Registry Cleaner Problem HELP
Post by Sandybeach57 on Wed Aug 19, 2009 1:49 am
I had a problem this morning, which I googled and I picked a site that downloaded a free registry scanner and cleaner. It fixed the problem but now I still have 500 odd left in there. To clean it I must spend $40 odd to fix it. I havent got $40, can anyone help me and give me a site that really does it for free. My computer is so slow, maybe this is whats wrong.
Sandybeach57
Posts Posts : 6
Joined Joined : 2009-06-27
Points Points : 27182
Re: Registry Cleaner Problem HELP
Post by Agent Cosmic on Wed Aug 19, 2009 4:54 am
Moderated Message:Moved from Programming to Software.
Post by Doctor Inferno on Wed Aug 19, 2009 11:10 am
Hello Sandybeach57,
We don't really recommend using registry cleaners. If a wrong key is deleted, your system might not be able to boot up again. However, if you insist, you can get CCleaner. It's free and fixes registry problems for you.
I can bet deleting empty or useless registry keys won't show much difference in speed, because I've tried it before. If you want to speed up your startup, post a HijackThis log here I can tell you what to remove.
Please download the current version of HijackThis from HERE
Post by Sandybeach57 on Fri Aug 21, 2009 9:14 am
Scan saved at 6:47:15 PM, on 8/21/2009
C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe
C:\PROGRA~1\AVG\AVG8\avgemc.exe
C:\PROGRA~1\AVG\AVG8\avgrsx.exe
C:\PROGRA~1\AVG\AVG8\avgnsx.exe
C:\Program Files\AVG\AVG8\avgcsrvx.exe
C:\Program Files\Google\Quick Search Box\GoogleQuickSearchBox.exe
C:\PROGRA~1\AVG\AVG8\avgtray.exe
C:\Program Files\Microsoft Office\Office12\ONENOTEM.EXE
C:\Program Files\Outlook Express\msimn.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://ninemsn.com.au/
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
R3 - URLSearchHook: AVG Security Toolbar BHO - {A3BC75A2-1F87-4686-AA43-5347D756017C} - C:\Program Files\AVG\AVG8\Toolbar\IEToolbar.dll
O2 - BHO: WormRadar.com IESiteBlocker.NavFilter - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - C:\Program Files\AVG\AVG8\avgssie.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre6\bin\ssv.dll
O2 - BHO: AVG Security Toolbar BHO - {A3BC75A2-1F87-4686-AA43-5347D756017C} - C:\Program Files\AVG\AVG8\Toolbar\IEToolbar.dll
O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - C:\Program Files\Google\Google Toolbar\GoogleToolbar.dll
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.1.1309.15642\swg.dll
O2 - BHO: Google Dictionary Compression sdch - {C84D72FE-E17D-4195-BB24-76C02E2E7C4E} - C:\Program Files\Google\Google Toolbar\Component\fastsearch_A8904FB862BD9564.dll
O3 - Toolbar: (no name) - {EE5D279F-081B-4404-994D-C6B60AAEBA6D} - (no file)
O3 - Toolbar: Google Toolbar - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - C:\Program Files\Google\Google Toolbar\GoogleToolbar.dll
O3 - Toolbar: AVG Security Toolbar - {CCC7A320-B3CA-4199-B1A6-9F516DD69829} - C:\Program Files\AVG\AVG8\Toolbar\IEToolbar.dll
O4 - HKLM\..\Run: [Google Quick Search Box] "C:\Program Files\Google\Quick Search Box\GoogleQuickSearchBox.exe" /autorun
O4 - HKLM\..\Run: [AVG8_TRAY] C:\PROGRA~1\AVG\AVG8\avgtray.exe
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 9.0\Reader\Reader_sl.exe"
O4 - HKCU\..\Run: [EPSON TX100 Series] C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\E_FATIEDP.EXE /FU "C:\WINDOWS\TEMP\E_SD3.tmp" /EF "HKCU"
O4 - Startup: OneNote 2007 Screen Clipper and Launcher.lnk = C:\Program Files\Microsoft Office\Office12\ONENOTEM.EXE
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\Office12\EXCEL.EXE/3000
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre6\bin\jp2iexp.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre6\bin\jp2iexp.dll
O9 - Extra button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~2\Office12\ONBttnIE.dll
O9 - Extra 'Tools' menuitem: S&end to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~2\Office12\ONBttnIE.dll
O16 - DPF: {C1FDEE68-98D5-4F42-A4DD-D0BECF5077EB} (EPUImageControl Class) - http://tools.ebayimg.com/eps/wl/activex/eBay_Enhanced_Picture_Control_v1-0-27-0.cab
O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object) - http://fpdownload2.macromedia.com/get/flashplayer/current/swflash.cab
O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} - http://platformdl.adobe.com/NOS/getPlusPlus/1.6/gp.cab
O18 - Protocol: linkscanner - {F274614C-63F8-47D5-A4D1-FBDDE494F8D1} - C:\Program Files\AVG\AVG8\avgpp.dll
O18 - Filter: x-sdch - {B1759355-3EEC-4C1E-B0F1-B719FE26E377} - C:\Program Files\Google\Google Toolbar\Component\fastsearch_A8904FB862BD9564.dll
O20 - Winlogon Notify: avgrsstarter - C:\WINDOWS\SYSTEM32\avgrsstx.dll
O23 - Service: AVG Free8 E-mail Scanner (avg8emc) - AVG Technologies CZ, s.r.o. - C:\PROGRA~1\AVG\AVG8\avgemc.exe
O23 - Service: AVG Free8 WatchDog (avg8wd) - AVG Technologies CZ, s.r.o. - C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe
End of file - 7252 bytes
Sandybeach57
Posts Posts : 6
Post by Sandybeach57 on Fri Aug 21, 2009 9:22 am
Before I got your message, I downloaded a free reg cleaner named Easycleaner, some people reckon it was really great. Well I think it was s...t
I ran it, then undid everything I did on it and deleted it. My computer is soooo slow Im falling asleep. I know I need more memory on this old gal.
Hope you can help me.
Plus I just want to say how wonderful you guys are. I cant beleive that there is actually lovely kind people like yourselves that are out there willing to help computer illiterate people like myself for FREE. You are wonderful, I tell everyone how fantastic you are. You helped me once with a really bad virus. thank you soooo much.
Sandybeach57
Posts Posts : 6
Post by Doctor Inferno on Fri Aug 21, 2009 11:56 am
No prob. Wink
I notice that you have Spybot's TeaTimer running. While this is normally a wonderful tool to protect against hijackers, it can also interfere with HijackThis fixes. So please disable TeaTimer by doing the following:
1) Run Spybot-S&D
2) Go to the Mode menu, and make sure "Advanced Mode" is selected
3) On the left hand side, choose Tools -> Resident
4) Uncheck "Resident TeaTimer" and OK any prompts
You can reenable TeaTimer once your system is clean.
Please make sure Teatimer is disable before we do this, otherwise this fix will fail.
Next, download and install CCleaner:
http://www.geekpolice.net/freeware-downloads-f14/ccleaner-t7.htm
CCleaner is a great tool used to clean out temporary files, it may also increase your computer speeds by a little.
Defragment your disk -
1. Open My Computer.
2. Right-click the local disk volume that you want to defragment, and then click Properties.
3. On the Tools tab, click Defragment Now.
4. Click Defragment.
Another way to speed up your computer is to uninstall unwanted softwares.
