Power Options Not Available
Solved Power Options Not Available
Post by rjuneau on Mon Aug 24, 2009 12:27 pm
When I try to set the power options, I have no power schemes & all the settings are dimmed & not available. I have a Sell Inspiron 1520 laptop & am running XP. I only have one log in as me - the administrator.
What can I do?
rjuneau
Posts Posts : 37
Joined Joined : 2009-08-13
Points Points : 27029
Solved Re: Power Options Not Available
Post by Safan on Mon Aug 24, 2009 1:34 pm
If you hold the Fn button and press the up and down arrow keys this should be able to adjust the brightness of the screen.
Posts Posts : 3292
Points Points : 40843
Post by rjuneau on Tue Aug 25, 2009 1:15 am
My problem is with changing the power schemes, where you can set when to turn off the monitor & hard disk, & when to go into standby & hibernate modes.
rjuneau
Posts Posts : 37
Post by Doctor Inferno on Tue Aug 25, 2009 3:35 am
Start >> All Programs >> Accessories >> Notepad.
Paste the following code into notepad:
[HKEY_USERS\.DEFAULT\Control Panel\PowerCfg]
"CurrentPowerPolicy"="3"
[HKEY_USERS\.DEFAULT\Control Panel\PowerCfg\GlobalPowerPolicy]
"Policies"=hex:01,00,00,00,06,00,00,00,03,00,00,00,00,00,00,00,06,00,00,00,03,\
  00,00,00,00,00,00,00,02,00,00,00,03,00,00,00,00,00,00,00,02,00,00,00,03,00,\
  00,00,00,00,00,00,00,00,00,00,01,00,00,00,00,00,00,00,00,00,00,00,01,00,00,\
  00,00,00,00,00,01,00,00,00,03,00,00,00,02,00,00,00,00,00,00,c0,01,00,00,00,\
  05,00,00,00,01,00,00,00,0a,00,00,00,00,00,00,00,03,00,00,00,01,00,00,00,01,\
  00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\
  00,02,00,00,00
[HKEY_USERS\.DEFAULT\Control Panel\PowerCfg\PowerPolicies]
[HKEY_USERS\.DEFAULT\Control Panel\PowerCfg\PowerPolicies\0]
"Name"="Home/Office Desk"
"Description"="This scheme is suited to most home or desktop computers that are left plugged in all the time."
"Policies"=hex:01,00,00,00,02,00,00,00,01,00,00,00,00,00,00,00,02,00,00,00,00,\
  00,00,00,00,00,00,00,b0,04,00,00,3c,00,00,00,32,32,00,00,04,00,00,00,05,00,\
  00,00,00,00,00,00,00,00,00,00,84,03,00,00,78,00,00,00,08,07,00,00,58,02,00,\
  00,01,01,64,50,64,64,00,00
[HKEY_USERS\.DEFAULT\Control Panel\PowerCfg\PowerPolicies\1]
"Name"="Portable/Laptop"
"Description"="This scheme is designed for extended battery life for portable computers on the road."
"Policies"=hex:01,00,00,00,02,00,00,00,01,00,00,00,00,00,00,00,02,00,00,00,01,\
  00,00,00,00,00,00,00,b0,04,00,00,2c,01,00,00,32,32,00,00,04,00,00,00,05,00,\
  00,00,00,00,00,00,00,00,00,00,84,03,00,00,78,00,00,00,08,07,00,00,b4,00,00,\
[HKEY_USERS\.DEFAULT\Control Panel\PowerCfg\PowerPolicies\2]
"Name"="Presentation"
"Description"="This scheme keeps the monitor on for doing presentations."
  00,00,00,00,00,00,00,00,00,00,00,84,03,00,00,32,32,03,02,04,00,00,00,04,00,\
  00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,2c,01,00,\
  00,01,01,50,50,64,64,00,00
[HKEY_USERS\.DEFAULT\Control Panel\PowerCfg\PowerPolicies\3]
"Name"="Always On"
"Description"="This scheme keeps the computer running so that it can be accessed from the network.  Use this scheme if you do not have network wakeup hardware."
  00,00,00,00,00,00,00,00,00,00,00,2c,01,00,00,32,32,00,00,04,00,00,00,05,00,\
  00,00,00,00,00,00,00,00,00,00,84,03,00,00,78,00,00,00,10,0e,00,00,b4,00,00,\
  00,00,01,64,64,64,64,00,00
[HKEY_USERS\.DEFAULT\Control Panel\PowerCfg\PowerPolicies\4]
"Name"="Minimal Power Management"
"Description"="This scheme keeps the computer on and optimizes it for high performance."
  00,00,00,00,00,00,00,00,00,00,00,2c,01,00,00,32,32,03,03,04,00,00,00,04,00,\
  00,00,00,00,00,00,00,00,00,00,84,03,00,00,2c,01,00,00,00,00,00,00,84,03,00,\
[HKEY_USERS\.DEFAULT\Control Panel\PowerCfg\PowerPolicies\5]
"Name"="Max Battery"
"Description"="This scheme is extremely aggressive for saving power."
"Policies"=hex:01,00,00,00,02,00,00,00,01,00,00,00,00,00,00,00,02,00,00,00,05,\
  00,00,00,00,00,00,00,b0,04,00,00,78,00,00,00,32,32,03,02,04,00,00,00,04,00,\
  00,00,00,00,00,00,00,00,00,00,84,03,00,00,3c,00,00,00,00,00,00,00,b4,00,00,\
  00,01,01,64,32,64,64,00,00
[HKEY_CURRENT_USER\Control Panel\PowerCfg]
[HKEY_CURRENT_USER\Control Panel\PowerCfg\GlobalPowerPolicy]
"Policies"=hex:01,00,00,00,06,00,00,00,03,00,00,00,00,00,00,00,00,00,00,00,03,\
  00,00,00,10,00,00,00,02,00,00,00,03,00,00,00,00,00,00,00,02,00,00,00,03,00,\
  00,00,00,00,00,01,00,00,00,03,00,00,00,02,00,00,00,04,00,00,c0,01,00,00,00,\
  02,00,00,00,01,00,00,00,0a,00,00,00,00,00,00,00,03,00,00,00,01,00,01,00,01,\
  00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,02,00,00,00,\
  00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,03,00,00,00,00,\
  00,02,00,00,00
[HKEY_CURRENT_USER\Control Panel\PowerCfg\PowerPolicies]
[HKEY_CURRENT_USER\Control Panel\PowerCfg\PowerPolicies\0]
[HKEY_CURRENT_USER\Control Panel\PowerCfg\PowerPolicies\1]
[HKEY_CURRENT_USER\Control Panel\PowerCfg\PowerPolicies\2]
[HKEY_CURRENT_USER\Control Panel\PowerCfg\PowerPolicies\3]
"Name"="Always On"
"Policies"=hex:01,00,00,00,00,00,00,00,01,00,00,00,00,00,00,00,02,00,00,00,00,\
  00,00,00,00,00,00,00,00,00,00,00,2c,01,00,00,32,32,00,00,02,00,00,00,02,00,\
  00,00,01,00,00,00,14,f2,06,00,2c,01,00,00,78,00,00,00,10,0e,00,00,b4,00,00,\
  00,00,00,64,64,64,64,95,71
[HKEY_CURRENT_USER\Control Panel\PowerCfg\PowerPolicies\4]
[HKEY_CURRENT_USER\Control Panel\PowerCfg\PowerPolicies\5]
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer]
"NoSaveSettings"=dword:00000000
Save the file as fix.reg onto your Desktop. Execute the file and try again.
Post by rjuneau on Tue Aug 25, 2009 4:06 am
That's fixed it!! You folks rock.
rjuneau
Posts Posts : 37
