Malwarebytes' Anti-Malware problem
Post by shimmeringmisty on 1st September 2009, 10:24 am
I'm pretty new here (though I've come here once for help to remove a nasty trojan). I downloaded the Malwarebytes' Anti-Malware before and it worked like a charm. I've been using it periodically ever since to ensure I have no more problems with that kind of stuff. My problem is though, just about two hours ago, the program doesn't work anymore. I opened it up, started a quick scan, and then it simply disappeared. When I tried to click on it again, I kept getting this message:
I've done nothing to change the program whatsoever. I have no idea what's causing this. I tried uninstalling and reinstalling it, but I still get the same result.
I've already installed the java update and the winlogin suggested on the [You must be registered and logged in to see this link.] page, and I recently updated my adobe previously. I primarily use Firefox, but still have Explorer as a backup, and I'm running on Windows XP.
Now, I'm not exactly computer savvy, but I get the feeling there is something wrong, and I would really like to stop the problem (if there is one) before it gets worse. I would greatly appreciate any help on this and thank you in advance.
By the way, I'm not sure this is under the correct topic, and I apologize in advance if it is.
shimmeringmisty
Posts Posts : 25
Joined Joined : 2009-09-01
Points Points : 26855
Re: Malwarebytes' Anti-Malware problem
Post by Belahzur on 1st September 2009, 5:20 pm
Lets fix that error.
    :filefind
    scecli.dll
    netlogon.dll
    eventlog.dll
Points Points : 245111
Post by shimmeringmisty on 1st September 2009, 7:48 pm
SystemLook v1.0 by jpshortstuff (29.08.09)
Log created at 14:18 on 01/09/2009 by Owner (Administrator - Elevation successful)
Searching for "scecli.dll"
C:\My Backup -- 08-08-25 0344AM\WINDOWS\system32\scecli.dll --a--- 180224 bytes [08:37 25/05/2008] [19:00 10/08/2004] 0F78E27F563F2AAF74B91A49E2ABF19A
C:\My Backup -- 09-03-16 0139AM\WINDOWS\SoftwareDistribution\Download\cf8ec753e88561d2ddb53e183dc05c3e\scecli.dll --a--- 181248 bytes [02:41 07/09/2008] [00:12 14/04/2008] A86BB5E61BF3E39B62AB4C7E7085A084
C:\My Backup -- 09-03-16 0139AM\WINDOWS\system32\scecli.dll --a--- 180224 bytes [08:37 25/05/2008] [19:00 10/08/2004] 0F78E27F563F2AAF74B91A49E2ABF19A
C:\WINDOWS\SoftwareDistribution\Download\e9500597a78495f397efb821e37bf356\scecli.dll --a--- 181248 bytes [11:27 16/03/2009] [00:12 14/04/2008] A86BB5E61BF3E39B62AB4C7E7085A084
C:\WINDOWS\system32\scecli.dll --a--- 180224 bytes [08:37 25/05/2008] [19:00 10/08/2004] 0F78E27F563F2AAF74B91A49E2ABF19A
Searching for "netlogon.dll"
C:\My Backup -- 08-08-25 0344AM\WINDOWS\system32\netlogon.dll --a--- 407040 bytes [08:36 25/05/2008] [19:00 10/08/2004] 96353FCECBA774BB8DA74A1C6507015A
C:\My Backup -- 09-03-16 0139AM\WINDOWS\SoftwareDistribution\Download\cf8ec753e88561d2ddb53e183dc05c3e\netlogon.dll --a--- 407040 bytes [02:40 07/09/2008] [00:12 14/04/2008] 1B7F071C51B77C272875C3A23E1E4550
C:\My Backup -- 09-03-16 0139AM\WINDOWS\system32\netlogon.dll --a--- 407040 bytes [08:36 25/05/2008] [19:00 10/08/2004] 96353FCECBA774BB8DA74A1C6507015A
C:\WINDOWS\$NtUninstallKB968389$\netlogon.dll -----c 407040 bytes [07:00 13/08/2009] [19:00 10/08/2004] 96353FCECBA774BB8DA74A1C6507015A
C:\WINDOWS\SoftwareDistribution\Download\e9500597a78495f397efb821e37bf356\netlogon.dll --a--- 407040 bytes [11:26 16/03/2009] [00:12 14/04/2008] 1B7F071C51B77C272875C3A23E1E4550
C:\WINDOWS\system32\dllcache\netlogon.dll -----c 408064 bytes [18:46 06/02/2009] [18:46 06/02/2009] 6C476D33D82F1054849790181E8F7772
C:\WINDOWS\system32\netlogon.dll --a--- 408064 bytes [08:36 25/05/2008] [18:46 06/02/2009] 6C476D33D82F1054849790181E8F7772
Searching for "eventlog.dll"
C:\My Backup -- 08-08-25 0344AM\WINDOWS\system32\eventlog.dll --a--- 55808 bytes [08:33 25/05/2008] [19:00 10/08/2004] 82B24CB70E5944E6E34662205A2A5B78
C:\My Backup -- 09-03-16 0139AM\WINDOWS\SoftwareDistribution\Download\cf8ec753e88561d2ddb53e183dc05c3e\eventlog.dll --a--- 56320 bytes [02:39 07/09/2008] [00:11 14/04/2008] 6D4FEB43EE538FC5428CC7F0565AA656
C:\My Backup -- 09-03-16 0139AM\WINDOWS\system32\eventlog.dll --a--- 55808 bytes [08:33 25/05/2008] [19:00 10/08/2004] 82B24CB70E5944E6E34662205A2A5B78
C:\WINDOWS\SoftwareDistribution\Download\e9500597a78495f397efb821e37bf356\eventlog.dll --a--- 56320 bytes [11:25 16/03/2009] [00:11 14/04/2008] 6D4FEB43EE538FC5428CC7F0565AA656
C:\WINDOWS\system32\eventlog.dll --a--- 62464 bytes [08:33 25/05/2008] [19:00 10/08/2004] (Unable to calculate MD5)
-=End Of File=-
shimmeringmisty
Posts Posts : 25
Post by Belahzur on 2nd September 2009, 12:30 am
Files to delete:
Post by shimmeringmisty on 2nd September 2009, 12:52 am
Platform: Windows XP
Rootkit scan active.
No rootkits found!
File "C:\WINDOWS\system32\eventlog.dll" deleted successfully.
Completed script processing.
Finished! Terminate.
shimmeringmisty
Posts Posts : 25
Post by Belahzur on 2nd September 2009, 1:05 am
The restrictions on programs is now gone, but the malware has left it's mark.
MBAM is corrupted, please uninstall, because were gonna need to re-install it.
Post by shimmeringmisty on 2nd September 2009, 1:43 am
Malwarebytes' Anti-Malware 1.40
Database version: 2728
9/1/2009 9:37:26 PM
mbam-log-2009-09-01 (21-37-26).txt
Objects scanned: 96859
Time elapsed: 8 minute(s), 38 second(s)
Registry Keys Infected: 9
Registry Values Infected: 2
Files Infected: 10
HKEY_CLASSES_ROOT\xml.xml (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{500bca15-57a7-4eaf-8143-8c619470b13d} (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{500bca15-57a7-4eaf-8143-8c619470b13d} (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{500bca15-57a7-4eaf-8143-8c619470b13d} (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\xml.xml.1 (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Typelib\{56acb669-4139-5611-cbba-f5acb0f4db09} (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Monopod (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\NordBull (Malware.Trace) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\XML (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\Monopod (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\System Tool (Fake.SystemTool) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\msxml71.dll (Trojan.FakeAlert) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\xa.tmp (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\ytasfwtumwkkst.sys (Trojan.TDSS) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\wbem\proquota.exe (Trojan.Dropper) -> Quarantined and deleted successfully.
C:\Documents and Settings\Owner\Local Settings\Temp\ytasfwerxnppecxf.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Documents and Settings\Owner\Local Settings\Temp\ytasfwfadmwrievb.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Documents and Settings\Owner\Local Settings\Temporary Internet Files\Content.IE5\CVQWOOA8\xi[1] (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\WINDOWS\Tasks\{7B02EF0B-A410-4938-8480-9BA26420A627}.job (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\WINDOWS\Tasks\{BB65B0FB-5712-401b-B616-E69AC55E2757}.job (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\Documents and Settings\Owner\Desktop\winlogon.exe (Heuristics.Reserved.Word.Exploit) -> Quarantined and deleted successfully.
shimmeringmisty
Posts Posts : 25
