OS problems after Malware removal.
Solved OS problems after Malware removal.
Post by Bigmaico on Mon Aug 17, 2009 2:19 pm
Not sure if this is the right forum for this, but I used AGV8.5 & Malware to remove problem for a Dell laptop.
It will boot up, but I can't run anything or install any thing? It's running XP home.
I had to attach it to my other system through a USB adapter to run AGV & Malware.
How do I go about getting the system back ? Can I reinstall Xp & not lose any of data?
Please let me know what to try.
Howard
Bigmaico
OS : XP
# Likes : 0
Solved Re: OS problems after Malware removal.
Post by Doctor Inferno on Tue Aug 18, 2009 2:34 am
You can perform a repair of the OS. All your data will be retained.
# Likes : 0
