system security virus..critical need help asap.plz
Post by Lito21 on Sun Aug 02, 2009 3:47 am
um running in safe mode,normal boot works but can't run any download ad-ware,nor malware or even spybot..can't access task manager or control panel..etc..internet works still but...the system security 2009 virus is very critical pop ups,and warning..etc..i really dn't have much time i been roamin the www all day lukn for solutions this is my last resort plz help...here i did wat you told me and hijackd this..
Scan saved at 10:50:05 PM, on 7/31/2009
C:\Documents and Settings\lil johnnie\Local Settings\Temporary Internet Files\Content.IE5\SPI3OXU3\winlogon[1].exe
C:\Program Files\Internet Explorer\Iexplore.exe
O4 - HKLM\..\Run: [SVCHOST] C:\WINDOWS\MDM.EXE
O4 - HKLM\..\Run: [IDTSysTrayApp] sttray.exe
O4 - HKLM\..\Run: [11747344] C:\Documents and Settings\All Users\Application Data\11747344\11747344.exe
O4 - HKLM\..\Run: [SNM] C:\Program Files\SpyNoMore\SNM.exe /startup
O4 - HKCU\..\Run: [Weather] C:\Program Files\AWS\WeatherBug\Weather.exe 1
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class)
Lito21
OS : xp
Re: system security virus..critical need help asap.plz
Post by Origin on Sun Aug 02, 2009 6:51 pm
Hello Lito21,
Welcome to Geek Police, my name is Origin and I will be helping you today. Please keep the following in mind:
  • If you do not get a reply from me or another helper within 2 days, please reply to your topic with the phrase BUMP
  • If you have any cracked/pirated software in your computer delete them or we will not help you.
  • Only follow advise from Geek Police Staff and not a regular member.
  • Do NOT run any tool without Geek Police supervision as it could hinder your system useless.
  • Open HijackThis.
    Do not mouse click combofix's window whilst it's running. That may cause it to stall.
OS : Windows Xp Sp3
