antivirus system pro
Post by ronmc on 4th August 2009, 7:17 pm
I have been infected..
Antivirus system pro has got my computer. I tried to follow one of the topics on here but the info the guy got from his scan didnt match mine so I was wondering if someone could help
ronmc
Posts Posts : 5
Joined Joined : 2009-08-04
Points Points : 26867
Re: antivirus system pro
Post by ronmc on 4th August 2009, 7:31 pm
I already ran hijack this but everytime I run it I get an error message saying notepad has been infected and wont open. everything I do gets stopped by a promp saying its infected.
any help would be appreciated
ronmc
Posts Posts : 5
Post by ronmc on 4th August 2009, 7:42 pm
ronmc
Posts Posts : 5
Post by ronmc on 5th August 2009, 11:45 am
bump
ronmc
Posts Posts : 5
Post by Belahzur on 5th August 2009, 5:19 pm
Can you open the log file with Wordpad instead of Notepad?
Points Points : 245121
Post by ronmc on 5th August 2009, 6:32 pm
I couldnt do anything at first. But I figured out that when I restarted my computer if I could open malwarebytes before the virus opened that I could run malwarebytes and the virus couldnt affect the way it worked. I ran malwarebytes with a quick scan and then with a full scan and it eliminated that nasty virus that kept opening websites on me and giving me all kinds of pop ups.
Thanks to Geek police for the help with this if I didnt read any of the other post's about this I would have had to format this thing.
ronmc
Posts Posts : 5
Post by Origin on 5th August 2009, 11:11 pm
Can you do the following now:
Posts Posts : 2685
Joined Joined : 2009-05-05
OS OS : Windows Xp Sp3
Points Points : 31533
