removed antivirus system pro per instructions read on this site.
Post by pesqo on 6th August 2009, 4:34 am
i accidentally did a full scan on my system using malwarebytes and after i did so i then looked at the log and hit the remove all. now i can get on the internet and browse thank goodness, but I am unable to log on to my msn.com account it acts like it is going to the login page but when it says done on the bottom left there is nothing on the screen. my log file is as follows:
Malwarebytes' Anti-Malware 1.40
Database version: 2568
8/5/2009 9:55:15 PM
mbam-log-2009-08-05 (21-55-15).txt
Scan type: Full Scan (C:\|)
Objects scanned: 145305
Time elapsed: 27 minute(s), 31 second(s)
Memory Modules Infected: 1
Registry Keys Infected: 4
Registry Values Infected: 2
Files Infected: 13
C:\WINDOWS\system32\iehelper.dll (Trojan.BHO) -> Delete on reboot.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{f64619ff-e19f-4016-bf9c-147cff821b46} (Trojan.Vundo.H) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{f64619ff-e19f-4016-bf9c-147cff821b46} (Trojan.Vundo.H) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{f64619ff-e19f-4016-bf9c-147cff821b46} (Trojan.BHO) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\AvScan (Malware.Trace) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\system tool (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\system tool (Trojan.FakeAlert) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\iehelper.dll (Trojan.Vundo.H) -> Quarantined and deleted successfully.
C:\Documents and Settings\Mark\Local Settings\Temporary Internet Files\Content.IE5\R5YPF4OC\omni[2].gif (Trojan.Dropper) -> Quarantined and deleted successfully.
C:\Documents and Settings\Mark\Local Settings\Temporary Internet Files\Content.IE5\ZGR33BI4\omni[1].gif (Trojan.Dropper) -> Quarantined and deleted successfully.
C:\System Volume Information\_restore{202550A8-7A33-4BCA-9586-051D24DDBF8F}\RP106\A0031133.dll (Trojan.BHO) -> Quarantined and deleted successfully.
C:\System Volume Information\_restore{202550A8-7A33-4BCA-9586-051D24DDBF8F}\RP106\A0031145.dll (Trojan.BHO) -> Quarantined and deleted successfully.
C:\System Volume Information\_restore{202550A8-7A33-4BCA-9586-051D24DDBF8F}\RP106\A0031157.dll (Trojan.BHO) -> Quarantined and deleted successfully.
C:\System Volume Information\_restore{202550A8-7A33-4BCA-9586-051D24DDBF8F}\RP106\A0031169.dll (Trojan.BHO) -> Quarantined and deleted successfully.
C:\System Volume Information\_restore{202550A8-7A33-4BCA-9586-051D24DDBF8F}\RP106\A0031181.dll (Trojan.BHO) -> Quarantined and deleted successfully.
C:\System Volume Information\_restore{202550A8-7A33-4BCA-9586-051D24DDBF8F}\RP106\A0031193.dll (Trojan.BHO) -> Quarantined and deleted successfully.
C:\System Volume Information\_restore{202550A8-7A33-4BCA-9586-051D24DDBF8F}\RP106\A0031209.dll (Trojan.BHO) -> Quarantined and deleted successfully.
C:\System Volume Information\_restore{202550A8-7A33-4BCA-9586-051D24DDBF8F}\RP106\A0031223.dll (Trojan.BHO) -> Quarantined and deleted successfully.
C:\WINDOWS\syssvc.exe (Trojan.Dropper) -> Quarantined and deleted successfully.
C:\Program Files\lnuaqb\tqwksysguard.exe (Trojan.FakeAlert) -> Quarantined and deleted successfully.
even though i do not get any errors from antivirus system pro it is frustrating that i can't log on to my email address. any insight would be greatly appreciated. Thanks, Mark
pesqo
Posts Posts : 3
Joined Joined : 2009-08-06
Points Points : 26835
Re: removed antivirus system pro per instructions read on this site.
Post by Belahzur on 6th August 2009, 2:15 pm
Points Points : 245111
Post by pesqo on 7th August 2009, 12:30 am
Scan saved at 6:28:53 PM, on 8/6/2009
C:\WINDOWS\System32\WLTRYSVC.EXE
C:\WINDOWS\System32\bcmwltry.exe
C:\WINDOWS\system32\rpcnet.exe
C:\WINDOWS\system32\hkcmd.exe
C:\WINDOWS\system32\WLTRAY.exe
C:\WINDOWS\stsystra.exe
C:\WINDOWS\system32\KADxMain.exe
C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe
C:\Program Files\Dell\MediaDirect\PCMService.exe
C:\WINDOWS\system32\igfxsrvc.exe
C:\PROGRA~1\SIMPLE~1\PHOTOS~1\data\Xtras\mssysmgr.exe
C:\Program Files\Digital Line Detect\DLG.exe
C:\Program Files\Verizon Wireless\VZAccess Manager\VZAccess Manager.exe
R1 - HKLM\Software\Microsoft\Internet Explorer\Search,Default_Page_URL = [You must be registered and logged in to see this link.]
O1 - Hosts: ::1 localhost
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.5.0_06\bin\ssv.dll
O2 - BHO: scriptproxy - {7DB2D5A0-7241-4E79-B68D-6309F01C5231} - c:\PROGRA~1\mcafee\VIRUSS~1\scriptsn.dll
O2 - BHO: Browser Address Error Redirector - {CA6319C0-31B7-401E-A518-A07C3DB8F777} - C:\Program Files\Dell\BAE\BAE.dll
O4 - HKLM\..\Run: [Persistence] C:\WINDOWS\system32\igfxpers.exe
O4 - HKLM\..\Run: [Broadcom Wireless Manager UI] C:\WINDOWS\system32\WLTRAY.exe
O4 - HKLM\..\Run: [SigmatelSysTrayApp] stsystra.exe
O4 - HKLM\..\Run: [KADxMain] C:\WINDOWS\system32\KADxMain.exe
O4 - HKLM\..\Run: [ISUSScheduler] "C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe" -start
O4 - HKLM\..\Run: [PCMService] "C:\Program Files\Dell\MediaDirect\PCMService.exe"
O4 - HKLM\..\Run: [dscactivate] c:\dell\dsca.exe 3
O4 - HKLM\..\Run: [ECenter] C:\Dell\E-Center\EULALauncher.exe
O4 - HKCU\..\Run: [PhotoShow Deluxe Media Manager] C:\PROGRA~1\SIMPLE~1\PHOTOS~1\data\Xtras\mssysmgr.exe
O4 - Startup: OneNote 2007 Screen Clipper and Launcher.lnk = C:\Program Files\Microsoft Office\Office12\ONENOTEM.EXE
O4 - Startup: OneNote Table Of Contents.onetoc2
O4 - Startup: VZAccess Manager.lnk = C:\Program Files\Verizon Wireless\VZAccess Manager\VZAccess Manager.exe
O4 - Global Startup: Digital Line Detect.lnk = C:\Program Files\Digital Line Detect\DLG.exe
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_06\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_06\bin\ssv.dll
O9 - Extra button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~2\Office12\ONBttnIE.dll
O9 - Extra 'Tools' menuitem: S&end to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~2\Office12\ONBttnIE.dll
O16 - DPF: {406B5949-7190-4245-91A9-30A17DE16AD0} (Snapfish Activia) - [You must be registered and logged in to see this link.]
O16 - DPF: {7584C670-2274-4EFB-B00B-D6AABA6D3850} (Microsoft RDP Client Control (redist)) - [You must be registered and logged in to see this link.]
O16 - DPF: {8A0019EB-51FA-4AE5-A40B-C0496BBFC739} (Verizon Wireless Media Upload) - [You must be registered and logged in to see this link.]
O17 - HKLM\System\CCS\Services\Tcpip\..\{43365455-03A3-40D1-8C8D-B33777F8CBC9}: NameServer = 66.174.92.14 66.174.95.44
O23 - Service: DSBrokerService - Unknown owner - C:\Program Files\DellSupport\brkrsvc.exe
O23 - Service: McAfee Network Agent (McNASvc) - Unknown owner - c:\program files\common files\mcafee\mna\mcnasvc.exe (file missing)
O23 - Service: Remote Procedure Call (RPC) Net (Rpcnet) - Absolute Software Corp. - C:\WINDOWS\system32\rpcnet.exe
O23 - Service: stllssvr - Unknown owner - C:\Program Files\Common Files\SureThing Shared\stllssvr.exe (file missing)
O23 - Service: Dell Wireless WLAN Tray Service (wltrysvc) - Unknown owner - C:\WINDOWS\System32\WLTRYSVC.EXE
End of file - 7063 bytes
pesqo
Posts Posts : 3
Post by pesqo on 7th August 2009, 12:43 am
also I can't log into mcafee.com to download my renewal so I would have my antivirus program
pesqo
Posts Posts : 3
Post by Belahzur on 7th August 2009, 11:12 pm
Lets remove Mcafee completely then and replace it with something else.
Completely Uninstall McAfee software
Download the [You must be registered and logged in to see this link.]
Using McAfee Consumer Product Removal Tool
Double click the MCPR.exe
A Command Line window will be displayed, and then close automatically.
Wait for a second Command Line window to be displayed. Note: Do not double-click MCPR.exe again, you may have to wait up to 1 minute for the next window to appear.
After the second window appears, the program will begin the cleanup.
Observe the installation, which could take several minutes. The following message will be displayed in the Command Line window: The machine must reboot to complete the un-installation. Reboot now? [y.n]
Press Y on the keyboard.
Wait for the computer to restart.
All McAfee products are now removed from your computer.
Please install Avira antivirus otherwise you won't be protected.
Then once you have done that,
  • Open HijackThis.
