mbam.exe doesn't work closes after 2 seconds
Post by Terri Callahan on Tue Aug 18, 2009 5:29 pm
I installed the malwarebyes_anti-malware on my C:\drive, nothing works (all executibles are corrupted)...I tried to run the same "mbam.exe" file from a thumb drive, and it looks like it's executing to quick scan the C; drive, and it disappears after 2 seconds....why ??
Terri Callahan
OS : XP
# Likes : 0
Re: mbam.exe doesn't work closes after 2 seconds
Post by Belahzur on Tue Aug 18, 2009 8:07 pm
# Likes : 1
trying to run HIJACK
Post by Terri Callahan on Tue Aug 18, 2009 8:24 pm
so now i've attempted to install HIJACK, I've loaded it to my C: drive and tried to run it, with no success, and then I tried to run it from my thumb drive......neither appear to work. I have had my Task Manager open for applications, and it just says "RUNNING" on the C: drive Task, but that's it..no sign of HIJACK setting up.
how long does it ususally take?
Terri Callahan
OS : XP
# Likes : 0
Post by Belahzur on Tue Aug 18, 2009 8:29 pm
Something is blocking it.
  • Download combofix from here
# Likes : 1
