9254660-7192-4823-9f5c-9c96fc47e416} not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{d9254660-7192-4823-9f5c-9c96fc47e416}\ not found.
Registry value HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\ShellServiceObjectDelayLoad\\vugiletew not found.
Registry value HKEY_LOCAL_MACHINE\software\microsoft\security center\\AntiVirusOverride deleted successfully.
Registry value HKEY_LOCAL_MACHINE\software\microsoft\security center\\FirewallOverride deleted successfully.
Registry value HKEY_LOCAL_MACHINE\software\microsoft\security center\\UpdatesDisableNotify deleted successfully.
OTM by OldTimer - Version 3.0.0.6 log created on 09142009_235320
tinagibson
Posts Posts : 38
Post by Belahzur on Tue Sep 15, 2009 5:22 pm
  • Copy and paste DDS.txt back here, I don't need to see attach.txt just yet.
Post by tinagibson on Wed Sep 16, 2009 12:12 am
Run by tina gibson at 20:07:16.45 on Tue 09/15/2009
Internet Explorer: 7.0.5730.13
Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.2814.2365 [GMT -4:00]
AV: AntiVir Desktop *On-access scanning enabled* (Outdated) {AD166499-45F9-482A-A743-FDD3350758C7}
svchost.exe
svchost.exe
svchost.exe
C:\Program Files\Avira\AntiVir Desktop\sched.exe
svchost.exe
C:\WINDOWS\system32\agrsmsvc.exe
C:\Program Files\Avira\AntiVir Desktop\avguard.exe
C:\Program Files\NewTech Infosystems\NTI Backup Now 5\Client\Agentsvc.exe
C:\Program Files\NewTech Infosystems\NTI Backup Now 5\BackupSvc.exe
C:\Program Files\NewTech Infosystems\NTI Backup Now 5\SchedulerSvc.exe
C:\Program Files\CyberLink\Shared Files\RichVideo.exe
C:\WINDOWS\system32\HPZipm12.exe
C:\Program Files\NewTech Infosystems\NTI Backup Now 5\BkupTray.exe
C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe
C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe
C:\Program Files\Java\jre1.6.0_05\bin\jusched.exe
C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe
C:\WINDOWS\RTHDCPL.EXE
C:\Acer\Empowering Technology\eRecovery\eRAgent.exe
C:\Program Files\Google\Quick Search Box\GoogleQuickSearchBox.exe
C:\Program Files\Avira\AntiVir Desktop\avgnt.exe
C:\Documents and Settings\tina gibson\Desktop\dds.scr
BHO: Google Toolbar Helper: {aa58ed58-01dd-4d91-8333-cf10577473f7} - c:\program files\google\google toolbar\GoogleToolbar_32.dll
BHO: Google Toolbar Notifier BHO: {af69de43-7d58-4638-b6fa-ce66b5ad205d} - c:\program files\google\googletoolbarnotifier\5.2.4204.1700\swg.dll
BHO: Google Dictionary Compression sdch: {c84d72fe-e17d-4195-bb24-76c02e2e7c4e} - c:\program files\google\google toolbar\component\fastsearch_B7C5AC242193BB3E.dll
BHO: {d2be9f52-416b-4ba8-9790-a7b44e2da14c} - No File
TB: Google Toolbar: {2318c2b1-4965-11d4-9b18-009027a5cd4f} - c:\program files\google\google toolbar\GoogleToolbar_32.dll
uRun: [swg] "c:\program files\google\googletoolbarnotifier\GoogleToolbarNotifier.exe"
uRun: [Steam] "c:\program files\steam\Steam.exe" -silent
mRun: [NvCplDaemon] RUNDLL32.EXE c:\windows\system32\NvCpl.dll,NvStartup
mRun: [nwiz] nwiz.exe /install
mRun: [NvMediaCenter] RUNDLL32.EXE c:\windows\system32\NvMcTray.dll,NvTaskbarInit
mRun: [BkupTray] "c:\program files\newtech infosystems\nti backup now 5\BkupTray.exe"
mRun: [Google Desktop Search] "c:\program files\google\google desktop search\GoogleDesktop.exe" /startup
mRun: [RemoteControl] "c:\program files\cyberlink\powerdvd\PDVDServ.exe"
mRun: [LanguageShortcut] "c:\program files\cyberlink\powerdvd\language\Language.exe"
mRun: [UpdateP2GoShortCut] "c:\program files\cyberlink\power2go\muitransfer\muistartmenu.exe" "c:\program files\cyberlink\power2go" updatewithcreateonce "software\cyberlink\power2go\6.0"
mRun: [UpdatePSTShortCut] "c:\program files\cyberlink\dvd suite\muitransfer\muistartmenu.exe" "c:\program files\cyberlink\dvd suite" updatewithcreateonce "software\cyberlink\PowerStarter"
mRun: [SunJavaUpdateSched] "c:\program files\java\jre1.6.0_05\bin\jusched.exe"
mRun: [IMJPMIG8.1] "c:\windows\ime\imjp8_1\IMJPMIG.EXE" /Spoil /RemAdvDef /Migration32
mRun: [MSPY2002] c:\windows\system32\ime\pintlgnt\ImScInst.exe /SYNC
mRun: [PHIME2002ASync] c:\windows\system32\ime\tintlgnt\TINTSETP.EXE /SYNC
mRun: [PHIME2002A] c:\windows\system32\ime\tintlgnt\TINTSETP.EXE /IMEName
mRun: [Adobe Reader Speed Launcher] "c:\program files\adobe\reader 8.0\reader\Reader_sl.exe"
mRun: [RTHDCPL] RTHDCPL.EXE
mRun: [eRecoveryService] c:\acer\empowering technology\erecovery\eRAgent.exe
mRun: [HP Software Update] c:\program files\hp\hp software update\HPWuSchd2.exe
mRun: [Google Quick Search Box] "c:\program files\google\quick search box\GoogleQuickSearchBox.exe" /autorun
mRun: [avgnt] "c:\program files\avira\antivir desktop\avgnt.exe" /min
mRun: [CPM47de95db] Rundll32.exe "c:\windows\system32\lofuvika.dll",a
mRun: [nejujatal] Rundll32.exe "c:\windows\system32\yiborewa.dll",a
StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\hpdigi~1.lnk - c:\program files\hp\digital imaging\bin\hpqtra08.exe
IE: &Search
IE: E&xport to Microsoft Excel - c:\progra~1\micros~2\office12\EXCEL.EXE/3000
IE: {2670000A-7350-4f3c-8081-5663EE0C6C49} - {48E73304-E1D6-4330-914C-F5F514E3486C} - c:\progra~1\micros~2\office12\ONBttnIE.dll
IE: {92780B25-18CC-41C8-B9BE-3C9C571A8263} - {FF059E31-CC5A-4E2E-BF3B-96E929D65503} - c:\progra~1\micros~2\office12\REFIEBAR.DLL
DPF: {C3F79A2B-B9B4-4A66-B012-3EE46475B072} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0016-0000-0005-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
AppInit_DLLs: sosilavu.dll c:\windows\system32\yiborewa.dll c:\windows\system32\rawiyewa.dll c:\windows\system32\juvilisi.dll c:\windows\system32\vamonumi.dll c:\windows\system32\pimenuda.dll c:\windows\system32\lofuvika.dll c:\windows\system32\huyowoza.dll
SSODL: petuzihad - {6edec331-1b69-4e1c-b84d-943ef183045b} - No File
SSODL: zulojifif - {fa733b55-a7c9-44b4-83f5-9c224726c61d} - c:\windows\system32\yiborewa.dll
SSODL: SSODL - {EC43E3FD-5C60-46a6-97D7-E0B85DBDD6C4} - c:\windows\system32\lofuvika.dll
STS: {6edec331-1b69-4e1c-b84d-943ef183045b} - No File
STS: kupuhivus: {fa733b55-a7c9-44b4-83f5-9c224726c61d} - c:\windows\system32\yiborewa.dll
STS: STS: {ec43e3fd-5c60-46a6-97d7-e0b85dbdd6c4} - c:\windows\system32\lofuvika.dll
LSA: Notification Packages = scecli fajeyeyi.dll
R1 avgio;avgio;c:\program files\avira\antivir desktop\avgio.sys [2009-9-7 11608]
R2 AntiVirSchedulerService;Avira AntiVir Scheduler;c:\program files\avira\antivir desktop\sched.exe [2009-9-7 108289]
R2 AntiVirService;Avira AntiVir Guard;c:\program files\avira\antivir desktop\avguard.exe [2009-9-7 185089]
R2 avgntflt;avgntflt;c:\windows\system32\drivers\avgntflt.sys [2009-9-7 55656]
R2 BUNAgentSvc;NTI Backup Now 5 Agent Service;c:\program files\newtech infosystems\nti backup now 5\client\Agentsvc.exe [2008-3-3 16384]
R2 NTIBackupSvc;NTI Backup Now 5 Backup Service;c:\program files\newtech infosystems\nti backup now 5\BackupSvc.exe [2008-4-7 50424]
R2 NTISchedulerSvc;NTI Backup Now 5 Scheduler Service;c:\program files\newtech infosystems\nti backup now 5\SchedulerSvc.exe [2008-4-4 131072]
S3 GoogleDesktopManager-080708-050100;Google Desktop Manager 5.7.808.7150;c:\program files\google\google desktop search\GoogleDesktop.exe [2008-10-28 24064]
2009-09-13 23:00 --d----- C:\Combo-Fix
2009-09-12 23:06 25,088 a------- c:\windows\system32\tftp.msc
2009-09-10 16:50 a-dshr-- C:\cmdcons
2009-09-10 16:46 229,888 a------- c:\windows\PEV.exe
2009-09-09 20:34 --d----- c:\program files\New Folder
2009-09-09 20:33 --d----- C:\New Folder
2009-09-09 17:14 552 a------- c:\windows\system32\d3d8caps.dat
2009-09-09 08:32 --d----- c:\program files\Angle Interactive
2009-09-08 14:45 --d----- c:\program files\Trend Micro
2009-09-08 14:12 38,160 a------- c:\windows\system32\drivers\mbamswissarmy.sys
2009-09-08 14:12 19,096 a------- c:\windows\system32\drivers\mbam.sys
2009-09-08 09:06 --d----- c:\program files\Malwarebytes' Anti-Malware
2009-09-08 08:14 390,144 a------- c:\windows\system32\huej1nqg.exe
2009-09-07 22:57 55,656 a------- c:\windows\system32\drivers\avgntflt.sys
2009-09-07 22:57 --d----- c:\program files\Avira
2009-09-07 22:57 --d----- c:\docume~1\alluse~1\applic~1\Avira
2009-09-07 17:53 --d----- c:\docume~1\tinagi~1\applic~1\TeamViewer
2009-09-07 17:52 --d----- c:\documents and settings\tina gibson\temp
2009-09-07 17:25 --d----- c:\program files\Counter-Strike 1.6
2009-09-07 16:40 a-d----- c:\program files\DOTNETFX
2009-09-07 16:08 839,680 a------- c:\program files\steamclient.dll
2009-09-07 16:07 3,649,536 a------- c:\program files\Steam.dll
2009-09-07 16:03 221,184 a------- c:\program files\hltv.exe
2009-09-07 16:03 397,312 a------- c:\program files\hlds.exe
2009-09-07 16:03 81,920 a------- c:\program files\hl.exe
2009-09-07 16:03 211,456 a------- c:\program files\a3dapi.dll
2009-09-07 15:55 67,826,994 a------- c:\windows\Counter strike 1.6.exe
2009-09-07 13:26 --d----- c:\program files\Steam
2009-09-05 22:57 227 a------- c:\windows\HP_CounterReport_Update_HPSU.ini
2009-09-05 22:57 214 a------- c:\windows\HP_48BitScanUpdatePatch.ini
2009-09-05 22:56 221 a------- c:\windows\HP_RedboxHprblog_HPSU.ini
2009-09-03 14:07 41,872 a------- c:\windows\system32\xfcodec.dll
2009-08-30 16:15 1,160 a------- c:\windows\wininit.ini
2009-08-30 00:11 2,232 a------- c:\windows\system32\drivers\kgpcpy.cfg
2009-08-30 00:06 2,024 a------- c:\windows\system32\drivers\kgpfr2.cfg
2009-08-30 00:05 --d----- c:\docume~1\alluse~1\applic~1\SITEguard
2009-08-30 00:05 --d----- c:\program files\common files\iS3
2009-08-30 00:05 --d----- c:\docume~1\alluse~1\applic~1\STOPzilla!
2009-08-29 00:38 4,224 -------- c:\windows\system32\drivers\beep.sys
2009-08-27 21:13 --d----- c:\program files\Counter-Strike 1.6 Non-Steam 2009-04-29
2009-08-23 20:29 --d----- c:\program files\Counter-Strike
2009-08-22 10:10 --d----- c:\program files\VALVe
2009-09-14 19:34 89,088 a--sh--- c:\windows\system32\yiborewa.dll
2009-09-14 19:34 37,888 a--sh--- c:\windows\system32\fegovoku.dll
2009-09-14 07:12 37,888 a--sh--- c:\windows\system32\titobigi.dll
2009-09-13 17:06 50,176 a--sh--- c:\windows\system32\huvahuwi.dll
2009-09-13 17:05 89,088 a--sh--- c:\windows\system32\neyivobu.dll
2009-09-09 20:19 88,064 a--sh--- c:\windows\system32\ludiyofu.dll
2009-08-13 20:51 15,829 a------- c:\docume~1\alluse~1\applic~1\usywupox.dat
2009-08-05 05:01 204,800 a------- c:\windows\system32\mswebdvd.dll
2009-08-02 14:32 1,689 a------- c:\program files\Dedicated Server.lnk
2009-07-17 15:01 58,880 a------- c:\windows\system32\atl.dll
2009-07-12 12:21 233,472 a------- c:\windows\system32\wmpdxm.dll
2009-06-29 12:12 827,392 -------- c:\windows\system32\wininet.dll
2009-06-29 12:12 78,336 a------- c:\windows\system32\ieencode.dll
2009-06-29 12:12 17,408 a------- c:\windows\system32\corpol.dll
2009-06-25 04:25 730,112 a------- c:\windows\system32\lsasrv.dll
2009-06-25 04:25 301,568 a------- c:\windows\system32\kerberos.dll
2009-06-25 04:25 147,456 a------- c:\windows\system32\schannel.dll
2009-06-25 04:25 136,192 a------- c:\windows\system32\msv1_0.dll
2009-06-25 04:25 56,832 a------- c:\windows\system32\secur32.dll
2009-06-25 04:25 54,272 a------- c:\windows\system32\wdigest.dll
2005-09-29 22:47 24,705 a------- c:\program files\HLTV-Readme.txt
2005-09-29 22:47 1,569 a------- c:\program files\hltv.cfg
2005-09-29 22:47 786 a------- c:\program files\hlds_steamgames.vdf
2005-08-13 15:24 171,014 a------- c:\program files\hl.ico
============= FINISH: 20:07:40.45 ===============
tinagibson
Posts Posts : 38
Post by tinagibson on Wed Sep 16, 2009 12:16 am
rundll error c:\windows\system32\welatili.dll
rundll error c:\windows\system 32\lofuvika.dll
tinagibson
Posts Posts : 38
Post by Belahzur on Wed Sep 16, 2009 4:36 pm
We need to run OTM one more time.
    :files
  • Close OTMoveIt
Post by tinagibson on Wed Sep 16, 2009 7:21 pm
c:\windows\system32\huej1nqg.exe moved successfully.
DllUnregisterServer procedure not found in c:\windows\system32\yiborewa.dll
c:\windows\system32\yiborewa.dll NOT unregistered.
c:\windows\system32\yiborewa.dll moved successfully.
DllUnregisterServer procedure not found in c:\windows\system32\fegovoku.dll
c:\windows\system32\fegovoku.dll NOT unregistered.
c:\windows\system32\fegovoku.dll moved successfully.
DllUnregisterServer procedure not found in c:\windows\system32\titobigi.dll
c:\windows\system32\titobigi.dll NOT unregistered.
c:\windows\system32\titobigi.dll moved successfully.
DllUnregisterServer procedure not found in c:\windows\system32\huvahuwi.dll
c:\windows\system32\huvahuwi.dll NOT unregistered.
c:\windows\system32\huvahuwi.dll moved successfully.
DllUnregisterServer procedure not found in c:\windows\system32\neyivobu.dll
c:\windows\system32\neyivobu.dll NOT unregistered.
c:\windows\system32\neyivobu.dll moved successfully.
DllUnregisterServer procedure not found in c:\windows\system32\ludiyofu.dll
c:\windows\system32\ludiyofu.dll NOT unregistered.
c:\windows\system32\ludiyofu.dll moved successfully.
OTM by OldTimer - Version 3.0.0.6 log created on 09162009_152122
tinagibson
Posts Posts : 38
Post by Belahzur on Wed Sep 16, 2009 7:56 pm
Now post a new Hijack This log.
Post by tinagibson on Wed Sep 16, 2009 9:25 pm
Scan saved at 5:25:06 PM, on 9/16/2009
C:\Program Files\Java\jre1.6.0_05\bin\jucheck.exe
C:\Program Files\hijackthis\HijackThis.exe
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.2.4204.1700\swg.dll
O2 - BHO: (no name) - {d2be9f52-416b-4ba8-9790-a7b44e2da14c} - (no file)
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\system32\NvMcTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [BkupTray] "C:\Program Files\NewTech Infosystems\NTI Backup Now 5\BkupTray.exe"
O4 - HKLM\..\Run: [Google Desktop Search] "C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe" /startup
O4 - HKLM\..\Run: [RemoteControl] "C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe"
O4 - HKLM\..\Run: [LanguageShortcut] "C:\Program Files\CyberLink\PowerDVD\Language\Language.exe"
O4 - HKLM\..\Run: [UpdateP2GoShortCut] "C:\Program Files\CyberLink\Power2Go\MUITransfer\MUIStartMenu.exe" "C:\Program Files\CyberLink\Power2Go" UpdateWithCreateOnce "SOFTWARE\CyberLink\Power2Go\6.0"
O4 - HKLM\..\Run: [UpdatePSTShortCut] "C:\Program Files\CyberLink\DVD Suite\MUITransfer\MUIStartMenu.exe" "C:\Program Files\CyberLink\DVD Suite" UpdateWithCreateOnce "Software\CyberLink\PowerStarter"
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre1.6.0_05\bin\jusched.exe"
O4 - HKLM\..\Run: [IMJPMIG8.1] "C:\WINDOWS\IME\imjp8_1\IMJPMIG.EXE" /Spoil /RemAdvDef /Migration32
O4 - HKLM\..\Run: [MSPY2002] C:\WINDOWS\system32\IME\PINTLGNT\ImScInst.exe /SYNC
O4 - HKLM\..\Run: [PHIME2002ASync] C:\WINDOWS\system32\IME\TINTLGNT\TINTSETP.EXE /SYNC
O4 - HKLM\..\Run: [PHIME2002A] C:\WINDOWS\system32\IME\TINTLGNT\TINTSETP.EXE /IMEName
O4 - HKLM\..\Run: [eRecoveryService] C:\Acer\Empowering Technology\eRecovery\eRAgent.exe
O4 - HKLM\..\Run: [Google Quick Search Box] "C:\Program Files\Google\Quick Search Box\GoogleQuickSearchBox.exe" /autorun
O4 - HKLM\..\Run: [avgnt] "C:\Program Files\Avira\AntiVir Desktop\avgnt.exe" /min
O4 - HKLM\..\Run: [CPM47de95db] Rundll32.exe "c:\windows\system32\lofuvika.dll",a
O4 - HKLM\..\Run: [nejujatal] Rundll32.exe "c:\windows\system32\yiborewa.dll",a
O4 - HKCU\..\Run: [Steam] "C:\Program Files\Steam\Steam.exe" -silent
O4 - HKUS\S-1-5-21-2091681362-145439996-2945738896-1007\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe (User 'kaitie justice')
O4 - HKUS\S-1-5-21-2091681362-145439996-2945738896-1007\..\Run: [msnmsgr] "C:\Program Files\Windows Live\Messenger\msnmsgr.exe" /background (User 'kaitie justice')
O4 - HKUS\S-1-5-21-2091681362-145439996-2945738896-1007\..\Run: [MSMSGS] "C:\Program Files\Messenger\msmsgs.exe" /background (User 'kaitie justice')
O4 - HKUS\S-1-5-21-2091681362-145439996-2945738896-1007\..\Run: [swg] C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe (User 'kaitie justice')
O4 - HKUS\S-1-5-21-2091681362-145439996-2945738896-1007\..\Run: [Protection System] "C:\Program Files\Protection System\psystem.exe" -noscan (User 'kaitie justice')
O4 - HKUS\S-1-5-21-2091681362-145439996-2945738896-1007\..\Run: [lejehipahe] Rundll32.exe "C:\WINDOWS\system32\welatili.dll",s (User 'kaitie justice')
O4 - HKUS\S-1-5-21-2091681362-145439996-2945738896-1007\..\Run: [nejujatal] Rundll32.exe "c:\windows\system32\yiborewa.dll",a (User 'kaitie justice')
O4 - HKUS\S-1-5-21-2091681362-145439996-2945738896-1008\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe (User 'peyton gibson')
O4 - S-1-5-21-2091681362-145439996-2945738896-1007 Startup: OneNote 2007 Screen Clipper and Launcher.lnk = C:\Program Files\Microsoft Office\Office12\ONENOTEM.EXE (User 'kaitie justice')
O4 - S-1-5-21-2091681362-145439996-2945738896-1007 User Startup: OneNote 2007 Screen Clipper and Launcher.lnk = C:\Program Files\Microsoft Office\Office12\ONENOTEM.EXE (User 'kaitie justice')
O9 - Extra button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~2\Office12\ONBttnIE.dll
O9 - Extra 'Tools' menuitem: S&end to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~2\Office12\ONBttnIE.dll
O16 - DPF: CabBuilder - [You must be registered and logged in to see this link.]
O16 - DPF: {C3F79A2B-B9B4-4A66-B012-3EE46475B072} (MessengerStatsClient Class) - [You must be registered and logged in to see this link.]
O16 - DPF: {F8C5C0F1-D884-43EB-A5A0-9E1C4A102FA8} (GoPetsWeb Control) - [You must be registered and logged in to see this link.]
O20 - AppInit_DLLs: sosilavu.dll c:\windows\system32\yiborewa.dll c:\windows\system32\rawiyewa.dll c:\windows\system32\juvilisi.dll c:\windows\system32\vamonumi.dll c:\windows\system32\pimenuda.dll c:\windows\system32\lofuvika.dll c:\windows\system32\huyowoza.dll c:\windows\system32\neyivobu.dll c:\windows\system32\ludiyofu.dll
O21 - SSODL: petuzihad - {6edec331-1b69-4e1c-b84d-943ef183045b} - (no file)
O21 - SSODL: zulojifif - {fa733b55-a7c9-44b4-83f5-9c224726c61d} - c:\windows\system32\yiborewa.dll (file missing)
O21 - SSODL: SSODL - {EC43E3FD-5C60-46a6-97D7-E0B85DBDD6C4} - c:\windows\system32\lofuvika.dll (file missing)
O22 - SharedTaskScheduler: mujuzedij - {6edec331-1b69-4e1c-b84d-943ef183045b} - (no file)
O22 - SharedTaskScheduler: kupuhivus - {fa733b55-a7c9-44b4-83f5-9c224726c61d} - c:\windows\system32\yiborewa.dll (file missing)
O22 - SharedTaskScheduler: STS - {EC43E3FD-5C60-46a6-97D7-E0B85DBDD6C4} - c:\windows\system32\lofuvika.dll (file missing)
O23 - Service: Agere Modem Call Progress Audio (AgereModemAudio) - Agere Systems - C:\WINDOWS\system32\agrsmsvc.exe
O23 - Service: Avira AntiVir Scheduler (AntiVirSchedulerService) - Avira GmbH - C:\Program Files\Avira\AntiVir Desktop\sched.exe
O23 - Service: Avira AntiVir Guard (AntiVirService) - Avira GmbH - C:\Program Files\Avira\AntiVir Desktop\avguard.exe
O23 - Service: NTI Backup Now 5 Agent Service (BUNAgentSvc) - NewTech Infosystems, Inc. - C:\Program Files\NewTech Infosystems\NTI Backup Now 5\Client\Agentsvc.exe
O23 - Service: Google Desktop Manager 5.7.808.7150 (GoogleDesktopManager-080708-050100) - Google - C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe
O23 - Service: NTI Backup Now 5 Backup Service (NTIBackupSvc) - NewTech InfoSystems, Inc. - C:\Program Files\NewTech Infosystems\NTI Backup Now 5\BackupSvc.exe
O23 - Service: NTI Backup Now 5 Scheduler Service (NTISchedulerSvc) - Unknown owner - C:\Program Files\NewTech Infosystems\NTI Backup Now 5\SchedulerSvc.exe
O23 - Service: Cyberlink RichVideo Service(CRVS) (RichVideo) - Unknown owner - C:\Program Files\CyberLink\Shared Files\RichVideo.exe
End of file - 11442 bytes
tinagibson
Posts Posts : 38
Post by Belahzur on Wed Sep 16, 2009 11:51 pm
That should do it for the infection, now lets remove some old Java.
  • Open HijackThis.
Post by tinagibson on Thu Sep 17, 2009 1:11 am
2007 Microsoft Office Suite Service Pack 1 (SP1)
Adobe Flash Player 10 ActiveX
Adobe Reader 8.1.2
Agere Systems PCI-SV92EX Soft Modem
Ask Toolbar
Avira AntiVir Personal - Free Antivirus
CCleaner (remove only)
Choice Guard
Counter-Strike
CyberLink DVD Suite
CyberLink DVD Suite
CyberLink Power2Go
CyberLink Power2Go
CyberLink PowerDVD
eMachines Games
GearDrvs
Google Desktop
HijackThis 2.0.2
HP Extended Capabilities 5.3
HP Image Zone Express
HP Imaging Device Functions 5.3
HP PSC & OfficeJet 5.3.B
HP Software Update
HP Solution Center & Imaging Support Tools 5.3
Java(TM) 6 Update 5
Microsoft .NET Framework 1.1
Microsoft Games for Windows - LIVE
Microsoft Games for Windows - LIVE Redistributable
Microsoft Office Home and Student 2007
Microsoft Office OneNote MUI (English) 2007
Microsoft Office PowerPoint Viewer 2007 (English)
Microsoft Office Suite Activation Assistant
Microsoft Works
MSN
MSVCRT
MSXML 4.0 SP2 (KB954430)
MSXML 6.0 Parser (KB925673)
NTI Backup Now 5
NTI Media Maker 8
NVIDIA Drivers
Security Update for 2007 Microsoft Office System (KB969559)
Security Update for 2007 Microsoft Office System (KB969679)
Security Update for Microsoft Office Excel 2007 (KB969682)
Security Update for Microsoft Office PowerPoint 2007 (KB957789)
Security Update for Microsoft Office system 2007 (KB969613)
Security Update for Microsoft Office Word 2007 (KB969604)
Segoe UI
Steam
TeamViewer 4
Update for Windows XP (KB961503)
Windows Live Call
Windows Live Essentials
Windows Live Messenger
Windows Live Upload Tool
Windows Presentation Foundation
WinRAR archiver
Xfire (remove only)
tinagibson
Posts Posts : 38
Post by Belahzur on Thu Sep 17, 2009 8:25 am
    Ask Toolbar
    Java(TM) 6 Update 5
ComboFix /u
Post by tinagibson on Thu Sep 17, 2009 4:32 pm
windows can't find combofix/u
startup got a rundll error c:\windows\system32\yiborewa.dll
avira isn't updating asks for system reboot and no scans can be performed
tinagibson
Posts Posts : 38
Post by Belahzur on Thu Sep 17, 2009 4:33 pm
Combofix uninstall sometimes doesn't work, not much bothered about that bit.
Post a new Hijack This log.
Post by tinagibson on Thu Sep 17, 2009 4:36 pm
Scan saved at 12:35:32 PM, on 9/17/2009
O20 - AppInit_DLLs: c:\windows\system32\yiborewa.dll c:\windows\system32\neyivobu.dll c:\windows\system32\ludiyofu.dll
End of file - 8814 bytes
tinagibson
Posts Posts : 38
Post by Belahzur on Thu Sep 17, 2009 11:38 pm
Post by tinagibson on Fri Sep 18, 2009 3:56 am
Database version: 2818
9/17/2009 11:49:38 PM
mbam-log-2009-09-17 (23-49-38).txt
Objects scanned: 130397
Time elapsed: 37 minute(s), 6 second(s)
Files Infected: 3
C:\WINDOWS\system32\jifuheja.dll (Trojan.Vundo) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\tftp.msc (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\WINDOWS\0535251103110107106.xry (KoobFace.Trace) -> Quarantined and deleted successfully.
tinagibson
Posts Posts : 38
Post by Belahzur on Fri Sep 18, 2009 9:10 am
Post by tinagibson on Sat Sep 19, 2009 2:09 am
DDS (Ver_09-07-30.01) - NTFSx86
Run by tina gibson at 17:16:16.18 on Fri 09/18/2009
Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.2814.2361 [GMT -4:00]
svchost.exe
svchost.exe
svchost.exe
svchost.exe
C:\WINDOWS\system32\notepad.exe
IE: &Search
2009-09-18 07:05 1,374 a------- c:\windows\imsins.BAK
2009-09-16 15:21 --d----- C:\_OTM
2009-09-08 14:12 38,224 a------- c:\windows\system32\drivers\mbamswissarmy.sys
2009-09-08 14:12 19,160 a------- c:\windows\system32\drivers\mbam.sys
============= FINISH: 17:16:30.45 ===============
tinagibson
Posts Posts : 38
Post by Belahzur on Sat Sep 19, 2009 6:03 pm
    "Notification Packages"=hex(7):73,63,65,63,6c,69,00,00
Post by tinagibson on Sat Sep 19, 2009 6:56 pm
cannot import c:\documents and settings\tinagibson\desktop\fix.reg: the specified file is not a registry script you can only import binary registry files from within the registry editor.
did i do something wrong?
tinagibson
Posts Posts : 38
Post by Belahzur on Sun Sep 20, 2009 2:07 am
You missed this line:
As the TOP line, or there is a space before/after that line.
Post by tinagibson on Sun Sep 20, 2009 2:48 am
successfully entered into registry
tinagibson
Posts Posts : 38
Post by tinagibson on Sun Sep 20, 2009 5:23 am
now what do we do? and how can we stop these reinfections if thats what they are? i'm 40 yrs old and computers are not my thing but with your help so far i've learned alot thank you so far for at less educating me on basic
computer op's
tinagibson
Posts Posts : 38
Post by tinagibson on Sun Sep 20, 2009 5:41 am
my kids enjoy a site called topix.com (local gossip site) sometimes this appears
HEUR\HTML.Malware asks if to be quarantined, deny access ignore deny access is that the right thing to do?
tinagibson
Posts Posts : 38
Post by Belahzur on Sun Sep 20, 2009 9:21 pm
Quarantine it.
Post by tinagibson on Mon Sep 21, 2009 1:46 am
now that we've done all this to the computer running this and that are we ok. Is there something else we need to do?
tinagibson
Posts Posts : 38
Post by Belahzur on Mon Sep 21, 2009 8:25 am
Nope, that should do it. The malware is gone.
