HELP WITH ANTIVIRUS SYSTEM PRO VIRUS
Post by danielsanchezmd on Thu Aug 13, 2009 3:11 pm
Hello, I followed someone's guide in removing this obnoxious virus via using malwarebytes antimalware. However, every time I run it, It says, "Run Time error '0'." Then after I click okay, it says,"Run Time error '440'."
Please help,
Daniel
danielsanchezmd
Joined Joined : 2009-08-13
Points Points : 26723
Re: HELP WITH ANTIVIRUS SYSTEM PRO VIRUS
Post by Belahzur on Thu Aug 13, 2009 4:18 pm
Points Points : 245069
