Antivirus System Pro
Post by bstwndws on 4th September 2009, 6:00 pm
My computer with Windows XP is infected with Antivirus System Pro. Tried to go to Microsoft Windows website to download their Malware Removal Software, but I got an "IE cannot display the web page" message. Even the websites that was being popped on me by the virus cannot be displayed. I finally downloaded abovementioned malware software from Microsoft Windows using a friend's computer onto a cd and used it to scan my infected computer under safe mode. It found 5 files infected, but when I when to normal mode the infection is still there.
Any help would be greatly appreciated. Thanks a lot.
bstwndws
Joined Joined : 2009-09-04
Points Points : 26554
Re: Antivirus System Pro
Post by Belahzur on 4th September 2009, 9:39 pm
Points Points : 245121
Post by bstwndws on 4th September 2009, 11:35 pm
Dear Belahzur,
Thanks for your response.
How will I download HijackThis when it blocks my IE connection? Everytime I click it, it just gives me the message that IE cannot display this web page (my default IE web page).
bstwndws
Post by Belahzur on 5th September 2009, 7:45 pm
See if this version will work instead.
