Antivirus System Pro
Post by lachatnoir on 14th August 2009, 10:07 pm
Can't remove this program! I think I found the culprit but cannot remove it.
File: qlwqsysguard.exe I would appreciate any help.
Here is my hijack log:
Scan saved at 2:19:59 PM, on 8/14/2009
C:\Program Files\Lavasoft\Ad-Aware 2007\aawservice.exe
C:\WINDOWS\arservice.exe
C:\WINDOWS\eHome\ehRecvr.exe
C:\WINDOWS\eHome\ehSched.exe
C:\Program Files\McAfee\SiteAdvisor\McSACore.exe
c:\program files\common files\mcafee\mna\mcnasvc.exe
C:\WINDOWS\system32\dllhost.exe
C:\Program Files\2Wire\2PortalMon.exe
C:\WINDOWS\system32\SYSWB6.exe
C:\Program Files\Lavasoft\Ad-Aware 2007\AAWTray.exe
C:\Program Files\jbtwld\qlwqsysguard.exe
C:\Program Files\Adobe\Acrobat 4.0\Distillr\AcroTray.exe
C:\Program Files\Compaq Connections\5577497\Program\Compaq Connections.exe
C:\Program Files\Orbitdownloader\orbitdm.exe
C:\Program Files\Sony\Sony Picture Utility\PMBCore\SPUVolumeWatcher.exe
C:\Program Files\Orbitdownloader\orbitnet.exe
C:\Documents and Settings\Compaq_Administrator\Desktop\winlogon.exe.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = [You must be registered and logged in to see this link.]
O1 - Hosts: ::1 localhost
O1 - Hosts: 91.206.201.8 winsecurepro.microsoft.com
O1 - Hosts: 91.206.201.8 winsecurepro.com
O1 - Hosts: 91.206.201.8 [You must be registered and logged in to see this link.]
O2 - BHO: btorbit.com - {000123B4-9B42-4900-B3F7-F4B073EFC214} - C:\Program Files\Orbitdownloader\orbitcth.dll
O2 - BHO: BHO - {10B3A0D2-3960-4d38-8158-D828A30F8DB1} - C:\WINDOWS\system32\iehelper.dll
O2 - BHO: (no name) - {6ef30ccb-cd54-4ad3-a14f-303d7e258137} - C:\WINDOWS\system32\kuzaveru.dll (file missing)
O2 - BHO: scriptproxy - {7DB2D5A0-7241-4E79-B68D-6309F01C5231} - c:\PROGRA~1\mcafee\VIRUSS~1\scriptsn.dll
O2 - BHO: McAfee SiteAdvisor BHO - {B164E929-A1B6-4A06-B104-2CD0E90A88FF} - c:\PROGRA~1\mcafee\SITEAD~1\mcieplg.dll
O3 - Toolbar: McAfee SiteAdvisor Toolbar - {0EBBBE48-BAD4-4B4C-8E5A-516ABECAE064} - c:\PROGRA~1\mcafee\SITEAD~1\mcieplg.dll
O3 - Toolbar: (no name) - {CCC7A320-B3CA-4199-B1A6-9F516DD69829} - (no file)
O4 - HKLM\..\Run: [2wSysTray] C:\Program Files\2Wire\2PortalMon.exe
O4 - HKLM\..\Run: [BitPump] "C:\Program Files\AnalogX\BitPump\bitpump.exe" /VerifySettings
O4 - HKLM\..\Run: [SYSWB6] SYSWB6
O4 - HKLM\..\Run: [AAWTray] C:\Program Files\Lavasoft\Ad-Aware 2007\AAWTray.exe
O4 - HKLM\..\Run: [HPDJ Taskbar Utility] C:\WINDOWS\system32\spool\drivers\w32x86\3\hpztsb04.exe
O4 - HKLM\..\Run: [autochk] rundll32.exe C:\WINDOWS\system32\autochk.dll,_IWMPEvents@16
O4 - HKLM\..\Run: [SNM] C:\Program Files\SpyNoMore\SNM.exe /startup
O4 - HKLM\..\Run: [msupdate] msupdate.exe
O4 - HKLM\..\Run: [dunakotiwo] Rundll32.exe "C:\WINDOWS\system32\rekomuzu.dll",s
O4 - HKLM\..\Run: [system tool] C:\Program Files\jbtwld\qlwqsysguard.exe
O4 - HKLM\..\Run: [CPMeb3a2aeb] Rundll32.exe "c:\windows\system32\bijapeka.dll",a
O4 - HKCU\..\Run: [autochk] rundll32.exe C:\DOCUME~1\NETWOR~1\protect.dll,_IWMPEvents@16
O4 - HKCU\..\Run: [system tool] C:\Program Files\jbtwld\qlwqsysguard.exe
O4 - HKUS\S-1-5-19\..\Run: [dunakotiwo] Rundll32.exe "C:\WINDOWS\system32\kigebele.dll",s (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-20\..\Run: [dunakotiwo] Rundll32.exe "C:\WINDOWS\system32\kigebele.dll",s (User 'NETWORK SERVICE')
O4 - S-1-5-18 Startup: Pin.lnk = C:\hp\bin\CLOAKER.EXE (User 'SYSTEM')
O4 - .DEFAULT Startup: Pin.lnk = C:\hp\bin\CLOAKER.EXE (User 'Default user')
O4 - .DEFAULT User Startup: Pin.lnk = C:\hp\bin\CLOAKER.EXE (User 'Default user')
O4 - Startup: Picture Motion Browser Media Check Tool.lnk = C:\Program Files\Sony\Sony Picture Utility\PMBCore\SPUVolumeWatcher.exe
O4 - Global Startup: Acrobat Assistant.lnk = C:\Program Files\Adobe\Acrobat 4.0\Distillr\AcroTray.exe
O4 - Global Startup: Compaq Connections.lnk = C:\Program Files\Compaq Connections\5577497\Program\Compaq Connections.exe
O4 - Global Startup: Orbit.lnk = C:\Program Files\Orbitdownloader\orbitdm.exe
O8 - Extra context menu item: &Download by Orbit - [You must be registered and logged in to see this link.] Files\Orbitdownloader\orbitmxt.dll/201
O8 - Extra context menu item: &Grab video by Orbit - [You must be registered and logged in to see this link.] Files\Orbitdownloader\orbitmxt.dll/204
O8 - Extra context menu item: Do&wnload selected by Orbit - [You must be registered and logged in to see this link.] Files\Orbitdownloader\orbitmxt.dll/203
O8 - Extra context menu item: Down&load all by Orbit - [You must be registered and logged in to see this link.] Files\Orbitdownloader\orbitmxt.dll/202
O8 - Extra context menu item: Open with BitPump - C:\Program Files\AnalogX\BitPump\ieint.htm
O9 - Extra button: Connection Help - {E2D4D26B-0180-43a4-B05F-462D6D54C789} - C:\WINDOWS\PCHEALTH\HELPCTR\Vendors\CN=Hewlett-Packard,L=Cupertino,S=Ca,C=US\IEButton\support.htm
O9 - Extra 'Tools' menuitem: Connection Help - {E2D4D26B-0180-43a4-B05F-462D6D54C789} - C:\WINDOWS\PCHEALTH\HELPCTR\Vendors\CN=Hewlett-Packard,L=Cupertino,S=Ca,C=US\IEButton\support.htm
O9 - Extra button: Yahoo! Messenger - {E5D12C4E-7B4F-11D3-B5C9-0050045C3C96} - C:\PROGRA~1\Yahoo!\MESSEN~1\YPager.exe
O9 - Extra 'Tools' menuitem: Yahoo! Messenger - {E5D12C4E-7B4F-11D3-B5C9-0050045C3C96} - C:\PROGRA~1\Yahoo!\MESSEN~1\YPager.exe
O15 - Trusted Zone: [You must be registered and logged in to see this link.] (HKLM)
O16 - DPF: {30528230-99f7-4bb4-88d8-fa1d4f56a2ab} (Installation Support) - C:\Program Files\Yahoo!\Common\Yinsthelper20073151.dll
O16 - DPF: {4ED9DDF0-7479-4BBE-9335-5A1EDB1D8A21} (McAfee.com Operating System Class) - [You must be registered and logged in to see this link.]
O16 - DPF: {B8BE5E93-A60C-4D26-A2DC-220313175592} (MSN Games - Installer) - [You must be registered and logged in to see this link.]
O16 - DPF: {BCC0FF27-31D9-4614-A68E-C18E1ADA4389} (DwnldGroupMgr Class) - [You must be registered and logged in to see this link.]
O18 - Protocol: sacore - {5513F07E-936B-4E52-9B00-067394E91CC5} - c:\PROGRA~1\mcafee\SITEAD~1\mcieplg.dll
O20 - AppInit_DLLs: C:\WINDOWS\system32\kuzinugi.dll c:\windows\system32\bijapeka.dll
O21 - SSODL: SSODL - {EC43E3FD-5C60-46a6-97D7-E0B85DBDD6C4} - c:\windows\system32\bijapeka.dll
O22 - SharedTaskScheduler: STS - {EC43E3FD-5C60-46a6-97D7-E0B85DBDD6C4} - c:\windows\system32\bijapeka.dll
O23 - Service: Ad-Aware 2007 Service (aawservice) - Lavasoft AB - C:\Program Files\Lavasoft\Ad-Aware 2007\aawservice.exe
O23 - Service: Adobe LM Service - Adobe Systems - C:\Program Files\Common Files\Adobe Systems Shared\Service\Adobelmsvc.exe
O23 - Service: GameConsoleService - WildTangent, Inc. - C:\Program Files\LG Software Innovations\1Click DVD Copy Pro\GameConsoleService.exe
O23 - Service: Macromedia Licensing Service - Unknown owner - C:\Program Files\Common Files\Macromedia Shared\Service\Macromedia Licensing.exe
O23 - Service: McAfee SiteAdvisor Service - Unknown owner - C:\Program Files\McAfee\SiteAdvisor\McSACore.exe
O23 - Service: McAfee Network Agent (McNASvc) - McAfee, Inc. - c:\program files\common files\mcafee\mna\mcnasvc.exe
O23 - Service: Pml Driver - HP - C:\WINDOWS\system32\HPHipm09.exe
End of file - 12730 bytes
lachatnoir
Posts Posts : 99
Joined Joined : 2009-06-28
Points Points : 28466
Re: Antivirus System Pro
Post by Belahzur on 14th August 2009, 10:58 pm
Points Points : 245111
It worked!
Post by lachatnoir on 15th August 2009, 1:00 pm
Thank you so much. I really appreciate your help and for responding so quickly!!!! I don't have much of an income, but I am going to donate to your site. You are awesome and this website is absolutely amazing!
lachatnoir
Posts Posts : 99
