Many different problems...
Re: Many different problems...
Post by Filbert on 12th September 2009, 5:19 pm
IE: E&xport to Microsoft Excel - c:\progra~1\MICROS~3\OFFICE11\EXCEL.EXE/3000
IE: Save YouTube Video as MP3 - c:\program files\Common Files\DVDVideoSoft\Dll\IEContextMenuY.dll/scriptY2MP3.htm
Trusted Zone: internet
Trusted Zone: mcafee.com
DPF: {4A116A80-85B6-4299-A018-A717FD7AC66A} - [You must be registered and logged in to see this link.]
FF - ProfilePath - c:\documents and settings\Gen-XDM(Games)\Application Data\Mozilla\Firefox\Profiles\b59ir2fc.default\
FF - component: c:\program files\Common Files\DVDVideoSoft\Dll\FFContextMenuY\components\FFContextMenu.dll
FF - plugin: c:\documents and settings\Gen-XDM(Games)\Application Data\Mozilla\Firefox\Profiles\b59ir2fc.default\extensions\flashplugin@idm\platform\WINNT\plugins\npidmdcp.dll
FF - plugin: c:\program files\Mozilla Firefox\plugins\npPandoWebInst.dll
FF - plugin: c:\program files\Mozilla Firefox\plugins\npViewpoint.dll
FF - plugin: c:\program files\Veoh Networks\VeohWebPlayer\NPVeohTVPlugin.dll
FF - plugin: c:\program files\Veoh Networks\VeohWebPlayer\npWebPlayerVideoPluginATL.dll
---- FIREFOX POLICIES ----
FF - user.js: dom.disable_open_during_load - true // Popupblocker control handled by McAfee Privacy Service
Rootkit scan 2009-09-12 10:05
[HKEY_USERS\S-1-5-21-1757981266-73586283-682003330-1005\Software\SecuROM\!CAUTION! NEVER A OR CHANGE ANY KEY*]
"??"=hex:49,70,bf,89,43,80,00,60,e8,c0,f1,02,43,23,c0,71,92,41,2f,74,a8,e8,9f,
14,2b,7e,1b,d9,a8,8b,d5,70,29,3a,bc,ba,90,56,8d,82,6c,a0,59,f9,99,25,9b,80,\
"??"=hex:69,6f,5c,46,6a,89,f9,ee,2d,48,e0,10,87,42,1e,12
[HKEY_USERS\S-1-5-21-1757981266-73586283-682003330-1005\Software\SecuROM\License information*]
"datasecu"=hex:57,55,ca,37,66,73,a0,1c,6c,fb,05,97,b3,f2,fb,ef,5d,d1,c3,c1,67,
94,24,ee,53,ff,5f,91,ac,e4,a1,84,73,b6,d6,73,ef,9d,b9,d3,36,f7,33,70,f8,05,\
"rkeysecu"=hex:9c,97,c0,28,b2,82,bf,30,cf,c9,48,b5,21,79,88,44
- - - - - - - > 'explorer.exe'(3252)
c:\progra~1\WINDOW~2\wmpband.dll
c:\program files\ArcSoft\PhotoImpression 5\share\pihook.dll
c:\program files\Ahead\InCD\InCDsrv.exe
c:\program files\Airlink101\AWLL5025\AWLL5025.exe
c:\progra~1\McAfee\MSC\mcmscsvc.exe
c:\progra~1\COMMON~1\McAfee\MNA\McNASvc.exe
c:\progra~1\COMMON~1\McAfee\McProxy\McProxy.exe
c:\progra~1\McAfee\VIRUSS~1\Mcshield.exe
c:\program files\McAfee\MPF\MpfSrv.exe
c:\nexon\MapleStory\npkcmsvc.exe
c:\windows\system32\PnkBstrA.exe
c:\windows\system32\PnkBstrB.exe
c:\progra~1\McAfee.com\Agent\mcagent.exe
c:\program files\AIM6\aolsoftware.exe
Completion time: 2009-09-12 10:10 - machine was rebooted
ComboFix-quarantined-files.txt 2009-09-12 17:09
ComboFix2.txt 2009-09-08 02:26
Pre-Run: 89,891,467,264 bytes free
Post-Run: 89,882,140,672 bytes free
320 --- E O F --- 2009-09-09 01:40
Filbert
Posts Posts : 22
Joined Joined : 2009-08-26
Points Points : 26647
Post by Belahzur on 12th September 2009, 11:10 pm
ComboFix /u
Points Points : 245101
Post by Filbert on 13th September 2009, 2:15 am
Great, it's no longer making loud noises when it starts up. Big Grin
Filbert
Posts Posts : 22
Post by Filbert on 13th September 2009, 4:23 pm
^ I take that back ^
It's still making noises on startup, I can't run a virus scan and it wont connect to the internet.
Filbert
Posts Posts : 22
Post by Belahzur on 14th September 2009, 12:09 am
Can you explain better? what does the noise sound like?
  1. Unzip it and start GMER.
