antivirus system pro
Post by chendog1010 on 23rd August 2009, 2:40 pm
recently i went to my computer and found out that anti virus was installed on my computer and so i tried to clear it out by add and remove programs but its not there so i did some research and saw u needed to download malwarebytes to get rid of it and then i had the error 0 run time 440 or somthing like that. so now its telling me to download hijack this and scan the computer and get a logfile or somthing so i did and its...
Scan saved at 9:38:45 AM, on 8/23/2009
c:\Program Files\Common Files\Symantec Shared\ccProxy.exe
c:\Program Files\Common Files\Symantec Shared\ccSetMgr.exe
c:\Program Files\Norton AntiVirus\navapsvc.exe
c:\Program Files\Common Files\Symantec Shared\ccEvtMgr.exe
C:\WINDOWS\system32\HPZipm12.exe
c:\Program Files\Common Files\Symantec Shared\Security Center\SymWSC.exe
C:\Program Files\Java\jre1.6.0_02\bin\jusched.exe
C:\windows\system\hpsysdrv.exe
C:\WINDOWS\system32\hphmon06.exe
C:\HP\KBD\KBD.EXE
C:\WINDOWS\system32\VTTimer.exe
C:\Program Files\Common Files\Symantec Shared\ccApp.exe
C:\WINDOWS\AGRSMMSG.exe
C:\Program Files\QuickTime\QTTask.exe
C:\WINDOWS\ALCXMNTR.EXE
C:\Program Files\Updates from HP\309731\Program\Updates from HP.exe
C:\Program Files\LimeWire\LimeWire.exe
C:\Program Files\glgikn\typmsysguard.exe
C:\Program Files\HP\Digital Imaging\bin\hpqgalry.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = [You must be registered and logged in to see this link.]
O1 - Hosts: ::1 localhost
O1 - Hosts: 91.206.201.8 osadwarekill.microsoft.com
O1 - Hosts: 91.206.201.8 osadwarekill.com
O1 - Hosts: 91.206.201.8 [You must be registered and logged in to see this link.]
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0_02\bin\ssv.dll
O2 - BHO: adssite - {962c8289-4e1f-c5ed-5d08-83370c200347} - C:\WINDOWS\system32\nsg81D.dll
O2 - BHO: Web assistant - {9ECB9560-04F9-4bbc-943D-298DDF1699E1} - c:\Program Files\Common Files\Symantec Shared\AdBlocking\NISShExt.dll
O2 - BHO: NAV Helper - {BDF3E430-B101-42AD-A544-FADC6B084872} - c:\Program Files\Norton AntiVirus\NavShExt.dll
O2 - BHO: BHO - {F03C6151-5D0E-4675-9E4B-01910A278C1F} - C:\WINDOWS\system32\iehelper.dll
O3 - Toolbar: HP view - {B2847E28-5D7D-4DEB-8B67-05D28BCF79F5} - c:\Program Files\HP\Digital Imaging\bin\HPDTLK02.dll
O3 - Toolbar: Norton AntiVirus - {42CDD1BF-3FFB-4238-8AD1-7859DF00B1D6} - c:\Program Files\Norton AntiVirus\NavShExt.dll
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre1.6.0_02\bin\jusched.exe"
O4 - HKLM\..\Run: [hpsysdrv] c:\windows\system\hpsysdrv.exe
O4 - HKLM\..\Run: [HPHUPD06] c:\Program Files\HP\{AAC4FC36-8F89-4587-8DD3-EBC57C83374D}\hphupd06.exe
O4 - HKLM\..\Run: [HPHmon06] C:\WINDOWS\system32\hphmon06.exe
O4 - HKLM\..\Run: [KBD] C:\HP\KBD\KBD.EXE
O4 - HKLM\..\Run: [Recguard] C:\WINDOWS\SMINST\RECGUARD.EXE
O4 - HKLM\..\Run: [VTTimer] VTTimer.exe
O4 - HKLM\..\Run: [ccApp] "C:\Program Files\Common Files\Symantec Shared\ccApp.exe"
O4 - HKLM\..\Run: [NAV CfgWiz] c:\Program Files\Common Files\Symantec Shared\CfgWiz.exe /GUID NAV /CMDLINE "REBOOT"
O4 - HKLM\..\Run: [IS CfgWiz] c:\Program Files\Common Files\Symantec Shared\cfgwiz.exe /GUID NIS /CMDLINE "REBOOT"
O4 - HKLM\..\Run: [SSC_UserPrompt] c:\Program Files\Common Files\Symantec Shared\Security Center\UsrPrmpt.exe
O4 - HKLM\..\Run: [AGRSMMSG] AGRSMMSG.exe
O4 - HKLM\..\Run: [PS2] C:\WINDOWS\system32\ps2.exe
O4 - HKLM\..\Run: [AlcxMonitor] ALCXMNTR.EXE
O4 - HKLM\..\Run: [system tool] C:\Program Files\glgikn\typmsysguard.exe
O4 - HKCU\..\Run: [system tool] C:\Program Files\glgikn\typmsysguard.exe
O4 - Startup: HP Organize.lnk = ?
O4 - Startup: LimeWire On Startup.lnk = C:\Program Files\LimeWire\LimeWire.exe
O4 - Global Startup: Adobe Reader Speed Launch.lnk = C:\Program Files\Adobe\Acrobat 7.0\Reader\reader_sl.exe
O4 - Global Startup: HP Image Zone Fast Start.lnk = C:\Program Files\HP\Digital Imaging\bin\hpqthb08.exe
O4 - Global Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office\OSA9.EXE
O4 - Global Startup: Updates from HP.lnk = C:\Program Files\Updates from HP\309731\Program\Updates from HP.exe
O8 - Extra context menu item: Add To HP Organize... - C:\PROGRA~1\HEWLET~1\HPORGA~1\bin\core.hp.main\SendTo.html
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_02\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_02\bin\ssv.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MI1933~1\OFFICE11\REFIEBAR.DLL
O16 - DPF: PackageCab - [You must be registered and logged in to see this link.]
O16 - DPF: {6F15128C-E66A-490C-B848-5000B5ABEEAC} (HP Download Manager) - [You must be registered and logged in to see this link.]
O16 - DPF: {73ECB3AA-4717-450C-A2AB-D00DAD9EE203} (GMNRev Class) - [You must be registered and logged in to see this link.]
O23 - Service: Symantec Event Manager (ccEvtMgr) - Symantec Corporation - c:\Program Files\Common Files\Symantec Shared\ccEvtMgr.exe
O23 - Service: Symantec Network Proxy (ccProxy) - Symantec Corporation - c:\Program Files\Common Files\Symantec Shared\ccProxy.exe
O23 - Service: Symantec Password Validation (ccPwdSvc) - Symantec Corporation - c:\Program Files\Common Files\Symantec Shared\ccPwdSvc.exe
O23 - Service: Symantec Settings Manager (ccSetMgr) - Symantec Corporation - c:\Program Files\Common Files\Symantec Shared\ccSetMgr.exe
O23 - Service: Norton AntiVirus Auto Protect Service (navapsvc) - Symantec Corporation - c:\Program Files\Norton AntiVirus\navapsvc.exe
O23 - Service: SAVScan - Symantec Corporation - c:\Program Files\Norton AntiVirus\SAVScan.exe
O23 - Service: Symantec Network Drivers Service (SNDSrvc) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\SNDSrvc.exe
O23 - Service: SymWMI Service (SymWSC) - Symantec Corporation - c:\Program Files\Common Files\Symantec Shared\Security Center\SymWSC.exe
End of file - 8651 bytes
so what should i do after this? this has been going on for almost a week and i cant take it anymore and i dont want to call geek squad for them to do somthing i can do.
thanks
chendog1010
Joined Joined : 2009-08-22
OS OS : windows XP
Points Points : 26663
Re: antivirus system pro
Post by Origin on 25th August 2009, 4:11 pm
Hello chendog1010,
Welcome to Geek Police, my name is Origin and I will be helping you today. Please keep the following in mind:
  • If you do not get a reply from me or another helper within 2 days, please reply to your topic with the phrase BUMP
  • If you have any cracked/pirated software in your computer delete them or we will not help you.
  • Only follow advise from Geek Police Staff and not a regular member.
  • Do NOT run any tool without Geek Police supervision as it could hinder your system useless.
  • Open HijackThis.
Posts Posts : 2685
Joined Joined : 2009-05-05
OS OS : Windows Xp Sp3
Points Points : 31513
