another system security problem
Post by fishininmt on Wed Aug 12, 2009 3:38 am
I had the system security virus for the last couple of days. It wouldn't let me do anything until I was able to install Process Explorer by renaming it and then shutting down the system security process. After that I was able to use Malwarebytes to detect and remove the virus. I've also installed the hijack this. I want to make sure this thing is really gone. Because for the most part everything is running fine however my computer has restarted on its own about four times today and I get the message that says the system has recovered from a serious error. I've tried sending the error report but it says the error report is corrupted. Here is the log from hijack this:
Scan saved at 1:20:05 PM, on 8/11/2009
C:\Program Files\CA\SharedComponents\HIPSEngine\UmxCfg.exe
C:\Program Files\CA\SharedComponents\HIPSEngine\UmxFwHlp.exe
C:\Program Files\CA\SharedComponents\HIPSEngine\UmxPol.exe
C:\Program Files\CA\SharedComponents\HIPSEngine\UmxAgent.exe
C:\Program Files\CA\CA Internet Security Suite\CA Anti-Virus\ISafe.exe
C:\Program Files\CA\SharedComponents\PPRT\bin\ITMRTSVC.exe
C:\WINDOWS\system32\lxcycoms.exe
C:\Program Files\MioNet\MioNetManager.exe
C:\Program Files\Common Files\New Boundary\PrismXL\PRISMXL.SYS
C:\Program Files\MioNet\jvm\bin\MioNet.exe
C:\Program Files\CA\CA Internet Security Suite\CA Anti-Virus\VetMsg.exe
C:\WINDOWS\system32\svcprs32.exe
C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe
C:\WINDOWS\zHotkey.exe
C:\Program Files\Digital Media Reader\shwiconem.exe
C:\WINDOWS\SOUNDMAN.EXE
C:\WINDOWS\ALCWZRD.EXE
C:\Program Files\QuickTime\qttask.exe
C:\Program Files\Lexmark 3400 Series\lxcymon.exe
C:\Program Files\Lexmark 3400 Series\ezprint.exe
C:\WINDOWS\VM_STI.EXE
C:\Program Files\CA\CA Internet Security Suite\cctray\cctray.exe
C:\Program Files\CA\CA Internet Security Suite\CA Anti-Virus\CAVRID.exe
C:\Program Files\CA\CA Internet Security Suite\CA Personal Firewall\capfasem.exe
C:\Program Files\CA\CA Internet Security Suite\ccprovsp.exe
C:\Program Files\SkyLink\SKYLINK 2-in-1 Phone Utility\SKYLINK 2-in-1 Phone Utility.exe
C:\Documents and Settings\Owner\Application Data\Smilebox\SmileboxTray.exe
C:\Program Files\CA\CA Internet Security Suite\CA Personal Firewall\capfsem.exe
C:\Program Files\BigFix\BigFix.exe
C:\Program Files\CA\CA Internet Security Suite\CA Anti-Spyware\CAPPActiveProtection.exe
C:\Program Files\Philips\Philips SPC315NC Webcam\TrayMin315.exe
C:\Program Files\CA\CA Internet Security Suite\CA Anti-Spyware\PPCtlPriv.exe
C:\Program Files\CA\CA Internet Security Suite\CA Website Inspector\Toolbar\CAGlobal.exe
C:\Program Files\CA\CA Internet Security Suite\CA Website Inspector\Light\CAGlobalLight.exe
C:\Program Files\Skype\Phone\Skype.exe
C:\Program Files\Skype\Plugin Manager\skypePM.exe
C:\Program Files\Malwarebytes' Anti-Malware\mbam.exe
O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - C:\Program Files\Google\Google Toolbar\GoogleToolbar.dll
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\3.1.807.1746\swg.dll
O2 - BHO: CA Toolbar Helper - {FBF2401B-7447-4727-BE5D-C19B2075CA84} - C:\Program Files\CA\CA Internet Security Suite\CA Website Inspector\Toolbar\CallingIDIE.dll
O2 - BHO: (no name) - {FDD3B846-8D59-4ffb-8758-209B6AD74ACC} - (no file)
O3 - Toolbar: &Google Toolbar - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - C:\Program Files\Google\Google Toolbar\GoogleToolbar.dll
O3 - Toolbar: CA Toolbar - {10134636-E7AF-4AC5-A1DC-C7C44BB97D81} - C:\Program Files\CA\CA Internet Security Suite\CA Website Inspector\Toolbar\CallingIDIE.dll
O4 - HKLM\..\Run: [Recguard] C:\WINDOWS\SMINST\RECGUARD.EXE
O4 - HKLM\..\Run: [High Definition Audio Property Page Shortcut] HDAudPropShortcut.exe
O4 - HKLM\..\Run: [NeroFilterCheck] C:\WINDOWS\system32\NeroCheck.exe
O4 - HKLM\..\Run: [RemoteControl] "C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe"
O4 - HKLM\..\Run: [CHotkey] zHotkey.exe
O4 - HKLM\..\Run: [ShowWnd] ShowWnd.exe
O4 - HKLM\..\Run: [SunKistEM] C:\Program Files\Digital Media Reader\shwiconem.exe
O4 - HKLM\..\Run: [SoundMan] SOUNDMAN.EXE
O4 - HKLM\..\Run: [AlcWzrd] ALCWZRD.EXE
O4 - HKLM\..\Run: [lxcymon.exe] "C:\Program Files\Lexmark 3400 Series\lxcymon.exe"
O4 - HKLM\..\Run: [EzPrint] "C:\Program Files\Lexmark 3400 Series\ezprint.exe"
O4 - HKLM\..\Run: [FaxCenterServer] "C:\Program Files\Lexmark Fax Solutions\fm3032.exe" /s
O4 - HKLM\..\Run: [LXCYCATS] rundll32 C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\LXCYtime.dll,_RunDLLEntry@16
O4 - HKLM\..\Run: [BigDogPath] C:\WINDOWS\VM_STI.EXE Philips SPC315NC Webcam
O4 - HKLM\..\Run: [cctray] "C:\Program Files\CA\CA Internet Security Suite\cctray\cctray.exe"
O4 - HKLM\..\Run: [QOELOADER] "C:\Program Files\CA\CA Internet Security Suite\CA Anti-Spam\QSP-6.0.1.33\QOELoader.exe"
O4 - HKLM\..\Run: [CAVRID] "C:\Program Files\CA\CA Internet Security Suite\CA Anti-Virus\CAVRID.exe"
O4 - HKLM\..\Run: [cafw] C:\Program Files\CA\CA Internet Security Suite\CA Personal Firewall\cafw.exe -cl
O4 - HKLM\..\Run: [capfasem] C:\Program Files\CA\CA Internet Security Suite\CA Personal Firewall\capfasem.exe
O4 - HKLM\..\Run: [capfupgrade] C:\Program Files\CA\CA Internet Security Suite\CA Personal Firewall\capfupgrade.exe
O4 - HKCU\..\Run: [SKYLINK 2-in-1 Phone Utility] C:\Program Files\SkyLink\SKYLINK 2-in-1 Phone Utility\SKYLINK 2-in-1 Phone Utility.exe
O4 - HKCU\..\Run: [SmileboxTray] "C:\Documents and Settings\Owner\Application Data\Smilebox\SmileboxTray.exe"
O4 - HKUS\S-1-5-19\..\Run: [tedokubife] Rundll32.exe "C:\WINDOWS\system32\fovifeso.dll",s (User '?')
O4 - HKUS\S-1-5-20\..\Run: [tedokubife] Rundll32.exe "C:\WINDOWS\system32\fovifeso.dll",s (User '?')
O4 - HKUS\S-1-5-21-3316625921-3142970554-1853782496-1003\..\Run: [swg] C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe (User '?')
O4 - HKUS\S-1-5-21-3316625921-3142970554-1853782496-1003\..\Run: [MSMSGS] "C:\Program Files\Messenger\msmsgs.exe" /background (User '?')
O4 - HKUS\S-1-5-21-3316625921-3142970554-1853782496-1003\..\Run: [SmileboxTray] "C:\Documents and Settings\Owner\Application Data\Smilebox\SmileboxTray.exe" (User '?')
O4 - Global Startup: BigFix.lnk = C:\Program Files\BigFix\BigFix.exe
O4 - Global Startup: TrayMin315.exe.lnk = ?
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~3\Office12\REFIEBAR.DLL
O9 - Extra button: Real.com - {CD67F990-D8E9-11d2-98FE-00C0F0318AFE} - C:\WINDOWS\system32\Shdocvw.dll
O16 - DPF: {01113300-3E00-11D2-8470-0060089874ED} (Support.com Configuration Class) - [You must be registered and logged in to see this link.]
O16 - DPF: {406B5949-7190-4245-91A9-30A17DE16AD0} (Snapfish Activia) - [You must be registered and logged in to see this link.]
O16 - DPF: {D4323BF2-006A-4440-A2F5-27E3E7AB25F8} (Virtools WebPlayer Class) - [You must be registered and logged in to see this link.]
O23 - Service: CaCCProvSP - CA, Inc. - C:\Program Files\CA\CA Internet Security Suite\ccprovsp.exe
O23 - Service: CAISafe - Computer Associates International, Inc. - C:\Program Files\CA\CA Internet Security Suite\CA Anti-Virus\ISafe.exe
O23 - Service: CA Pest Patrol Realtime Protection Service (ITMRTSVC) - CA, Inc. - C:\Program Files\CA\SharedComponents\PPRT\bin\ITMRTSVC.exe
O23 - Service: lxcy_device - - C:\WINDOWS\system32\lxcycoms.exe
O23 - Service: Macromedia Licensing Service - Unknown owner - C:\Program Files\Common Files\Macromedia Shared\Service\Macromedia Licensing.exe
O23 - Service: MioNet Service (MioNet) - Unknown owner - C:\Program Files\MioNet\MioNetManager.exe
O23 - Service: PPCtlPriv - CA, Inc. - C:\Program Files\CA\CA Internet Security Suite\CA Anti-Spyware\PPCtlPriv.exe
O23 - Service: PrismXL - New Boundary Technologies, Inc. - C:\Program Files\Common Files\New Boundary\PrismXL\PRISMXL.SYS
O23 - Service: SupportSoft RemoteAssist - SupportSoft, Inc. - C:\Program Files\Common Files\supportsoft\bin\ssrc.exe
O23 - Service: HIPS Event Manager (UmxAgent) - CA - C:\Program Files\CA\SharedComponents\HIPSEngine\UmxAgent.exe
O23 - Service: HIPS Configuration Interpreter (UmxCfg) - CA - C:\Program Files\CA\SharedComponents\HIPSEngine\UmxCfg.exe
O23 - Service: HIPS Firewall Helper (UmxFwHlp) - CA - C:\Program Files\CA\SharedComponents\HIPSEngine\UmxFwHlp.exe
O23 - Service: HIPS Policy Manager (UmxPol) - CA - C:\Program Files\CA\SharedComponents\HIPSEngine\UmxPol.exe
O23 - Service: VET Message Service (VETMSGNT) - CA, Inc. - C:\Program Files\CA\CA Internet Security Suite\CA Anti-Virus\VetMsg.exe
O23 - Service: WinSock Svchost Manager (WinSvchostManager) - Unknown owner - C:\WINDOWS\system32\svcprs32.exe
End of file - 11978 bytes
fishininmt
OS : xp
# Likes : 0
Re: another system security problem
Post by Belahzur on Wed Aug 12, 2009 4:54 pm
# Likes : 1
Post by fishininmt on Wed Aug 12, 2009 6:03 pm
Here is MBAM log:
Malwarebytes' Anti-Malware 1.40
Database version: 2612
8/12/2009 12:02:11 PM
mbam-log-2009-08-12 (12-02-11).txt
Objects scanned: 98638
Time elapsed: 6 minute(s), 33 second(s)
fishininmt
OS : xp
# Likes : 0
Post by Belahzur on Wed Aug 12, 2009 9:11 pm
# Likes : 1
Post by fishininmt on Thu Aug 13, 2009 2:44 am
DDS (Ver_09-07-30.01) - NTFSx86
Run by Owner at 20:34:44.90 on Wed 08/12/2009
Internet Explorer: 6.0.2900.2180 BrowserJavaVersion: 1.6.0_15
AV: CA Anti-Virus *On-access scanning enabled* (Outdated) {17CFD1EA-56CF-40B5-A06B-BD3A27397C93}
FW: CA Personal Firewall *enabled* {14CB4B80-8E52-45EA-905E-67C1267B4160}
mDefault_Page_URL = [You must be registered and logged in to see this link.]
mDefault_Search_URL = [You must be registered and logged in to see this link.]
BHO: Google Toolbar Helper: {aa58ed58-01dd-4d91-8333-cf10577473f7} - c:\program files\google\google toolbar\GoogleToolbar.dll
BHO: Google Toolbar Notifier BHO: {af69de43-7d58-4638-b6fa-ce66b5ad205d} - c:\program files\google\googletoolbarnotifier\3.1.807.1746\swg.dll
BHO: CA Toolbar Helper: {fbf2401b-7447-4727-be5d-c19b2075ca84} - c:\program files\ca\ca internet security suite\ca website inspector\toolbar\CallingIDIE.dll
BHO: {FDD3B846-8D59-4ffb-8758-209B6AD74ACC} - No File
TB: &Google Toolbar: {2318c2b1-4965-11d4-9b18-009027a5cd4f} - c:\program files\google\google toolbar\GoogleToolbar.dll
TB: CA Toolbar: {10134636-e7af-4ac5-a1dc-c7c44bb97d81} - c:\program files\ca\ca internet security suite\ca website inspector\toolbar\CallingIDIE.dll
TB: {42CDD1BF-3FFB-4238-8AD1-7859DF00B1D6} - No File
EB: Real.com: {fe54fa40-d68c-11d2-98fa-00c0f0318afe} - c:\windows\system32\Shdocvw.dll
uRun: [swg] c:\program files\google\googletoolbarnotifier\GoogleToolbarNotifier.exe
uRun: [SKYLINK 2-in-1 Phone Utility] c:\program files\skylink\skylink 2-in-1 phone utility\SKYLINK 2-in-1 Phone Utility.exe
uRun: [SmileboxTray] "c:\documents and settings\owner\application data\smilebox\SmileboxTray.exe"
mRun: [Recguard] c:\windows\sminst\RECGUARD.EXE
mRun: [High Definition Audio Property Page Shortcut] HDAudPropShortcut.exe
mRun: [NeroFilterCheck] c:\windows\system32\NeroCheck.exe
mRun: [RemoteControl] "c:\program files\cyberlink\powerdvd\PDVDServ.exe"
mRun: [CHotkey] zHotkey.exe
mRun: [ShowWnd] ShowWnd.exe
mRun: [SunKistEM] c:\program files\digital media reader\shwiconem.exe
mRun: []
mRun: [SoundMan] SOUNDMAN.EXE
mRun: [AlcWzrd] ALCWZRD.EXE
mRun: [Alcmtr] ALCMTR.EXE
mRun: [SunJavaUpdateSched] "c:\program files\java\jre6\bin\jusched.exe"
mRun: [lxcymon.exe] "c:\program files\lexmark 3400 series\lxcymon.exe"
mRun: [EzPrint] "c:\program files\lexmark 3400 series\ezprint.exe"
mRun: [FaxCenterServer] "c:\program files\lexmark fax solutions\fm3032.exe" /s
mRun: [LXCYCATS] rundll32 c:\windows\system32\spool\drivers\w32x86\3\LXCYtime.dll,_RunDLLEntry@16
mRun: [Adobe Reader Speed Launcher] "c:\program files\adobe\reader 8.0\reader\Reader_sl.exe"
mRun: [BigDogPath] c:\windows\VM_STI.EXE Philips SPC315NC Webcam
mRun: [cctray] "c:\program files\ca\ca internet security suite\cctray\cctray.exe"
mRun: [QOELOADER] "c:\program files\ca\ca internet security suite\ca anti-spam\qsp-6.0.1.33\QOELoader.exe"
mRun: [CAVRID] "c:\program files\ca\ca internet security suite\ca anti-virus\CAVRID.exe"
mRun: [cafw] c:\program files\ca\ca internet security suite\ca personal firewall\cafw.exe -cl
mRun: [capfasem] c:\program files\ca\ca internet security suite\ca personal firewall\capfasem.exe
mRun: [capfupgrade] c:\program files\ca\ca internet security suite\ca personal firewall\capfupgrade.exe
StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\bigfix.lnk - c:\program files\bigfix\BigFix.exe
StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\traymi~1.lnk - c:\program files\philips\philips spc315nc webcam\TrayMin315.exe
mPolicies-explorer: EnableShellExecuteHooks = 1 (0x1)
IE: E&xport to Microsoft Excel
IE: {92780B25-18CC-41C8-B9BE-3C9C571A8263} - {FF059E31-CC5A-4E2E-BF3B-96E929D65503} - c:\progra~1\micros~3\office12\REFIEBAR.DLL
IE: {CD67F990-D8E9-11d2-98FE-00C0F0318AFE} - {FE54FA40-D68C-11d2-98FA-00C0F0318AFE} - c:\windows\system32\Shdocvw.dll
LSP: c:\windows\system32\VetRedir.dll
DPF: {01113300-3E00-11D2-8470-0060089874ED} - [You must be registered and logged in to see this link.]
DPF: {406B5949-7190-4245-91A9-30A17DE16AD0} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0014-0002-0000-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0015-0000-0011-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0016-0000-0003-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0016-0000-0005-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0016-0000-0007-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0016-0000-0015-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {D4323BF2-006A-4440-A2F5-27E3E7AB25F8} - [You must be registered and logged in to see this link.]
Handler: skype4com - {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - c:\progra~1\common~1\skype\SKYPE4~1.DLL
Notify: PFW - UmxWnp.Dll
SEH: ShellHook Class: {1869181a-9f50-4fcf-8bff-1b8588ecb85c} - c:\program files\ca\ca internet security suite\ca website inspector\linkadvisor\CIDLinkAdvisor.dll
FF - ProfilePath - c:\docume~1\owner\applic~1\mozilla\firefox\profiles\bnv22n3t.default\
FF - component: c:\program files\ca\ca internet security suite\ca website inspector\linkadvisor\firefox\components\CallingIDLinkAdvisorGecko.dll
FF - component: c:\program files\ca\ca internet security suite\ca website inspector\toolbar\firefox\components\CIDDomFx3.dll
FF - plugin: c:\documents and settings\owner\application data\mozilla\firefox\profiles\bnv22n3t.default\extensions\moveplayer@movenetworks.com\platform\winnt_x86-msvc\plugins\npmnqmp071300000040.dll
FF - plugin: c:\program files\viewpoint\viewpoint experience technology\npViewpoint.dll
FF - plugin: c:\program files\virtools\3d life player\npvirtools.dll
FF - HiddenExtension: Java Console: No Registry Reference - c:\program files\mozilla firefox\extensions\{CAFEEFAC-0016-0000-0007-ABCDEFFEDCBA}
FF - HiddenExtension: Java Console: No Registry Reference - c:\program files\mozilla firefox\extensions\{CAFEEFAC-0016-0000-0015-ABCDEFFEDCBA}
2009-08-11 12:38 --d----- c:\program files\Trend Micro
2009-08-10 23:20 411,368 a------- c:\windows\system32\deploytk.dll
2009-08-10 03:00 729,088 -c------ c:\windows\system32\dllcache\lsasrv.dll
2009-08-10 03:00 714,752 -c------ c:\windows\system32\dllcache\ntdll.dll
2009-08-10 03:00 617,472 -c------ c:\windows\system32\dllcache\advapi32.dll
2009-08-10 03:00 473,600 -c------ c:\windows\system32\dllcache\fastprox.dll
2009-08-10 03:00 453,120 -c------ c:\windows\system32\dllcache\wmiprvsd.dll
2009-08-10 03:00 401,408 -c------ c:\windows\system32\dllcache\rpcss.dll
2009-08-10 03:00 284,160 -c------ c:\windows\system32\dllcache\pdh.dll
2009-08-10 03:00 227,840 -c------ c:\windows\system32\dllcache\wmiprvse.exe
2009-08-10 03:00 110,592 -c------ c:\windows\system32\dllcache\services.exe
2009-08-09 10:18 1,203,922 -c------ c:\windows\system32\dllcache\sysmain.sdb
2009-08-09 10:18 215,552 -c------ c:\windows\system32\dllcache\wordpad.exe
2009-08-09 10:18 2,560 -------- c:\windows\system32\xpsp4res.dll
2009-08-09 10:06 --d----- c:\docume~1\owner\applic~1\Malwarebytes
2009-08-09 10:06 38,160 a------- c:\windows\system32\drivers\mbamswissarmy.sys
2009-08-09 10:06 19,096 a------- c:\windows\system32\drivers\mbam.sys
2009-08-09 10:06 --d----- c:\program files\Malwarebytes' Anti-Malware
2009-08-09 10:06 --d----- c:\docume~1\alluse~1\applic~1\Malwarebytes
2009-08-09 09:45 70,102 a------- c:\windows\system32\drivers\kmxcfg.u2k0
2009-08-09 09:45 64 a------- c:\windows\system32\drivers\kmxcfg.u2k7
2009-08-09 09:45 64 a------- c:\windows\system32\drivers\kmxcfg.u2k6
2009-08-09 09:45 64 a------- c:\windows\system32\drivers\kmxcfg.u2k5
2009-08-09 09:45 64 a------- c:\windows\system32\drivers\kmxcfg.u2k4
2009-08-09 09:45 64 a------- c:\windows\system32\drivers\kmxcfg.u2k3
2009-08-09 09:45 64 a------- c:\windows\system32\drivers\kmxcfg.u2k2
2009-08-09 09:45 64 a------- c:\windows\system32\drivers\kmxcfg.u2k1
2009-08-09 09:35 250,544 a------- c:\windows\system32\KeyHelp.ocx
2009-08-09 09:35 --d----- c:\program files\common files\Scanner
2009-08-09 09:34 879,760 a------- c:\windows\system32\drivers\vetefile.sys
2009-08-09 09:34 108,288 a------- c:\windows\system32\drivers\veteboot.sys
2009-08-09 09:34 99,568 a------- c:\windows\system32\isafeif.dll
2009-08-09 09:34 91,376 a------- c:\windows\system32\isafprod.dll
2009-08-09 09:34 83,256 a------- c:\windows\system32\vetredir.dll
2009-08-09 09:34 32,240 a------- c:\windows\system32\drivers\vetmonnt.sys
2009-08-09 09:34 26,352 a------- c:\windows\system32\drivers\vet-filt.sys
2009-08-09 09:34 21,488 a------- c:\windows\system32\drivers\vetfddnt.sys
2009-08-09 09:34 21,104 a------- c:\windows\system32\drivers\vet-rec.sys
2009-08-08 23:18 5,120 a------- c:\windows\system32\drivers\c3bd37fb.sys
2009-08-06 16:02 --d----- c:\program files\Skype
2009-08-02 17:04 --d----- c:\windows\system32\wbem\Repository
2009-08-02 17:03 --d----- c:\docume~1\owner\applic~1\CallingID
2009-08-02 17:03 --d----- c:\docume~1\alluse~1\applic~1\CA
2009-08-02 17:03 --d----- c:\program files\CA
2009-08-02 14:19 --d----- c:\docume~1\alluse~1\applic~1\CA(2)
2009-08-02 14:19 --d----- c:\program files\CA(2)
2009-07-18 10:05 1,509,888 -c------ c:\windows\system32\dllcache\shdocvw.dll
2009-06-26 10:50 666,624 a------- c:\windows\system32\wininet.dll
2009-06-26 10:50 81,920 a------- c:\windows\system32\ieencode.dll
2009-06-16 08:36 119,808 a------- c:\windows\system32\t2embed.dll
2009-06-16 08:36 81,920 a------- c:\windows\system32\fontsub.dll
2009-06-05 22:05 90,112 a------- c:\windows\DUMP4ce7.tmp
2009-06-03 13:09 1,291,264 a------- c:\windows\system32\quartz.dll
2008-06-16 22:26 126 a------- c:\docume~1\owner\applic~1\wklnhst.dat
2008-10-01 16:42 30,720 a--sh--- c:\windows\rnapxs\rnapxs.dat
2008-08-20 11:39 32,768 a--sh--- c:\windows\system32\config\systemprofile\local settings\history\history.ie5\mshist012008082020080821\index.dat
============= FINISH: 20:36:30.79 ===============
fishininmt
OS : xp
# Likes : 0
Post by Belahzur on Thu Aug 13, 2009 4:32 pm
How is the machine running? log looks ok.
# Likes : 1
Post by fishininmt on Thu Aug 13, 2009 7:44 pm
It seems to be running fine,but I'm still experiecing the computer restarting on its own and then the message that the system has recovered from a serious error. This problem was happening before the virus so it must be unrelated and a separate issue.
fishininmt
OS : xp
# Likes : 0
Post by Belahzur on Fri Aug 14, 2009 6:24 pm
Okay, lets uninstall some old software, then we'll see if we can dig up anything about the restarting problems.
  • Open HijackThis.
# Likes : 1
Post by fishininmt on Fri Aug 14, 2009 7:29 pm
2007 Microsoft Office Suite Service Pack 1 (SP1)
3DVIA player 4.1
ABBYY FineReader 6.0 Sprint
Adobe Acrobat and Reader 8.1.2 Security Update 1 (KB403742)
Adobe AIR
Adobe AIR
Adobe Flash Player 10 ActiveX
Adobe Flash Player 10 Plugin
Adobe Media Player
Adobe Media Player
Adobe Reader 8.1.2
Apple Mobile Device Support
Apple Software Update
Avanquest update
AVIConverter 5.1.0
BigFix
Bonjour
BresnanClientSetup
CA Anti-Spyware
CA Anti-Virus
CA Desktop DNA Migrator
GIMP 2.4.5
Google Earth
HijackThis 2.0.2
Intel(R) PRO Network Adapters and Drivers
iTunes
J2SE Runtime Environment 5.0 Update 11
Java 2 Runtime Environment, SE v1.4.2
Java(TM) 6 Update 15
Java(TM) 6 Update 3
Java(TM) 6 Update 5
Java(TM) 6 Update 7
Learn2 Player (Uninstall Only)
Lexmark 3400 Series
Microsoft .NET Framework 1.1
Microsoft Age of Empires II
Microsoft Money 2004
Microsoft Money 2004 System Pack
Microsoft Office Access MUI (English) 2007
Microsoft Office Access Setup Metadata MUI (English) 2007
Microsoft Office InfoPath MUI (English) 2007
Microsoft Office Professional Plus 2007
Microsoft Office Publisher MUI (English) 2007
Microsoft Picture It! Photo Premium 9
Microsoft Silverlight
Microsoft Works
MioNet
Mozilla Firefox (3.0.13)
MSN
MSXML 4.0 SP2 (KB936181)
MSXML 4.0 SP2 (KB954430)
Multimedia Keyboard Driver
Nero BurnRights
Nero OEM
Netflix Movie Viewer
oobeFlagNetscape0
Philips VLounge
PowerDVD
QuickTime
RealPlayer Basic
SampleTestInstall
Security Update for 2007 Microsoft Office System (KB951550)
Security Update for 2007 Microsoft Office System (KB951944)
Security Update for 2007 Microsoft Office System (KB958439)
Security Update for Microsoft Office Excel 2007 (KB958437)
Security Update for Microsoft Office PowerPoint 2007 (KB951338)
Security Update for Microsoft Office Publisher 2007 (KB950114)
Security Update for Microsoft Office system 2007 (KB954326)
Security Update for Microsoft Office system 2007 (KB956828)
Security Update for Microsoft Office Word 2007 (KB956358)
Skype™ 3.8
SoftV92 Data Fax Modem with SmartCP
Update for Microsoft Office Outlook 2007 (KB952142)
Update for Office 2007 (KB946691)
Update for Outlook 2007 Junk Email Filter (kb959634)
Viewpoint Media Player
Web Easy Professional 7
Windows Backup Utility
Windows XP Service Pack 3
fishininmt
OS : xp
# Likes : 0
Post by Belahzur on Fri Aug 14, 2009 8:50 pm
    Java(TM) 6 Update 3
    Java(TM) 6 Update 5
    Java(TM) 6 Update 7
Have you installed any other software other than what we have used here?
I ask because I used to get this error alot, turns out Folder Locker was causing it.
# Likes : 1
Post by fishininmt on Sat Aug 15, 2009 9:30 pm
I can't think of any programs that I've installed other than those. I'm having trouble removing the ones you told me to remove the java update 3 5 and 7. I've got all but one of those removed but for some reason it just won't remove it. Also I think I still have a virus on here. I've noticed on the internet that when you do a search and click on the search results that it redirects to another page sometimes it takes me to a site that looks like the my computer screen and it says that the computer is infected. Malwarebytes doesn't turn up anything. But I ran the spyware doctor program and it showed the trojan.virtumonde on there I deleted it. I was reading that that trojan hides out in the java updates sometimes so I'm wondering if that's why I can't remove the program. I also have computer associates internet security and it keeps saying that it is unable to update. I'm also getting this message at startup, "One of the files containing the system's Registry data had to be recovered by use of a log or alternate copy. The recovery was successful." So this machine seems to have a lot of problems right now. Thanks for your help.
fishininmt
OS : xp
# Likes : 0
Post by Belahzur on Sat Aug 15, 2009 11:44 pm
  • First, unzip it.
  • Then run JavaRa. (If you are running Vista, you will need to right click JavaRa > select "Run as administrator")
  • This will open JavaRa.
  • Press Remove older versions
  • Press yes to the prompt.
# Likes : 1
Post by fishininmt on Sun Aug 16, 2009 3:02 pm
JavaRa 1.15 Removal Log.
Report follows after line.
The JavaRa removal process was started on Sun Aug 16 08:59:15 2009
Found and removed: C:\Program Files\Java\jre1.6.0_05
Found and removed: C:\Program Files\Java\jre1.6.0_07
Found and removed: SOFTWARE\JavaSoft\Java Runtime Environment\1.4
Found and removed: Software\JavaSoft\Java2D\1.5.0_11
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0011-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\JavaPlugin.150_11
Found and removed: SOFTWARE\Classes\JavaWebStart.isInstalled.1.5.0.0
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0003-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0005-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0003-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0005-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0003-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0005-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\Installer\Features\8A0F842331866D117AB7000B0D610005
Found and removed: SOFTWARE\Classes\Installer\Products\8A0F842331866D117AB7000B0D610005
Found and removed: SOFTWARE\Classes\Installer\UpgradeCodes\7A0F842331866D117AB7000B0D610005
Found and removed: SOFTWARE\Classes\JavaPlugin.160_03
Found and removed: SOFTWARE\Classes\JavaPlugin.160_05
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UpgradeCodes\7A0F842331866D117AB7000B0D610005
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\ACBB9B2318A96D117A58000B0D610005
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\8A0F842331866D117AB7000B0D610005
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{3248F0A8-6813-11D6-A77B-00B0D0160050}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0000-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0000-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\8A0F841731866D117AB7000B0D410200
Found and removed: SOFTWARE\Classes\JavaPlugin.142
Found and removed: SOFTWARE\JavaSoft\Java Plug-in\1.6.0_07
Found and removed: SOFTWARE\JavaSoft\Java Runtime Environment\1.6.0_07
Found and removed: SOFTWARE\Microsoft\Active Setup\Installed Components\{08B0E5C0-4FCB-11CF-AAA5-00401C608500}
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\ACBB9B2318A96D117A58000B0D610007
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\8A0F842331866D117AB7000B0D610007
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{3248F0A8-6813-11D6-A77B-00B0D0160070}
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\Folders\\C:\Program Files\Java\jre1.6.0_05\
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\Folders\\C:\Program Files\Java\jre1.6.0_05\bin\
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\Folders\\C:\Program Files\Java\jre1.6.0_07\bin\
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\Folders\C:\Program Files\Common Files\Java\Update\Base Images\jre1.6.0.b105\patch-jre1.6.0_05.b13\
Finished reporting.
fishininmt
OS : xp
# Likes : 0
Post by Belahzur on Sun Aug 16, 2009 6:51 pm
The old versions of Java are gone now.
  • Download combofix from here
# Likes : 1
Post by fishininmt on Mon Aug 17, 2009 7:43 pm
ComboFix 09-08-10.06 - Owner 08/17/2009 12:59.1.2 - NTFSx86
Running from: c:\documents and settings\Owner\Desktop\Combo-Fix.exe
AV: CA Anti-Virus *On-access scanning disabled* (Outdated) {17CFD1EA-56CF-40B5-A06B-BD3A27397C93}
FW: CA Personal Firewall *disabled* {14CB4B80-8E52-45EA-905E-67C1267B4160}
* Created a new restore point
c:\recycler\S-1-5-21-3930982258-2436965536-317756311-1003
c:\windows\Installer\109ebc.msi
c:\windows\Installer\25974bb.msp
c:\windows\Installer\25974bd.msp
c:\windows\Installer\28551bc.msp
c:\windows\Installer\28551be.msp
c:\windows\Installer\2abd045.msi
c:\windows\Installer\3178f8a.msp
c:\windows\Installer\50fd01c.msi
c:\windows\Installer\5903c7e.msi
c:\windows\system32\drivers\SKYNETnetlwhxv.sys
c:\windows\system32\SKYNETnbowpilt.dat
c:\windows\system32\SKYNETrevxubld.dll
c:\windows\system32\SKYNETstlxymxf.dat
c:\windows\system32\SKYNETvhpmpexn.dll
D:\Autorun.inf
-------\Service_SKYNETpxmepcfm
-------\Legacy_SKYNETpxmepcfm
((((((((((((((((((((((((( Files Created from 2009-07-17 to 2009-08-17 )))))))))))))))))))))))))))))))
2009-08-17 00:31 . 2009-08-17 00:31 -------- d-----w- c:\program files\Bonjour
2009-08-16 18:36 . 2009-08-16 18:36 544768 ----a-w- c:\documents and settings\All Users\Application Data\CA-SupportBridge\Tools.Scripting.Client.dll
2009-08-16 18:36 . 2009-08-16 18:36 22016 ----a-w- c:\documents and settings\All Users\Application Data\CA-SupportBridge\Tools.Scripting.Client_rc.dll
2009-08-16 18:35 . 2009-08-16 18:35 70920 ----a-w- c:\documents and settings\All Users\Application Data\CA-SupportBridge\Customer_rc.dll
2009-08-16 18:35 . 2009-08-16 18:35 626440 ----a-w- c:\documents and settings\All Users\Application Data\CA-SupportBridge\Customer.exe
2009-08-16 18:35 . 2009-08-16 18:35 599304 ----a-w- c:\documents and settings\All Users\Application Data\CA-SupportBridge\Controller.exe
2009-08-16 18:16 . 2008-08-30 21:14 26352 ----a-w- c:\windows\system32\drivers\vet-filt.sys
2009-08-16 18:16 . 2008-08-30 21:14 91376 ----a-w- c:\windows\system32\isafprod.dll
2009-08-16 18:16 . 2008-08-30 21:14 32240 ----a-w- c:\windows\system32\drivers\vetmonnt.sys
2009-08-16 18:16 . 2008-08-30 21:14 21104 ----a-w- c:\windows\system32\drivers\vet-rec.sys
2009-08-16 18:16 . 2008-08-30 21:14 108288 ----a-w- c:\windows\system32\drivers\veteboot.sys
2009-08-16 18:16 . 2008-08-30 21:14 21488 ----a-w- c:\windows\system32\drivers\vetfddnt.sys
2009-08-16 18:16 . 2008-08-30 21:14 879760 ----a-w- c:\windows\system32\drivers\vetefile.sys
2009-08-16 18:16 . 2009-08-16 18:16 -------- d-sh--w- c:\documents and settings\Owner\IECompatCache
2009-08-16 18:05 . 2009-08-16 18:05 20232 ----a-w- c:\documents and settings\All Users\Application Data\CA-SupportBridge\SelfServe_rc.dll
2009-08-16 18:05 . 2009-08-16 18:05 615688 ----a-w- c:\documents and settings\All Users\Application Data\CA-SupportBridge\SelfServe.exe
2009-08-16 18:05 . 2009-08-16 18:05 353544 ----a-w- c:\documents and settings\All Users\Application Data\CA-SupportBridge\SoftwareUpdater.exe
2009-08-16 18:05 . 2009-08-16 18:36 -------- d-----w- c:\documents and settings\All Users\Application Data\CA-SupportBridge
2009-08-16 18:05 . 2009-08-16 18:05 632072 ----a-w- c:\documents and settings\All Users\Application Data\CA-SupportBridge\msvcr80.dll
2009-08-15 19:37 . 2008-12-11 14:38 159600 ----a-w- c:\windows\system32\drivers\pctgntdi.sys
2009-08-15 19:36 . 2009-04-03 17:18 130936 ----a-w- c:\windows\system32\drivers\PCTCore.sys
2009-08-15 19:36 . 2008-12-18 18:16 73840 ----a-w- c:\windows\system32\drivers\PCTAppEvent.sys
2009-08-15 19:36 . 2009-08-15 19:37 -------- d-----w- c:\program files\Common Files\PC Tools
2009-08-15 19:36 . 2008-12-10 17:36 64392 ----a-w- c:\windows\system32\drivers\pctplsg.sys
2009-08-15 19:36 . 2009-08-17 19:15 -------- d-----w- c:\program files\Spyware Doctor
2009-08-15 19:36 . 2009-08-15 19:36 -------- d-----w- c:\documents and settings\Owner\Application Data\PC Tools
2009-08-15 19:36 . 2009-08-15 19:36 -------- d-----w- c:\documents and settings\All Users\Application Data\PC Tools
2009-08-15 19:12 . 2009-08-15 19:12 -------- d-----w- c:\documents and settings\All Users\Application Data\Norton
2009-08-15 19:12 . 2009-08-15 19:12 -------- d-----w- c:\windows\system32\drivers\NSS
2009-08-15 19:12 . 2009-08-15 19:12 -------- d-----w- c:\program files\Norton Security Scan
2009-08-15 19:12 . 2009-08-15 19:12 -------- d-----w- c:\program files\NortonInstaller
2009-08-15 19:12 . 2009-08-15 19:12 -------- d-----w- c:\documents and settings\All Users\Application Data\NortonInstaller
2009-08-15 19:11 . 2009-08-15 19:35 -------- d-----w- c:\documents and settings\All Users\Application Data\Google Updater
2009-08-15 18:33 . 2009-08-15 18:33 -------- d-----w- C:\VundoFix Backups
2009-08-15 18:10 . 2009-08-17 19:15 -------- d---a-w- c:\documents and settings\All Users\Application Data\TEMP
2009-08-15 01:37 . 2009-08-15 01:38 -------- dc-h--w- c:\windows\ie8
2009-08-15 00:03 . 2009-08-15 00:03 -------- d-sh--w- c:\documents and settings\Owner\PrivacIE
2009-08-14 23:30 . 2009-08-14 23:30 -------- d-sh--w- c:\windows\system32\config\systemprofile\IETldCache
2009-08-14 23:29 . 2009-08-14 23:29 -------- d-sh--w- c:\documents and settings\Owner\IETldCache
2009-08-14 23:25 . 2009-07-03 17:09 12800 -c----w- c:\windows\system32\dllcache\xpshims.dll
2009-08-14 23:25 . 2009-07-03 17:09 246272 -c----w- c:\windows\system32\dllcache\ieproxy.dll
2009-08-14 23:25 . 2009-08-15 01:30 -------- d-----w- c:\windows\ie8updates
2009-08-14 23:25 . 2009-07-01 07:08 101376 -c----w- c:\windows\system32\dllcache\iecompat.dll
2009-08-13 08:36 . 2009-07-10 13:27 1315328 -c----w- c:\windows\system32\dllcache\msoe.dll
2009-08-11 18:38 . 2009-08-11 18:38 -------- d-----w- c:\program files\Trend Micro
2009-08-11 05:20 . 2009-08-11 05:19 411368 ----a-w- c:\windows\system32\deploytk.dll
2009-08-11 05:19 . 2009-08-11 05:19 152576 ----a-w- c:\documents and settings\Owner\Application Data\Sun\Java\jre1.6.0_15\lzma.dll
2009-08-10 09:00 . 2009-06-25 08:25 730112 -c----w- c:\windows\system32\dllcache\lsasrv.dll
2009-08-10 09:00 . 2009-03-06 14:22 284160 -c----w- c:\windows\system32\dllcache\pdh.dll
2009-08-10 09:00 . 2009-02-09 12:10 714752 -c----w- c:\windows\system32\dllcache\ntdll.dll
2009-08-10 09:00 . 2009-02-09 12:10 617472 -c----w- c:\windows\system32\dllcache\advapi32.dll
2009-08-10 09:00 . 2009-02-09 12:10 473600 -c----w- c:\windows\system32\dllcache\fastprox.dll
2009-08-10 09:00 . 2009-02-09 12:10 453120 -c----w- c:\windows\system32\dllcache\wmiprvsd.dll
2009-08-10 09:00 . 2009-02-09 12:10 401408 -c----w- c:\windows\system32\dllcache\rpcss.dll
2009-08-10 09:00 . 2009-02-06 11:11 110592 -c----w- c:\windows\system32\dllcache\services.exe
2009-08-10 09:00 . 2009-02-06 10:10 227840 -c----w- c:\windows\system32\dllcache\wmiprvse.exe
2009-08-09 16:18 . 2008-05-03 11:55 2560 ------w- c:\windows\system32\xpsp4res.dll
2009-08-09 16:18 . 2008-04-21 12:08 215552 -c----w- c:\windows\system32\dllcache\wordpad.exe
2009-08-09 16:06 . 2009-08-09 16:06 -------- d-----w- c:\documents and settings\Owner\Application Data\Malwarebytes
2009-08-09 16:06 . 2009-08-03 19:36 38160 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2009-08-09 16:06 . 2009-08-09 16:06 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
2009-08-09 16:06 . 2009-08-09 16:06 -------- d-----w- c:\documents and settings\All Users\Application Data\Malwarebytes
2009-08-09 16:06 . 2009-08-03 19:36 19096 ----a-w- c:\windows\system32\drivers\mbam.sys
2009-08-02 20:19 . 2009-08-02 23:03 -------- d-----w- c:\documents and settings\All Users\Application Data\CA(2)
2009-08-02 20:19 . 2009-08-02 23:03 -------- d-----w- c:\program files\CA(2)
fishininmt
OS : xp
# Likes : 0
Post by fishininmt on Mon Aug 17, 2009 7:44 pm
2009-08-17 18:54 . 2009-08-09 15:45 94262 ----a-w- c:\windows\system32\drivers\kmxcfg.u2k0
2009-08-17 18:54 . 2009-08-09 15:45 64 ----a-w- c:\windows\system32\drivers\kmxcfg.u2k7
2009-08-17 18:54 . 2009-08-09 15:45 64 ----a-w- c:\windows\system32\drivers\kmxcfg.u2k6
2009-08-17 18:54 . 2009-08-09 15:45 64 ----a-w- c:\windows\system32\drivers\kmxcfg.u2k5
2009-08-17 18:54 . 2009-08-09 15:45 64 ----a-w- c:\windows\system32\drivers\kmxcfg.u2k4
2009-08-17 18:54 . 2009-08-09 15:45 64 ----a-w- c:\windows\system32\drivers\kmxcfg.u2k3
2009-08-17 18:54 . 2009-08-09 15:45 64 ----a-w- c:\windows\system32\drivers\kmxcfg.u2k2
2009-08-17 18:54 . 2009-08-09 15:45 64 ----a-w- c:\windows\system32\drivers\kmxcfg.u2k1
2009-08-17 18:44 . 2008-05-03 23:05 -------- d-----w- c:\documents and settings\Owner\Application Data\Skype
2009-08-17 18:28 . 2008-03-17 05:11 -------- d-----w- c:\program files\lx_cats
2009-08-17 18:26 . 2008-05-03 23:00 -------- d-----w- c:\program files\MioNet
2009-08-17 18:07 . 2008-03-11 05:10 664 ----a-w- c:\windows\system32\d3d9caps.dat
2009-08-17 16:10 . 2008-06-10 22:49 -------- d-----w- c:\documents and settings\Owner\Application Data\skypePM
2009-08-17 02:47 . 2009-08-02 23:03 -------- d-----w- c:\documents and settings\Owner\Application Data\CallingID
2009-08-16 18:25 . 2009-08-09 15:35 -------- d-----w- c:\program files\Common Files\Scanner
2009-08-16 18:13 . 2008-10-01 22:36 -------- d-----w- c:\documents and settings\Owner\Application Data\GetRightToGo
2009-08-16 14:59 . 2008-02-12 23:10 -------- d-----w- c:\program files\Java
2009-08-15 19:34 . 2008-05-07 20:12 -------- d-----w- c:\documents and settings\All Users\Application Data\Microsoft Help
2009-08-15 19:16 . 2008-02-12 23:05 -------- d-----w- c:\program files\Common Files\Symantec Shared
2009-08-15 19:12 . 2008-02-12 23:05 -------- d-----w- c:\documents and settings\All Users\Application Data\Symantec
2009-08-15 19:10 . 2008-03-03 05:32 -------- d-----w- c:\program files\Google
2009-08-09 15:36 . 2009-08-02 23:03 -------- d-----w- c:\documents and settings\All Users\Application Data\CA
2009-08-09 15:35 . 2009-08-02 23:03 -------- d-----w- c:\program files\CA
2009-08-09 05:18 . 2009-08-09 05:18 5120 ----a-w- c:\windows\system32\drivers\c3bd37fb.sys
2009-08-06 22:02 . 2009-08-06 22:02 -------- d-----w- c:\program files\Skype
2009-08-06 22:02 . 2008-06-10 22:48 -------- d-----w- c:\documents and settings\All Users\Application Data\Skype
2009-08-06 22:02 . 2009-08-06 22:02 -------- d-----w- c:\program files\Common Files\Skype
2009-08-05 09:01 . 2004-08-26 16:12 204800 ----a-w- c:\windows\system32\mswebdvd.dll
2009-08-04 14:56 . 2009-08-04 14:56 1961720 ----a-w- c:\documents and settings\Owner\Application Data\Macromedia\Flash Player\[You must be registered and logged in to see this link.]
2009-08-02 23:03 . 2008-02-12 23:04 -------- d--h--w- c:\program files\InstallShield Installation Information
2009-08-02 23:03 . 2008-02-12 23:04 -------- d-----w- c:\program files\Common Files\InstallShield
2009-07-17 19:01 . 2004-08-26 16:11 58880 ----a-w- c:\windows\system32\atl.dll
2009-07-14 05:43 . 2004-08-26 16:12 286208 ----a-w- c:\windows\system32\wmpdxm.dll
2009-07-03 17:09 . 2004-08-26 16:12 915456 ----a-w- c:\windows\system32\wininet.dll
2009-07-01 20:08 . 2009-07-01 20:08 1878984 ----a-w- c:\documents and settings\Owner\Application Data\Macromedia\Flash Player\[You must be registered and logged in to see this link.]
2009-06-25 08:25 . 2004-08-26 16:12 54272 ----a-w- c:\windows\system32\wdigest.dll
2009-06-25 08:25 . 2004-08-26 16:12 56832 ----a-w- c:\windows\system32\secur32.dll
2009-06-25 08:25 . 2004-08-26 16:12 147456 ----a-w- c:\windows\system32\schannel.dll
2009-06-25 08:25 . 2004-08-26 16:12 136192 ----a-w- c:\windows\system32\msv1_0.dll
2009-06-25 08:25 . 2004-08-26 16:11 730112 ----a-w- c:\windows\system32\lsasrv.dll
2009-06-25 08:25 . 2004-08-26 16:11 301568 ----a-w- c:\windows\system32\kerberos.dll
2009-06-24 11:18 . 2004-08-26 16:11 92928 ----a-w- c:\windows\system32\drivers\ksecdd.sys
2009-06-16 14:36 . 2004-08-26 16:12 119808 ----a-w- c:\windows\system32\t2embed.dll
2009-06-16 14:36 . 2004-08-26 16:11 81920 ----a-w- c:\windows\system32\fontsub.dll
2009-06-12 12:31 . 2004-08-26 16:12 76288 ----a-w- c:\windows\system32\telnet.exe
2009-06-10 15:19 . 2004-08-26 18:00 2066432 ----a-w- c:\windows\system32\mstscax.dll
2009-06-10 14:13 . 2004-08-26 16:11 84992 ----a-w- c:\windows\system32\avifil32.dll
2009-06-10 06:14 . 2004-08-26 16:12 132096 ----a-w- c:\windows\system32\wkssvc.dll
2009-06-06 04:05 . 2008-02-12 22:50 90112 ----a-w- c:\windows\DUMP4ce7.tmp
2009-06-03 19:09 . 2004-08-26 16:12 1291264 ----a-w- c:\windows\system32\quartz.dll
2008-10-01 22:42 . 2008-10-01 22:42 30720 --sha-w- c:\windows\rnapxs\rnapxs.dat
fishininmt
OS : xp
# Likes : 0
"swg"="c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2008-05-04 68856]
"SKYLINK 2-in-1 Phone Utility"="c:\program files\SkyLink\SKYLINK 2-in-1 Phone Utility\SKYLINK 2-in-1 Phone Utility.exe" [2006-12-07 315392]
"SmileboxTray"="c:\documents and settings\Owner\Application Data\Smilebox\SmileboxTray.exe" [2009-01-29 254600]
"RegistryMechanic"="c:\program files\Registry Mechanic\RegMech.exe" [2009-06-30 2836376]
"Recguard"="c:\windows\SMINST\RECGUARD.EXE" [2002-09-13 212992]
"RemoteControl"="c:\program files\CyberLink\PowerDVD\PDVDServ.exe" [2003-11-01 32768]
"SunKistEM"="c:\program files\Digital Media Reader\shwiconem.exe" [2004-10-18 135168]
"QuickTime Task"="c:\program files\QuickTime\qttask.exe" [2008-11-04 413696]
"lxcymon.exe"="c:\program files\Lexmark 3400 Series\lxcymon.exe" [2007-06-25 291504]
"EzPrint"="c:\program files\Lexmark 3400 Series\ezprint.exe" [2007-06-25 82608]
"FaxCenterServer"="c:\program files\Lexmark Fax Solutions\fm3032.exe" [2007-06-25 295600]
"LXCYCATS"="c:\windows\System32\spool\DRIVERS\W32X86\3\LXCYtime.dll" [2006-11-21 106496]
"Adobe Reader Speed Launcher"="c:\program files\Adobe\Reader 8.0\Reader\Reader_sl.exe" [2008-01-12 39792]
"BigDogPath"="c:\windows\VM_STI.EXE" [2004-06-09 40960]
"cctray"="c:\program files\CA\CA Internet Security Suite\cctray\cctray.exe" [2009-05-21 181488]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2008-11-20 290088]
"CAVRID"="c:\program files\CA\CA Internet Security Suite\CA Anti-Virus\CAVRID.exe" [2008-08-30 234736]
"cafw"="c:\program files\CA\CA Internet Security Suite\CA Personal Firewall\cafw.exe" [2008-08-28 771312]
"capfasem"="c:\program files\CA\CA Internet Security Suite\CA Personal Firewall\capfasem.exe" [2008-08-28 173296]
"capfupgrade"="c:\program files\CA\CA Internet Security Suite\CA Personal Firewall\capfupgrade.exe" [2008-08-28 259312]
"ISTray"="c:\program files\Spyware Doctor\pctsTray.exe" [2008-12-08 1173384]
"High Definition Audio Property Page Shortcut"="HDAudPropShortcut.exe" - c:\windows\system32\Hdaudpropshortcut.exe [2004-03-17 61952]
"CHotkey"="zHotkey.exe" - c:\windows\zHotkey.exe [2004-05-18 543232]
"ShowWnd"="ShowWnd.exe" - c:\windows\ShowWnd.exe [2003-09-19 36864]
"SoundMan"="SOUNDMAN.EXE" - c:\windows\SOUNDMAN.EXE [2004-09-24 77824]
"AlcWzrd"="ALCWZRD.EXE" - c:\windows\ALCWZRD.EXE [2004-09-25 2559488]
BigFix.lnk - c:\program files\BigFix\BigFix.exe [2008-2-12 1742384]
TrayMin315.exe.lnk - c:\program files\Philips\Philips SPC315NC Webcam\TrayMin315.exe [2008-5-3 278528]
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\policies\explorer]
"EnableShellExecuteHooks"= 1 (0x1)
"{1869181A-9F50-4FCF-8BFF-1B8588ECB85C}"= "c:\program files\CA\CA Internet Security Suite\CA Website Inspector\LinkAdvisor\CIDLinkAdvisor.dll" [2008-06-23 1373624]
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\PFW]
2007-05-18 20:30 79368 ----a-w- c:\windows\system32\UmxWNP.dll
[HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\CA Personal Firewall]
[HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\ComputerAssociatesAntiVirus]
"EnableFirewall"= 0 (0x0)
"c:\\WINDOWS\\system32\\lxcycoms.exe"=
"1700:TCP"= 1700:TCP:MioNet Remote Drive Access
"1641:TCP"= 1641:TCP:MioNet Remote Drive Verification
R1 c3bd37fb.sys;c3bd37fb.sys;c:\windows\System32\drivers\c3bd37fb.sys [2009-08-09 5120]
R3 MBAMSwissArmy;MBAMSwissArmy;c:\windows\system32\drivers\mbamswissarmy.sys [2009-08-03 38160]
R3 PPCtlPriv;PPCtlPriv;c:\program files\CA\CA Internet Security Suite\CA Anti-Spyware\PPCtlPriv.exe [2008-08-28 185584]
S0 KmxStart;KmxStart;c:\windows\System32\DRIVERS\kmxstart.sys [2008-03-19 93712]
S0 PCTCore;PCTools KDS;c:\windows\system32\drivers\PCTCore.sys [2009-04-03 130936]
S1 KmxAgent;KmxAgent;c:\windows\system32\DRIVERS\kmxagent.sys [2008-03-21 63504]
S1 KmxFile;KmxFile;c:\windows\system32\DRIVERS\KmxFile.sys [2008-03-21 45584]
S1 KmxFw;KmxFw;c:\windows\system32\DRIVERS\kmxfw.sys [2008-03-19 115216]
S2 KmxCF;KmxCF;c:\windows\system32\DRIVERS\KmxCF.sys [2008-06-04 134648]
S2 KmxSbx;KmxSbx;c:\windows\system32\DRIVERS\KmxSbx.sys [2008-03-21 66576]
S2 lxcy_device;lxcy_device;c:\windows\system32\lxcycoms.exe [2007-06-20 537264]
S2 MioNet;MioNet Service;c:\program files\MioNet\MioNetManager.exe [2005-07-15 139264]
S2 sdAuxService;PC Tools Auxiliary Service;c:\program files\Spyware Doctor\pctsAuxs.exe [2009-01-07 348752]
S2 UmxAgent;HIPS Event Manager;c:\program files\CA\SharedComponents\HIPSEngine\UmxAgent.exe [2007-10-18 1010192]
S2 UmxCfg;HIPS Configuration Interpreter;c:\program files\CA\SharedComponents\HIPSEngine\UmxCfg.exe [2007-10-18 801296]
S2 UmxPol;HIPS Policy Manager;c:\program files\CA\SharedComponents\HIPSEngine\UmxPol.exe [2008-04-15 281104]
S2 WinSvchostManager;WinSock Svchost Manager;c:\windows\system32\svcprs32.exe [2007-11-14 823296]
S3 KmxCfg;KmxCfg;c:\windows\system32\DRIVERS\kmxcfg.sys [2008-05-30 88816]
fishininmt
OS : xp
# Likes : 0
Post by fishininmt on Mon Aug 17, 2009 7:45 pm
*Deregistered* - mchInjDrv
*Deregistered* - NDISRD
[HKEY_LOCAL_MACHINE\software\microsoft\active setup\installed components\>{60B49E34-C7CC-11D0-8953-00A0C90347FF}]
"c:\windows\system32\rundll32.exe" "c:\windows\system32\iedkcs32.dll",BrandIEActiveSetup SIGNUP
2009-08-10 c:\windows\Tasks\CAAntiSpywareScan_Daily as Owner at 9 35 AM.job
- c:\program files\CA\CA Internet Security Suite\CA Anti-Spyware\CAAntiSpyware.exe [2009-08-09 00:44]
2009-08-17 c:\windows\Tasks\Google Software Updater.job
- c:\program files\Google\Common\Google Updater\GoogleUpdaterService.exe [2008-03-03 19:10]
2009-08-15 c:\windows\Tasks\Norton Security Scan for Owner.job
- c:\program files\Norton Security Scan\Engine\2.3.0.44\Nss.exe [2009-08-15 19:12]
HKLM-Run-QOELOADER - c:\program files\CA\CA Internet Security Suite\CA Anti-Spam\QSP-6.0.1.33\QOELoader.exe
FF - ProfilePath - c:\documents and settings\Owner\Application Data\Mozilla\Firefox\Profiles\bnv22n3t.default\
FF - component: c:\program files\CA\CA Internet Security Suite\CA Website Inspector\LinkAdvisor\Firefox\components\CallingIDLinkAdvisorGecko.dll
FF - component: c:\program files\CA\CA Internet Security Suite\CA Website Inspector\Toolbar\Firefox\components\CIDDomFx3.dll
FF - plugin: c:\documents and settings\Owner\Application Data\Mozilla\Firefox\Profiles\bnv22n3t.default\extensions\moveplayer@movenetworks.com\platform\WINNT_x86-msvc\plugins\npmnqmp071300000040.dll
FF - plugin: c:\program files\Google\Google Updater\2.4.1636.7222\npCIDetect13.dll
FF - plugin: c:\program files\Virtools\3D Life Player\npvirtools.dll
disk not found C:\
please note that you need administrator rights to perform deep scan
LXCYCATS = rundll32 c:\windows\System32\spool\DRIVERS\W32X86\3\LXCYtime.dll,_RunDLLEntry@16???????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????
hidden files:
[HKEY_LOCAL_MACHINE\software\Classes\CLSID\{19114156-8E9A-4D4E-9EE9-17A0E48D3BBB}]
@Denied: (A 2) (Everyone)
@="FlashBroker"
"LocalizedString"="@c:\\WINDOWS\\system32\\Macromed\\Flash\\FlashUtil10c.exe,-101"
[HKEY_LOCAL_MACHINE\software\Classes\CLSID\{19114156-8E9A-4D4E-9EE9-17A0E48D3BBB}\Elevation]
"Enabled"=dword:00000001
[HKEY_LOCAL_MACHINE\software\Classes\CLSID\{19114156-8E9A-4D4E-9EE9-17A0E48D3BBB}\LocalServer32]
@="c:\\WINDOWS\\system32\\Macromed\\Flash\\FlashUtil10c.exe"
[HKEY_LOCAL_MACHINE\software\Classes\CLSID\{19114156-8E9A-4D4E-9EE9-17A0E48D3BBB}\TypeLib]
[HKEY_LOCAL_MACHINE\software\Classes\Interface\{1D4C8A81-B7AC-460A-8C23-98713C41D6B3}]
@="IFlashBroker3"
[HKEY_LOCAL_MACHINE\software\Classes\Interface\{1D4C8A81-B7AC-460A-8C23-98713C41D6B3}\ProxyStubClsid32]
[HKEY_LOCAL_MACHINE\software\Classes\Interface\{1D4C8A81-B7AC-460A-8C23-98713C41D6B3}\TypeLib]
"Version"="1.0"
- - - - - - - > 'winlogon.exe'(744)
c:\windows\system32\UmxWnp.Dll
c:\program files\CA\SharedComponents\PPRT\bin\CACheck.dll
c:\program files\CA\SharedComponents\PPRT\bin\CAHook.dll
c:\program files\CA\SharedComponents\PPRT\bin\CAServer.dll
Completion time: 2009-08-17 13:36
ComboFix-quarantined-files.txt 2009-08-17 19:36
Pre-Run: 142,249,988,096 bytes free
Post-Run: 142,152,478,720 bytes free
318 --- E O F --- 2009-08-14 23:25
fishininmt
OS : xp
# Likes : 0
Post by Belahzur on Mon Aug 17, 2009 9:54 pm
ComboFix /u
# Likes : 1
Post by fishininmt on Mon Aug 17, 2009 10:14 pm
The machine seems to be running good now. At least at hasn't shut down on me since I ran that combo fix. Before I did that the machine shut down 4 times this morning and it hasn't done it since. But so far so good.
fishininmt
OS : xp
# Likes : 0
