Remove BlockDefense (Block Defense) [Removal Guide]
Page 1 of 1 • Share •
This guide will give you easy instructions on how to remove BlockDefense for free.
What is BlockDefense? (Information)
BlockDefense is a fake security software which uses fraudulent strategies by displaying false or exaggerated security issues on your computer rather than any legitimate ones to coerce you into purchasing their software.
BlockDefense is a new malicious specimen from the same family of rouge anti-spyware as SaveKeep, SaveSoldier, TrustNinja and SaveDefense. This rouge anti-spyware uses similar infiltration techniques as it's successors mentioned above.
BlockDefense Registry Keys, Values, Files and Folders
1. Please download this tool; Malwarebytes' Anti-Malware.
2. Install Malwarebytes' Anti-Malware by double clicking on mbam-setup.exe
4. Malwarebytes' Anti-Malware will automatically update itself after the install, you can press the OK button to close that box and you will now be at the main program as shown below.
If you are having problems with the updater, you can use this link to manually update Malwarebytes' Anti-Malware with the latest database
5. Close ALL open Windows, Programs, File or Folders.
6. Make sure you are on the Scanner tab. Select Perform quick scan then click the Scan button as shown above.
8. When the scan is finished a message box will appear, click Ok to continue.
9. Click Show Results.
11. Click on Remove seletced
12. When removing the files, Malwarebytes' Anti-Malware may require you to restart the computer in order to do a complete removal. If it displays a message stating that it needs to restart, please allow it to do so.
13. After that you can close the Malwarebytes' Anti-Malware window, your computer is now cleaned.
To protect your computer from future threats like this, you may want to consider purchasing the Pro version of Malwarebytes' Anti-Malware with real-time protection from this link.
If you are still experiencing problems or difficulties following this guide or require any assistance removing this software, please post your questions in our Virus, Spyware & Malware Removal forums for free help.
You have to be logged in to post questions. Registration is free. By registering you are privileged to other virus removal resources in future.
- %Temp%\nsm2.tmp\nsProcess.dll
- %Temp%\nsm2.tmp\nsSCM.dll
- %Documents and Settings%\All Users\Desktop\BlockDefense.lnk
- %Documents and Settings%\All Users\Start Menu\Programs\BlockDefense\1 BlockDefense.lnk
- %Documents and Settings%\All Users\Start Menu\Programs\BlockDefense\2 BlockDefense.lnk
- %Documents and Settings%\All Users\Start Menu\Programs\BlockDefense\3 BlockDefense.lnk
- %ProgramFiles%\BlockDefense Software\BlockDefense
- %ProgramFiles%\BlockDefense Software\BlockDefense\data.bin
- %ProgramFiles%\BlockDefense Software\BlockDefense\license.txt
- %ProgramFiles%\BlockDefense Software\BlockDefense\BlockDefense.exe
- %ProgramFiles%\BlockDefense Software\BlockDefense\BlockDefenseSvc.exe
- %ProgramFiles%\BlockDefense Software\BlockDefense\uninstall.exe
- HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\BlockDefense
- HKEY_LOCAL_MACHINE\SOFTWARE\BlockDefense
- HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Enum\Root\LEGACY_BLOCKDEFENSESVC
- HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Enum\Root\LEGACY_BLOCKDEFENSESVC\0000
- HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Enum\Root\LEGACY_BLOCKDEFENSESVC\0000\Control
- HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\BlockDefenseSvc
- HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\BlockDefenseSvc\Security
- HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\BlockDefenseSvc\Enum
- HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root\LEGACY_BLOCKDEFENSESVC
- HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root\LEGACY_BLOCKDEFENSESVC\0000
- HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root\LEGACY_BLOCKDEFENSESVC\0000\Control
- HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\BlockDefenseSvc
- HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\BlockDefenseSvc\Security
- HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\BlockDefenseSvc\Enum
- Spoiler:
- Malwarebytes' Anti-Malwares' latest database
Doctor Inferno- The GeekPolice
Similar topics» Boarding Guide
» Strategical Guide
» FORCE BLADER GUIDE
» Sector And Universe Trader Guide
» How to remove or uninstall: WhiteSmoke Translator & other products
» Strategical Guide
Page 1 of 1
by
