Windows antivirus pro and police pro major problems
Post by caniac23 on 6th September 2009, 2:36 pm
I picked this thing up yesterday and it has wrecked my computer. (Dell Latitude 610 with windows XP). It will not let me access anything. The only way I can get online is to click the Dell users guide on the desktop. If I click on IE or any other icon, it wont start. When I go to the control panel and try to click on anything, I get a "parameter is incorrect" message. It also wiped out my wireless connection. I have tried some things I've seen here like Malwarebytes anti malware and Hijack This with no luck. I downloaded malwarbytes but can't run it. As soon as the screen pops up, it's wiped out. With Hijack This, I was able to do a scan, but it was wiped out before i could save it. Now it wont let me run it again!
Please Help!
caniac23
Posts Posts : 10
Joined Joined : 2009-09-05
OS OS : windowsxp
Points Points : 26542
Re: Windows antivirus pro and police pro major problems
Post by Belahzur on 6th September 2009, 6:20 pm
    :filefind
    scecli.dll
    netlogon.dll
    eventlog.dll
    cngaudit.dll
Points Points : 245111
Will not let me open anything on my Desktop
Post by caniac23 on 6th September 2009, 9:55 pm
I downloaded the SystemLook onto the desktop, but when I double click, or go through the Open option nothing happens. Is there any other way to access it?
caniac23
Posts Posts : 10
OS OS : windowsxp
Post by Origin on 6th September 2009, 10:34 pm
Hello, try to run SystemLook in Safemode and see if it works:
Please do the following in Safe Mode with Networking: as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode with Networking" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.) Once in the start up menu, select "Safe Mode with Networking", then do the following instructions:
Posts Posts : 2685
Joined Joined : 2009-05-05
OS OS : Windows Xp Sp3
Points Points : 31523
Post by caniac23 on 7th September 2009, 9:30 pm
OK - I tried it in safe-mode and get the same results. The window opens, then immediately closes. It wont run!
caniac23
Posts Posts : 10
OS OS : windowsxp
Post by caniac23 on 7th September 2009, 10:45 pm
This thing is letting me do NOTHING! I've never been so frustrated. I can't open any programs. I can't do a system restore. Anything I search for on Google gets redirected. My wireless connection has been shut down. My bookmarks have been deleted. What is going on?
caniac23
Posts Posts : 10
OS OS : windowsxp
Post by Belahzur on 7th September 2009, 11:19 pm
Lets try something else.
Post by caniac23 on 7th September 2009, 11:40 pm
I downloaded "Silent Runners" to my desktop. When I try to start it, I get a message saying Silent Runners has started and a log will be created. Then it shuts down and I get a message saying Silent Runners cannot use WMI to identify the operating system and it suggests I use MS tool WMID. iag to diagnose VMI. When I try to do that, the tool wont start.
caniac23
Posts Posts : 10
OS OS : windowsxp
Post by Belahzur on 8th September 2009, 1:21 am
  1. Unzip it and start GMER.
Post by caniac23 on 8th September 2009, 10:46 pm
GMER wont run in safe mode. It starts, then immediately shuts down. Also, this thing has now added "geekpolice.com to my drop down address bar.
caniac23
Posts Posts : 10
OS OS : windowsxp
Post by Belahzur on 9th September 2009, 12:10 am
Probably just browser memory, that can be cleared later.
Extract it and start the program.
Will IceSword run in Safe Mode?
Post by caniac23 on 11th September 2009, 5:39 pm
I can't download it. I get a message saying I am forbidden from downloading the file. ( Sorry for the delay-I've working out of town the past 3 days.
caniac23
Posts Posts : 10
OS OS : windowsxp
Post by Belahzur on 11th September 2009, 8:01 pm
I've uploaded it here, see if you can download it from this host.
Choose "free user", and hit the big download button.
See if you can run it.
Post by caniac23 on 11th September 2009, 9:07 pm
I had no problem downloading it, but it won't run. When I try to open it, a window opens and immediately closes. That happens in both normal and safe modes.
Ken
caniac23
Posts Posts : 10
OS OS : windowsxp
Post by Origin on 12th September 2009, 5:35 am
  • Copy and paste DDS.txt back here, I don't need to see attach.txt just yet.
Posts Posts : 2685
Post by caniac23 on 12th September 2009, 11:44 am
I downloaded it to my desktop with no problem, but it won't run. When I double-click the icon, I get a screen saying the publisher can't be verified and asking if I want to run it anyway. When I click "run", a screen opens for a split second, then closes. The same happens when I try it in safe mode.
Ken
caniac23
Posts Posts : 10
OS OS : windowsxp
Post by Belahzur on 12th September 2009, 10:49 pm
Is it dosote.exe window that opens/closes real fast?
Post by caniac23 on 13th September 2009, 11:29 am
Yes, it is.
caniac23
Posts Posts : 10
OS OS : windowsxp
Post by Belahzur on 14th September 2009, 12:49 am
Please delete this file in red:
C:\Windows\system32\desot.exe
Next, download [You must be registered and logged in to see this link.] file.
Download it to your Desktop.
Double click it to run it; select yes to the registry merge prompt.
Can you try running Hijack This now?
