Restart Required Message Won't Go Away
Solved Restart Required Message Won't Go Away
Post by jimclark1947 on 12th August 2009, 6:11 pm
I built a new computer a few weeks ago. As I was loading all the drivers and software I did not encounter any difficulty. But shortly after loading everything I started getting a Windows message box whenever I would reboot the computer. In the header of the box it states Restart required with OK or Cancel buttons. There is nothing else in the box to identify which program or driver it might be associated with. At first I clicked the OK button which caused the computer to reboot, only to find that the same message box appears again when the system boots up. Since then I have clicked Cancel and the box closes without a problem. All the hardware and software work without a problem, but it is a bit of an annoyance to deal with this Restart required box.
I have no idea where to even start to look for the solution to this problem. Any ideas will be appreciated.
jimclark1947
Posts Posts : 18
Joined Joined : 2009-08-11
Points Points : 26810
Solved Re: Restart Required Message Won't Go Away
Post by jimclark1947 on 13th August 2009, 1:42 am
For anyone else having this problem I discovered the cause. In the System Configuration Utility under the Startup tab I found Adobe Updater was checked. After unchecking the problem is gone. I'll be following up with Adobe to see if they have an answer for this and will post an update here if I find anything.
jimclark1947
Posts Posts : 18
Post by groovybluedog on 14th August 2009, 11:39 am
Glad you sorted it.
groovybluedog
Posts Posts : 40
Joined Joined : 2009-07-10
OS OS : XP, Vista, Mac, 7, Linux and Unix (DONT GET UNIX!!!)
Points Points : 27148
