Little annoying problems
Re: Little annoying problems
Post by Belahzur on Thu Aug 06, 2009 4:23 pm
Damn, didn't work. Were gonna have to try this next method manually.
Go to Start and in the little search box, just type "Run", then when it finds the run command, right click and select "Run as administrator"
Now when the run command box opens, copy/paste in the following, do not edit this in any way.
notepad "C:\Windows\System32\drivers\vsfoceyqcnixtb.sys"
When it opens, it will show a bunch of random letter junk, this is normal.
Press ctrl+A to select everything (it will go blue highlight) and press the backspace key so it deletes everything, leaving it blank.
Go to File > Save. Press ok to any warning about overwriting it.
Let me know how that goes.
Points Points : 245049
Post by piggyjelly on Thu Aug 06, 2009 4:55 pm
I did it, as far as I know it stays blank with nothing special happening.
piggyjelly
Posts Posts : 30
Joined Joined : 2009-08-01
OS OS : Vista
Points Points : 26854
Post by Belahzur on Thu Aug 06, 2009 6:27 pm
Yes, nothing special is supposed to happen. It worked, I didn't think it would.
Reboot normally.
Now navigate to and see if you can manually delete this file:
Right click > Delete.
Let me know how it goes.
Post by piggyjelly on Thu Aug 06, 2009 7:21 pm
I was able to delete it.
piggyjelly
Posts Posts : 30
OS OS : Vista
Post by Origin on Thu Aug 06, 2009 7:43 pm
Can you run another GMER scan, I want to make sure there's no leftovers.
Posts Posts : 2685
Joined Joined : 2009-05-05
OS OS : Windows Xp Sp3
Points Points : 31463
Post by piggyjelly on Thu Aug 06, 2009 10:10 pm
GMER 1.0.15.15011 [moomoofarm.exe] - [You must be registered and logged in to see this link.]
Rootkit scan 2009-08-06 15:18:23
Windows 6.0.6002 Service Pack 2
---- Services - GMER 1.0.15 ----
Service system32\drivers\vsfoceyqcnixtb.sys (*** hidden *** ) [SYSTEM] vsfocebqneokrv <-- ROOTKIT !!!
Reg HKLM\SYSTEM\CurrentControlSet\Services\vsfocebqneokrv@start 1
Reg HKLM\SYSTEM\CurrentControlSet\Services\vsfocebqneokrv@type 1
Reg HKLM\SYSTEM\CurrentControlSet\Services\vsfocebqneokrv@group file system
Reg HKLM\SYSTEM\CurrentControlSet\Services\vsfocebqneokrv@imagepath \systemroot\system32\drivers\vsfoceyqcnixtb.sys
Reg HKLM\SYSTEM\CurrentControlSet\Services\vsfocebqneokrv\main
Reg HKLM\SYSTEM\CurrentControlSet\Services\vsfocebqneokrv\main@aid
Reg HKLM\SYSTEM\CurrentControlSet\Services\vsfocebqneokrv\main@sid
Reg HKLM\SYSTEM\CurrentControlSet\Services\vsfocebqneokrv\main@cmddelay 0
Reg HKLM\SYSTEM\CurrentControlSet\Services\vsfocebqneokrv\main\delete
Reg HKLM\SYSTEM\CurrentControlSet\Services\vsfocebqneokrv\main\injector
Reg HKLM\SYSTEM\CurrentControlSet\Services\vsfocebqneokrv\main\injector@*
Reg HKLM\SYSTEM\CurrentControlSet\Services\vsfocebqneokrv\main\tasks
Reg HKLM\SYSTEM\CurrentControlSet\Services\vsfocebqneokrv\modules
Reg HKLM\SYSTEM\CurrentControlSet\Services\vsfocebqneokrv\modules@vsfocerk.sys \systemroot\system32\drivers\vsfoceyqcnixtb.sys
Reg HKLM\SYSTEM\CurrentControlSet\Services\vsfocebqneokrv\modules@vsfoce.dat
Reg HKLM\SYSTEM\CurrentControlSet\Services\vsfocebqneokrv\modules@vsfocelog.dat
Reg HKLM\SYSTEM\CurrentControlSet\Services\vsfocebqneokrv\modules@vsfocecmd.dll
Reg HKLM\SYSTEM\CurrentControlSet\Services\vsfocebqneokrv\modules@vsfocewsp.dll
Reg HKLM\SYSTEM\ControlSet003\Services\vsfocebqneokrv@start 1
Reg HKLM\SYSTEM\ControlSet003\Services\vsfocebqneokrv@type 1
Reg HKLM\SYSTEM\ControlSet003\Services\vsfocebqneokrv@group file system
Reg HKLM\SYSTEM\ControlSet003\Services\vsfocebqneokrv@imagepath \systemroot\system32\drivers\vsfoceyqcnixtb.sys
Reg HKLM\SYSTEM\ControlSet003\Services\vsfocebqneokrv\main (not active ControlSet)
Reg HKLM\SYSTEM\ControlSet003\Services\vsfocebqneokrv\main@aid
Reg HKLM\SYSTEM\ControlSet003\Services\vsfocebqneokrv\main@sid
Reg HKLM\SYSTEM\ControlSet003\Services\vsfocebqneokrv\main@cmddelay 0
Reg HKLM\SYSTEM\ControlSet003\Services\vsfocebqneokrv\main\delete (not active ControlSet)
Reg HKLM\SYSTEM\ControlSet003\Services\vsfocebqneokrv\main\injector (not active ControlSet)
Reg HKLM\SYSTEM\ControlSet003\Services\vsfocebqneokrv\main\injector@*
Reg HKLM\SYSTEM\ControlSet003\Services\vsfocebqneokrv\main\tasks (not active ControlSet)
Reg HKLM\SYSTEM\ControlSet003\Services\vsfocebqneokrv\modules (not active ControlSet)
Reg HKLM\SYSTEM\ControlSet003\Services\vsfocebqneokrv\modules@vsfocerk.sys \systemroot\system32\drivers\vsfoceyqcnixtb.sys
Reg HKLM\SYSTEM\ControlSet003\Services\vsfocebqneokrv\modules@vsfoce.dat
Reg HKLM\SYSTEM\ControlSet003\Services\vsfocebqneokrv\modules@vsfocelog.dat
Reg HKLM\SYSTEM\ControlSet003\Services\vsfocebqneokrv\modules@vsfocecmd.dll
Reg HKLM\SYSTEM\ControlSet003\Services\vsfocebqneokrv\modules@vsfocewsp.dll
Reg HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Perflib@Last Counter 5112
Reg HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Perflib@Last Help 5113
---- Disk sectors - GMER 1.0.15 ----
Disk \Device\Harddisk0\DR0 sector 60: copy of MBR
---- EOF - GMER 1.0.15 ----
piggyjelly
Posts Posts : 30
OS OS : Vista
Post by Belahzur on Thu Aug 06, 2009 11:32 pm
Okay, lets finish this now.
1. Copy all the text contained in the code box below to your Clipboard by highlighting it and pressing (Ctrl+CCrying
Drivers to disable:
vsfocebqneokrv
Drivers to delete:
vsfocebqneokrv
Files to delete:
C:\WINDOWS\system32\drivers\vsfoceyqcnixtb.sys
Registry keys to delete:
2. Now, start The Avenger program by clicking on its icon on your desktop.
3. Please copy/paste the content of c:\avenger.txt into your reply.
Post by piggyjelly on Fri Aug 07, 2009 12:06 am
Platform: Windows Vista
Rootkit scan active.
No rootkits found!
Driver "vsfocebqneokrv" disabled successfully.
Driver "vsfocebqneokrv" deleted successfully.
Error: file "C:\WINDOWS\system32\drivers\vsfoceyqcnixtb.sys" not found!
Deletion of file "C:\WINDOWS\system32\drivers\vsfoceyqcnixtb.sys" failed!
--> the object does not exist
Error: registry key "HKLM\SYSTEM\CurrentControlSet\Services\vsfocebqneokrv" not found!
Deletion of registry key "HKLM\SYSTEM\CurrentControlSet\Services\vsfocebqneokrv" failed!
Registry key "HKLM\SYSTEM\ControlSet003\Services\vsfocebqneokrv" deleted successfully.
Completed script processing.
Finished! Terminate.
piggyjelly
Posts Posts : 30
OS OS : Vista
Post by Belahzur on Fri Aug 07, 2009 11:07 pm
Okay, one more scan.
Post by piggyjelly on Sat Aug 08, 2009 12:00 am
DDS (Ver_09-07-30.01) - NTFSx86
Run by andrew at 17:05:31.49 on Fri 08/07/2009
Internet Explorer: 7.0.6002.18005
Microsoft® Windows Vista™ Home Premium 6.0.6002.2.1252.1.1033.18.1918.926 [GMT -7:00]
SP: Lavasoft Ad-Watch Live! *disabled* (Updated) {67844DAE-4F77-4D69-9457-98E8CFFDAA22}
SP: Windows Defender *disabled* (Updated) {D68DDC3A-831F-4FAE-9E44-DA132C1ACF46}
SP: SUPERAntiSpyware *disabled* (Updated) {222A897C-5018-402e-943F-7E7AC8560DA7}
C:\Windows\system32\wininit.exe
C:\Windows\system32\lsm.exe
C:\Windows\system32\svchost.exe -k DcomLaunch
C:\Windows\system32\nvvsvc.exe
C:\Windows\system32\svchost.exe -k rpcss
C:\Windows\System32\svchost.exe -k secsvcs
C:\Windows\System32\svchost.exe -k LocalServiceNetworkRestricted
C:\Windows\System32\svchost.exe -k LocalSystemNetworkRestricted
C:\Windows\system32\svchost.exe -k netsvcs
C:\Windows\system32\SLsvc.exe
C:\Windows\system32\svchost.exe -k LocalService
C:\Windows\system32\svchost.exe -k NetworkService
C:\Windows\system32\rundll32.exe
C:\Windows\System32\spoolsv.exe
C:\Windows\system32\svchost.exe -k LocalServiceNoNetwork
C:\Windows\system32\Dwm.exe
C:\Windows\system32\taskeng.exe
C:\Windows\Explorer.EXE
C:\Program Files\Windows Defender\MSASCui.exe
C:\Windows\RtHDVCpl.exe
C:\Program Files\Spare Backup\SpareBackup.exe
C:\Program Files\McAfee\MSK\mskagent.exe
C:\Program Files\McAfee.com\Agent\mcagent.exe
C:\Windows\System32\rundll32.exe
C:\Program Files\Windows Mail\WinMail.exe
C:\Windows\ehome\ehtray.exe
C:\Windows\ehome\ehmsas.exe
C:\Program Files\Windows Media Player\wmpnscfg.exe
C:\Program Files\Hewlett-Packard\Digital Imaging\bin\hpobnz08.exe
C:\Program Files\Hewlett-Packard\Digital Imaging\bin\hpotdd01.exe
C:\Program Files\Seagate\SeagateManager\Sync\FreeAgentService.exe
C:\Program Files\Common Files\McAfee\HackerWatch\HWAPI.exe
C:\PROGRA~1\McAfee\VIRUSS~1\mcods.exe
c:\PROGRA~1\COMMON~1\mcafee\redirsvc\redirsvc.exe
C:\PROGRA~1\McAfee\MPS\mps.exe
C:\Program Files\McAfee\MSK\MskSrver.exe
C:\Windows\system32\svchost.exe -k NetworkServiceNetworkRestricted
C:\Program Files\Common Files\New Boundary\PrismXL\PRISMXL.SYS
C:\Windows\system32\svchost.exe -k imgsvc
C:\Program Files\McAfee\MPS\mpsevh.exe
C:\Windows\System32\svchost.exe -k WerSvcGroup
C:\Windows\system32\SearchIndexer.exe
C:\Windows\system32\DRIVERS\xaudio.exe
C:\Windows\system32\WUDFHost.exe
C:\Program Files\Windows Media Player\wmpnetwk.exe
c:\program files\common files\mcafee\mna\mcnasvc.exe
C:\Windows\System32\mobsync.exe
C:\Windows\system32\wbem\wmiprvse.exe
C:\Users\andrew\Desktop\dds.scr
uStart Page =
uURLSearchHooks: Yahoo! Toolbar: {ef99bd32-c1fb-11d2-892f-0090271d4f88} - c:\program files\yahoo!\companion\installs\cpn0\yt.dll
BHO: &Yahoo! Toolbar Helper: {02478d38-c3f9-4efb-9b51-7695eca05670} - c:\program files\yahoo!\companion\installs\cpn0\yt.dll
BHO: SSVHelper Class: {761497bb-d6f0-462c-b6eb-d4daf1d92d43} - c:\program files\java\jre1.6.0_01\bin\ssv.dll
BHO: scriptproxy: {7db2d5a0-7241-4e79-b68d-6309f01c5231} - c:\program files\mcafee\virusscan\scriptcl.dll
BHO: Google Toolbar Helper: {aa58ed58-01dd-4d91-8333-cf10577473f7} - c:\program files\google\google toolbar\GoogleToolbar_32.dll
BHO: Google Toolbar Notifier BHO: {af69de43-7d58-4638-b6fa-ce66b5ad205d} - c:\program files\google\googletoolbarnotifier\5.2.4204.1700\swg.dll
BHO: Google Dictionary Compression sdch: {c84d72fe-e17d-4195-bb24-76c02e2e7c4e} - c:\program files\google\google toolbar\component\fastsearch_B7C5AC242193BB3E.dll
BHO: CBrowserHelperObject Object: {ca6319c0-31b7-401e-a518-a07c3db8f777} - c:\windows\system32\BAE.dll
BHO: SingleInstance Class: {fdad4da1-61a2-4fd8-9c17-86f7ac245081} - c:\program files\yahoo!\companion\installs\cpn0\YTSingleInstance.dll
TB: Yahoo! Toolbar: {ef99bd32-c1fb-11d2-892f-0090271d4f88} - c:\program files\yahoo!\companion\installs\cpn0\yt.dll
TB: Google Toolbar: {2318c2b1-4965-11d4-9b18-009027a5cd4f} - c:\program files\google\google toolbar\GoogleToolbar_32.dll
uRun: [ehTray.exe] c:\windows\ehome\ehTray.exe
uRun: [swg] "c:\program files\google\googletoolbarnotifier\GoogleToolbarNotifier.exe"
uRun: [SUPERAntiSpyware] c:\program files\superantispyware\SUPERAntiSpyware.exe
uRun: [WMPNSCFG] c:\program files\windows media player\WMPNSCFG.exe
uRunOnce: [FlashPlayerUpdate] c:\windows\system32\macromed\flash\NPSWF32_FlashUtil.exe -p
mRun: [Windows Defender] %ProgramFiles%\Windows Defender\MSASCui.exe -hide
mRun: [RtHDVCpl] RtHDVCpl.exe
mRun: [Google Desktop Search] "c:\program files\google\google desktop search\GoogleDesktop.exe" /startup
mRun: [Spare Backup] "c:\program files\spare backup\SpareBackup.exe" /silent
mRun: [BigFix] c:\program files\bigfix\bigfix.exe /atstartup
mRun: [MskAgentexe] c:\program files\mcafee\msk\MskAgent.exe
mRun: [mcagent_exe] "c:\program files\mcafee.com\agent\mcagent.exe" /runkey
mRun: [NvCplDaemon] RUNDLL32.EXE c:\windows\system32\NvCpl.dll,NvStartup
mRun: [NvMediaCenter] RUNDLL32.EXE c:\windows\system32\NvMcTray.dll,NvTaskbarInit
mRun: [MaxMenuMgr] "c:\program files\seagate\seagatemanager\freeagent status\StxMenuMgr.exe"
mRun: [Adobe Reader Speed Launcher] "c:\program files\adobe\reader 9.0\reader\Reader_sl.exe"
mRunOnce: [Launcher] %WINDIR%\SMINST\launcher.exe
StartupFolder: c:\progra~2\micros~1\windows\startm~1\programs\startup\hppsc2~1.lnk - c:\program files\hewlett-packard\digital imaging\bin\hpobnz08.exe
StartupFolder: c:\progra~2\micros~1\windows\startm~1\programs\startup\hpoddt~1.lnk - c:\program files\hewlett-packard\digital imaging\bin\hpotdd01.exe
mPolicies-explorer: BindDirectlyToPropertySetStorage = 0 (0x0)
mPolicies-system: EnableLUA = 0 (0x0)
mPolicies-system: EnableUIADesktopToggle = 0 (0x0)
IE: E&xport to Microsoft Excel - c:\progra~1\micros~2\office12\EXCEL.EXE/3000
IE: {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - {CAFEEFAC-0016-0000-0001-ABCDEFFEDCBC} - c:\program files\java\jre1.6.0_01\bin\npjpi160_01.dll
Notify: !SASWinLogon - c:\program files\superantispyware\SASWINLO.dll
AppInit_DLLs: c:\progra~1\google\google~1\GoogleDesktopNetwork3.dll
SEH: SABShellExecuteHook Class: {5ae067d3-9afb-48e0-853a-ebb7f4a000da} - c:\program files\superantispyware\SASSEH.DLL
FF - ProfilePath - c:\users\andrew\appdata\roaming\mozilla\firefox\profiles\597hpac1.default\
FF - plugin: c:\program files\unity\webplayer\loader\npUnity3D32.dll
FF - HiddenExtension: Microsoft .NET Framework Assistant: {20a82645-c095-46ed-80e3-08825760534b} - c:\windows\microsoft.net\framework\v3.5\windows presentation foundation\dotnetassistantextension\
piggyjelly
Posts Posts : 30
OS OS : Vista
---- FIREFOX POLICIES ----
c:\program files\mozilla firefox\greprefs\all.js - pref("media.enforce_same_site_origin", false);
c:\program files\mozilla firefox\greprefs\all.js - pref("media.cache_size", 51200);
c:\program files\mozilla firefox\greprefs\all.js - pref("media.ogg.enabled", true);
c:\program files\mozilla firefox\greprefs\all.js - pref("media.wave.enabled", true);
c:\program files\mozilla firefox\greprefs\all.js - pref("media.autoplay.enabled", true);
c:\program files\mozilla firefox\greprefs\all.js - pref("browser.urlbar.autocomplete.enabled", true);
c:\program files\mozilla firefox\greprefs\all.js - pref("capability.policy.mailnews.*.wholeText", "noAccess");
c:\program files\mozilla firefox\greprefs\all.js - pref("dom.storage.default_quota", 5120);
c:\program files\mozilla firefox\greprefs\all.js - pref("content.sink.event_probe_rate", 3);
c:\program files\mozilla firefox\greprefs\all.js - pref("network.http.prompt-temp-redirect", true);
c:\program files\mozilla firefox\greprefs\all.js - pref("layout.css.dpi", -1);
c:\program files\mozilla firefox\greprefs\all.js - pref("layout.css.devPixelsPerPx", -1);
c:\program files\mozilla firefox\greprefs\all.js - pref("gestures.enable_single_finger_input", true);
c:\program files\mozilla firefox\greprefs\all.js - pref("dom.max_chrome_script_run_time", 0);
c:\program files\mozilla firefox\greprefs\all.js - pref("network.tcp.sendbuffer", 131072);
c:\program files\mozilla firefox\greprefs\all.js - pref("geo.enabled", true);
c:\program files\mozilla firefox\greprefs\security-prefs.js - pref("security.remember_cert_checkbox_default_setting", true);
c:\program files\mozilla firefox\defaults\pref\firefox-branding.js - pref("browser.search.param.yahoo-fr", "moz35");
c:\program files\mozilla firefox\defaults\pref\firefox-branding.js - pref("browser.search.param.yahoo-fr-cjkt", "moz35");
c:\program files\mozilla firefox\defaults\pref\firefox.js - pref("extensions.blocklist.level", 2);
c:\program files\mozilla firefox\defaults\pref\firefox.js - pref("browser.urlbar.restrict.typed", "~");
c:\program files\mozilla firefox\defaults\pref\firefox.js - pref("browser.urlbar.default.behavior", 0);
c:\program files\mozilla firefox\defaults\pref\firefox.js - pref("privacy.clearOnShutdown.history", true);
c:\program files\mozilla firefox\defaults\pref\firefox.js - pref("privacy.clearOnShutdown.formdata", true);
c:\program files\mozilla firefox\defaults\pref\firefox.js - pref("privacy.clearOnShutdown.passwords", false);
c:\program files\mozilla firefox\defaults\pref\firefox.js - pref("privacy.clearOnShutdown.downloads", true);
c:\program files\mozilla firefox\defaults\pref\firefox.js - pref("privacy.clearOnShutdown.cookies", true);
c:\program files\mozilla firefox\defaults\pref\firefox.js - pref("privacy.clearOnShutdown.cache", true);
c:\program files\mozilla firefox\defaults\pref\firefox.js - pref("privacy.clearOnShutdown.sessions", true);
c:\program files\mozilla firefox\defaults\pref\firefox.js - pref("privacy.clearOnShutdown.offlineApps", false);
c:\program files\mozilla firefox\defaults\pref\firefox.js - pref("privacy.clearOnShutdown.siteSettings", false);
c:\program files\mozilla firefox\defaults\pref\firefox.js - pref("privacy.cpd.history", true);
c:\program files\mozilla firefox\defaults\pref\firefox.js - pref("privacy.cpd.formdata", true);
c:\program files\mozilla firefox\defaults\pref\firefox.js - pref("privacy.cpd.passwords", false);
c:\program files\mozilla firefox\defaults\pref\firefox.js - pref("privacy.cpd.downloads", true);
c:\program files\mozilla firefox\defaults\pref\firefox.js - pref("privacy.cpd.cookies", true);
c:\program files\mozilla firefox\defaults\pref\firefox.js - pref("privacy.cpd.cache", true);
c:\program files\mozilla firefox\defaults\pref\firefox.js - pref("privacy.cpd.sessions", true);
c:\program files\mozilla firefox\defaults\pref\firefox.js - pref("privacy.cpd.offlineApps", false);
c:\program files\mozilla firefox\defaults\pref\firefox.js - pref("privacy.cpd.siteSettings", false);
c:\program files\mozilla firefox\defaults\pref\firefox.js - pref("privacy.sanitize.migrateFx3Prefs", false);
c:\program files\mozilla firefox\defaults\pref\firefox.js - pref("browser.ssl_override_behavior", 2);
c:\program files\mozilla firefox\defaults\pref\firefox.js - pref("security.alternate_certificate_error_page", "certerror");
c:\program files\mozilla firefox\defaults\pref\firefox.js - pref("browser.privatebrowsing.autostart", false);
c:\program files\mozilla firefox\defaults\pref\firefox.js - pref("browser.privatebrowsing.dont_prompt_on_enter", false);
c:\program files\mozilla firefox\defaults\pref\firefox.js - pref("geo.wifi.uri", "https://www.google.com/loc/json");
R0 AFS;AFS;c:\windows\system32\drivers\AFS.SYS [2008-4-14 77004]
R0 Lbd;Lbd;c:\windows\system32\drivers\Lbd.sys [2009-7-22 64160]
R1 SASKUTIL;SASKUTIL;c:\program files\superantispyware\SASKUTIL.SYS [2009-6-23 74480]
R2 FreeAgentGoNext Service;Seagate Service;c:\program files\seagate\seagatemanager\sync\FreeAgentService.exe [2009-3-27 165160]
R3 AVer88xHD;AVerMedia 23888 AvStream Video Capture;c:\windows\system32\drivers\AVer88xHD.sys [2007-9-15 401408]
R3 SASENUM;SASENUM;c:\program files\superantispyware\SASENUM.SYS [2009-6-23 7408]
S1 SASDIFSV;SASDIFSV;c:\program files\superantispyware\sasdifsv.sys [2009-6-23 9968]
S3 GoogleDesktopManager-061008-081103;Google Desktop Manager 5.7.806.10245;c:\program files\google\google desktop search\GoogleDesktop.exe [2007-9-15 29744]
S3 Lavasoft Ad-Aware Service;Lavasoft Ad-Aware Service;c:\program files\lavasoft\ad-aware\AAWService.exe [2009-7-3 1029456]
S3 NETw2v32;Intel(R) PRO/Wireless 2200BG Network Connection Driver for Windows Vista;c:\windows\system32\drivers\NETw2v32.sys [2006-11-2 2589184]
2009-08-04 07:27 91 a------- c:\windows\system32\vsfocetpbcydmi.dat
2009-08-04 07:16 18,944 a------- c:\windows\system32\vsfocetvpobrha.dll
2009-08-04 07:16 41,472 a------- c:\windows\system32\vsfoceihbjcqxm.dll
2009-08-03 15:20 26,193 a------- c:\windows\system32\vsfoceiyrvdopr.dat
2009-08-03 14:20 762 a------- c:\windows\system32\vsfoceeeadtedu.dat
2009-08-02 20:44 --d----- c:\program files\common files\Wise Installation Wizard
2009-08-02 16:13 91 a------- c:\windows\system32\vsfocebxtctfpi.dat
2009-08-02 16:02 18,944 a------- c:\windows\system32\vsfocedutbikto.dll
2009-08-02 16:02 41,472 a------- c:\windows\system32\vsfocevmjirnqw.dll
2009-08-02 15:14 11,196 a------- c:\windows\system32\vsfoceprlibcit.dat
2009-08-02 15:04 18,944 a------- c:\windows\system32\vsfoceebipxxii.dll
2009-08-02 15:04 41,472 a------- c:\windows\system32\vsfocexkivgxni.dll
2009-08-02 15:04 67,072 a------- c:\windows\system32\drivers\vsfocevsubmmox.sys
2009-08-02 15:03 402 a------- c:\windows\system32\vsfocevymmowtj.dat
2009-08-02 15:03 --d----- C:\_OTM
2009-08-02 13:34 196,500,522 a------- c:\windows\MEMORY.DMP
2009-08-01 22:58 --dsh--- C:\$RECYCLE.BIN
2009-08-01 22:31 219,648 a------- c:\windows\PEV.exe
2009-08-01 22:31 161,792 a------- c:\windows\SWREG.exe
2009-08-01 22:31 98,816 a------- c:\windows\sed.exe
2009-08-01 16:28 --d----- c:\programdata\Seagate
2009-08-01 16:28 --d----- c:\program files\Seagate
2009-08-01 16:28 --d----- c:\progra~2\Seagate
2009-08-01 16:27 --dsh--- c:\windows\ftpcache
2009-08-01 11:30 91 a------- c:\windows\system32\vsfoceavmbqomv.dat
2009-07-31 15:03 --d----- c:\programdata\SUPERAntiSpyware.com
2009-07-31 15:03 --d----- c:\progra~2\SUPERAntiSpyware.com
2009-07-31 15:02 --d----- c:\users\andrew\appdata\roaming\SUPERAntiSpyware.com
2009-07-31 15:02 --d----- c:\program files\SUPERAntiSpyware
2009-07-31 10:30 18,944 a------- c:\windows\system32\vsfoceionrqtct.dll
2009-07-31 10:28 67,072 a------- c:\windows\system32\drivers\vsfocewrsrpiim.sys
2009-07-31 10:28 41,472 a------- c:\windows\system32\vsfocekicdvdsa.dll
2009-07-31 10:28 18,944 a------- c:\windows\system32\vsfoceqyeuhsgn.dll
2009-07-31 10:27 21,740 a------- c:\windows\system32\vsfoceqiotvxxo.dat
2009-07-31 10:27 67,072 a------- c:\windows\system32\drivers\vsfoceicnqwlro.sys
2009-07-31 10:27 41,472 a------- c:\windows\system32\vsfoceokutuses.dll
2009-07-28 16:18 828,416 a------- c:\windows\system32\wininet.dll
2009-07-28 16:18 78,336 a------- c:\windows\system32\ieencode.dll
2009-07-26 17:32 --d----- c:\windows\system32\eu-ES
2009-07-26 17:32 --d----- c:\windows\system32\ca-ES
2009-07-26 17:32 --d----- c:\windows\system32\vi-VN
2009-07-26 14:20 --d----- c:\windows\system32\EventProviders
2009-07-26 11:17 2,926,592 a------- c:\windows\explorer.exe
2009-07-26 11:16 155,456 a------- c:\windows\system32\mscorier.dll
2009-07-26 11:15 7,168 a------- c:\windows\system32\f3ahvoas.dll
2009-07-26 11:14 247,808 a------- c:\windows\system32\drvstore.dll
2009-07-23 15:00 --d-h--- C:\$AVG8.VAULT$
2009-07-23 14:46 --d----- c:\program files\AVG
2009-07-23 14:46 --d----- c:\programdata\avg8
2009-07-23 14:46 --d----- c:\progra~2\avg8
2009-07-22 23:56 --d----- c:\users\andrew\appdata\roaming\Uniblue
2009-07-22 23:52 506,368 a------- c:\windows\system32\msxml.dll
2009-07-22 23:49 --d----- c:\program files\CCleaner
2009-07-22 23:43 15,688 a------- c:\windows\system32\lsdelete.exe
2009-07-22 23:24 64,160 a------- c:\windows\system32\drivers\Lbd.sys
2009-07-22 23:21 -cd-h--- c:\programdata\{EF63305C-BAD7-4144-9208-D65528260864}
2009-07-22 23:21 -cd-h--- c:\progra~2\{EF63305C-BAD7-4144-9208-D65528260864}
2009-07-22 23:21 --d----- c:\programdata\Lavasoft
2009-07-22 23:21 --d----- c:\program files\Lavasoft
2009-07-22 21:34 --d----- c:\users\andrew\appdata\roaming\AVG8
2009-07-22 20:53 1,110,399 a------- c:\windows\system32\UACcmgexbqvwf.db
2009-07-21 13:17 --d----- c:\program files\iPod
2009-07-21 13:17 --d----- c:\program files\iTunes
2009-07-16 19:17 --d----- c:\users\andrew\appdata\roaming\uTorrent
2009-07-15 00:48 289,792 a------- c:\windows\system32\atmfd.dll
2009-07-15 00:48 156,672 a------- c:\windows\system32\t2embed.dll
2009-07-15 00:48 72,704 a------- c:\windows\system32\fontsub.dll
2009-07-15 00:48 34,304 a------- c:\windows\system32\atmlib.dll
2009-07-15 00:48 23,552 a------- c:\windows\system32\lpk.dll
2009-07-15 00:48 10,240 a------- c:\windows\system32\dciman32.dll
2009-07-14 02:56 --d----- c:\program files\Trend Micro
2009-07-14 02:54 --d----- c:\users\andrew\appdata\roaming\Malwarebytes
2009-07-14 02:54 38,160 a------- c:\windows\system32\drivers\mbamswissarmy.sys
2009-07-14 02:54 19,096 a------- c:\windows\system32\drivers\mbam.sys
2009-07-14 02:54 --d----- c:\programdata\Malwarebytes
2009-07-14 02:54 --d----- c:\program files\Malwarebytes' Anti-Malware
2009-07-14 02:54 --d----- c:\progra~2\Malwarebytes
2009-07-14 02:17 a-d----- c:\programdata\TEMP
2009-08-06 17:10 31,548 a------- c:\users\andrew\appdata\roaming\wklnhst.dat
2009-07-26 17:40 143,360 a------- c:\windows\inf\infstrng.dat
2009-07-26 17:40 86,016 a------- c:\windows\inf\infstor.dat
2009-07-26 17:40 51,200 a------- c:\windows\inf\infpub.dat
2009-07-26 17:32 665,600 a------- c:\windows\inf\drvindex.dat
2009-06-05 11:42 2,060,288 a------- c:\windows\system32\usbaaplrc.dll
2008-09-22 14:47 174 a--sh--- c:\program files\desktop.ini
2006-11-02 05:42 287,440 a------- c:\windows\inf\perflib\0409\perfi.dat
2006-11-02 05:42 287,440 a------- c:\windows\inf\perflib\0409\perfh.dat
2006-11-02 05:42 30,674 a------- c:\windows\inf\perflib\0409\perfd.dat
2006-11-02 05:42 30,674 a------- c:\windows\inf\perflib\0409\perfc.dat
2006-11-02 02:20 287,440 a------- c:\windows\inf\perflib\0000\perfi.dat
2006-11-02 02:20 287,440 a------- c:\windows\inf\perflib\0000\perfh.dat
2006-11-02 02:20 30,674 a------- c:\windows\inf\perflib\0000\perfd.dat
2006-11-02 02:20 30,674 a------- c:\windows\inf\perflib\0000\perfc.dat
============= FINISH: 17:06:05.74 ===============
piggyjelly
Posts Posts : 30
OS OS : Vista
Post by Belahzur on Sat Aug 08, 2009 12:16 am
Lets finish this off now. We've removed the big problems, now just the files to go, and then we can tidy this up.
Files to delete:
Post by piggyjelly on Sat Aug 08, 2009 12:26 am
No rootkits found!
Error: file "Hello." not found!
Deletion of file "Hello." failed!
File "c:\windows\system32\vsfocetpbcydmi.dat" deleted successfully.
File "c:\windows\system32\vsfocetvpobrha.dll" deleted successfully.
File "c:\windows\system32\vsfoceihbjcqxm.dll" deleted successfully.
File "c:\windows\system32\vsfoceiyrvdopr.dat" deleted successfully.
File "c:\windows\system32\vsfoceeeadtedu.dat" deleted successfully.
File "c:\windows\system32\vsfocebxtctfpi.dat" deleted successfully.
File "c:\windows\system32\vsfocedutbikto.dll" deleted successfully.
File "c:\windows\system32\vsfocevmjirnqw.dll" deleted successfully.
File "c:\windows\system32\vsfoceprlibcit.dat" deleted successfully.
File "c:\windows\system32\vsfoceebipxxii.dll" deleted successfully.
File "c:\windows\system32\vsfocexkivgxni.dll" deleted successfully.
File "c:\windows\system32\drivers\vsfocevsubmmox.sys" deleted successfully.
File "c:\windows\system32\vsfocevymmowtj.dat" deleted successfully.
File "c:\windows\system32\vsfoceavmbqomv.dat" deleted successfully.
File "c:\windows\system32\vsfoceionrqtct.dll" deleted successfully.
File "c:\windows\system32\drivers\vsfocewrsrpiim.sys" deleted successfully.
File "c:\windows\system32\vsfocekicdvdsa.dll" deleted successfully.
File "c:\windows\system32\vsfoceqyeuhsgn.dll" deleted successfully.
File "c:\windows\system32\vsfoceqiotvxxo.dat" deleted successfully.
File "c:\windows\system32\drivers\vsfoceicnqwlro.sys" deleted successfully.
File "c:\windows\system32\vsfoceokutuses.dll" deleted successfully.
File "c:\windows\system32\msxml.dll" deleted successfully.
File "c:\windows\system32\UACcmgexbqvwf.db" deleted successfully.
piggyjelly
Posts Posts : 30
OS OS : Vista
Post by Origin on Sat Aug 08, 2009 12:29 am
Run another Malwarebytes scan and post the results here.
Posts Posts : 2685
Post by piggyjelly on Sat Aug 08, 2009 12:42 am
Malwarebytes' Anti-Malware 1.40
Database version: 2575
8/7/2009 5:50:26 PM
mbam-log-2009-08-07 (17-50-26).txt
Objects scanned: 78558
Time elapsed: 3 minute(s), 27 second(s)
piggyjelly
Posts Posts : 30
OS OS : Vista
Post by Origin on Sat Aug 08, 2009 12:44 am
ComboFix /u
Posts Posts : 2685
Post by piggyjelly on Sat Aug 08, 2009 12:49 am
I don't get redirected anymore, and I can use the standby again.
Thank you guys sooo much!
piggyjelly
Posts Posts : 30
OS OS : Vista
Post by Origin on Sat Aug 08, 2009 12:57 am
Posts Posts : 2685
