How to Increse DL speed
Post by wath56 on 26th July 2009, 6:23 am
My LAN connection should be 100mb/s but i only have 1.0 upload speed and and 9.94 DL (speedtest.net - 54mi distance) ISP Rogers - (Firefox/GoogleChrome) I've heard i just have to speed it up at the TCP but i dont want to try it without some proffesional advice- what can i do and if its not worth it say so please.
WIN XP
1.5GB Memory
Geforce 8500GT
I aslo defragg malware bites est. regularly
wath56
Posts Posts : 19
Joined Joined : 2009-07-23
OS OS : 7
Points Points : 27083
Re: How to Increse DL speed
Post by Doctor Inferno on 26th July 2009, 7:30 am
You could use 'Open DNS'. They allow you to go through their DNS servers and many have reported a noticeable increase in speed.
They have configuration pages for your OS or hardware router.
http://www.opendns.com/
Secondly, If you’re on Windows, install 'FastCache'.
AnalogX FastCache is a caching DNS server that runs on your local machine and handles any DNS request that your computer makes, from Internet Explorer to your favorite FTP client. Once a query is made, FastCache will override the normal timeout for the item with one that you specify, so instead of saving a query for a couple of seconds, it can save it for a couple of days. Now every time you ask for it again while it's in the cache, it gives it to you instantly.
http://www.analogx.com/CONTENTS/download/network/fc.htm
You could also tweak your internet speed if you are using firefox by doing the following:
in the address bar type in about:config >> in the filter bar type in pipe under network.http.pipelining >> right click toogle >> under network.http.pipelining.maxrequests >> right click >> Modify and change the value to 30.
This makes firefox use 30 connections instead of just 4. making your surfing speed slightly faster.
Points Points : 104630
Post by wath56 on 27th July 2009, 12:00 am
I've already tried those a while ago any other ways? also i think my connection is faster if not just as fast as open dns
wath56
Posts Posts : 19
OS OS : 7
Post by Doctor Inferno on 5th August 2009, 7:55 am
I think you are referring the connection speed of 100MB/s to the one shown in the notification area in Windows. That is simply the connection speed of the network card to your router/modem. Not the Internet connection speed.
