desot.exe problems HELP!
Post by Johntheripper222 on 16th August 2009, 3:17 am
yes i got the nasty Windows Securtiy Pro virus and i removed it but then i just made a quick check on the system32 and i deleted svchast (which ik needed to be gone) but then i read on another forum that i must delete desot.exe so I did and now when i click on any executable i get the "open with" box that makes u select a program to open it with. so i was wondering HOW DO I FIX THIS!!!!!!!!!!!!!!!!!!
Johntheripper222
Posts Posts : 8
Joined Joined : 2009-08-16
Points Points : 26746
Re: desot.exe problems HELP!
Post by Doctor Inferno on 16th August 2009, 9:59 am
Please read this: [You must be registered and logged in to see this link.]
And post your HijackThis log here.
Points Points : 104640
Post by Johntheripper222 on 18th August 2009, 8:57 pm
sorry but i cant. the problem is i cant open .exe files. so i cant install Hijack this. its making me very mad.
Johntheripper222
Posts Posts : 8
Post by Belahzur on 19th August 2009, 12:05 am
See if you can run this, I want to check something.
    :filefind
    scecli.dll
    netlogon.dll
    eventlog.dll
Points Points : 245111
Post by Johntheripper222 on 19th August 2009, 8:47 pm
sadly i cant. when i click on it a error box comes up and has the file path and says application not found.
Johntheripper222
Posts Posts : 8
Post by Johntheripper222 on 19th August 2009, 9:20 pm
and i cant because its a exectuable.
Johntheripper222
Posts Posts : 8
Post by Belahzur on 20th August 2009, 12:25 am
Download MBAM from here:
Once downloaded, remove the .exe and add .scr so the file should be called mbam-setup.scr
Run it, will it install? [if it goes right, it will install, but won't run]
Let me know.
Post by Johntheripper222 on 22nd August 2009, 10:17 pm
if this works imma hunt u down and hug u. lol jk. ya ill try it later today.
Johntheripper222
Posts Posts : 8
Post by Johntheripper222 on 22nd August 2009, 10:21 pm
o crap. how do i save it as a .scr file?
Johntheripper222
Posts Posts : 8
Post by Origin on 25th August 2009, 3:37 pm
RIght-Click on the MBAM set up and click on rename, now instead of the .exe at the end rename it to .scr now see if it runs.
Posts Posts : 2685
Joined Joined : 2009-05-05
OS OS : Windows Xp Sp3
Points Points : 31523
Post by Johntheripper222 on 26th August 2009, 11:46 pm
ugh. i did that. now in the downloads list it is named: mbam-setup.scr.exe...........and it still wont run. and i did the rename thing and its still a exe
Johntheripper222
Posts Posts : 8
