System Security problems annoying!
Re: System Security problems annoying!
Post by Belahzur on Mon Aug 03, 2009 8:03 pm
Lets give this a try.
Please download this fix tool from [You must be registered and logged in to see this link.].
Double click it to run it.
Allow it to run if protection programs stop it.
The services should now be back to default value and no longer appear in Hijack This.
Points Points : 245059
Post by qwerty8520 on Sun Aug 09, 2009 3:28 pm
it ran but that little red shield with an X is still there.
qwerty8520
Posts Posts : 22
Joined Joined : 2009-07-31
Points Points : 26891
Post by qwerty8520 on Sun Aug 09, 2009 3:34 pm
to rephrase the issue: the little red shield is telling me that Automatic Updates are turned off. When I go into the Windows Security Center to turn them on, it wont let me. It says to do it under "system". When i go there, it says they are already on.
qwerty8520
Posts Posts : 22
Post by Belahzur on Mon Aug 10, 2009 12:12 am
Please download Combofix again, I want to run a script.
Now open a new notepad file.
Registry::
"lsass"=-
"cmdService"=-
"NetSvc"=-
"AntiVirusOverride"=-
RegNull::
[HKEY_USERS\S-1-5-21-3718120316-2962900541-1544400087-1006\Software\Microsoft\Windows\CurrentVersion\Shell Extensions\Approved\{269ACD91-1918-BD05-1028-476C5D1839CA}*]
Post by qwerty8520 on Thu Aug 13, 2009 2:29 am
ComboFix 09-08-10.06 - Randi 08/12/2009 14:21.2.1 - NTFSx86
Microsoft Windows XP Professional 5.1.2600.2.1252.1.1033.18.510.265 [GMT -5:00]
Running from: c:\documents and settings\Randi\Desktop\ComboFix.exe
Command switches used :: c:\documents and settings\Randi\Desktop\CFScript.txt
AV: AntiVir Desktop *On-access scanning disabled* (Outdated) {AD166499-45F9-482A-A743-FDD3350758C7}
AV: Norton AntiVirus *On-access scanning disabled* (Updated) {E10A9785-9598-4754-B552-92431C1C35F8}
c:\windows\Downloaded Program Files\popcaploader.inf
((((((((((((((((((((((((( Files Created from 2009-07-12 to 2009-08-12 )))))))))))))))))))))))))))))))
2009-08-12 04:01 . 2009-08-12 04:01 459131 ----a-w- c:\documents and settings\All Users\Application Data\Avira\AntiVir Desktop\TEMP\UPDATE\ave2\win32\int\aescript.dll
2009-08-12 04:01 . 2009-08-12 04:01 356725 ----a-w- c:\documents and settings\All Users\Application Data\Avira\AntiVir Desktop\TEMP\UPDATE\ave2\win32\int\aegen.dll
2009-08-09 15:48 . 2009-07-28 21:33 55656 ----a-w- c:\windows\system32\drivers\avgntflt.sys
2009-08-09 15:48 . 2009-03-30 15:33 96104 ----a-w- c:\windows\system32\drivers\avipbb.sys
2009-08-09 15:48 . 2009-02-13 17:29 22360 ----a-w- c:\windows\system32\drivers\avgntmgr.sys
2009-08-09 15:48 . 2009-02-13 17:17 45416 ----a-w- c:\windows\system32\drivers\avgntdd.sys
2009-08-09 15:48 . 2009-08-09 15:48 -------- d-----w- c:\program files\Avira
2009-08-09 15:48 . 2009-08-09 15:48 -------- d-----w- c:\documents and settings\All Users\Application Data\Avira
2009-08-06 15:01 . 2009-08-06 15:01 69632 ----a-w- c:\documents and settings\All Users\Application Data\Apple Computer\Installer Cache\Safari 4.31.9.1\SetupAdmin.exe
2009-08-03 02:56 . 2009-08-03 02:56 -------- d-----w- c:\documents and settings\Randi\Local Settings\Application Data\PC_Drivers_Headquarters
2009-08-03 02:54 . 2009-08-03 02:54 -------- d-----w- c:\documents and settings\All Users\Application Data\PC Drivers HeadQuarters
2009-08-03 02:54 . 2009-08-03 02:54 -------- d-----w- c:\program files\PC Drivers HeadQuarters
2009-08-02 19:11 . 2009-08-02 19:11 -------- d-s---w- C:\Combo-Fix
2009-08-01 01:01 . 2009-07-11 19:34 276344 ----a-w- c:\documents and settings\All Users\Application Data\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\Norton\Definitions\IPSDefs\20090730.003\IDSXpx86.sys
2009-08-01 01:01 . 2009-07-11 19:34 293424 ----a-w- c:\documents and settings\All Users\Application Data\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\Norton\Definitions\IPSDefs\20090730.003\IDSvix86.sys
2009-08-01 01:01 . 2009-07-11 19:34 533880 ----a-w- c:\documents and settings\All Users\Application Data\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\Norton\Definitions\IPSDefs\20090730.003\Scxpx86.dll
2009-08-01 01:01 . 2009-07-11 19:34 451960 ----a-w- c:\documents and settings\All Users\Application Data\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\Norton\Definitions\IPSDefs\20090730.003\IDSxpx86.dll
2009-08-01 01:01 . 2009-07-11 19:34 397360 ----a-w- c:\documents and settings\All Users\Application Data\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\Norton\Definitions\IPSDefs\20090730.003\IDSviA64.sys
2009-08-01 00:22 . 2009-07-31 23:59 177520 ----a-w- c:\documents and settings\All Users\Application Data\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\Norton\Definitions\VirusDefs\20090731.025\NAVENG32.DLL
2009-08-01 00:22 . 2009-07-31 23:59 1181040 ----a-w- c:\documents and settings\All Users\Application Data\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\Norton\Definitions\VirusDefs\20090731.025\NAVEX32A.DLL
2009-08-01 00:22 . 2009-07-31 23:59 371248 ----a-w- c:\documents and settings\All Users\Application Data\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\Norton\Definitions\VirusDefs\20090731.025\EECTRL.SYS
2009-08-01 00:22 . 2009-07-31 23:59 101936 ----a-w- c:\documents and settings\All Users\Application Data\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\Norton\Definitions\VirusDefs\20090731.025\ERASER.SYS
2009-08-01 00:22 . 2009-07-31 23:59 259368 ----a-w- c:\documents and settings\All Users\Application Data\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\Norton\Definitions\VirusDefs\20090731.025\ECMSVR32.DLL
2009-08-01 00:22 . 2009-07-31 23:59 2414128 ----a-w- c:\documents and settings\All Users\Application Data\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\Norton\Definitions\VirusDefs\20090731.025\CCERASER.DLL
2009-08-01 00:11 . 2009-08-01 00:11 -------- d-----w- c:\documents and settings\Randi\Local Settings\Application Data\Symantec
2009-08-01 00:00 . 2009-07-31 23:59 36400 ----a-r- c:\windows\system32\drivers\SymIM.sys
2009-07-31 23:59 . 2009-07-31 23:59 60808 ----a-w- c:\windows\system32\S32EVNT1.DLL
2009-07-31 23:59 . 2009-07-31 23:59 124464 ----a-w- c:\windows\system32\drivers\SYMEVENT.SYS
2009-07-31 23:59 . 2009-07-31 23:59 -------- d-----w- c:\program files\Symantec
2009-07-31 23:59 . 2009-07-31 23:59 1290592 ----a-w- c:\documents and settings\All Users\Application Data\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\Norton\SyKnAppS\SyKnAppS.dll
2009-07-31 23:59 . 2009-07-31 23:59 136840 ----a-w- c:\documents and settings\All Users\Application Data\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\Norton\SyKnAppS\patch25.dll
2009-07-31 23:59 . 2009-07-31 23:59 796016 ----a-w- c:\documents and settings\All Users\Application Data\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\Norton\CLT\cltLMSx.dll
2009-07-31 23:59 . 2009-07-31 23:59 -------- d-----w- c:\windows\system32\drivers\NAV
2009-07-31 23:59 . 2009-07-31 23:59 -------- d-----w- c:\program files\Norton AntiVirus
2009-07-31 23:59 . 2009-07-31 23:59 -------- d-----w- c:\program files\Windows Sidebar
2009-07-31 23:24 . 2009-07-31 23:24 -------- d-----w- c:\documents and settings\LocalService\Application Data\Apple Computer
2009-07-31 23:24 . 2009-07-31 23:24 -------- d-----w- c:\documents and settings\LocalService\Local Settings\Application Data\Apple Computer
2009-07-31 08:00 . 2009-07-31 08:00 87888 ----a-w- c:\documents and settings\All Users\Application Data\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\Norton\Definitions\VirusDefs\20090731.025\NAVENG.SYS
2009-07-31 08:00 . 2009-07-31 08:00 875728 ----a-w- c:\documents and settings\All Users\Application Data\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\Norton\Definitions\VirusDefs\20090731.025\NAVEX15.SYS
2009-07-30 21:55 . 2009-07-30 21:55 -------- d-----w- c:\program files\Common Files\Wise Installation Wizard
2009-07-30 02:18 . 2009-07-30 02:18 444 ----a-w- c:\windows\system32\d3d8caps.dat
2009-07-25 18:20 . 2009-07-25 18:21 -------- d-----w- c:\program files\iTunes
2009-07-25 18:14 . 2009-07-25 18:14 75040 ----a-w- c:\documents and settings\All Users\Application Data\Apple Computer\Installer Cache\iTunes 8.2.1.6\SetupAdmin.exe
2009-07-25 05:53 . 2009-08-01 00:00 -------- d-----w- c:\documents and settings\All Users\Application Data\Norton
2009-07-25 05:53 . 2009-07-31 23:58 -------- d-----w- c:\documents and settings\All Users\Application Data\NortonInstaller
2009-07-25 03:18 . 2001-08-16 21:19 61440 ----a-w- c:\windows\system32\mjpcodec.dll
2009-07-25 03:18 . 2000-09-15 20:51 372736 ----a-w- c:\windows\system32\ijl15.dll
2009-07-25 02:51 . 2009-07-25 02:51 -------- d-----w- c:\windows\system32\Adobe
2009-08-12 18:33 . 2009-03-05 22:24 -------- d-----w- c:\program files\Safari
2009-08-11 01:36 . 2008-09-19 03:34 -------- d---a-w- c:\documents and settings\All Users\Application Data\TEMP
2009-08-01 02:38 . 2008-11-26 23:52 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
2009-08-01 00:03 . 2008-07-03 23:06 -------- d-----w- c:\program files\Common Files\Symantec Shared
2009-08-01 00:01 . 2008-09-17 23:03 -------- d-----w- c:\documents and settings\Randi\Application Data\GetRightToGo
2009-07-31 23:59 . 2008-07-05 01:08 805 ----a-w- c:\windows\system32\drivers\SYMEVENT.INF
2009-07-31 23:59 . 2008-07-05 01:08 7386 ----a-w- c:\windows\system32\drivers\SYMEVENT.CAT
2009-07-31 23:59 . 2008-07-03 23:18 -------- d-----w- c:\documents and settings\All Users\Application Data\Symantec
2009-07-26 23:32 . 2008-08-25 22:41 -------- d-----w- c:\documents and settings\Randi\Application Data\U3
2009-07-25 18:21 . 2005-02-26 02:36 -------- d-----w- c:\program files\iPod
2009-07-25 18:21 . 2007-09-03 21:42 -------- d-----w- c:\program files\Common Files\Apple
2009-07-13 18:36 . 2008-11-26 23:52 38160 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2009-07-13 18:36 . 2008-11-26 23:52 19096 ----a-w- c:\windows\system32\drivers\mbam.sys
2009-07-11 19:34 . 2009-07-11 19:34 276344 ----a-w- c:\documents and settings\All Users\Application Data\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\Norton\Definitions\IPSDefs\BinHub\IDSXpx86.sys
2009-07-11 19:34 . 2009-07-11 19:34 293424 ----a-w- c:\documents and settings\All Users\Application Data\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\Norton\Definitions\IPSDefs\BinHub\IDSvix86.sys
2009-07-11 19:34 . 2009-07-11 19:34 533880 ----a-w- c:\documents and settings\All Users\Application Data\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\Norton\Definitions\IPSDefs\BinHub\Scxpx86.dll
2009-07-11 19:34 . 2009-07-11 19:34 451960 ----a-w- c:\documents and settings\All Users\Application Data\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\Norton\Definitions\IPSDefs\BinHub\IDSxpx86.dll
2009-07-11 19:34 . 2009-07-11 19:34 397360 ----a-w- c:\documents and settings\All Users\Application Data\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\Norton\Definitions\IPSDefs\BinHub\IDSviA64.sys
2009-07-07 18:36 . 2009-07-07 18:32 -------- d-----w- c:\program files\Celtx
2009-07-07 18:33 . 2009-07-07 18:33 -------- d-----w- c:\documents and settings\Randi\Application Data\Greyfirst
2009-07-02 01:17 . 2009-07-02 01:17 69632 ----a-w- c:\documents and settings\All Users\Application Data\Apple Computer\Installer Cache\Safari 4.30.19.1\SetupAdmin.exe
2009-06-28 16:18 . 2004-10-28 21:53 -------- d-----w- c:\program files\Yahoo!
2009-06-28 16:16 . 2004-10-22 15:58 -------- d--h--w- c:\program files\InstallShield Installation Information
2009-06-28 16:15 . 2004-11-13 16:03 -------- d-----w- c:\documents and settings\Randi\Application Data\Atari
2009-06-15 03:54 . 2008-05-20 01:06 -------- d-----w- c:\program files\Common Files\DVDVideoSoft
2009-06-15 03:54 . 2008-05-20 21:18 -------- d-----w- c:\program files\DVDVideoSoft
2009-06-14 19:45 . 2009-06-14 19:45 -------- d-----w- c:\program files\SystemRequirementsLab
2009-06-07 17:53 . 2009-06-07 17:53 784 ----a-w- c:\documents and settings\Randi\Application Data\mpauth.dat
2009-06-05 22:43 . 2009-06-05 22:43 69632 ----a-w- c:\documents and settings\All Users\Application Data\Apple Computer\Installer Cache\Safari 4.30.17.0\SetupAdmin.exe
2009-05-29 18:36 . 2008-09-10 02:22 2060288 ----a-w- c:\windows\system32\usbaaplrc.dll
2009-05-29 18:36 . 2007-10-14 19:21 39424 ----a-w- c:\windows\system32\drivers\usbaapl.sys
2007-05-27 00:27 . 2006-03-30 18:02 288 ---ha-w- c:\program files\hpothb07.dat
2007-05-27 00:27 . 2006-03-30 18:02 17221 ---ha-w- c:\program files\hpothb07.tif
2006-03-30 18:02 . 2006-03-30 18:02 11996604 ----a-w- c:\program files\Scan0001.tif
qwerty8520
Posts Posts : 22
"Messenger (Yahoo!)"="c:\program files\Yahoo!\Messenger\YahooMessenger.exe" [2009-02-04 4363504]
"QuickTime Task"="c:\program files\QuickTime\QTTask.exe" [2009-05-26 413696]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2009-07-13 292128]
"Malwarebytes Anti-Malware (reboot)"="c:\program files\Malwarebytes' Anti-Malware\mbam.exe" [2009-07-13 1287440]
"avgnt"="c:\program files\Avira\AntiVir Desktop\avgnt.exe" [2009-03-02 209153]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\SymEFA.sys]
@="FSFilter Activity Monitor"
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Adobe Reader Speed Launch.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\Adobe Reader Speed Launch.lnk
backup=c:\windows\pss\Adobe Reader Speed Launch.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Microsoft Office.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\Microsoft Office.lnk
backup=c:\windows\pss\Microsoft Office.lnkCommon Startup
"iPodService"=3 (0x3)
"YPCService"=3 (0x3)
"WMPNetworkSvc"=3 (0x3)
"WANMiniportService"=2 (0x2)
"Symantec Core LC"=3 (0x3)
"SPTISRV"=3 (0x3)
"Pml Driver HPZ12"=3 (0x3)
"PACSPTISVR"=3 (0x3)
"MSCSPTISRV"=3 (0x3)
"MDM"=2 (0x2)
"LVPrcSrv"=2 (0x2)
"LiveUpdate Notice"=2 (0x2)
"LiveUpdate"=3 (0x3)
"iPod Service"=3 (0x3)
"IDriverT"=3 (0x3)
"gusvc"=3 (0x3)
"dsNcService"=2 (0x2)
"comHost"=3 (0x3)
"CLTNetCnService"=2 (0x2)
"ccSetMgr"=2 (0x2)
"ccEvtMgr"=2 (0x2)
"Automatic LiveUpdate Scheduler"=2 (0x2)
"AOL ACS"=2 (0x2)
"MSIServer"=3 (0x3)
"c:\\Program Files\\Trillian\\trillian.exe"=
"c:\\Program Files\\Microsoft Office\\Office12\\GROOVE.EXE"=
"c:\\Program Files\\Common Files\\McAfee\\MNA\\McNASvc.exe"=
"3389:TCP"= 3389:TCP:*:Disabled:@xpsp2res.dll,-22009
R0 SymEFA;Symantec Extended File Attributes;c:\windows\SYSTEM32\DRIVERS\NAV\1005000.086\SymEFA.sys [7/31/2009 06:59 PM 310320]
R1 BHDrvx86;Symantec Heuristics Driver;c:\windows\SYSTEM32\DRIVERS\NAV\1005000.086\BHDrvx86.sys [7/31/2009 06:59 PM 258608]
R1 ccHP;Symantec Hash Provider;c:\windows\SYSTEM32\DRIVERS\NAV\1005000.086\cchpx86.sys [7/31/2009 06:59 PM 482352]
R1 IDSxpx86;IDSxpx86;c:\documents and settings\All Users\Application Data\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\Norton\Definitions\IPSDefs\20090730.003\IDSXpx86.sys [7/31/2009 08:01 PM 276344]
R2 AntiVirSchedulerService;Avira AntiVir Scheduler;c:\program files\Avira\AntiVir Desktop\sched.exe [8/9/2009 10:48 AM 108289]
R2 McAfee SiteAdvisor Service;McAfee SiteAdvisor Service;c:\program files\McAfee\SiteAdvisor\McSACore.exe [11/26/2008 07:18 PM 203280]
R2 Norton AntiVirus;Norton AntiVirus;c:\program files\Norton AntiVirus\Engine\16.5.0.134\ccSvcHst.exe [7/31/2009 06:59 PM 115560]
S3 smrtdrv;SMART Technologies Inc. Mirror Driver;c:\windows\system32\DRIVERS\smrtdrv.sys --> c:\windows\system32\DRIVERS\smrtdrv.sys [?]
*NewlyCreated* - SSMDRV
*Deregistered* - IPVNMon
2009-08-07 c:\windows\Tasks\AppleSoftwareUpdate.job
- c:\program files\Apple Software Update\SoftwareUpdate.exe [2008-07-30 17:34]
2009-07-15 c:\windows\Tasks\McDefragTask.job
- c:\progra~1\mcafee\mqc\QcConsol.exe [2008-11-27 19:32]
2009-08-01 c:\windows\Tasks\McQcTask.job
2009-08-12 c:\windows\Tasks\User_Feed_Synchronization-{B36647E1-C803-449B-949A-7AEA25C58288}.job
- c:\windows\system32\msfeedssync.exe [2006-10-17 17:58]
Rootkit scan 2009-08-12 14:33
[HKEY_LOCAL_MACHINE\System\ControlSet003\Services\Norton AntiVirus]
"ImagePath"="\"c:\program files\Norton AntiVirus\Engine\16.5.0.134\ccSvcHst.exe\" /s \"Norton AntiVirus\" /m \"c:\program files\Norton AntiVirus\Engine\16.5.0.134\diMaster.dll\" /prefetch:1"
- - - - - - - > 'winlogon.exe'(792)
c:\windows\system32\SEGina.dll
Completion time: 2009-08-12 14:40
ComboFix-quarantined-files.txt 2009-08-12 19:38
ComboFix2.txt 2009-08-01 05:25
Pre-Run: 24,101,564,416 bytes free
Post-Run: 24,149,221,376 bytes free
224 --- E O F --- 2008-07-08 22:46
qwerty8520
Posts Posts : 22
Post by Belahzur on Thu Aug 13, 2009 4:30 pm
Does updates work now?
Post by qwerty8520 on Fri Aug 14, 2009 2:43 am
Nope. Still tells me to go to "system" under control panel. But when I go there, it says its already on. Yet the little pop up by my clock tells me it's not. I have a link to some pictures of it.
Security center:
System properties:
qwerty8520
Posts Posts : 22
Post by Belahzur on Fri Aug 14, 2009 6:09 pm
I wonder if it's a bug.
Turn automatic updates off, then switch them back on again, it should work itself out then.
Post by qwerty8520 on Sat Aug 22, 2009 6:56 pm
Nope. Still there. No way!
qwerty8520
Posts Posts : 22
Post by Origin on Sat Aug 22, 2009 6:58 pm
  • Close all windows and double click OTListIt2.exe
  • It will produce two logs for you, one will pop up - OTListIt2.txt, the other will be saved on your Desktop - Extras.txt. Post both logs in this thread.
Posts Posts : 2685
Joined Joined : 2009-05-05
OS OS : Windows Xp Sp3
Points Points : 31473
