Need help
Need help
Post by Stephon on 20th August 2009, 8:10 am
Well I just did a full scan with Malwarebytes and it came up with a few things..
Malwarebytes' Anti-Malware 1.40
Database version: 2661
8/20/2009 1:08:10 AM
mbam-log-2009-08-20 (01-08-10).txt
Scan type: Full Scan (C:\|D:\|E:\|F:\|G:\|H:\|I:\|)
Objects scanned: 119985
Time elapsed: 23 minute(s), 19 second(s)
Files Infected: 20
C:\Program Files\MSN\MSNCoreFiles\Install\msnsusii.exe (Worm.Autorun) -> Quarantined and deleted successfully.
C:\Program Files\MSN\MSNCoreFiles\Install\MSN9Components\Digcore.exe (Worm.Autorun) -> Quarantined and deleted successfully.
C:\Program Files\MSN\MSNCoreFiles\Install\MSN9Components\Msncli.exe (Worm.Autorun) -> Quarantined and deleted successfully.
C:\WINDOWS\SoftwareDistribution\Download\0581874009280c186f856f079594d1ccc7a851f4 (Worm.Autorun) -> Quarantined and deleted successfully.
C:\WINDOWS\SoftwareDistribution\Download\c0b5e28a5c81ac2876216f0a963fdd4b6d478378 (Worm.Autorun) -> Quarantined and deleted successfully.
C:\WINDOWS\SoftwareDistribution\Download\97cb99aa729a3e84c1961060d22d93aab9a0c576 (Worm.Autorun) -> Quarantined and deleted successfully.
C:\WINDOWS\SoftwareDistribution\Download\9866fb57abdc0ea2f5d4e132d055ba4e\digcore.exe (Worm.Autorun) -> Quarantined and deleted successfully.
C:\WINDOWS\SoftwareDistribution\Download\9866fb57abdc0ea2f5d4e132d055ba4e\msncli.exe (Worm.Autorun) -> Quarantined and deleted successfully.
C:\WINDOWS\SoftwareDistribution\Download\9866fb57abdc0ea2f5d4e132d055ba4e\msnsusii.exe (Worm.Autorun) -> Quarantined and deleted successfully.
C:\WINDOWS\SoftwareDistribution\Download\9866fb57abdc0ea2f5d4e132d055ba4e\netsetup.exe (Worm.Autorun) -> Quarantined and deleted successfully.
C:\WINDOWS\SoftwareDistribution\Download\9866fb57abdc0ea2f5d4e132d055ba4e\wextract.exe (Worm.Autorun) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\wextract.exe (Worm.Autorun) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\netsetup.exe (Worm.Autorun) -> Quarantined and deleted successfully.
C:\WINDOWS\ServicePackFiles\i386\msncli.exe (Worm.Autorun) -> Quarantined and deleted successfully.
C:\WINDOWS\ServicePackFiles\i386\msnsusii.exe (Worm.Autorun) -> Quarantined and deleted successfully.
C:\WINDOWS\ServicePackFiles\i386\wextract.exe (Worm.Autorun) -> Quarantined and deleted successfully.
C:\WINDOWS\ServicePackFiles\i386\netsetup.exe (Worm.Autorun) -> Quarantined and deleted successfully.
C:\WINDOWS\ServicePackFiles\i386\digcore.exe (Worm.Autorun) -> Quarantined and deleted successfully.
C:\WINDOWS\$NtServicePackUninstall$\netsetup.exe (Worm.Autorun) -> Quarantined and deleted successfully.
C:\WINDOWS\$NtServicePackUninstall$\wextract.exe (Worm.Autorun) -> Quarantined and deleted successfully.
Then after I clicked removed, Windows XP starts saying that some system files are missing or not recognized. Are those false or are they real?
Stephon
Posts Posts : 93
Joined Joined : 2008-09-06
Points Points : 30200
Re: Need help
Post by Belahzur on 20th August 2009, 7:50 pm
Open MBAM, go into the quarantine tab please.
Restore each of them items MBAM has removed.
Next, go into the update tab and run check for updates. Latest database as of right now is 2666.
Now close MBAM.
Next, go to Start > Run.
In the run box, copy and paste in the following:
mbam /developer
Now run a new scan and see what it finds.
Once done, DO NOT!! remove anything, copy and paste the log file back here.
Points Points : 245101
Re: Need help
Post by Stephon on 22nd August 2009, 6:16 am
I removed the items..
Here's the scan anyways..
Database version: 2675
8/22/2009 12:10:12 AM
mbam-log-2009-08-22 (00-10-12).txt
Objects scanned: 118427
Time elapsed: 39 minute(s), 18 second(s)
Stephon
Posts Posts : 93
