little help with dual boot
Solved little help with dual boot
Post by Xenos on 28th August 2009, 10:56 am
hey..... is its the first time i have ever used dual boot as normally i use a second HDD instead of partitioning
Dual boot : XP + 7
but my problem is, when i turn the PC on i dont have a option to choose either XP or seven, it just auto loads XP
any idea how i can fix that?
thanks
Main System Spec: Intel Quad Q9550 (OC to 3.4Ghz), Gigabyte Ga-ep45-ud3l, 4gb kingston hyperX @ 1066mhz, Corsair tx 650, Nvidia 8600GT.
Xenos
Posts Posts : 180
Joined Joined : 2009-08-09
Points Points : 27264
Solved Re: little help with dual boot
Post by skilldegree on 28th August 2009, 11:49 am
Judging from your other post, you had vista installed first and then installed xp?
you will need to modify your vista boot loader, this article is pretty handy, page 4 should be helpful to you.
http://apcmag.com/how_to_dual_boot_vista_and_xp_with_vista_installed_first__the_stepbystep_guide.htm
Hope that helps you.
skilldegree
Posts Posts : 55
Joined Joined : 2009-08-16
OS OS : Win7 x64 Ultimate
Points Points : 26884
Post by Xenos on 28th August 2009, 12:22 pm
yeah I had vista installed, but a few days ago I did a clean install of windows 7 (totally removing vista)
Then found out a driver that is essential for me, wouldn't install on seven . So I created the dual boot with 7 and XP. And now I only have access to XP
Thanks for the link I will have a look at it Smile
Xenos
Posts Posts : 180
Post by Xenos on 28th August 2009, 12:49 pm
UPDATE:
skilldegree, it worked like a charm. took about 30 seconds to do, so easy. i Just had to repair and add XP to the bootloader
Cheers Mate Thanks
SOLVED!
Xenos
Posts Posts : 180
Post by skilldegree on 29th August 2009, 3:37 pm
No worries, glad to help Smile
skilldegree
Posts Posts : 55
Post by dozoclown on 29th August 2009, 6:15 pm
I have Vista and Ubuntu as a dual boot. I want to have Ubuntu as the first choice since I use mostly Ubuntu and I'd like to turn the computer on and have it boot to Ubuntu.
dozoclown
Joined Joined : 2009-08-29
OS OS : XP,Vista,Ubuntu
Points Points : 26602
Post by Xenos on 29th August 2009, 7:19 pm
Within Ubuntu
Copy this line into the terminal and press enter, it will back up your menu.lst and you can use the backup to restore your default settings.
sudo cp /boot/grub/menu.lst /boot/grub/menu.lst_backup
Edit the menu.lst file with one of the following commands (depending on what version of Ubuntu you're using):
Ubuntu
gksudo gedit /boot/grub/menu.lst
Kubuntu
kdesu kate /boot/grub/menu.lst
Xubuntu
gksudo mousepad /boot/grub/menu.lst
Find this line in the document that was just opened, it will read like this:
## default num
# Set the default entry to the entry number NUM. Numbering starts from 0, and
# the entry number 0 is the default if the command is not used.
default    0
Replace the 0 with the number on the startup list corresponding to the option you want, counting from 0. For example, if you have a list like this one and want to change to Windows XP Home:
title      Ubuntu, kernel 2.6.15-27-amd64-generic
title      Ubuntu, memtest86+
title      Other operating systems:
title      Microsoft Windows XP Home
...you would change the number to 3. It is important to note that each lines such as "Other Operating Systems" should be counted as well.
Save the edited file
Xenos
Posts Posts : 180
