slow system and spyware
Post by amibra on Thu Aug 27, 2009 4:36 pm
My system became very slow because of spyware here is the hijackthislog thanks in advance
Scan saved at 18:35:54, on 27/08/2009
MSIE: Internet Explorer v6.00 SP3 (6.00.2900.5512)
C:\Program Files\WIDCOMM\Bluetooth Software\bin\btwdins.exe
C:\Program Files\MSN Messenger\MsnMsgr.Exe
C:\WINDOWS\System32\reader_s.exe
C:\WINDOWS\system32\dvdpaly.exe
C:\WINDOWS\system32\sofatnet.exe
C:\Documents and Settings\Rachid\reader_s.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName = Koppelingen
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.2.4204.1700\swg.dll
O4 - HKLM\..\Run: [31630] C:\WINDOWS\system32\B.tmp.exe
O4 - HKLM\..\Run: [Regedit32] C:\WINDOWS\system32\regedit.exe
O4 - HKLM\..\Run: [reader_s] C:\WINDOWS\System32\reader_s.exe
O4 - HKCU\..\Run: [MsnMsgr] "C:\Program Files\MSN Messenger\MsnMsgr.Exe" /background
O4 - HKUS\S-1-5-18\..\Run: [reader_s] C:\Documents and Settings\Rachid\reader_s.exe (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [reader_s] C:\Documents and Settings\Rachid\reader_s.exe (User 'Default user')
O8 - Extra context menu item: Verzenden naar &Bluetooth-apparaat... - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie_ctx.htm
O8 - Extra context menu item: Verzenden naar Bluetooth - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
O9 - Extra button: @btrez.dll,-4015 - {CCA281CA-C863-46ef-9331-5C8D4460577F} - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
O9 - Extra 'Tools' menuitem: @btrez.dll,-12650 - {CCA281CA-C863-46ef-9331-5C8D4460577F} - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
O23 - Service: Bluetooth Service (btwdins) - Broadcom Corporation. - C:\Program Files\WIDCOMM\Bluetooth Software\bin\btwdins.exe
O23 - Service: sofatnet Service (sofatnet) - Sigma Designs In - C:\WINDOWS\system32\sofatnet.exe
End of file - 4273 bytes
amibra
# Likes : 0
Re: slow system and spyware
Post by amibra on Thu Aug 27, 2009 9:47 pm
I have another small problem I wanted to disable my beep under the Non-Plug and Play drivers but I uninstalled it. My question is how can I re-install the beep.sys thanks
amibra
# Likes : 0
Post by Metalmusk on Fri Aug 28, 2009 1:09 am
In your log, i see this.
Sad tearing
Metalmusk
OS : XP
# Likes : 0
Post by Metalmusk on Fri Aug 28, 2009 1:12 am
Go to this location.
C:\windows\system32\drivers\etc\
You will be finding a file called Host. Right click that Host file & Open with Notepad.
Copy the contents you see in your HOST file & post it here in your next post. Smile
Metalmusk
OS : XP
# Likes : 0
Post by amibra on Fri Aug 28, 2009 1:42 am
I only found a file called hosts :
127.0.0.1 jL.chura.pl
#9 Microsoft Corp.
# Dit is een voorbeeld HOSTS-bestand dat wordt gebruikt door Microsoft TCP/IP for Windows.
# Dit bestand bevat de toewijzingen van IP-adressen naar hostnamen. Elke vermelding
# moet op een afzonderlijke regel staan. Het IP-adres dient in de eerste kolom te worden
# geplaatst, gevolgd door de bijbehorende hostnaam. Het IP-adres en de hostnaam dienen
# gescheiden te zijn door ten minste één spatie.
# Daarnaast kunnen opmerkingen (zoals deze) worden toegevoegd op extra
# regels of gevolgd door de computernaam, voorafgegaan door een #.
# Bijvoorbeeld:
# 102.54.94.97 rhino.acme.com # bronserver
# 38.25.63.10 x.acme.com # x clienthost
127.0.0.1 localhost
amibra
# Likes : 0
Post by Metalmusk on Sat Aug 29, 2009 11:42 am
You have posted the contents i was looking for.. I have a Bad News for you. Sad tearing
Your Computer is Infected with a Deadly virus called W32/Virut. "Virut" is a family of polymorphic file infectors.
Viruses belonging to this family infect files with .EXE and .SCR extensions. I.e you can not take a back up of any files with the extension .EXE or .SCR .
I dont think someone has a fix for this Virus. Some can guide you to Calm it Down a bit, but its quite impossible to cure. None of the AV Engine has the capability to cure Virut. The best possible way is to do a complete fresh re-installation of your OS.
--- Still, Please Check with the final words of Admin---.
Metalmusk
OS : XP
# Likes : 0
Post by Belahzur on Sat Aug 29, 2009 5:49 pm
I'm afraid I have bad news.
Your system is infected with a polymorphic file infector called Virut. Virut is capable of infecting all the machine's executable files (.exe) and screensaver files (.scr). However, the problem is that the virus has a number of bugs in its code, and as a result, it may misinfect a proportion of executable files and therefore, the files are corrupted beyond repair. As of now, security experts suggest that a format and clean install, or destructive recovery if you have an OEM recovery partition, is the best way to clean the infection and it is the best and safest way to return the machine to its normal working state.
Backup all your documents and important items (personal data, work documents, etc) only. DO NOT backup any executable files (softwares) and screensavers (*.scr). It attempts to infect any accessed .exe or .scr files by appending itself to the executable.
Also, avoid backing up compressed files (zip/cab/rar) files that have .exe or .scr files inside them. Virut can penetrate and infect .exe files inside compressed files too.
Recent variants also modify htm, html, asp and php files.
Do not back up to another machine, as it may become compromised. Burn to DVD/CD, or to an external drive which has nothing else on it, and which you can format should it happen to become infected from the backups.
For more information, please see [You must be registered and logged in to see this link.]
Instructions how to format and reinstall Windows can be found [You must be registered and logged in to see this link.]
# Likes : 1
Post by amibra on Sat Aug 29, 2009 9:47 pm
Ok thanks, but my laptop doesn't have a cd drive. How can I format my system then? I do have a copy off windows xp on my usb but can I format my laptop with it? Or do I have to make it bootable? I have another laptop wich I use for similar cases can you also tell me if it's also infected with the same virus? Here's the hijackthislog off my other laptop thanks:
Scan saved at 11:54:37 , on 29/08/2009
C:\WINDOWS\system32\agrsmsvc.exe
C:\Program Files\ESET\ESET NOD32 Antivirus\ekrn.exe
C:\Program Files\ESET\ESET NOD32 Antivirus\egui.exe
C:\Program Files\MSN Messenger\msnmsgr.exe
C:\Documents and Settings\amin\reader_s.exe
C:\Program Files\MSN Messenger\usnsvc.exe
O2 - BHO: Groove GFS Browser Helper - {72853161-30C5-4D22-B7F9-0BBC1D38A37E} - C:\Program Files\Microsoft Office\Office12\GrooveShellExtensions.dll
O2 - BHO: (no name) - {7E853D72-626A-48EC-A868-BA8D5E23E045} - (no file)
O4 - HKLM\..\Run: [30476] C:\WINDOWS\system32\3.tmp.exe
O4 - HKLM\..\Run: [egui] "C:\Program Files\ESET\ESET NOD32 Antivirus\egui.exe" /hide /waitservice
O4 - HKCU\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\ctfmon.exe
O4 - HKCU\..\Run: [reader_s] C:\Documents and Settings\amin\reader_s.exe
O4 - HKCU\..\RunOnce: [Shockwave Updater] C:\WINDOWS\system32\Adobe\Shockwave 11\SwHelper_1150596.exe -Update -1150596 -"Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; .NET CLR 2.0.50727; InfoPath.2; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729)" -"http://www.maidmarian.com/ClubMarian.htm"
O4 - HKUS\S-1-5-19\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-20\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'NETWORK SERVICE')
O4 - HKUS\S-1-5-18\..\Run: [reader_s] C:\Documents and Settings\amin\reader_s.exe (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [reader_s] C:\Documents and Settings\amin\reader_s.exe (User 'Default user')
O8 - Extra context menu item: E&xporteren naar Microsoft Excel - [You must be registered and logged in to see this link.]
O8 - Extra context menu item: Send to &Bluetooth Device... - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie_ctx.htm
O8 - Extra context menu item: Send To Bluetooth - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
O9 - Extra button: Verzenden naar OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~2\Office12\ONBttnIE.dll
O9 - Extra 'Tools' menuitem: Verz&enden naar OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~2\Office12\ONBttnIE.dll
O9 - Extra button: PartyPoker.com - {B7FE5D70-9AA2-40F1-9C6B-12A255F085E1} - C:\Program Files\PartyGaming\PartyPoker\RunApp.exe
O9 - Extra 'Tools' menuitem: PartyPoker.com - {B7FE5D70-9AA2-40F1-9C6B-12A255F085E1} - C:\Program Files\PartyGaming\PartyPoker\RunApp.exe
O16 - DPF: {0E5F0222-96B9-11D3-8997-00104BD12D94} (PCPitstop Utility) - [You must be registered and logged in to see this link.]
O16 - DPF: {FFB3A759-98B1-446F-BDA9-909C6EB18CC7} (PCPitstop Exam) - [You must be registered and logged in to see this link.]
O18 - Protocol: grooveLocalGWS - {88FED34C-F0CA-4636-A375-3CB6248B04CD} - C:\Program Files\Microsoft Office\Office12\GrooveSystemServices.dll
O23 - Service: Agere Modem Call Progress Audio (AgereModemAudio) - Agere Systems - C:\WINDOWS\system32\agrsmsvc.exe
O23 - Service: Mobiel Apple apparaat (Apple Mobile Device) - Apple Inc. - C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
O23 - Service: Bonjour-service (Bonjour Service) - Apple Inc. - C:\Program Files\Bonjour\mDNSResponder.exe
O23 - Service: Com4QLBEx - Hewlett-Packard Development Company, L.P. - C:\Program Files\Hewlett-Packard\HP Quick Launch Buttons\Com4QLBEx.exe
O23 - Service: Eset HTTP Server (EhttpSrv) - ESET - C:\Program Files\ESET\ESET NOD32 Antivirus\EHttpSrv.exe
O23 - Service: Eset Service (ekrn) - ESET - C:\Program Files\ESET\ESET NOD32 Antivirus\ekrn.exe
O23 - Service: iPod-service (iPod Service) - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
End of file - 6939 bytes
amibra
# Likes : 0
Post by Belahzur on Sat Aug 29, 2009 10:51 pm
Sorry, I don't think a USB will work. Needs to be a CD.
CD drives are easily fit able, they usually only have the 3 cables that need plugging in.
# Likes : 1
