Internett speed
Internett speed
Post by colin93 on Fri Sep 04, 2009 7:45 pm
Am having problems with my internet and i wanna know how fast it is when downloading, even when am playing a game like wow. And if its low how can increase the speed? Smile
colin93
OS : Vista
Re: Internett speed
Post by Safan on Fri Sep 04, 2009 8:15 pm
To monitor how fast you are downloading, you can download a Gadget for Windows Sidebar called Network Meter from http://addgadget.com/
In WoW you can press Ctrl + R to check the Frames per Second. This is not exactly how much it is downloading but it shows how fast the game is running on your computer. The higher the value, the higher the memory usage is. If the value is high and you appear to move very slowly, then I would recommend trying to lower the graphics in the game.
OS : Windows 7 x64
Re: Internett speed
Post by noornabi on Sun Sep 13, 2009 7:52 pm
dear sir
i have internet dsl modeam we are recievig speed proper but i want's to increase it is there any hacking trick to increase internet speed from server
noornabi
OS : win xp sp2
Re: Internett speed
Post by Doctor Inferno on Mon Sep 14, 2009 3:09 am
You could use 'Open DNS'. They allow you to go through their DNS servers and many have reported a noticeable increase in speed.
They have configuration pages for your OS or hardware router.
http://www.opendns.com/
Secondly, If you’re on Windows, install 'FastCache'.
AnalogX FastCache is a caching DNS server that runs on your local machine and handles any DNS request that your computer makes, from Internet Explorer to your favorite FTP client. Once a query is made, FastCache will override the normal timeout for the item with one that you specify, so instead of saving a query for a couple of seconds, it can save it for a couple of days. Now every time you ask for it again while it's in the cache, it gives it to you instantly.
http://www.analogx.com/CONTENTS/download/network/fc.htm
You could also tweak your internet speed if you are using firefox by doing the following:
in the address bar type in about:config >> in the filter bar type in pipe under network.http.pipelining >> right click toogle >> under network.http.pipelining.maxrequests >> right click >> Modify and change the value to 30.
This makes firefox use 30 connections instead of just 4. making your surfing speed slightly faster.
Re: Internett speed
Post by venus89 on Mon Nov 25, 2013 11:42 am
@colin93 wrote:Am having problems with my internet and i wanna know how fast it is when downloading, even when am playing a game like wow. And if its low how can increase the speed? Smile
You can check your internet speed from the site ScanMySpeed.com It helps to check your internet speed accurately.
If your internet speed is slow you need not worry ,Use the following tips given below and increase your internet speed easily.
1.clear your cookies from your browser
2.Delete unwanted files
3.PC Optimization:
It is important to clean your PC regularly. It means a normal maintenance tasks such as, cleaning the disks, registry repairs and Disk Derangement.
4.If you are using a DSL connection over your landline, make sure that you have high-quality filters in place to get optimum signal speed.
5.Upgrade your modem.
6. Use Updated browser.
7.Consult with your Internet service provider to ensure that your modem is configured correctly.
8.Replace your telephone modem with a fast-access connection such as wave, ISDN, DSL, satellite, a cable modem.
9.Tweak our router settings
10.Install Antivirus Software.
11.Reduce our bandwidth overhead
After, completing this steps, you can check our internet speed whether increase or not using the site which i mentioned above.
venus89
OS : windows 7
