Start up issue related to battery message
Post by dlipkin on 7th September 2009, 1:02 pm
When I boot up my computer a screen appears which indicates I have a battery problem. Specifically it says the battery is not a Dell battery and it will not be able to charge properly. I also get this message periodically when working on the computer.
The screen commands showing ask me to configure set up by hitting F2 or press any key to continue with the booting process. After I hit enter all goes fine.
I have the original Dell Battery, I have pulled it and reinstalled it and the battery is charging properly and lasts about 2 hours.
How do I get rid of this boot up problem?
Beardog
dlipkin
Posts Posts : 3
Joined Joined : 2009-09-07
OS OS : Vista Home Basic
Points Points : 26485
Re: Start up issue related to battery message
Post by Doctor Inferno on 7th September 2009, 2:11 pm
Please post the exact message you receive, so that we can better troubleshoot your problem.
Points Points : 104610
Post by dlipkin on 8th September 2009, 8:39 am
It says;
WARNING: The battery cannot be identified.
This system will not be able to charge the battery
Press any key to continue
Press twice to enter set up
Press and any key to enter Boot menu
dlipkin
Posts Posts : 3
Post by Doctor Inferno on 8th September 2009, 8:59 am
I found this on another website, let's see if it works for you too.
Use the battery until the screen blacks out. Start the laptop with out the AC adaptor, the system will warn you of low battery and press F1. After pressing F1, plug the AC adapter back in and the problem should be solved.
Post by dlipkin on 8th September 2009, 9:45 am
Thank you. I will give it a try and let you know the result.
dlipkin
Posts Posts : 3
