Firefox and IE + Registry problems?
Post by wath56 on Thu Jul 23, 2009 3:39 am
hey b4 i start ill list my computer specs:
1533 MB Memory (RAM)
160 GB hardrive (94 FREE)
FIREFOX/IE8
WINDOWS XP
NORTON 360
Geforce 8500 GT
the problem is that when i use firefox to open certain websites like hotmail (which used to work just fine) it wont really load. and on IE it loads but you cant open the mail. I defragment alot and use N360 to perform scans regualarly i also used most of your tips to try and speed up my connection (gotten slow lately) but i cant seem to open the dns site suggestion. also my connection is currently broadband-secondly i used a trail version or regcure to scan for registry problems it found quite a few (but norton cant fix that kind of stuff) so can u reccommend a free registry fixing program?
*update used open dns so diregard that part - also constant video buffing because of my connection can be added to problem list
wath56
Posts Posts : 19
Joined Joined : 2009-07-23
OS OS : 7
Points Points : 27053
Re: Firefox and IE + Registry problems?
Post by AuroraRange on Thu Jul 23, 2009 7:24 am
Registry fixing is not recommended as it might cause even more problem. If you insist, try CCleaner or advance system care.
Posts Posts : 507
Joined Joined : 2008-08-22
OS OS : Xubuntu & Windows 7
Points Points : 30789
Post by wath56 on Fri Jul 24, 2009 12:39 am
hmm well now the only problem is that when i try to open some pages they just show a white blank page and the bottom sais its loading somthin but nothing will apear after long waiting
wath56
Posts Posts : 19
OS OS : 7
