Anti Virus System Pro removal help
Post by Rchjr on 2nd August 2009, 8:26 am
Per your instructions I have started this thread here for help in removing this off of my computer. As I have stated I purchased a flash drive and downloaded the malware program on it and tried to install it on this infected computer. Each time I go thru the process of installing it actually installs the program. But after installed i double click on the icon it created and nothing happens. I would appreciate any and all help in removint this off of my system.
My laptop is rendered completely usless at this point. I cant use it to download anything or even connect to the internet.
Sorry for the double post!
Thanks,
Rchjr
Rchjr
Posts Posts : 24
Joined Joined : 2009-08-02
OS OS : windows xp
Points Points : 26908
Re: Anti Virus System Pro removal help
Post by Origin on 2nd August 2009, 7:47 pm
Hello Rchjr,
Welcome to Geek Police, my name is Origin and I will be helping you today. Please keep the following in mind:
  • If you do not get a reply from me or another helper within 2 days, please reply to your topic with the phrase BUMP
  • If you have any cracked/pirated software in your computer delete them or we will not help you.
  • Only follow advise from Geek Police Staff and not a regular member.
  • Do NOT run any tool without Geek Police supervision as it could hinder your system useless.
Posts Posts : 2685
Joined Joined : 2009-05-05
OS OS : Windows Xp Sp3
Points Points : 31533
Post by Rchjr on 2nd August 2009, 8:29 pm
I had to download hijack this onto a flash drive. Then I put it on the infected computer. When I try to install it on the infected computer I never get the agreement that I am supposed to see. It does leave an icon on my desk top. I click on it and nothing happens! I never see an installation progess bar or anything. What a am I doing wrong?
Thank for you helop,
Rchjr
Rchjr
Posts Posts : 24
OS OS : windows xp
Post by Origin on 2nd August 2009, 8:36 pm
See if it works downloading it from here:
Posts Posts : 2685
Post by Rchjr on 2nd August 2009, 9:00 pm
That worked here is the file:
Scan saved at 1:54:41 PM, on 8/2/2009
MSIE: Internet Explorer v6.00 SP3 (6.00.2900.5512)
C:\WINDOWS\system32\csrss.exe
C:\Program Files\Ahead\InCD\InCDsrv.exe
C:\WINDOWS\system32\acs.exe
C:\Program Files\ESET\ESET NOD32 Antivirus\ekrn.exe
C:\Program Files\iolo\common\lib\ioloServiceManager.exe
C:\Program Files\iolo\System Mechanic 6\IoloSGCtrl.exe
C:\Program Files\Spyware Doctor\pctsAuxs.exe
C:\WINDOWS\system32\slserv.exe
C:\Program Files\Sectra\IDS5web\bin\viewer_service.exe
C:\WINDOWS\System32\alg.exe
C:\Program Files\Synaptics\SynTP\SynTPLpr.exe
C:\Program Files\ESET\ESET NOD32 Antivirus\egui.exe
C:\Program Files\ScanSoft\PaperPort\pptd40nt.exe
C:\PROGRA~1\McAfee\MWL\MwlGui.exe
C:\PROGRA~1\McAfee.com\Agent\McUpdate.exe
C:\PROGRA~1\McAfee.com\Agent\McAgent.exe
C:\WINDOWS\CTHELPER.EXE
C:\Program Files\Atheros\ACU.exe
C:\Program Files\Spyware Doctor\pctsTray.exe
C:\WINDOWS\SOUNDMAN.EXE
C:\WINDOWS\system32\rundll32.exe
C:\Program Files\iolo\System Mechanic 6\SMSystemAnalyzer.exe
C:\Program Files\Skype\Phone\Skype.exe
C:\Program Files\Skype\Plugin Manager\skypePM.exe
I:\winlogon.exe
C:\WINDOWS\system32\wbem\wmiprvse.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Local Page =
R3 - URLSearchHook: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - (no file)
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: CMVideoPlugin - {0D23EE44-2319-4B6C-93D2-A572E0F5B0E0} - (no file)
O2 - BHO: Skype add-on (mastermind) - {22BF413B-C6D2-4d91-82A9-A0F997BA588C} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll
O2 - BHO: RealPlayer Download and Record Plugin for Internet Explorer - {3049C3E9-B461-4BC5-8870-4C09146192CA} - C:\Program Files\Real\RealPlayer\rpbrowserrecordplugin.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0_07\bin\ssv.dll
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.2.4204.1700\swg.dll
O2 - BHO: BHO - {F64619FF-E19F-4016-BF9C-147CFF821B46} - C:\WINDOWS\system32\iehelper.dll
O4 - HKLM\..\Run: [Ptipbmf] "rundll32.exe" ptipbmf.dll,SetWriteCacheMode
O4 - HKLM\..\Run: [SynTPLpr] "C:\Program Files\Synaptics\SynTP\SynTPLpr.exe"
O4 - HKLM\..\Run: [SynTPEnh] "C:\Program Files\Synaptics\SynTP\SynTPEnh.exe"
O4 - HKLM\..\Run: [High Definition Audio Property Page Shortcut] HDAudPropShortcut.exe
O4 - HKLM\..\Run: [NvCplDaemon] "RUNDLL32.EXE" C:\WINDOWS\system32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [UserFaultCheck] C:\WINDOWS\system32\dumprep 0 -u
O4 - HKLM\..\Run: [egui] "C:\Program Files\ESET\ESET NOD32 Antivirus\egui.exe" /hide /waitservice
O4 - HKLM\..\Run: [system tool] C:\Program Files\iiuoww\tlxrsysguard.exe
O4 - HKLM\..\Run: [SystemGuardAlerter] "C:\Program Files\iolo\System Mechanic 6\SystemGuardAlerter.exe"
O4 - HKLM\..\Run: [SSBkgdUpdate] "C:\Program Files\Common Files\Scansoft Shared\SSBkgdUpdate\SSBkgdupdate.exe" -Embedding -boot
O4 - HKLM\..\Run: [SpyHunter] "C:\PROGRA~1\Grisoft\AVG7\avgcc.exe" /STARTUP
O4 - HKLM\..\Run: [SetDefPrt] "C:\Program Files\Brother\Brmfl06a\BrStDvPt.exe"
O4 - HKLM\..\Run: [REGSHAVE] "C:\Program Files\REGSHAVE\REGSHAVE.EXE" /AUTORUN
O4 - HKLM\..\Run: [PaperPort PTD] "C:\Program Files\ScanSoft\PaperPort\pptd40nt.exe"
O4 - HKLM\..\Run: [nwiz] "nwiz.exe" /install
O4 - HKLM\..\Run: [NeroFilterCheck] C:\WINDOWS\system32\NeroCheck.exe
O4 - HKLM\..\Run: [MWLExe] "C:\PROGRA~1\McAfee\MWL\MwlGui.exe" /Start
O4 - HKLM\..\Run: [MCUpdateExe] C:\PROGRA~1\McAfee.com\Agent\McUpdate.exe
O4 - HKLM\..\Run: [MCAgentExe] C:\PROGRA~1\McAfee.com\Agent\McAgent.exe
O4 - HKLM\..\Run: [CTHelper] CTHELPER.EXE
O4 - HKLM\..\Run: [ControlCenter3] "C:\Program Files\Brother\ControlCenter3\brctrcen.exe" /autorun
O4 - HKLM\..\Run: [BrMfcWnd] "C:\Program Files\Brother\Brmfcmon\BrMfcWnd.exe" /AUTORUN
O4 - HKLM\..\Run: [AVG7_CC] "C:\PROGRA~1\Grisoft\AVG7\avgcc.exe" /STARTUP
O4 - HKLM\..\Run: [AlcWzrd] ALCWZRD.EXE
O4 - HKLM\..\Run: [ACU] "C:\Program Files\Atheros\ACU.exe" -nogui
O4 - HKLM\..\Run: [ISTray] "C:\Program Files\Spyware Doctor\pctsTray.exe"
O4 - HKLM\..\Run: [SoundMan] SOUNDMAN.EXE
O4 - HKCU\..\Run: [updateMgr] "C:\Program Files\Adobe\Acrobat 7.0\Reader\AdobeUpdateManager.exe" AcRdB7_0_8
O4 - HKCU\..\Run: [SMSystemAnalyzer] "C:\Program Files\iolo\System Mechanic 6\SMSystemAnalyzer.exe"
O4 - HKCU\..\Run: [SetDefaultMIDI] MIDIDef.exe
O4 - HKCU\..\Run: [CNN.Pipeline.Alerter] "C:\Program Files\CNN Pipeline\CNN.VideoNet.App.exe" /cnndriver:startapp alerter
O4 - HKCU\..\Run: [Skype] "C:\Program Files\Skype\Phone\Skype.exe" /nosplash /minimized
O6 - HKCU\Software\Policies\Microsoft\Internet Explorer\Control Panel present
O6 - HKLM\Software\Policies\Microsoft\Internet Explorer\Control Panel present
O8 - Extra context menu item: Open using &Advanced JPEG Compressor - C:\Program Files\Advanced JPEG Compressor\ajcieex.htm
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_07\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_07\bin\ssv.dll
O9 - Extra button: Skype - {77BF5300-1474-4EC7-9980-D32B190E9B07} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll
O10 - Broken Internet access because of LSP provider 'c:\windows\system32\lsp.dll' missing
O16 - DPF: {13EC55CF-D993-475B-9ACA-F4A384957956} (Controller Class) - [You must be registered and logged in to see this link.]
O16 - DPF: {30528230-99f7-4bb4-88d8-fa1d4f56a2ab} (Installation Support) - C:\Program Files\Yahoo!\Common\Yinsthelper200711281.dll
O16 - DPF: {4ED9DDF0-7479-4BBE-9335-5A1EDB1D8A21} (McAfee.com Operating System Class) - [You must be registered and logged in to see this link.]
O16 - DPF: {5ED80217-570B-4DA9-BF44-BE107C0EC166} (Windows Live Safety Center Base Module) - [You must be registered and logged in to see this link.]
O16 - DPF: {644E432F-49D3-41A1-8DD5-E099162EEEC5} (Symantec RuFSI Utility Class) - [You must be registered and logged in to see this link.]
O16 - DPF: {67DABFBF-D0AB-41FA-9C46-CC0F21721616} (DivXBrowserPlugin Object) - [You must be registered and logged in to see this link.]
O16 - DPF: {7C705EA9-3C3B-4F3A-B1AA-2184CDFAE4D0} (Viewer Class) - [You must be registered and logged in to see this link.]
O16 - DPF: {85D1F3B2-2A21-11D7-97B9-0010DC2A6243} (SecureLogin class) - [You must be registered and logged in to see this link.]
O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} (Java Runtime Environment 1.6.0) - [You must be registered and logged in to see this link.]
O16 - DPF: {BE833F39-1E0C-468C-BA70-25AAEE55775E} (System Requirements Lab) - [You must be registered and logged in to see this link.]
O16 - DPF: {E473A65C-8087-49A3-AFFD-C5BC4A10669B} (Quantum Streaming IE Player Class) - [You must be registered and logged in to see this link.]
O16 - DPF: {FC11A119-C2F7-46F4-9E32-937ABA26816E} (AMI DicomDir TreeView Control 2.1) - [You must be registered and logged in to see this link.]
O17 - HKLM\System\CCS\Services\Tcpip\..\{95AF6E28-54A4-4810-B520-8B17B411C6C6}: NameServer = 85.255.112.143,85.255.112.203
O17 - HKLM\System\CCS\Services\Tcpip\..\{CFB47ADC-3A7B-40C0-B972-EE9E4C7B1155}: NameServer = 85.255.112.143,85.255.112.203
O17 - HKLM\System\CS1\Services\Tcpip\Parameters: NameServer = 85.255.112.143,85.255.112.203
O17 - HKLM\System\CS2\Services\Tcpip\Parameters: NameServer = 85.255.112.143,85.255.112.203
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: NameServer = 85.255.112.143,85.255.112.203
O22 - SharedTaskScheduler: IPC Configuration Utility - IPC Configuration Utility - (no file)
O23 - Service: Atheros Configuration Service (ACS) - Atheros - C:\WINDOWS\system32\acs.exe
O23 - Service: Eset HTTP Server (EhttpSrv) - ESET - C:\Program Files\ESET\ESET NOD32 Antivirus\EHttpSrv.exe
O23 - Service: Eset Service (ekrn) - ESET - C:\Program Files\ESET\ESET NOD32 Antivirus\ekrn.exe
O23 - Service: InCD Helper (InCDsrv) - Nero AG - C:\Program Files\Ahead\InCD\InCDsrv.exe
O23 - Service: iolo FileInfoList Service (ioloFileInfoList) - Unknown owner - C:\Program Files\iolo\common\lib\ioloServiceManager.exe
O23 - Service: iolo System Service (ioloSystemService) - Unknown owner - C:\Program Files\iolo\common\lib\ioloServiceManager.exe
O23 - Service: iolo System Guard (IOLO_SRV) - Unknown owner - C:\Program Files\iolo\System Mechanic 6\IoloSGCtrl.exe
O23 - Service: McAfee Wireless Security Service (MwlSvc) - McAfee, Inc. - C:\PROGRA~1\McAfee\MWL\MwlSvc.exe
O23 - Service: PC Tools Auxiliary Service (sdAuxService) - PC Tools - C:\Program Files\Spyware Doctor\pctsAuxs.exe
O23 - Service: SmartLinkService (SLService) - - C:\WINDOWS\SYSTEM32\slserv.exe
O23 - Service: SECTRA Viewer Update Service (viewer_service) - Unknown owner - C:\Program Files\Sectra\IDS5web\bin\viewer_service.exe
O24 - Desktop Component 0: (no name) - [You must be registered and logged in to see this link.]
Rchjr
Posts Posts : 24
OS OS : windows xp
Post by Origin on 2nd August 2009, 9:05 pm
Hello Rchjr,
  • Open HijackThis.
Posts Posts : 2685
Post by Rchjr on 2nd August 2009, 9:28 pm
I have a question: Once I download malware, you say to up date it. If I download this program on the uninfected computer and there is an update and it updates itself. How do I then get the updated program onto a flash drive so it will install on the infected computer. Am I able to download an updated version of malware onto a flash drive.
I have allready completed the previous step and fixed those problems.
Thanks for your help,
Rchjr
Rchjr
Posts Posts : 24
OS OS : windows xp
Post by Origin on 2nd August 2009, 9:32 pm
You can do that but you can however download the latest database offline from here and install it in the infected computer when Malwarebytes is already installed:
Posts Posts : 2685
Post by Rchjr on 2nd August 2009, 10:11 pm
There appears to be a problem with the second link you provided. It has been stuck at 21% for quite sometime and the time needed to complete the download jumps from 21 seconds to 18 minutes. I have tried this several times and it still is taking for ever, is this normal?
Rchjr
Rchjr
Posts Posts : 24
OS OS : windows xp
Post by Rchjr on 2nd August 2009, 10:50 pm
Well I had to update it on the uninfected computer The link you provided was not working. I then saved it to my flash drive. I then installed it onto the infected computer, tried to install it, Looked like it did but will not run! Why is this program not running?
Rchjr
Rchjr
Posts Posts : 24
OS OS : windows xp
Post by Belahzur on 3rd August 2009, 8:05 pm
Before we can get the big tools out, a lot more has to go first.
  • Open HijackThis.
Points Points : 245121
Post by Rchjr on 4th August 2009, 1:56 am
Ok here is the list it provided:
3DMark05
Adobe Download Manager 2.0 (Remove Only)
Adobe Flash Player 10 ActiveX
Adobe Photoshop 7.0
Adobe Reader 7.0.8
Adobe Shockwave Player
Advanced JPEG Compressor 4.8
AGEIA PhysX v7.07.09
ah Screen Saver
AlienAutopsy
AlienGUIse
Aliens vs. Predator 2
Apple Mobile Device Support
Apple Software Update
ARC996PRO for Uniden BCD996T
ArcSoft VideoImpression 1.6FP
Atheros Client Installation Program
Ballistic Explorer Ver. 6.2.0
BC_VUP
BCD996T_UASD
BisonCam, USB2.0
Bonjour
Brother MFL-Pro Suite
Command & Conquer 3
Command & Conquer Generals
Crysis(R)
DivX Content Uploader
DivX Web Player
Doks Satellite 6.0
Doom 3
Error Messages for Windows
Eudora
Ex2Em-V4-en
FinePixViewer Ver.3.0
FSX Flight Weather Report
FSX_Screensaver
FTDI USB Serial Converter Drivers
FUJIFILM USB Driver
getPlus(R) for Adobe
Ghost Recon Advanced Warfighter
GL Excess v1.2v
HijackThis 2.0.2
HTvid
IDS5web
ImageMixer for HDD Camcorder
InCD
iolo technologies' System Mechanic
iolo technologies' System Mechanic 6
iTunes
Java(TM) 6 Update 7
LimeWire PRO 4.18.8
Logitech Gaming Software
Malwarebytes' Anti-Malware
McAfee Uninstall Wizard
Medal of Honor Airborne
Microsoft .NET Framework 1.1
Microsoft .NET Framework 2.0 Service Pack 1
Microsoft Money 2007 Home & Business
Microsoft Money Shared Libraries
Microsoft Office Standard Edition 2003
Microsoft WSE 2.0 SP3 Runtime
MSXML 4.0 SP2 (KB925672)
MSXML 4.0 SP2 (KB927978)
MSXML 4.0 SP2 (KB936181)
MSXML 4.0 SP2 (KB954430)
MSXML 4.0 SP2 Parser and SDK
Nero Digital
Nero OEM
NeroVision Express Content
Notebook Hardware Control 2.0 Pre-Release-04
NovaGPS
PaperPort
ParetoLogic Privacy Controls
PC Wizard 2006.1.691
PowerDVD
ProScan 1.8.2
PunkBuster Services
QuickTime
RealPlayer
REALTEK Gigabit and Fast Ethernet NIC Driver
SAMSUNG CDMA Modem Driver Set
Satellite PC
ScanControl
Security Update for Windows XP (KB913433)
Security Update for Windows XP (KB950759)
Security Update for Windows XP (KB956390)
Security Update for Windows XP (KB958215)
Security Update for Windows XP (KB960714)
Security Update for Windows XP (KB963027)
Security Update for Windows XP (KB969897)
Skype™ 4.0
Smart Link 56K Voice Modem
SpeedFan (remove only)
Sprint PCS Connection Manager
SpyHunter
Spyware Doctor 6.1
Star Trek Legacy
Star Wars Empire at War
Star Wars Empire at War Forces of Corruption
Synaptics Pointing Device Driver
Theme Manager
Tom Clancy's Ghost Recon Advanced Warfighter® 2
TOPO!
TrunkStar Elite Pro
Windows Live Safety Scanner
Windows XP Service Pack 3
Thanks again for your help,
Rchjr
Rchjr
Posts Posts : 24
OS OS : windows xp
Post by Belahzur on 4th August 2009, 7:17 pm
You are running two antivirus', I see from the uninstall list you have NOD32 installed, along with AVG. This is a bad idea as they can conflict and cause more problems. I would recommend that you remove AVG to avoid conflict and other future problems.
Completely Uninstall AVG software
Download and run avgremover.exe
For 32-Bit, Download: [You must be registered and logged in to see this link.]
    Java(TM) 6 Update 7
    LimeWire PRO 4.18.8
Next,
  • Download combofix from here
Post by Rchjr on 5th August 2009, 12:31 am
Well I was able to remove the avg software as you said. I then downloaded combofix to the flash drive and tried to install it on the infected computer and it would not install. What next?
Rchjr
Rchjr
Posts Posts : 24
OS OS : windows xp
Post by Belahzur on 5th August 2009, 5:52 pm
Did you download as renamed to Combo-Fix?
Post by Rchjr on 5th August 2009, 7:52 pm
Yes that was the problem, I feel so stupid. Below is the log combo-fix created:
It says the message was to big so I am ddoing this in parts!
ComboFix 09-08-04.03 - C. Harris 08/05/2009 12:14.1.2 - NTFSx86
Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.2046.1668 [GMT -7:00]
Running from: I:\Combo-Fix.exe
AV: ESET NOD32 Antivirus 3.0 *On-access scanning disabled* (Outdated) {E5E70D32-0101-4F12-8FB0-D96ACA4F34C0}
* Resident AV is active
WARNING -THIS MACHINE DOES NOT HAVE THE RECOVERY CONSOLE INSTALLED !!
c:\program files\CMVideoPlugin
c:\program files\perfect codec
c:\windows\7673d9ac.ocx
c:\windows\80f54c17.ocx
c:\windows\85a58256.ocx
c:\windows\c4e7b72c.ocx
c:\windows\Installer\111349c.msp
c:\windows\Installer\11b08e8.msp
c:\windows\Installer\11ba651.msp
c:\windows\Installer\11fbf73.msp
c:\windows\Installer\1308a76.msp
c:\windows\Installer\1383ba.msp
c:\windows\Installer\13e189.msp
c:\windows\Installer\13ea472.msp
c:\windows\Installer\148797c.msp
c:\windows\Installer\15e1ce.msp
c:\windows\Installer\1980cf.msp
c:\windows\Installer\1af30c.msp
c:\windows\Installer\1b221b.msp
c:\windows\Installer\1b272df.msp
c:\windows\Installer\1ea0d.msp
c:\windows\Installer\1f826.msp
c:\windows\Installer\2070b.msp
c:\windows\Installer\20cb8.msp
c:\windows\Installer\20cd7.msp
c:\windows\Installer\20f96.msp
c:\windows\Installer\21274.msp
c:\windows\Installer\21543.msp
c:\windows\Installer\21572.msp
c:\windows\Installer\2168b.msp
c:\windows\Installer\21737.msp
c:\windows\Installer\218fc.msp
c:\windows\Installer\21999.msp
c:\windows\Installer\219b8.msp
c:\windows\Installer\21a73.msp
c:\windows\Installer\21ad1.msp
c:\windows\Installer\21c58.msp
c:\windows\Installer\21d71.msp
c:\windows\Installer\21ec9.msp
c:\windows\Installer\21ef8.msp
c:\windows\Installer\21f17.msp
c:\windows\Installer\21f26.msp
c:\windows\Installer\21f84.msp
c:\windows\Installer\21f85.msp
c:\windows\Installer\22011.msp
c:\windows\Installer\22040.msp
c:\windows\Installer\220ec.msp
c:\windows\Installer\222a1.msp
c:\windows\Installer\222c0.msp
c:\windows\Installer\222e0.msp
c:\windows\Installer\222ef.msp
c:\windows\Installer\2238b.msp
c:\windows\Installer\22408.msp
c:\windows\Installer\22409.msp
c:\windows\Installer\224d4.msp
c:\windows\Installer\22594.msp
c:\windows\Installer\225fc.msp
c:\windows\Installer\226f6.msp
c:\windows\Installer\227d1.msp
c:\windows\Installer\227f0.msp
c:\windows\Installer\2283f.msp
c:\windows\Installer\229c5.msp
c:\windows\Installer\22a23.msp
c:\windows\Installer\22a90.msp
c:\windows\Installer\22b6b.msp
c:\windows\Installer\22baa.msp
c:\windows\Installer\22fe0.msp
c:\windows\Installer\234ffa.msp
c:\windows\Installer\23510.msp
c:\windows\Installer\2360a.msp
c:\windows\Installer\239c3.msp
c:\windows\Installer\23bb7.msp
c:\windows\Installer\23bb8.msp
c:\windows\Installer\23d0f.msp
c:\windows\Installer\2403b.msp
c:\windows\Installer\24106.msp
c:\windows\Installer\24116.msp
c:\windows\Installer\24154.msp
c:\windows\Installer\24220.msp
c:\windows\Installer\242cb.msp
c:\windows\Installer\24397.msp
c:\windows\Installer\2459a.msp
c:\windows\Installer\24b47.msp
c:\windows\Installer\24c61.msp
c:\windows\Installer\24d99.msp
c:\windows\Installer\2545f.msp
c:\windows\Installer\2550b.msp
c:\windows\Installer\25615.msp
c:\windows\Installer\2573e.msp
c:\windows\Installer\257da.msp
c:\windows\Installer\257f9.msp
c:\windows\Installer\25903.msp
c:\windows\Installer\25a7a.msp
c:\windows\Installer\25a8a.msp
c:\windows\Installer\25b55.msp
c:\windows\Installer\25cdb.msp
c:\windows\Installer\25e62.msp
c:\windows\Installer\25e91.msp
c:\windows\Installer\25eef.msp
c:\windows\Installer\26140.msp
c:\windows\Installer\261ae.msp
c:\windows\Installer\261cd.msp
c:\windows\Installer\26298.msp
c:\windows\Installer\26305.msp
c:\windows\Installer\2648c.msp
c:\windows\Installer\264ea.msp
c:\windows\Installer\265a5.msp
c:\windows\Installer\266827.msp
c:\windows\Installer\26690.msp
c:\windows\Installer\266be0.msp
c:\windows\Installer\2674b.msp
c:\windows\Installer\2678a.msp
c:\windows\Installer\26855.msp
c:\windows\Installer\26910.msp
c:\windows\Installer\2694f.msp
c:\windows\Installer\269bc.msp
c:\windows\Installer\26ac6.msp
c:\windows\Installer\26bcf.msp
c:\windows\Installer\26c9b.msp
c:\windows\Installer\26d08.msp
c:\windows\Installer\26e9e.msp
c:\windows\Installer\26f1b.msp
c:\windows\Installer\26f4a.msp
c:\windows\Installer\270d1.msp
c:\windows\Installer\2718c.msp
c:\windows\Installer\27296.msp
c:\windows\Installer\27351.msp
c:\windows\Installer\27371.msp
c:\windows\Installer\273bf.msp
c:\windows\Installer\2763f.msp
c:\windows\Installer\27759.msp
c:\windows\Installer\2792d.msp
c:\windows\Installer\27a75.msp
c:\windows\Installer\27b21.msp
c:\windows\Installer\27b6f.msp
c:\windows\Installer\27bae.msp
c:\windows\Installer\27d54.msp
c:\windows\Installer\27e5d.msp
c:\windows\Installer\27ecb.msp
c:\windows\Installer\27fc5.msp
c:\windows\Installer\28051.msp
c:\windows\Installer\2814b.msp
c:\windows\Installer\28217.msp
c:\windows\Installer\2865c.msp
c:\windows\Installer\28708.msp
c:\windows\Installer\28870.msp
c:\windows\Installer\2890c.msp
c:\windows\Installer\289e7.msp
c:\windows\Installer\28a64.msp
c:\windows\Installer\29001.msp
c:\windows\Installer\290eb.msp
c:\windows\Installer\29262.msp
c:\windows\Installer\294e3.msp
c:\windows\Installer\2957f.msp
c:\windows\Installer\29699.msp
c:\windows\Installer\296b8.msp
c:\windows\Installer\299a44.msp
c:\windows\Installer\299b5.msp
c:\windows\Installer\299d5.msp
c:\windows\Installer\29aa0.msp
c:\windows\Installer\29ade.msp
c:\windows\Installer\29b61.msp
c:\windows\Installer\2a00e.msp
c:\windows\Installer\2a06e9.msp
c:\windows\Installer\2a2444.msp
c:\windows\Installer\2a30c.msp
c:\windows\Installer\2a406.msp
c:\windows\Installer\2a83c.msp
c:\windows\Installer\2acc0.msp
c:\windows\Installer\2adab.msp
c:\windows\Installer\2b01a4.msp
c:\windows\Installer\2b0f7.msp
c:\windows\Installer\2b1a2.msp
c:\windows\Installer\2b297f.msp
c:\windows\Installer\2b6ba9.msp
c:\windows\Installer\2bdb8.msp
c:\windows\Installer\2bdf7.msp
c:\windows\Installer\2c876.msp
c:\windows\Installer\2c903.msp
c:\windows\Installer\2cccc.msp
c:\windows\Installer\2cf9a.msp
c:\windows\Installer\2d0d3.msp
c:\windows\Installer\2d1fc.msp
c:\windows\Installer\2dd75.msp
c:\windows\Installer\2ddc3.msp
c:\windows\Installer\2e332.msp
c:\windows\Installer\2e5c2.msp
c:\windows\Installer\2e6ad.msp
c:\windows\Installer\2e70a.msp
c:\windows\Installer\2e8fe.msp
c:\windows\Installer\2eb02.msp
c:\windows\Installer\2ec2b.msp
c:\windows\Installer\2ee1f.msp
c:\windows\Installer\2ee3e.msp
c:\windows\Installer\2ef28.msp
c:\windows\Installer\2f35f.msp
c:\windows\Installer\2f5df.msp
c:\windows\Installer\2f61e.msp
c:\windows\Installer\2f6ca.msp
c:\windows\Installer\2f850.msp
c:\windows\Installer\2f860.msp
c:\windows\Installer\2f9a8.msp
c:\windows\Installer\2fd03.msp
c:\windows\Installer\2ff94.msp
c:\windows\Installer\30139.msp
c:\windows\Installer\30783.msp
c:\windows\Installer\30948.msp
c:\windows\Installer\30b4c.msp
c:\windows\Installer\30f43.msp
c:\windows\Installer\3106c.msp
c:\windows\Installer\31195.msp
c:\windows\Installer\3136a.msp
c:\windows\Installer\313d7.msp
c:\windows\Installer\31425.msp
c:\windows\Installer\31acc.msp
c:\windows\Installer\31d7c.msp
c:\windows\Installer\32154.msp
c:\windows\Installer\321a2.msp
c:\windows\Installer\324bf.msp
c:\windows\Installer\324ee.msp
c:\windows\Installer\3258a.msp
c:\windows\Installer\326b3.msp
c:\windows\Installer\327ad.msp
c:\windows\Installer\328a7.msp
c:\windows\Installer\32b57.msp
c:\windows\Installer\32e16.msp
c:\windows\Installer\33154.msp
c:\windows\Installer\3325c.msp
c:\windows\Installer\333a4.msp
c:\windows\Installer\33615.msp
c:\windows\Installer\33ae7.msp
c:\windows\Installer\33b83.msp
c:\windows\Installer\33c10.msp
c:\windows\Installer\34075.msp
c:\windows\Installer\340c3.msp
c:\windows\Installer\340d3.msp
c:\windows\Installer\34150.msp
c:\windows\Installer\34509.msp
c:\windows\Installer\3468f.msp
c:\windows\Installer\34d08.msp
c:\windows\Installer\35276.msp
c:\windows\Installer\35313.msp
c:\windows\Installer\35370.msp
c:\windows\Installer\3546a.msp
c:\windows\Installer\35891.msp
c:\windows\Installer\3590e.msp
c:\windows\Installer\35ac3.msp
c:\windows\Installer\35b11.msp
c:\windows\Installer\35bfc.msp
c:\windows\Installer\35c79.msp
c:\windows\Installer\35eda.msp
c:\windows\Installer\360de.msp
c:\windows\Installer\361f7.msp
c:\windows\Installer\363bc.msp
c:\windows\Installer\364c6.msp
c:\windows\Installer\36746.msp
c:\windows\Installer\36795.msp
c:\windows\Installer\36d80.msp
c:\windows\Installer\36e0d.msp
c:\windows\Installer\36f36.msp
c:\windows\Installer\36f93.msp
c:\windows\Installer\3709d.msp
c:\windows\Installer\3735c.msp
c:\windows\Installer\37418.msp
c:\windows\Installer\3781f.msp
c:\windows\Installer\3789c.msp
c:\windows\Installer\37c36.msp
c:\windows\Installer\37e0b.msp
c:\windows\Installer\3806c.msp
c:\windows\Installer\38b0b.msp
c:\windows\Installer\38e76.msp
c:\windows\Installer\38f12.msp
c:\windows\Installer\3905a.msp
c:\windows\Installer\3927d.msp
c:\windows\Installer\39694.msp
c:\windows\Installer\39c02.msp
c:\windows\Installer\3a29a.msp
c:\windows\Installer\3a99f.msp
c:\windows\Installer\3aa0c.msp
c:\windows\Installer\3accb.msp
c:\windows\Installer\3b094.msp
c:\windows\Installer\3b22a.msp
c:\windows\Installer\3b557.msp
c:\windows\Installer\3b94e.msp
c:\windows\Installer\3bad5.msp
c:\windows\Installer\3bcf8.msp
c:\windows\Installer\3bd75.msp
c:\windows\Installer\3bdf2.msp
c:\windows\Installer\3be50.msp
c:\windows\Installer\3c082.msp
c:\windows\Installer\3c545.msp
c:\windows\Installer\3c546.msp
c:\windows\Installer\3d0007.msp
c:\windows\Installer\3d0be.msp
c:\windows\Installer\3e2cf.msp
c:\windows\Installer\3e5cd.msp
c:\windows\Installer\3e734.msp
c:\windows\Installer\40079.msp
c:\windows\Installer\4019d9.msp
c:\windows\Installer\42305.msp
c:\windows\Installer\42fc7.msp
c:\windows\Installer\441e7.msp
c:\windows\Installer\44274.msp
c:\windows\Installer\44821.msp
c:\windows\Installer\4559e.msp
c:\windows\Installer\47d79a.msp
c:\windows\Installer\49d75.msp
c:\windows\Installer\4abbd.msp
c:\windows\Installer\4d392a.msp
c:\windows\Installer\4e7dfe.msp
c:\windows\Installer\4edb8.msp
c:\windows\Installer\51979b8.msp
c:\windows\Installer\52ded.msp
c:\windows\Installer\5627a.msp
c:\windows\Installer\585b2.msp
c:\windows\Installer\58fa5.msp
c:\windows\Installer\59e6a.msp
c:\windows\Installer\5ac16.msp
c:\windows\Installer\5b2fc.msp
c:\windows\Installer\5c25d.msp
c:\windows\Installer\5c952.msp
c:\windows\Installer\5cf0f.msp
c:\windows\Installer\5d72d.msp
c:\windows\Installer\5e595.msp
c:\windows\Installer\5ecc8.msp
c:\windows\Installer\5fcd6.msp
c:\windows\Installer\611d5.msp
c:\windows\Installer\62010c.msp
c:\windows\Installer\6290d9.msp
c:\windows\Installer\6498e.msp
c:\windows\Installer\65d882.msp
c:\windows\Installer\66ef9.msp
c:\windows\Installer\69da05.msp
c:\windows\Installer\6fec19.msp
c:\windows\Installer\78ba7e.msp
c:\windows\Installer\7ca155.msp
c:\windows\Installer\839405.msp
c:\windows\Installer\8c0c6a.msp
c:\windows\Installer\8f4d4d.msp
c:\windows\Installer\8f7288.msp
c:\windows\Installer\951ae.msp
c:\windows\Installer\95d879.msp
c:\windows\Installer\9c17d6.msp
c:\windows\Installer\9d7db0.msp
c:\windows\Installer\9d7dd6.msp
c:\windows\Installer\9d7de7.msp
c:\windows\Installer\a3fff87.msp
c:\windows\Installer\aea5f6.msp
c:\windows\Installer\b02a34.msp
c:\windows\Installer\b0e41e.msp
c:\windows\Installer\b1612.msp
c:\windows\Installer\cf517c.msp
c:\windows\Installer\ddc224.msp
c:\windows\Installer\eeee42.msp
c:\windows\Installer\f66d15.msp
c:\windows\ios.dat
c:\windows\syssvc.exe
c:\windows\system32\7158fcfb.ocx
c:\windows\system32\92cb8819.ocx
c:\windows\system32\drivers\ESQULmneoaxvukyxjcxdkjbotoqvpxctpejnl.sys
c:\windows\system32\ef841279.ocx
c:\windows\system32\ESQULmpqdxuqpqegxvmokitdcdwtphytarmfv.dll
c:\windows\system32\ESQULoptnvafxiibersivibhysetewigdfbui.dll
c:\windows\system32\ESQULzcounter
c:\windows\system32\iehelper.dll
c:\windows\system32\mfc45.dll
Rchjr
Posts Posts : 24
OS OS : windows xp
Post by Rchjr on 5th August 2009, 7:54 pm
Here is the another part
-------\Service_ESQULserv.sys
((((((((((((((((((((((((( Files Created from 2009-07-05 to 2009-08-05 )))))))))))))))))))))))))))))))
2009-08-02 20:22 . 2009-08-02 20:22 -------- d-----w- c:\program files\Trend Micro
2009-08-02 02:03 . 2009-07-13 20:36 38160 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2009-08-02 02:03 . 2009-08-04 01:51 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
2009-08-02 02:03 . 2009-07-13 20:36 19096 ----a-w- c:\windows\system32\drivers\mbam.sys
2009-07-31 21:17 . 2009-07-31 21:17 -------- d-----w- c:\program files\iiuoww
2009-07-31 17:53 . 2009-07-31 17:53 -------- d-----w- c:\program files\HTvid
2009-07-28 21:23 . 2009-07-30 21:32 -------- d-----w- c:\documents and settings\C. Harris\Application Data\Apple Computer
2009-07-28 21:22 . 2009-03-19 23:32 23400 ----a-w- c:\windows\system32\drivers\GEARAspiWDM.sys
2009-07-28 21:22 . 2008-04-17 19:12 107368 ----a-w- c:\windows\system32\GEARAspi.dll
2009-07-28 21:22 . 2009-07-28 21:22 -------- d-----w- c:\program files\iPod
2009-07-28 21:22 . 2009-07-28 21:22 -------- d-----w- c:\program files\iTunes
2009-07-28 21:22 . 2009-07-28 21:22 -------- d-----w- c:\docume~1\ALLUSE~1\APPLIC~1\{8CD7F5AF-ECFA-4793-BF40-D8F42DBFF906}
2009-07-28 21:22 . 2009-07-28 21:22 -------- d-----w- c:\program files\Bonjour
2009-07-28 21:21 . 2009-07-28 21:22 -------- d-----w- c:\program files\QuickTime
2009-07-28 21:21 . 2009-07-28 21:21 -------- d-----w- c:\docume~1\ALLUSE~1\APPLIC~1\Apple Computer
2009-07-28 21:21 . 2009-07-28 21:21 -------- d-----w- c:\documents and settings\C. Harris\Local Settings\Application Data\Apple
2009-07-28 21:21 . 2009-07-28 21:21 -------- d-----w- c:\program files\Apple Software Update
2009-07-28 21:20 . 2009-07-28 21:20 -------- d-----w- c:\program files\Common Files\Apple
2009-07-28 21:20 . 2009-07-28 21:20 -------- d-----w- c:\docume~1\ALLUSE~1\APPLIC~1\Apple
2009-07-28 21:20 . 2009-07-28 21:23 -------- d-----w- c:\documents and settings\C. Harris\Local Settings\Application Data\Apple Computer
2009-08-05 01:22 . 2006-08-19 07:33 -------- d-----w- c:\documents and settings\C. Harris\Application Data\Petroglyph
2009-08-05 01:22 . 2005-06-23 16:59 -------- d--h--w- c:\program files\InstallShield Installation Information
2009-08-05 01:22 . 2006-08-19 07:22 -------- d-----w- c:\program files\LucasArts
2009-08-05 01:06 . 2007-05-12 16:20 -------- d---a-w- c:\docume~1\ALLUSE~1\APPLIC~1\TEMP
2009-08-05 00:28 . 2009-05-26 22:38 -------- d-----w- c:\documents and settings\C. Harris\Application Data\Skype
2009-08-05 00:21 . 2008-11-24 01:48 -------- d-----w- c:\documents and settings\C. Harris\Application Data\skypePM
2009-07-22 20:10 . 2008-09-22 04:15 -------- d-----w- c:\documents and settings\C. Harris\Application Data\LimeWire
2009-07-12 07:33 . 2006-08-12 06:35 24032 ----a-w- c:\documents and settings\C. Harris\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
2009-07-06 04:21 . 2008-07-17 05:10 -------- d-----w- c:\program files\Common Files\Real
2009-07-06 04:20 . 2009-07-06 04:20 -------- d-----w- c:\program files\Common Files\xing shared
2009-07-06 04:20 . 2009-07-06 04:20 -------- d-----w- c:\program files\Real
2009-07-06 04:20 . 2003-03-19 05:14 499712 ----a-w- c:\windows\system32\msvcp71.dll
2009-07-06 04:20 . 2003-02-21 11:42 348160 ----a-w- c:\windows\system32\msvcr71.dll
2009-07-05 22:47 . 2007-02-22 22:19 -------- d-----w- c:\program files\SpeedFan
2009-06-30 23:39 . 2006-10-23 03:18 21840 ----atw- c:\windows\system32\SIntfNT.dll
2009-06-30 23:39 . 2006-10-23 03:18 17212 ----atw- c:\windows\system32\SIntf32.dll
2009-06-30 23:39 . 2006-10-23 03:18 12067 ----atw- c:\windows\system32\SIntf16.dll
2009-06-26 16:50 . 2004-08-04 12:00 666624 ----a-w- c:\windows\system32\wininet.dll
2009-06-26 16:50 . 2004-08-04 12:00 81920 ----a-w- c:\windows\system32\ieencode.dll
2009-06-16 14:36 . 2004-08-04 12:00 81920 ----a-w- c:\windows\system32\fontsub.dll
2009-06-16 14:36 . 2004-08-04 12:00 119808 ----a-w- c:\windows\system32\t2embed.dll
2009-06-03 19:09 . 2004-08-04 12:00 1291264 ----a-w- c:\windows\system32\quartz.dll
2009-06-02 03:50 . 2009-06-02 03:50 612 ----a-w- c:\windows\eReg.dat
2008-10-29 03:42 . 2008-10-29 03:42 109 --sha-w- c:\windows\system32\2351735403.dat
"swg"="c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2009-02-19 39408]
"updateMgr"="c:\program files\Adobe\Acrobat 7.0\Reader\AdobeUpdateManager.exe" [2006-03-30 313472]
"SMSystemAnalyzer"="c:\program files\iolo\System Mechanic 6\SMSystemAnalyzer.exe" [2006-12-20 557056]
"SetDefaultMIDI"="MIDIDef.exe" - c:\windows\MIDIDEF.EXE [2005-02-17 24576]
"SynTPLpr"="c:\program files\Synaptics\SynTP\SynTPLpr.exe" [2005-05-06 102490]
"SynTPEnh"="c:\program files\Synaptics\SynTP\SynTPEnh.exe" [2005-05-06 708698]
"NvCplDaemon"="c:\windows\system32\NvCpl.dll" [2007-03-09 7561216]
"egui"="c:\program files\ESET\ESET NOD32 Antivirus\egui.exe" [2008-03-13 1443072]
"TkBellExe"="c:\program files\Common Files\Real\Update_OB\realsched.exe" [2009-07-06 198160]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2009-07-13 292128]
"SystemGuardAlerter"="c:\program files\iolo\System Mechanic 6\SystemGuardAlerter.exe" [2006-12-20 386048]
"SSBkgdUpdate"="c:\program files\Common Files\Scansoft Shared\SSBkgdUpdate\SSBkgdupdate.exe" [2003-10-14 155648]
"SetDefPrt"="c:\program files\Brother\Brmfl06a\BrStDvPt.exe" [2005-01-27 49152]
"REGSHAVE"="c:\program files\REGSHAVE\REGSHAVE.EXE" [2002-02-05 53248]
"PaperPort PTD"="c:\program files\ScanSoft\PaperPort\pptd40nt.exe" [2005-03-17 57393]
"ControlCenter3"="c:\program files\Brother\ControlCenter3\brctrcen.exe" [2006-06-29 77824]
"BrMfcWnd"="c:\program files\Brother\Brmfcmon\BrMfcWnd.exe" [2006-06-28 622592]
"ACU"="c:\program files\Atheros\ACU.exe" [2006-03-26 335961]
"Ptipbmf"="ptipbmf.dll" - c:\windows\system32\ptipbmf.dll [2005-05-05 118784]
"High Definition Audio Property Page Shortcut"="HDAudPropShortcut.exe" - c:\windows\system32\Hdaudpropshortcut.exe [2004-08-13 61952]
"nwiz"="nwiz.exe" - c:\windows\system32\nwiz.exe [2007-03-09 1519616]
"CTHelper"="CTHELPER.EXE" - c:\windows\CTHELPER.EXE [2005-02-17 14848]
"AlcWzrd"="ALCWZRD.EXE" - c:\windows\ALCWZRD.EXE [2005-05-06 2748928]
"SoundMan"="SOUNDMAN.EXE" - c:\windows\SOUNDMAN.EXE [2005-05-06 77824]
"{EDB0E980-90BD-11D4-8599-0008C7D3B6F8}"= "c:\program files\Qualcomm\Eudora\EuShlExt.dll" [2005-11-14 86016]
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\WB]
2001-12-21 06:34 24576 ----a-w- c:\program files\AlienGUIse\fastload.dll
"AppInit_DLLs"=c:\windows\system32\wbsys.dll
BootExecute REG_MULTI_SZ autocheck autochk *\0smrgdf c:\program files\iolo\System Mechanic 6"
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Adobe Gamma Loader.lnk]
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Exif Launcher.lnk]
[HKLM\~\startupfolder\C:^Documents and Settings^C. Harris^Start Menu^Programs^Startup^Registration Ghost Recon Advanced Warfighter.LNK]
path=c:\documents and settings\C. Harris\Start Menu\Programs\Startup\Registration Ghost Recon Advanced Warfighter.LNK
backup=c:\windows\pss\Registration Ghost Recon Advanced Warfighter.LNKStartup
HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Cleanup
HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\ioloDelayModule
HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Microsoft Location Finder
HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\MPFExe
HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\OASClnt
HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\VSOCheckTask
"Sprint PCS v3 Utility Service"=2 (0x2)
"MpfService"=2 (0x2)
"mcupdmgr.exe"=3 (0x3)
"McTskshd.exe"=2 (0x2)
"McDetect.exe"=2 (0x2)
"AVGEMS"=2 (0x2)
"Avg7UpdSvc"=2 (0x2)
"Avg7Alrt"=2 (0x2)
"AVG Anti-Spyware Guard"=2 (0x2)
"ProductivITService"=2 (0x2)
"PnkBstrA"=2 (0x2)
"UpdatesDisableNotify"=dword:00000001
"EnableFirewall"= 0 (0x0)
"DisableNotifications"= 1 (0x1)
"c:\\Program Files\\McAfee\\MWL\\MWLSvc.exe"=
"c:\\Program Files\\Electronic Arts\\Crytek\\Crysis\\Bin32\\Crysis.exe"=
"c:\\Program Files\\Electronic Arts\\Crytek\\Crysis\\Bin32\\CrysisDedicatedServer.exe"=
"c:\\Program Files\\LucasArts\\Star Wars Empire at War\\GameData\\sweaw.exe"=
R1 epfwtdir;epfwtdir;c:\windows\system32\drivers\epfwtdir.sys [3/13/2008 4:52 PM 33800]
R1 TeksKernel;TeksKernel;c:\windows\system32\drivers\TeksKernel.sys [7/8/2004 2:14 PM 9060]
R2 ekrn;Eset Service;c:\program files\ESET\ESET NOD32 Antivirus\ekrn.exe [3/13/2008 4:49 PM 472320]
R2 ioloFileInfoList;iolo FileInfoList Service;c:\program files\iolo\Common\Lib\ioloServiceManager.exe [12/14/2008 9:31 PM 596336]
R2 ioloSystemService;iolo System Service;c:\program files\iolo\Common\Lib\ioloServiceManager.exe [12/14/2008 9:31 PM 596336]
R2 viewer_service;SECTRA Viewer Update Service;c:\program files\Sectra\IDS5web\bin\viewer_service.exe [11/12/2007 7:05 PM 24628]
R3 Slazldrv;SmartLink AMR_PCI Driver;c:\windows\system32\drivers\SLDRV\slazldrv.sys [5/5/2005 6:33 PM 230448]
S3 1012NDS5;1012NDS5 NDIS Protocol Driver;c:\windows\system32\1012NDS5.sys [3/11/2003 3:33 PM 15872]
S3 getPlus(R) Helper;getPlus(R) Helper;c:\program files\NOS\bin\getPlus_HelperSvc.exe [1/13/2009 9:19 PM 33752]
S4 ProductivITService;ProductivIT Service;c:\program files\AlienAutopsy\TEKS_Service.exe [7/8/2004 2:22 PM 77824]
Rchjr
Posts Posts : 24
OS OS : windows xp
Post by Rchjr on 5th August 2009, 7:57 pm
Here is the last part:
*Deregistered* - mchInjDrv
BHO-{F64619FF-E19F-4016-BF9C-147CFF821B46} - c:\windows\system32\iehelper.dll
HKCU-Run-CNN.Pipeline.Alerter - c:\program files\CNN Pipeline\CNN.VideoNet.App.exe
HKLM-Run-SpyHunter - c:\progra~1\Grisoft\AVG7\avgcc.exe
HKLM-Run-AVG7_CC - c:\progra~1\Grisoft\AVG7\avgcc.exe
SharedTaskScheduler-IPC Configuration Utility - (no file)
mDefault_Search_URL = [You must be registered and logged in to see this link.]
IE: E&xport to Microsoft Excel
IE: Open using &Advanced JPEG Compressor - c:\program files\Advanced JPEG Compressor\ajcieex.htm
DPF: {7C705EA9-3C3B-4F3A-B1AA-2184CDFAE4D0} - [You must be registered and logged in to see this link.]
DPF: {FC11A119-C2F7-46F4-9E32-937ABA26816E} - [You must be registered and logged in to see this link.]
------- File Associations -------
JSEFile=NOTEPAD.EXE %1
VBEFile=NOTEPAD.EXE %1
VBSFile=NOTEPAD.EXE %1
Rootkit scan 2009-08-05 12:32
"ImagePath"="\??\c:\documents and settings\C. Harris\Desktop\GetThermal_for_SAGER
[1].CLEVO.KAPOK\winio.sys"
[HKEY_LOCAL_MACHINE\System\ControlSet001\Services\WINIO]
[HKEY_USERS\S-1-5-21-3740775528-3358379298-2972928916-1005\Software\Microsoft\Windows\CurrentVersion\Explorer\CLSID]
@Denied: (Full) (LocalSystem)
@SACL=
[HKEY_USERS\S-1-5-21-3740775528-3358379298-2972928916-1005\Software\SecuROM\!CAUTION! NEVER A OR CHANGE ANY KEY*]
"??"=hex:a6,11,e5,54,e3,56,1f,51,48,57,d6,ec,34,d2,aa,b5,14,f2,ca,83,7e,a0,80,
f5,90,52,ad,c9,0a,10,31,32,12,51,91,19,77,ca,a9,25,98,12,b4,c4,4e,6c,f2,14,\
"??"=hex:a1,5e,47,db,25,65,bb,27,8b,92,55,34,10,3f,d9,49
- - - - - - - > 'winlogon.exe'(996)
c:\program files\iolo\Common\Lib\sguard.dll
- - - - - - - > 'lsass.exe'(1052)
- - - - - - - > 'explorer.exe'(3480)
c:\windows\system32\nview.dll
c:\windows\system32\nvwddi.dll
- - - - - - - > 'csrss.exe'(972)
c:\program files\Ahead\InCD\InCDsrv.exe
c:\windows\system32\acs.exe
c:\program files\iolo\System Mechanic 6\IoloSGCtrl.exe
c:\progra~1\McAfee\MWL\MWLSvc.exe
c:\windows\system32\slserv.exe
c:\windows\system32\msiexec.exe
Completion time: 2009-08-05 12:39 - machine was rebooted
ComboFix-quarantined-files.txt 2009-08-05 19:39
Pre-Run: 56,548,380,672 bytes free
Post-Run: 56,473,346,048 bytes free
616 --- E O F --- 2009-08-05 19:36
Thanks for your help. I will make a donation when done.
Rchjr
Rchjr
Posts Posts : 24
OS OS : windows xp
Post by Belahzur on 6th August 2009, 3:16 pm
Now open a new notepad file.
Folder::
File::
Registry::
"UpdatesDisableNotify"=-
"AntiVirusOverride"=-
"FirewallOverride"=-
Post by Rchjr on 6th August 2009, 7:47 pm
Here is the second combi-fix log:
ComboFix 09-08-04.03 - C. Harris 08/06/2009 12:37.2.2 - NTFSx86
Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.2046.1555 [GMT -7:00]
Command switches used :: c:\documents and settings\C. Harris\Desktop\CFScript.txt.lnk
c:\windows\Installer\2765f.msp
c:\windows\Installer\4a247.msp
((((((((((((((((((((((((( Files Created from 2009-07-06 to 2009-08-06 )))))))))))))))))))))))))))))))
"AVGEMS"=2 (0x2)
"Avg7Alrt"=2 (0x2)
"PnkBstrA"=2 (0x2)
Rootkit scan 2009-08-06 12:42
@SACL=
- - - - - - - > 'winlogon.exe'(1016)
- - - - - - - > 'lsass.exe'(1072)
- - - - - - - > 'csrss.exe'(992)
Completion time: 2009-08-06 12:44
ComboFix-quarantined-files.txt 2009-08-06 19:44
ComboFix2.txt 2009-08-05 19:39
Pre-Run: 56,425,750,528 bytes free
Post-Run: 56,376,803,328 bytes free
206 --- E O F --- 2009-08-06 19:30
Rchjr
Posts Posts : 24
OS OS : windows xp
Post by Origin on 6th August 2009, 7:50 pm
[You must be registered and logged in to see this link.] wrote:Hello.
Folder::
File::
Registry::
Hello, it seems that you didn't copy all the contents in the box, please run ComboFix again and make sure you copy all the contents in the box.
Posts Posts : 2685
Post by Rchjr on 7th August 2009, 3:50 am
When I try to drag and drop CFScript.txt into combo-fix again it tells me that it is inncorrectly spelled, it is spelled right. I have tried this 6 times. So I decided that i would delete the desktop icon for combo fix and put another one there. Now when I drag and drop CFScript.txt into combo-fix it tells me that I cant rename combofix to combo-fix, to use something preferrabley something made up of alpha numeric characters. What is going on? What am I doing wrong?
Rchjr
Rchjr
Posts Posts : 24
OS OS : windows xp
Post by Belahzur on 7th August 2009, 6:06 pm
Hello
That didn't work right. You saved it as CFScript.txt.lnk. Remove the .ink extension.
Post by Rchjr on 8th August 2009, 2:42 am
I do not know how the .ink got on the end of the file. Now I have tried this again and now when I drag and drop CFScript.txt into the combo-fix to re run it it tells me that I can not rename combofix to combo-fix. Where have I gone wrong?
Rchjr
Rchjr
Posts Posts : 24
OS OS : windows xp
Post by Belahzur on 8th August 2009, 5:25 pm
Re-download Combofix via the link, but do not rename this time.
Now try dragging and dropping again.
Post by Rchjr on 8th August 2009, 9:05 pm
Here is the log it created. When it ran it said that it needed to install the windows recovery console. MY infected computer is not able to get internet connection due to this malware that has infected it. It said that it could not download files so it aborted. Then it ran and gave this log, this is it in it's enitirety! I have to post this in parts becasue of the size of the log it created.
ComboFix 09-08-07.09 - C. Harris 08/08/2009 13:51.3.2 - NTFSx86
Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.2046.1573 [GMT -7:00]
Running from: I:\ComboFix.exe
* Created a new restore point
((((((((((((((((((((((((( Files Created from 2009-07-08 to 2009-08-08 )))))))))))))))))))))))))))))))
2009-08-07 03:38 . 2009-08-07 03:38 -------- d-s---w- C:\Combo-Fix
2009-07-28 21:22 . 2009-07-28 21:22 -------- d-----w- c:\documents and settings\All Users\Application Data\{8CD7F5AF-ECFA-4793-BF40-D8F42DBFF906}
2009-07-28 21:21 . 2009-07-28 21:21 -------- d-----w- c:\documents and settings\All Users\Application Data\Apple Computer
2009-07-28 21:20 . 2009-07-28 21:20 -------- d-----w- c:\documents and settings\All Users\Application Data\Apple
2009-07-13 21:22 . 2009-07-13 21:22 75048 ----a-w- c:\documents and settings\All Users\Application Data\Apple Computer\Installer Cache\iTunes 8.2.1.6\SetupAdmin.exe
2009-08-05 01:06 . 2007-05-12 16:20 -------- d---a-w- c:\documents and settings\All Users\Application Data\TEMP
"AVGEMS"=2 (0x2)
"Avg7Alrt"=2 (0x2)
"PnkBstrA"=2 (0x2)
Rchjr
Posts Posts : 24
OS OS : windows xp
Post by Rchjr on 8th August 2009, 9:10 pm
Here is the second part:
2009-07-28 c:\windows\Tasks\AppleSoftwareUpdate.job
- c:\program files\Apple Software Update\SoftwareUpdate.exe [2008-07-30 19:34]
2008-12-28 c:\windows\Tasks\ParetoLogic Privacy Controls_{06439176-D49B-11DD-B5FF-000B6B34F7FE}.job
- c:\program files\ParetoLogic\Privacy Controls\Pareto_PC.exe [2008-11-25 18:29]
2009-07-31 c:\windows\Tasks\ParetoLogic Update Version2.job
- c:\program files\Common Files\ParetoLogic\UUS2\Pareto_Update.exe [2008-02-22 19:25]
2009-08-08 c:\windows\Tasks\XoftSpySE 2.job
- c:\program files\XoftSpySE\XoftSpy.exe [2008-12-23 17:08]
2008-12-28 c:\windows\Tasks\XoftSpySE.job
Rootkit scan 2009-08-08 13:56
@SACL=
- - - - - - - > 'explorer.exe'(3592)
- - - - - - - > 'csrss.exe'(988)
Completion time: 2009-08-08 13:57
ComboFix-quarantined-files.txt 2009-08-08 20:57
ComboFix2.txt 2009-08-06 19:44
ComboFix3.txt 2009-08-05 19:39
Pre-Run: 56,389,099,520 bytes free
Post-Run: 56,341,078,016 bytes free
220 --- E O F --- 2009-08-06 19:30
Rchjr
Posts Posts : 24
OS OS : windows xp
whats up
Post by Rchjr on 11th August 2009, 11:34 pm
Hey there,
Have not heard from you in two days, have I done something wrong?
Rchjr
Rchjr
Posts Posts : 24
OS OS : windows xp
Post by Belahzur on 12th August 2009, 5:12 pm
  • Save it to your desktop.
    :files
  • Close OTMoveIt
Please post the OTMoveIt log.
Post by Rchjr on 14th August 2009, 8:35 pm
Here is the log it created:
========== FILES ==========
c:\program files\iiuoww moved successfully.
c:\documents and settings\C. Harris\Application Data\LimeWire\xml\data moved successfully.
c:\documents and settings\C. Harris\Application Data\LimeWire\xml moved successfully.
c:\documents and settings\C. Harris\Application Data\LimeWire\themes\limewirePro_theme moved successfully.
c:\documents and settings\C. Harris\Application Data\LimeWire\themes moved successfully.
c:\documents and settings\C. Harris\Application Data\LimeWire\promotion moved successfully.
c:\documents and settings\C. Harris\Application Data\LimeWire\certificate moved successfully.
c:\documents and settings\C. Harris\Application Data\LimeWire\.AppSpecialShare moved successfully.
c:\documents and settings\C. Harris\Application Data\LimeWire moved successfully.
OTM by OldTimer - Version 3.0.0.6 log created on 08142009_133100
Thaks for your help,
Rchjr
Rchjr
Posts Posts : 24
OS OS : windows xp
Post by Belahzur on 14th August 2009, 9:01 pm
ComboFix /u
Post by Rchjr on 14th August 2009, 9:41 pm
Well I was able to run malwarebytes now and it picked up 19 infected objects. I still have a problem, I am unable to connect to the internet. Somewhere during this process something happened, I have mcafee wireless security and it says that it is disconnected. I dont know how to connect it back. I used to have mcafee virus scan as well and awhile back I tried to unisntall it and everytime I do I get this message " The installation cannot continue because some components are missing c:/progra`1mcafee.com/agent/uninst/comrem.dll) are missing. So I cant uninstall mcafee security suite ( this was for my wireless network) to remove it and start over. Any suggestions? I beleive the original problem is gone.
Thank for your help ,
Rchjr
Rchjr
Posts Posts : 24
OS OS : windows xp
Post by Belahzur on 14th August 2009, 10:55 pm
Completely Uninstall McAfee software
Download the [You must be registered and logged in to see this link.]
Using McAfee Consumer Product Removal Tool
· Double click the MCPR.exe
· A Command Line window will be displayed, and then close automatically.
· Wait for a second Command Line window to be displayed. Note: Do not double-click MCPR.exe again, you may have to wait up to 1 minute for the next window to appear.
· After the second window appears, the program will begin the cleanup.
· Observe the installation, which could take several minutes. The following message will be displayed in the Command Line window: The machine must reboot to complete the un-installation. Reboot now? [y.n]
· Press Y on the keyboard.
· Wait for the computer to restart.
· All McAfee products are now removed from your computer.
Re: Anti Virus System Pro removal help
Post by Rchjr on 15th August 2009, 12:02 am
That did not work, after it ran it locked up about 3/4's of a way thru it. It stayed on something called " removing mwl " , it stayed there for a a half hour. So I closed the window and rebooted. Now when I try and run it again I get two messages. One says clean up failed, the other says clean uip is allready running. What next?
Thanks,
Rchjr
Rchjr
Posts Posts : 24
Joined Joined : 2009-08-02
OS OS : windows xp
Points Points : 26908
Post by Belahzur on 15th August 2009, 1:54 am
Please download Revo Uninstall from here: [You must be registered and logged in to see this link.]
  1. Download and run the setup file for Revo Uninstaller.
  2. Once setup, run Revo Uninstaller.
  3. Select the following item for removal by clicking on it once.
    Mcafee Security Suite
  4. Then hit the "Uninstall" button at the top.
  5. Close Revo Uninstaller.
Post by Rchjr on 15th August 2009, 3:27 am
I must be cursed or something, I installed the revo uninstaller. But the icons for Mcafee wireless network does not show up, nor do any of the mcafee programs accept for the mcafee uninstaller. So that was the only thing it unistalled. How do I get mcafee home wireless network security to show up in the revo uninstaller? I tried to reinstall that program but it said that I had to unistall the previoius version before I could install the new one.
Frustrated!,
Rchjr
Rchjr
Posts Posts : 24
OS OS : windows xp
Post by Origin on 15th August 2009, 6:12 pm
We'll have to remove Mcafee manually with ComboFix:
Posts Posts : 2685
Joined Joined : 2009-05-05
OS OS : Windows Xp Sp3
Points Points : 31533
Post by Rchjr on 15th August 2009, 9:19 pm
I used the respawn disc that came with my alienware laptop and it fixed the problem. I thank you for your help, you got rid of that stupid virus for me.
Where do I make a donationa at?
Thanks again!
Rchjr
Rchjr
Posts Posts : 24
OS OS : windows xp
Post by Belahzur on 15th August 2009, 11:32 pm
