GeekPolice is a website which provides free Computer Technical Support & Virus/Spyware Removal to our members.
Take 30 seconds to register below and unlock the limitations of this website to discover new computer knowledge!
IDT Audio system tray application probelm
Post by ryanjo79 on Sun 30 Aug 2009, 4:49 pm
Every time I log onto my computer I keep getting the error that my IDT Audio system tray has encountered a problem and needs to be shut down. My choices are either: send error report, don't send or cancel. How do I fix this problem?
ryanjo79
Operating System: Windows XP Home Edition
Re: IDT Audio system tray application probelm
Post by AuroraRange on Mon 31 Aug 2009, 8:04 am
Try reinstalling ur idt driver.
Tech Advisor
Tech Advisor
Operating System: Xubuntu & Windows 7
Post by ryanjo79 on Mon 31 Aug 2009, 10:18 am
I don't even have a disk for this how would I find this driver?
ryanjo79
Post by AuroraRange on Mon 31 Aug 2009, 12:47 pm
Tech Advisor
Tech Advisor
IDT Audio Driver Problem
Post by Knollwooder on Thu 10 Dec 2009, 12:58 pm
I am also having the same problem, an error message which states that the IDT Audio system tray application is having difficulty. I have read the replies to the original question but they are not clear to me. Where do I find the referenced driver?
Knollwooder
Unborn
Unborn
Operating System: XP
Post by gdowns on Mon 01 Feb 2010, 5:45 pm
I have encountered the same problem with my comuter. I reloaded the Dell Driver R114282 and the problem continues. Please advise what to do next.
I even took advice from another website and purchased Registry Mechanic. That found and fixed a lot of problems but it did nothing for this issue.
gdowns
Unborn
Unborn
Operating System: Windows XP Professional
IDT Audio System Tray Error **Fix**
Post by RUSerious on Tue 15 Jun 2010, 4:38 pm
First download the proper Sigmatel driver from Dell ...... support.dell.com
Click on Drivers and downloads/click on service tag and type in your service tag number
Look on the back of your computer for the service tag number
Next uninstall the Sigmatel driver in device manager
Then go to control panel, Add/Remove Programs and uninstall the Sigmatel program
Then install the driver you downloaded from Dell
restart your computer
Problem should be resolved
RUSerious
Unborn
Unborn
