Antivirus System Pro
Post by doreron on Sun Aug 16, 2009 12:17 pm
I've got this damn thing on the pc and can't get rid of it also. It only happened when my stupid partner went on a vile website and then it all started.
Luckily I have the laptop, but the pc don't work at all with all this rubbish on it. I've been told various ways in which to get rid of it, but I can't because I can't get passed all the boxes that won't move with all the things on. I can't download the removal tool, which isn't much good on the laptop, is it?
doreron
Joined Joined : 2009-08-16
OS OS : Vista
Points Points : 26693
Re: Antivirus System Pro
Post by Belahzur on Sun Aug 16, 2009 6:45 pm
Points Points : 245069
