Many different problems...
Post by Filbert on Fri Aug 28, 2009 3:04 pm
I've downloaded a rather nasty virus.
It has disabled all virus scanning.
It has dissabled HijackThis
75% of the time it will restart my computer or freeze when I log in.
It will randomly restart my computer.
It will not allow me to get to some websites directly and some indirectly. (I either have to google the website or type it in the bar)
It opens Internet Explorer in an invisible window and plays television audio.
Filbert
OS : Windows XP
Re: Many different problems...
Post by Filbert on Mon Aug 31, 2009 4:14 am
Bump
Filbert
OS : Windows XP
Post by Belahzur on Mon Aug 31, 2009 5:36 pm
    :filefind
    scecli.dll
    netlogon.dll
    eventlog.dll
Post by Filbert on Mon Aug 31, 2009 10:30 pm
Searching for "scecli.dll"
C:\WINDOWS\SoftwareDistribution\Download\dd9ab5193501484cf5e6884fa1d22f9e\scecli.dll --a--- 181248 bytes [22:40 03/09/2008] [00:12 14/04/2008] A86BB5E61BF3E39B62AB4C7E7085A084
C:\WINDOWS\system32\dllcache\scecli.dll --a--c 180224 bytes [12:00 04/08/2004] [12:00 04/08/2004] 0F78E27F563F2AAF74B91A49E2ABF19A
C:\WINDOWS\system32\scecli.dll --a--- 180224 bytes [12:00 04/08/2004] [12:00 04/08/2004] 0F78E27F563F2AAF74B91A49E2ABF19A
Searching for "netlogon.dll"
C:\WINDOWS\$hf_mig$\KB968389\SP2QFE\netlogon.dll --a--- 408064 bytes [18:46 06/02/2009] [18:46 06/02/2009] 6C476D33D82F1054849790181E8F7772
C:\WINDOWS\SoftwareDistribution\Download\dd9ab5193501484cf5e6884fa1d22f9e\netlogon.dll --a--- 407040 bytes [22:39 03/09/2008] [00:12 14/04/2008] 1B7F071C51B77C272875C3A23E1E4550
C:\WINDOWS\system32\dllcache\netlogon.dll --a--c 407040 bytes [12:00 04/08/2004] [12:00 04/08/2004] 96353FCECBA774BB8DA74A1C6507015A
C:\WINDOWS\system32\netlogon.dll --a--- 407040 bytes [12:00 04/08/2004] [12:00 04/08/2004] 96353FCECBA774BB8DA74A1C6507015A
Searching for "eventlog.dll"
C:\WINDOWS\SoftwareDistribution\Download\dd9ab5193501484cf5e6884fa1d22f9e\eventlog.dll --a--- 56320 bytes [22:38 03/09/2008] [00:11 14/04/2008] 6D4FEB43EE538FC5428CC7F0565AA656
C:\WINDOWS\system32\dllcache\eventlog.dll --a--c 55808 bytes [12:00 04/08/2004] [12:00 04/08/2004] 82B24CB70E5944E6E34662205A2A5B78
C:\WINDOWS\system32\eventlog.dll --a--- 62976 bytes [12:00 04/08/2004] [12:00 04/08/2004] (Unable to calculate MD5)
-=End Of File=-
Filbert
OS : Windows XP
Post by Belahzur on Tue Sep 01, 2009 5:47 pm
Files to delete:
Post by Filbert on Tue Sep 01, 2009 11:40 pm
Avenger Pre-Processor log
Platform: Windows XP (build 2600, Service Pack 2)
Tue Sep 01 15:57:28 2009
15:57:28: Error: Invalid script. A valid script must begin with a command directive.
Aborting execution!
Rootkit scan active.
Hidden driver "a2htv6qj" found!
Could not open driver a2htv6qj for rootkit scan. Error:c0000034 (STATUS_OBJECT_NAME_NOT_FOUND)
--> the object does not exist
Rootkit scan completed.
File "C:\WINDOWS\system32\eventlog.dll" deleted successfully.
Completed script processing.
Now google is redirecting me to random sites
Filbert
OS : Windows XP
Post by Belahzur on Wed Sep 02, 2009 12:42 am
Delete the Hijack This you have now, it's corrupted by the malware. Now that patched file is gone, the restrictions go with it, we can work with tools now.
Please download Hijack This from here:
Run it, do a system scan with logfile.
Post by Filbert on Wed Sep 02, 2009 1:52 am
Scan saved at 6:52:28 PM, on 9/1/2009
C:\Program Files\Ahead\InCD\InCDsrv.exe
C:\Program Files\Airlink101\AWLL5025\WLService.exe
C:\Program Files\Airlink101\AWLL5025\AWLL5025.exe
c:\PROGRA~1\COMMON~1\mcafee\mna\mcnasvc.exe
C:\Nexon\MapleStory\npkcmsvc.exe
C:\WINDOWS\system32\PnkBstrA.exe
C:\WINDOWS\system32\PnkBstrB.exe
C:\Program Files\Ahead\InCD\InCD.exe
C:\WINDOWS\system32\RunDll32.exe
C:\WINDOWS\system32\atwtusb.exe
C:\WINDOWS\system32\spool\drivers\w32x86\3\hpztsb07.exe
C:\WINDOWS\system32\hphmon04.exe
C:\Program Files\PeerGuardian2\pg2.exe
C:\Program Files\AIM6\aim6.exe
C:\Program Files\Veoh Networks\VeohWebPlayer\veohwebplayer.exe
C:\Program Files\IC Media Corp\ICM532\Launchpad.exe
C:\Program Files\AIM6\aolsoftware.exe
C:\Program Files\Microsoft Office\OFFICE11\WINWORD.EXE
C:\Program Files\Internet Explorer\Iexplore.exe
C:\Documents and Settings\Gen-XDM(Games)\Desktop\winlogon(2).exe
O2 - BHO: scriptproxy - {7DB2D5A0-7241-4E79-B68D-6309F01C5231} - C:\Program Files\McAfee\VirusScan\scriptsn.dll
O2 - BHO: SingleInstance Class - {FDAD4DA1-61A2-4FD8-9C17-86F7AC245081} - C:\PROGRA~1\Yahoo!\Companion\Installs\cpn\YTSingleInstance.dll
O3 - Toolbar: Veoh Web Player Video Finder - {0FBB9689-D3D7-4f7a-A2E2-585B10099BFC} - C:\Program Files\Veoh Networks\VeohWebPlayer\VeohIEToolbar.dll
O4 - HKLM\..\Run: [NeroFilterCheck] C:\WINDOWS\system32\NeroCheck.exe
O4 - HKLM\..\Run: [InCD] C:\Program Files\Ahead\InCD\InCD.exe
O4 - HKLM\..\Run: [CmPCIaudio] RunDll32 CMICNFG3.CPL,CMICtrlWnd
O4 - HKLM\..\Run: [EPSON Stylus CX6400] C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\E_S4I2L1.EXE /P19 "EPSON Stylus CX6400" /O6 "USB001" /M "Stylus CX6400"
O4 - HKLM\..\Run: [atwtusb] atwtusb.exe beta
O4 - HKLM\..\Run: [HPDJ Taskbar Utility] C:\WINDOWS\system32\spool\drivers\w32x86\3\hpztsb07.exe
O4 - HKLM\..\Run: [HPHmon04] C:\WINDOWS\system32\hphmon04.exe
O4 - HKLM\..\Run: [HPHUPD04] "C:\Program Files\HP Photosmart 11\hphinstall\UniPatch\hphupd04.exe"
O4 - HKLM\..\Run: [mcinfo_1196897665] C:\DOCUME~1\GEN-XD~1\LOCALS~1\Temp\mcinfo_1196897665.exe /insfin
O4 - HKLM\..\Run: [PWRISOVM.EXE] C:\Program Files\PowerISO\PWRISOVM.EXE
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\system32\NvMcTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [UserFaultCheck] %systemroot%\system32\dumprep 0 -u
O4 - HKCU\..\Run: [PeerGuardian] C:\Program Files\PeerGuardian2\pg2.exe
O4 - HKCU\..\Run: [Aim6] "C:\Program Files\AIM6\aim6.exe" /d locale=en-US [You must be registered and logged in to see this link.]
O4 - HKCU\..\Run: [DAEMON Tools] "C:\Program Files\DAEMON Tools\daemon.exe" -lang 1033
O4 - HKCU\..\Run: [Uniblue RegistryBooster 2009] C:\Program Files\Uniblue\RegistryBooster\RegistryBooster.exe /S
O4 - HKCU\..\Run: [VeohPlugin] "C:\Program Files\Veoh Networks\VeohWebPlayer\veohwebplayer.exe"
O4 - HKCU\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\QTTask.exe" -atboottime
O4 - HKCU\..\Run: [Monopod] C:\DOCUME~1\GEN-XD~1\LOCALS~1\Temp\b.exe
O4 - HKUS\S-1-5-18\..\Run: [SansaDispatch] C:\Documents and Settings\LocalService\Application Data\SanDisk\Sansa Updater\SansaDispatch.exe (User 'SYSTEM')
O4 - HKUS\S-1-5-18\..\RunOnce: [RunNarrator] Narrator.exe (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [SansaDispatch] C:\Documents and Settings\LocalService\Application Data\SanDisk\Sansa Updater\SansaDispatch.exe (User 'Default user')
O4 - HKUS\.DEFAULT\..\RunOnce: [RunNarrator] Narrator.exe (User 'Default user')
O4 - Startup: Adobe Media Player.lnk = C:\Program Files\Adobe Media Player\Adobe Media Player.exe
O4 - Global Startup: Adobe Gamma Loader.lnk = C:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe
O4 - Global Startup: Launchpad.lnk = ?
O8 - Extra context menu item: Save YouTube Video as MP3 - [You must be registered and logged in to see this link.] Files\Common Files\DVDVideoSoft\Dll\IEContextMenuY.dll/scriptY2MP3.htm
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~3\OFFICE11\REFIEBAR.DLL
O9 - Extra button: ShopperReports - Compare product prices - {C5428486-50A0-4a02-9D20-520B59A9F9B2} - C:\Program Files\ShoppingReport\Bin\2.5.0\ShoppingReport.dll (file missing)
O9 - Extra button: ShopperReports - Compare travel rates - {C5428486-50A0-4a02-9D20-520B59A9F9B3} - C:\Program Files\ShoppingReport\Bin\2.5.0\ShoppingReport.dll (file missing)
O16 - DPF: {2DFF31F9-7893-4922-AF66-C9A1EB4EBB31} (Rhapsody Player Engine) - [You must be registered and logged in to see this link.]
O16 - DPF: {39B0684F-D7BF-4743-B050-FDC3F48F7E3B} - [You must be registered and logged in to see this link.]
O16 - DPF: {48DD0448-9209-4F81-9F6D-D83562940134} (MySpace Uploader Control) - [You must be registered and logged in to see this link.]
O16 - DPF: {4A116A80-85B6-4299-A018-A717FD7AC66A} (AXIDMDCP Class) - [You must be registered and logged in to see this link.]
O16 - DPF: {54B52E52-8000-4413-BD67-FC7FE24B59F2} (EARTPatchX Class) - [You must be registered and logged in to see this link.]
O16 - DPF: {70BA88C8-DAE8-4CE9-92BB-979C4A75F53B} (GSDACtl Class) - [You must be registered and logged in to see this link.]
O16 - DPF: {AB86CE53-AC9F-449F-9399-D8ABCA09EC09} (Get_ActiveX Control) - [You must be registered and logged in to see this link.]
O16 - DPF: {D1548A26-B8F6-4E86-AE74-E7062CCC2E2A} (igLoader Content on Demand) - [You must be registered and logged in to see this link.]
O16 - DPF: {D4323BF2-006A-4440-A2F5-27E3E7AB25F8} - [You must be registered and logged in to see this link.]
O16 - DPF: {E13F1132-4CA0-4005-84D3-51406E27D269} (BTDownloadCtrl Control) - [You must be registered and logged in to see this link.]
O16 - DPF: {EB387D2F-E27B-4D36-979E-847D1036C65D} (QDiagHUpdateObj Class) - [You must be registered and logged in to see this link.]
O20 - AppInit_DLLs: WIKI.DLL igxzuk.dll snzejl.dll
O23 - Service: Airlink101 USB XR Adapter WLService - Unknown owner - C:\Program Files\Airlink101\AWLL5025\WLService.exe
O23 - Service: InCD Helper (InCDsrv) - Nero AG - C:\Program Files\Ahead\InCD\InCDsrv.exe
O23 - Service: InCD Helper (read only) (InCDsrvR) - Nero AG - C:\Program Files\Ahead\InCD\InCDsrv.exe
O23 - Service: McAfee Scanner (McODS) - Unknown owner - C:\PROGRA~1\McAfee\VIRUSS~1\mcods.exe
O23 - Service: nProtect GameGuard Service (npggsvc) - Unknown owner - C:\WINDOWS\system32\GameMon.des.exe (file missing)
O23 - Service: npkcmsvc - INCA Internet Co., Ltd. - C:\Nexon\MapleStory\npkcmsvc.exe
O23 - Service: Pml Driver HPH11 - HP - C:\WINDOWS\system32\HPHipm11.exe
O23 - Service: PnkBstrA - Unknown owner - C:\WINDOWS\system32\PnkBstrA.exe
O23 - Service: PnkBstrB - Unknown owner - C:\WINDOWS\system32\PnkBstrB.exe
O23 - Service: Sansa Updater Service (SansaService) - Unknown owner - C:\Program Files\Sandisk\Sansa Updater\SansaSvr.exe
O23 - Service: PC Tools Auxiliary Service (sdAuxService) - PC Tools - C:\Program Files\Spyware Doctor\pctsAuxs.exe
O23 - Service: PC Tools Security Service (sdCoreService) - Unknown owner - C:\Program Files\Spyware Doctor\pctsSvc.exe
O23 - Service: Viewpoint Manager Service - Unknown owner - C:\Program Files\Viewpoint\Common\ViewpointService.exe (file missing)
End of file - 12912 bytes
Filbert
OS : Windows XP
Post by Belahzur on Wed Sep 02, 2009 1:03 pm
Post by Filbert on Wed Sep 02, 2009 10:40 pm
I can't open MBAM.
Filbert
OS : Windows XP
Post by Belahzur on Wed Sep 02, 2009 11:53 pm
  • Download combofix from here
Post by Filbert on Thu Sep 03, 2009 1:02 am
CFScript Name Error
Were you trying to run CFScript?
The name, CFScript appears to be incorrectly spelt.
Filbert
OS : Windows XP
Post by Belahzur on Thu Sep 03, 2009 3:11 pm
That doesn't sound right.
Were not using CFScript here. Did you rename Combofix to Combo-Fix?
Post by Filbert on Thu Sep 03, 2009 10:17 pm
Yes, I did. Does it matter that I couldn't save it as an application?
I could only save it as a binary file.
Filbert
OS : Windows XP
Post by Filbert on Mon Sep 07, 2009 2:49 am
Is there anything else I can try?
Filbert
OS : Windows XP
Post by Belahzur on Mon Sep 07, 2009 8:53 pm
Can you try download Combofix via another machine and transport it via USB? It needs to be saved as an application.
Post by Filbert on Tue Sep 08, 2009 2:32 am
ComboFix 09-09-07.03 - Gen-XDM(Games) 09/07/2009 19:04.1.1 - NTFSx86
Microsoft Windows XP Home Edition 5.1.2600.2.1252.1.1033.18.1023.645 [GMT -7:00]
Running from: E:\Combo-Fix.exe
* Created a new restore point
* Resident AV is active
ADS - system32: deleted 40 bytes in 1 streams.
ADS - WINDOWS: deleted 24 bytes in 1 streams.
c:\documents and settings\Gen-XDM(Games)\Application Data\ShoppingReport
c:\documents and settings\Gen-XDM(Games)\Application Data\ShoppingReport\cs\Config.xml
C:\install.exe
c:\windows\desktop
c:\windows\desktop\Instal~1.lnk
c:\windows\Installer\10978fbb.msp
c:\windows\Installer\13d45cd.msp
c:\windows\Installer\13d96c4c.msp
c:\windows\Installer\13d96c50.msp
c:\windows\Installer\13d96c54.msp
c:\windows\Installer\14e72dcf.msi
c:\windows\Installer\1501134f.msp
c:\windows\Installer\15011353.msp
c:\windows\Installer\15011357.msp
c:\windows\Installer\1501135b.msp
c:\windows\Installer\1501135f.msp
c:\windows\Installer\15011363.msp
c:\windows\Installer\1bb55dea.msp
c:\windows\Installer\216778c.msp
c:\windows\Installer\237a32f.msp
c:\windows\Installer\27a059.msp
c:\windows\Installer\27faa.msi
c:\windows\Installer\28a371.msp
c:\windows\Installer\35602453.msp
c:\windows\Installer\35602457.msp
c:\windows\Installer\3560245b.msp
c:\windows\Installer\3e8d0dc.msp
c:\windows\Installer\4b9a421.msi
c:\windows\Installer\4dd867.msp
c:\windows\Installer\51479.msp
c:\windows\Installer\5147d.msp
c:\windows\Installer\51481.msp
c:\windows\Installer\51485.msp
c:\windows\Installer\51489.msp
c:\windows\Installer\5148d.msp
c:\windows\Installer\51491.msp
c:\windows\Installer\51495.msp
c:\windows\Installer\51499.msp
c:\windows\Installer\5149d.msp
c:\windows\Installer\527c19a.msp
c:\windows\Installer\527c19e.msp
c:\windows\Installer\52d02d1.msp
c:\windows\Installer\52f993.msp
c:\windows\Installer\539b7cf.msp
c:\windows\Installer\539b7d3.msp
c:\windows\Installer\539b7d7.msp
c:\windows\Installer\58cdd07.msp
c:\windows\Installer\58cdd0b.msp
c:\windows\Installer\58cdd0f.msp
c:\windows\Installer\58cdd13.msp
c:\windows\Installer\9546f02b.msp
c:\windows\Installer\9546f02f.msp
c:\windows\Installer\9546f033.msp
c:\windows\Installer\9546f037.msp
c:\windows\Installer\9546f03b.msp
c:\windows\Installer\9546f03f.msp
c:\windows\Installer\9546f043.msp
c:\windows\Installer\9546f047.msp
c:\windows\Installer\9546f04b.msp
c:\windows\Installer\9546f04f.msp
c:\windows\Installer\9546f053.msp
c:\windows\Installer\9edbf.msp
c:\windows\Installer\9edc3.msp
c:\windows\Installer\9ff69e6.msp
c:\windows\Installer\a061f.msp
c:\windows\Installer\acbf27e.msp
c:\windows\Installer\acbf282.msp
c:\windows\Installer\b1c7f1.msp
c:\windows\Installer\b1c7f3.msp
c:\windows\Installer\b3b659f.msp
c:\windows\run.log
c:\windows\system32\9044134.dll
c:\windows\system32\drivers\ss.sys
c:\windows\system32\drivers\UACsodlhtkboc.sys
c:\windows\system32\UAChdwdlnbair.dll
c:\windows\system32\uacinit.dll
c:\windows\system32\UACjcskcjadyf.dll
c:\windows\system32\UACkfkrpxnktv.db
c:\windows\system32\UACmgqskwaalf.dll
c:\windows\system32\UACvmfnoddtfe.dat
c:\windows\system32\UACxdqjusibor.dll
c:\windows\system32\uBbIRXbc.ini
c:\windows\system32\uBbIRXbc.ini2
c:\windows\system32\winio.vxd
-------\Service_UACd.sys
-------\Legacy_UACd.sys
-------\Legacy_{79007602-0CDB-4405-9DBF-1257BB3226EE}
-------\Service_StreamSurge
((((((((((((((((((((((((( Files Created from 2009-08-08 to 2009-09-08 )))))))))))))))))))))))))))))))
2009-08-30 17:27 . 2009-08-30 17:27 20747 ----a-w- c:\windows\system32\drivers\AegisP.sys
2009-08-30 17:27 . 2004-04-30 22:12 40960 ----a-w- c:\windows\system32\AWLL5025.dll
2009-08-30 17:27 . 2003-10-13 22:30 94208 ----a-w- c:\windows\system32\GTW32N50.dll
2009-08-30 17:27 . 2003-09-26 05:15 15872 ----a-w- c:\windows\system32\GTNDIS5.sys
2009-08-28 15:13 . 2009-08-03 20:36 38160 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2009-08-28 15:13 . 2009-08-31 22:37 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
2009-08-28 15:13 . 2009-08-03 20:36 19096 ----a-w- c:\windows\system32\drivers\mbam.sys
2009-08-27 04:04 . 2009-09-06 19:28 -------- d-----w- c:\documents and settings\Rawr\Tracing
2009-08-27 04:04 . 2009-08-27 04:04 -------- d-----w- c:\documents and settings\Rawr\Local Settings\Application Data\Yahoo
2009-08-26 18:24 . 2009-08-26 18:24 -------- d-----w- c:\documents and settings\Gen-XDM(Games)\.housecall6.6
2009-08-26 17:24 . 2009-08-26 17:24 -------- d-----w- c:\documents and settings\Gen-XDM(Games)\Application Data\McAfee
2009-08-26 00:46 . 2009-08-26 00:56 -------- d-----w- c:\documents and settings\All Users\Application Data\SecTaskMan
2009-08-26 00:46 . 2009-08-26 00:56 -------- d-----w- c:\program files\Security Task Manager
2009-08-25 21:09 . 2009-07-08 20:44 79816 ----a-w- c:\windows\system32\drivers\mfeavfk.sys
2009-08-25 21:09 . 2009-07-08 20:44 40552 ----a-w- c:\windows\system32\drivers\mfesmfk.sys
2009-08-25 21:09 . 2009-07-08 20:44 35272 ----a-w- c:\windows\system32\drivers\mfebopk.sys
2009-08-25 21:09 . 2009-07-16 19:32 120136 ----a-w- c:\windows\system32\drivers\Mpfp.sys
2009-08-25 21:08 . 2009-08-25 21:09 -------- d-----w- c:\program files\Common Files\McAfee
2009-08-25 21:08 . 2009-08-25 21:09 -------- d-----w- c:\program files\McAfee.com
2009-08-25 21:08 . 2009-09-01 22:19 -------- d-----w- c:\program files\McAfee
2009-08-25 20:48 . 2009-07-08 20:43 34248 ----a-w- c:\windows\system32\drivers\mferkdk.sys
2009-08-23 02:51 . 2009-08-26 02:48 -------- d-----w- c:\program files\VstPlugins
2009-08-23 02:51 . 2006-06-20 08:56 225280 ----a-w- c:\windows\system32\rewire.dll
2009-08-23 02:50 . 2009-08-23 02:50 -------- d-----w- c:\program files\Outsim
2009-08-23 02:44 . 2009-08-25 23:06 -------- d-----w- c:\program files\Image-Line
2009-08-20 20:39 . 2009-08-20 20:39 -------- d-----w- c:\program files\BlackIsle
2009-08-20 20:35 . 2009-08-20 20:39 52736 ----a-w- c:\windows\ipuninst.exe
2009-08-20 18:30 . 2009-08-20 18:30 -------- d-----w- c:\documents and settings\Gen-XDM(Games)\Application Data\SlySoft
2009-08-20 18:25 . 2009-08-20 18:25 -------- d-----w- c:\documents and settings\All Users\Application Data\SlySoft
2009-08-16 05:42 . 2009-08-16 05:43 -------- d-----w- C:\844daf670dcd1f731db2c24aaa
2009-08-11 22:28 . 2009-08-11 22:28 -------- d-----w- c:\windows\ServicePackFiles
2009-09-07 03:53 . 2009-05-24 19:02 -------- d-----w- c:\program files\Cheat Engine
2009-08-31 03:55 . 2007-12-04 03:07 -------- d-----w- c:\documents and settings\All Users\Application Data\McAfee
2009-08-30 17:27 . 2006-06-03 17:42 -------- d--h--w- c:\program files\InstallShield Installation Information
2009-08-28 20:11 . 2006-06-20 04:40 -------- d-----w- c:\program files\Warcraft III
2009-08-26 19:23 . 2007-02-10 16:38 -------- d---a-w- c:\documents and settings\All Users\Application Data\TEMP
2009-08-26 18:24 . 2008-10-10 21:42 102664 ----a-w- c:\windows\system32\drivers\tmcomm.sys
2009-08-26 17:20 . 2006-12-26 22:15 -------- d-----w- c:\program files\Common Files\Adobe
2009-08-26 04:11 . 2008-08-04 19:48 -------- d-----w- c:\program files\Common Files\DVDVideoSoft
2009-08-26 01:14 . 2009-04-22 21:29 -------- d-----w- c:\program files\PowerISO
2009-08-26 00:31 . 2006-12-12 03:43 -------- d-----w- c:\program files\EA GAMES
2009-08-26 00:31 . 2009-07-19 05:57 -------- d-----w- c:\program files\DivX
2009-08-25 22:26 . 2008-10-14 23:37 -------- d-----w- c:\documents and settings\Gen-XDM(Games)\Application Data\uTorrent
2009-08-25 19:25 . 2007-11-11 00:38 79400 ----a-w- c:\windows\War3Unin.dat
2009-08-25 19:20 . 2006-07-01 19:05 46616 ----a-w- c:\documents and settings\Gen-XDM(Games)\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
2009-08-25 18:42 . 2009-08-25 18:42 784563 ----a-w- c:\windows\system32\xa.tmp
2009-08-24 15:25 . 2008-06-13 13:49 -------- d-----w- c:\program files\Sword of the New World
2009-08-23 18:37 . 2009-07-23 18:20 -------- d-----w- c:\program files\Project64 1.6
2009-08-09 04:48 . 2009-08-08 18:26 -------- d-----w- c:\documents and settings\Gen-XDM(Games)\Application Data\Orbit
2009-08-08 23:57 . 2009-08-08 23:57 -------- d-----w- c:\program files\Trend Micro
2009-08-08 19:07 . 2009-08-08 18:54 -------- d-----w- c:\documents and settings\All Users\Application Data\River Past G5
2009-08-08 18:54 . 2009-08-08 18:54 163513 ----a-w- c:\windows\Audio Converter Uninstaller.exe
2009-08-08 18:54 . 2009-08-08 18:54 -------- d-----w- c:\documents and settings\Gen-XDM(Games)\Application Data\River Past G5
2009-08-08 18:54 . 2009-08-08 18:54 -------- d-----w- c:\program files\Common Files\River Past
2009-08-08 18:54 . 2009-08-08 18:54 -------- d-----w- c:\program files\River Past
2009-08-05 09:11 . 2004-08-04 12:00 204800 ----a-w- c:\windows\system32\mswebdvd.dll
2009-07-27 02:38 . 2006-06-03 17:57 -------- d-----w- c:\program files\Microsoft Games
2009-07-24 18:42 . 2008-07-01 15:57 34 -c--a-w- c:\documents and settings\Gen-XDM(Games)\jagex_runescape_preferences.dat
2009-07-23 18:17 . 2009-01-05 04:26 -------- d-----w- c:\documents and settings\All Users\Application Data\WinZip
2009-07-19 06:06 . 2009-07-19 06:06 -------- d-----w- c:\documents and settings\Gen-XDM(Games)\Application Data\DivX
2009-07-19 05:58 . 2009-07-19 05:57 -------- d-----w- c:\program files\Common Files\DivX Shared
2009-07-17 18:55 . 2004-08-04 12:00 58880 ----a-w- c:\windows\system32\atl.dll
2009-07-14 06:43 . 2004-08-04 12:00 286208 ----a-w- c:\windows\system32\wmpdxm.dll
2009-07-13 19:28 . 2009-07-13 05:08 -------- d-----w- c:\documents and settings\Gen-XDM(Games)\Application Data\Hamachi
2009-07-13 05:07 . 2009-07-13 05:07 25280 ----a-w- c:\windows\system32\drivers\hamachi.sys
2009-07-12 19:32 . 2007-02-08 00:12 43520 ----a-w- c:\windows\system32\CmdLineExt03.dll
2009-07-11 21:33 . 2009-07-11 21:27 -------- d-----w- c:\program files\WinDS PRO
2009-07-11 21:28 . 2009-07-11 21:27 -------- d-----w- c:\documents and settings\All Users\Application Data\WinDS PRO
2009-07-08 20:44 . 2009-07-08 20:44 214024 ----a-w- c:\windows\system32\drivers\mfehidk.sys
2009-07-02 19:01 . 2009-07-01 05:49 139016 ----a-w- c:\windows\system32\drivers\PnkBstrK.sys
2009-07-02 19:01 . 2009-07-01 05:48 189488 ----a-w- c:\windows\system32\PnkBstrB.exe
2009-07-01 05:49 . 2009-07-01 05:49 139152 ----a-w- c:\documents and settings\Gen-XDM(Games)\Application Data\PnkBstrK.sys
2009-07-01 05:48 . 2009-07-01 05:48 75064 ----a-w- c:\windows\system32\PnkBstrA.exe
2009-07-01 05:48 . 2009-07-01 05:48 794408 ----a-w- c:\windows\system32\pbsvc.exe
2009-06-29 16:12 . 2004-08-04 12:00 827392 ----a-w- c:\windows\system32\wininet.dll
2009-06-29 16:12 . 2004-08-04 12:00 78336 ----a-w- c:\windows\system32\ieencode.dll
2009-06-29 16:12 . 2004-08-04 12:00 17408 ----a-w- c:\windows\system32\corpol.dll
2009-06-25 08:44 . 2004-08-04 12:00 724480 ----a-w- c:\windows\system32\lsasrv.dll
2009-06-25 08:44 . 2004-08-04 12:00 59392 ----a-w- c:\windows\system32\wdigest.dll
2009-06-25 08:44 . 2004-08-04 12:00 56320 ----a-w- c:\windows\system32\secur32.dll
2009-06-25 08:44 . 2004-08-04 12:00 298496 ----a-w- c:\windows\system32\kerberos.dll
2009-06-25 08:44 . 2004-08-04 12:00 168448 ----a-w- c:\windows\system32\schannel.dll
2009-06-25 08:44 . 2004-08-04 12:00 133632 ----a-w- c:\windows\system32\msv1_0.dll
2009-06-22 11:34 . 2004-08-04 12:00 92544 ----a-w- c:\windows\system32\drivers\ksecdd.sys
2009-06-21 15:46 . 2006-06-03 17:13 485920 ----a-w- c:\windows\system32\NVUNINST.EXE
2009-06-16 14:55 . 2004-08-04 12:00 82432 ----a-w- c:\windows\system32\fontsub.dll
2009-06-16 14:55 . 2004-08-04 12:00 119808 ----a-w- c:\windows\system32\t2embed.dll
2009-06-12 11:50 . 2004-08-04 12:00 76288 ----a-w- c:\windows\system32\telnet.exe
2009-06-10 14:21 . 2004-08-04 12:00 84992 ----a-w- c:\windows\system32\avifil32.dll
2009-06-10 06:32 . 2004-08-04 12:00 132096 ----a-w- c:\windows\system32\wkssvc.dll
Filbert
OS : Windows XP
Post by Filbert on Tue Sep 08, 2009 2:33 am
------- Sigcheck -------
[-] 2008-04-14 . 6D4FEB43EE538FC5428CC7F0565AA656 . 56320 . . [5.1.2600.5512] . . c:\windows\SoftwareDistribution\Download\dd9ab5193501484cf5e6884fa1d22f9e\eventlog.dll
[7] 2004-08-04 . 82B24CB70E5944E6E34662205A2A5B78 . 55808 . . [5.1.2600.2180] . . c:\windows\system32\dllcache\eventlog.dll
c:\windows\system32\eventlog.dll ... is missing !!
"PeerGuardian"="c:\program files\PeerGuardian2\pg2.exe" [2007-01-30 1432064]
"Aim6"="c:\program files\AIM6\aim6.exe" [2009-05-19 49968]
"VeohPlugin"="c:\program files\Veoh Networks\VeohWebPlayer\veohwebplayer.exe" [2009-05-19 3561720]
"QuickTime Task"="c:\program files\QuickTime\QTTask.exe" [2009-01-05 413696]
"UserFaultCheck"="c:\windows\system32\dumprep 0 -u" [X]
"InCD"="c:\program files\Ahead\InCD\InCD.exe" [2006-01-16 1398272]
"NvCplDaemon"="c:\windows\system32\NvCpl.dll" [2008-05-16 13529088]
"EPSON Stylus CX6400"="c:\windows\System32\spool\DRIVERS\W32X86\3\E_S4I2L1.EXE" [2003-06-02 99840]
"TkBellExe"="c:\program files\Common Files\Real\Update_OB\realsched.exe" [2006-09-30 185784]
"HPDJ Taskbar Utility"="c:\windows\system32\spool\drivers\w32x86\3\hpztsb07.exe" [2006-01-06 188416]
"HPHmon04"="c:\windows\system32\hphmon04.exe" [2006-01-06 348160]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2009-04-02 342312]
"SunJavaUpdateSched"="c:\program files\Java\jre6\bin\jusched.exe" [2009-03-09 148888]
"NvMediaCenter"="c:\windows\system32\NvMcTray.dll" [2008-05-16 86016]
"mcagent_exe"="c:\program files\McAfee.com\Agent\mcagent.exe" [2009-07-10 645328]
"nwiz"="nwiz.exe" - c:\windows\system32\nwiz.exe [2008-05-16 1630208]
"atwtusb"="atwtusb.exe" - c:\windows\system32\atwtusb.exe [2005-04-26 290816]
"RunNarrator"="Narrator.exe" - c:\windows\system32\narrator.exe [2006-10-04 53760]
Adobe Gamma Loader.lnk - c:\program files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe [2007-6-8 113664]
Launchpad.lnk - c:\program files\IC Media Corp.\ICM532\Launchpad.exe [2009-5-4 49152]
"EnableFirewall"= 0 (0x0)
"c:\\Program Files\\Microsoft Games\\Halo\\halo.exe"=
"c:\\Program Files\\Warcraft III\\Warcraft III.exe"=
"c:\\Program Files\\Warcraft III\\War3.exe"=
"c:\\Program Files\\LucasArts\\Star Wars Battlefront\\GameData\\Battlefront.exe"=
"c:\\Program Files\\CCP\\EVE\\bin\\ExeFile.exe"=
"c:\\Documents and Settings\\All Users\\Application Data\\NexonUS\\NGM\\NGM.exe"=
"c:\nexon\Combat Arms\CombatArms.exe"= c:\nexon\Combat Arms\CombatArms.exe:*Enabled:CombatArms.exe
"c:\nexon\Combat Arms\Engine.exe"= c:\nexon\Combat Arms\Engine.exe:*Enabled:Engine.exe
"c:\\Nexon\\Combat Arms\\NMService.exe"=
"c:\\Program Files\\Steam\\Steam.exe"=
"c:\\Program Files\\Java\\jre6\\bin\\javaw.exe"=
"c:\\Program Files\\Steam\\SteamApps\\common\\bioshock demo\\Builds\\Release\\Bioshock.exe"=
"c:\\Program Files\\Steam\\SteamApps\\common\\dawn of war ii - spd\\DOW2.exe"=
"c:\\Program Files\\Pando Networks\\Media Booster\\PMB.exe"=
"c:\\Program Files\\LucasArts\\Star Wars Jedi Knight Jedi Academy\\GameData\\jamp.exe"=
"c:\\WINDOWS\\system32\\PnkBstrA.exe"=
"c:\\WINDOWS\\system32\\PnkBstrB.exe"=
"c:\\AeriaGames\\WolfTeam\\Wolfteam.bin"=
"c:\\Program Files\\Veoh Networks\\VeohWebPlayer\\veohwebplayer.exe"=
"c:\\Program Files\\River Past\\Audio Converter\\AudioConverter.exe"=
"c:\\Program Files\\Common Files\\McAfee\\MNA\\McNASvc.exe"=
"56730:TCP"= 56730:TCP:Pando Media Booster
"56730:UDP"= 56730:UDP:Pando Media Booster
"57627:TCP"= 57627:TCP:Pando Media Booster
"57627:UDP"= 57627:UDP:Pando Media Booster
"58871:TCP"= 58871:TCP:Pando Media Booster
"58871:UDP"= 58871:UDP:Pando Media Booster
S1 aiptektp;HyperPen;c:\windows\system32\drivers\aiptektp.sys [5/27/2007 7:01 PM 22272]
S3 DCamUSBUVT;ICM532A;c:\windows\system32\Drivers\usbuvt.sys --> c:\windows\system32\Drivers\usbuvt.sys [?]
S3 gel90xne;gel90xne;\??\c:\docume~1\GEN-XD~1\LOCALS~1\Temp\gel90xne.sys --> c:\docume~1\GEN-XD~1\LOCALS~1\Temp\gel90xne.sys [?]
S3 MEMSWEEP2;MEMSWEEP2;\??\c:\windows\system32\2D4.tmp --> c:\windows\system32\2D4.tmp [?]
S3 ProtoWall;ProtoWall Defender;c:\windows\system32\DRIVERS\ProtoWall.sys --> c:\windows\system32\DRIVERS\ProtoWall.sys [?]
S3 XDva090;XDva090;\??\c:\windows\system32\XDva090.sys --> c:\windows\system32\XDva090.sys [?]
S3 XDva143;XDva143;\??\c:\windows\system32\XDva143.sys --> c:\windows\system32\XDva143.sys [?]
S3 XDva275;XDva275;\??\c:\windows\system32\XDva275.sys --> c:\windows\system32\XDva275.sys [?]
S3 XDva279;XDva279;\??\c:\windows\system32\XDva279.sys --> c:\windows\system32\XDva279.sys [?]
*NewlyCreated* - PGFILTER
2009-08-27 c:\windows\Tasks\AppleSoftwareUpdate.job
- c:\program files\Apple Software Update\SoftwareUpdate.exe [2008-07-30 19:34]
2009-08-25 c:\windows\Tasks\McDefragTask.job
- c:\progra~1\mcafee\mqc\QcConsol.exe [2009-08-25 04:26]
2009-08-25 c:\windows\Tasks\McQcTask.job
HKCU-Run-DAEMON Tools - c:\program files\DAEMON Tools\daemon.exe
HKCU-Run-Uniblue RegistryBooster 2009 - c:\program files\Uniblue\RegistryBooster\RegistryBooster.exe
HKLM-Run-HPHUPD04 - c:\program files\HP Photosmart 11\hphinstall\UniPatch\hphupd04.exe
HKLM-Run-PWRISOVM.EXE - c:\program files\PowerISO\PWRISOVM.EXE
HKLM-Run-CmPCIaudio - CMICNFG3.CPL
Filbert
OS : Windows XP
IE: E&xport to Microsoft Excel - c:\progra~1\MICROS~3\OFFICE11\EXCEL.EXE/3000
IE: Save YouTube Video as MP3 - c:\program files\Common Files\DVDVideoSoft\Dll\IEContextMenuY.dll/scriptY2MP3.htm
Trusted Zone: internet
Trusted Zone: mcafee.com
DPF: {4A116A80-85B6-4299-A018-A717FD7AC66A} - [You must be registered and logged in to see this link.]
FF - ProfilePath - c:\documents and settings\Gen-XDM(Games)\Application Data\Mozilla\Firefox\Profiles\b59ir2fc.default\
FF - component: c:\program files\Common Files\DVDVideoSoft\Dll\FFContextMenuY\components\FFContextMenu.dll
FF - plugin: c:\documents and settings\Gen-XDM(Games)\Application Data\Mozilla\Firefox\Profiles\b59ir2fc.default\extensions\flashplugin@idm\platform\WINNT\plugins\npidmdcp.dll
FF - plugin: c:\program files\Mozilla Firefox\plugins\npPandoWebInst.dll
FF - plugin: c:\program files\Mozilla Firefox\plugins\npViewpoint.dll
FF - plugin: c:\program files\Veoh Networks\VeohWebPlayer\NPVeohTVPlugin.dll
FF - plugin: c:\program files\Veoh Networks\VeohWebPlayer\npWebPlayerVideoPluginATL.dll
---- FIREFOX POLICIES ----
FF - user.js: dom.disable_open_during_load - true // Popupblocker control handled by McAfee Privacy Service
Rootkit scan 2009-09-07 19:17
[HKEY_LOCAL_MACHINE\System\ControlSet001\Services\MEMSWEEP2]
"ImagePath"="\??\c:\windows\system32\2D4.tmp"
[HKEY_LOCAL_MACHINE\System\ControlSet001\Services\npggsvc]
"ImagePath"="c:\windows\system32\GameMon.des -service"
[HKEY_USERS\S-1-5-21-1757981266-73586283-682003330-1005\Software\SecuROM\!CAUTION! NEVER A OR CHANGE ANY KEY*]
"??"=hex:49,70,bf,89,43,80,00,60,e8,c0,f1,02,43,23,c0,71,92,41,2f,74,a8,e8,9f,
14,2b,7e,1b,d9,a8,8b,d5,70,29,3a,bc,ba,90,56,8d,82,6c,a0,59,f9,99,25,9b,80,\
"??"=hex:69,6f,5c,46,6a,89,f9,ee,2d,48,e0,10,87,42,1e,12
[HKEY_USERS\S-1-5-21-1757981266-73586283-682003330-1005\Software\SecuROM\License information*]
"datasecu"=hex:57,55,ca,37,66,73,a0,1c,6c,fb,05,97,b3,f2,fb,ef,5d,d1,c3,c1,67,
94,24,ee,53,ff,5f,91,ac,e4,a1,84,73,b6,d6,73,ef,9d,b9,d3,36,f7,33,70,f8,05,\
"rkeysecu"=hex:9c,97,c0,28,b2,82,bf,30,cf,c9,48,b5,21,79,88,44
- - - - - - - > 'explorer.exe'(2704)
c:\progra~1\WINDOW~2\wmpband.dll
c:\program files\ArcSoft\PhotoImpression 5\share\pihook.dll
c:\program files\Ahead\InCD\InCDsrv.exe
c:\program files\Airlink101\AWLL5025\WLService.exe
c:\program files\Airlink101\AWLL5025\AWLL5025.exe
c:\progra~1\McAfee\MSC\mcmscsvc.exe
c:\progra~1\COMMON~1\McAfee\MNA\McNASvc.exe
c:\progra~1\COMMON~1\McAfee\McProxy\McProxy.exe
c:\progra~1\McAfee\VIRUSS~1\Mcshield.exe
c:\program files\McAfee\MPF\MpfSrv.exe
c:\nexon\MapleStory\npkcmsvc.exe
c:\progra~1\McAfee.com\Agent\mcagent.exe
c:\program files\IC Media Corp\ICM532\launchpad.exe
c:\program files\AIM6\aolsoftware.exe
Completion time: 2009-09-08 19:26 - machine was rebooted
ComboFix-quarantined-files.txt 2009-09-08 02:25
Pre-Run: 79,891,668,992 bytes free
Post-Run: 90,051,653,632 bytes free
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect /usepmtimer
412 --- E O F --- 2009-08-26 20:00
Filbert
OS : Windows XP
Post by Belahzur on Tue Sep 08, 2009 2:40 pm
Now open a new notepad file.
File::
FCopy::
c:\windows\SoftwareDistribution\Download\dd9ab5193501484cf5e6884fa1d22f9e\eventlog.dll | c:\windows\system32\eventlog.dll
Driver::
gel90xne
MEMSWEEP2
ProtoWall
XDva090
XDva143
XDva275
XDva279
Registry::
[-HKEY_LOCAL_MACHINE\System\ControlSet001\Services\MEMSWEEP2]
[-HKEY_LOCAL_MACHINE\System\ControlSet001\Services\npggsvc]
Post by Filbert on Wed Sep 09, 2009 1:26 am
It won't reboot my computer, it just sits there and says that it's going to.
Filbert
OS : Windows XP
Post by Belahzur on Wed Sep 09, 2009 7:27 pm
Reboot it manually then in that case.
Post by Filbert on Thu Sep 10, 2009 2:40 am
I did. No new log.
Filbert
OS : Windows XP
Post by Belahzur on Thu Sep 10, 2009 7:17 pm
Try running Combofix normally, no CFScript this time.
Post by Filbert on Sat Sep 12, 2009 5:18 pm
I was able to run it with CFScript. Big Grin
ComboFix 09-09-11.05 - Gen-XDM(Games) 09/12/2009 9:09.4.1 - NTFSx86
Microsoft Windows XP Home Edition 5.1.2600.2.1252.1.1033.18.1023.591 [GMT -7:00]
Command switches used :: E:\CFScript.txt
FILE ::
"c:\windows\system32\xa.tmp"
c:\windows\Installer\127bfe.msp
c:\windows\SoftwareDistribution\Download\dd9ab5193501484cf5e6884fa1d22f9e\eventlog.dll --> c:\windows\system32\eventlog.dll
-------\Legacy_GEL90XNE
-------\Legacy_MEMSWEEP2
-------\Legacy_XDVA090
-------\Legacy_XDVA143
-------\Legacy_XDVA275
-------\Legacy_XDVA279
-------\Service_gel90xne
-------\Service_ProtoWall
-------\Service_XDva090
-------\Service_XDva143
-------\Service_XDva275
-------\Service_XDva279
((((((((((((((((((((((((( Files Created from 2009-08-12 to 2009-09-12 )))))))))))))))))))))))))))))))
2009-09-09 00:45 . 2009-09-09 01:05 -------- d-----w- C:\ComboFix
2009-06-29 16:12 . 2004-08-04 12:00 827392 ------w- c:\windows\system32\wininet.dll
+ 2009-09-12 16:32 . 2009-09-12 16:32 16384 c:\windows\Temp\Perflib_Perfdata_660.dat
+ 2007-01-27 23:44 . 2008-07-08 13:02 17272 c:\windows\system32\spmsg.dll
- 2007-01-27 23:44 . 2009-05-26 11:40 17272 c:\windows\system32\spmsg.dll
+ 2004-08-04 12:00 . 2009-08-13 15:16 512000 c:\windows\system32\jscript.dll
+ 2006-06-03 04:37 . 2009-06-21 22:04 153088 c:\windows\system32\dllcache\triedit.dll
- 2006-06-03 04:37 . 2004-08-04 12:00 153088 c:\windows\system32\dllcache\triedit.dll
+ 2004-08-04 12:00 . 2009-08-13 15:16 512000 c:\windows\system32\dllcache\jscript.dll
+ 2004-08-04 12:00 . 2009-05-20 11:56 2458112 c:\windows\system32\WMVCore.dll
- 2004-08-04 12:00 . 2008-06-18 13:03 2458112 c:\windows\system32\WMVCore.dll
+ 2004-08-04 12:00 . 2009-05-20 11:56 2458112 c:\windows\system32\dllcache\WMVCore.dll
- 2004-08-04 12:00 . 2008-06-18 13:03 2458112 c:\windows\system32\dllcache\WMVCore.dll
+ 2006-06-06 23:42 . 2009-08-28 21:38 24689600 c:\windows\system32\MRT.exe
R2 Airlink101 USB XR Adapter WLService;Airlink101 USB XR Adapter WLService;c:\program files\Airlink101\AWLL5025\WLService.exe [8/30/2009 10:27 AM 49152]
S3 sdAuxService;PC Tools Auxiliary Service;c:\program files\Spyware Doctor\pctsAuxs.exe [2/19/2009 5:27 PM 356920]
S4 Viewpoint Manager Service;Viewpoint Manager Service;"c:\program files\Viewpoint\Common\ViewpointService.exe" --> c:\program files\Viewpoint\Common\ViewpointService.exe [?]
Filbert
OS : Windows XP
Post by Filbert on Sat Sep 12, 2009 5:19 pm
Rootkit scan 2009-09-12 10:05
- - - - - - - > 'explorer.exe'(3252)
Completion time: 2009-09-12 10:10 - machine was rebooted
ComboFix-quarantined-files.txt 2009-09-12 17:09
ComboFix2.txt 2009-09-08 02:26
Pre-Run: 89,891,467,264 bytes free
Post-Run: 89,882,140,672 bytes free
320 --- E O F --- 2009-09-09 01:40
Filbert
OS : Windows XP
Post by Belahzur on Sat Sep 12, 2009 11:10 pm
ComboFix /u
Post by Filbert on Sun Sep 13, 2009 2:15 am
Great, it's no longer making loud noises when it starts up. Big Grin
Filbert
OS : Windows XP
Post by Filbert on Sun Sep 13, 2009 4:23 pm
^ I take that back ^
It's still making noises on startup, I can't run a virus scan and it wont connect to the internet.
Filbert
OS : Windows XP
Post by Belahzur on Mon Sep 14, 2009 12:09 am
Can you explain better? what does the noise sound like?
  1. Unzip it and start GMER.
