No Audio Device
Solved No Audio Device
Post by DaltonRogers on Tue 08 Sep 2009, 9:26 am
Just did a System Restore on my computer. Everything seems to be working fine, except for the audio. In the Sounds and Audio Devices Properties, it only says "No Audio Device." How do I fix this problem?
DaltonRogers
Operating System : XP
Solved Re: No Audio Device
Post by skilldegree on Tue 08 Sep 2009, 9:41 am
If your only using onboard audio then head to your motherboards manufacturer website and download the latest audio drivers for your board. If you can't do that, try to find the disk that came with the board and grab them from that.
skilldegree
Rookie Surfer
Rookie Surfer
Operating System : Win7 x64 Ultimate
Post by DaltonRogers on Wed 09 Sep 2009, 11:29 pm
So, by motherboard, does that mean Toshiba?
DaltonRogers
Post by skilldegree on Fri 11 Sep 2009, 9:20 am
Ahh you brought your computer from toshiba?
Is it a laptop?
can you give me the series and model of it?
eg.
Satellite Pro - 4280XCDT
skilldegree
Rookie Surfer
Rookie Surfer
Post by DaltonRogers on Fri 11 Sep 2009, 11:02 am
Yes, it is a laptop.
Where do I find the series and model?
DaltonRogers
Post by skilldegree on Mon 14 Sep 2009, 11:45 am
Start --> Control Panel --> System
It should say it on the bottom half of the window that opens up (General Tab).
If you cant find control panel in your stat menu, open up my computer/Explorer and paste this into the address bar (Control Panel) remove the brackets.
skilldegree
Rookie Surfer
Rookie Surfer
Post by DaltonRogers on Wed 16 Sep 2009, 12:11 pm
Intel(R) Celeron(R) M
processor 1.70GHz
1.69 GHz. 448 MB of RAM
DaltonRogers
Post by skilldegree on Mon 21 Sep 2009, 5:25 pm
Nearly.
yours would say toshiba...
if not you will have to look around the the laptop somewhere, usualy on the back of the screen or around the keyboard.
skilldegree
Rookie Surfer
Rookie Surfer
Post by Sponsored content Today at 11:23 pm
