System Secure - cant open programs or safe mode, winlogon.exe method not working
Post by Drew_Irons on Thu Jul 23, 2009 12:16 am
I am experiencing the same symptoms as everyone else with System Secure. I noticed that the winlogon.exe method is supposed to help you run programs but I cant get them to run. I cant open the task manager, regedit, msconfig, add or remove programs, or boot in safe mode. I am thinking about wiping the hard drive.
What should I do?
Drew_Irons
Joined Joined : 2009-07-23
Points Points : 26934
Re: System Secure - cant open programs or safe mode, winlogon.exe method not working
Post by Origin on Fri Jul 24, 2009 6:35 pm
Hello Drew_Irons,
Welcome to Geek Police, my name is Origin and I will be helping you today. Please keep the following in mind:
  • If you do not get a reply from me or another helper within 2 days, please reply to your topic with the phrase BUMP
  • If you have any cracked/pirated software in your computer delete them or we will not help you.
  • Only follow advise from Geek Police Staff and not a regular member.
  • Do NOT run any tool without Geek Police supervision as it could hinder your system useless.
  3. Then look in the left hand bottom of the program and press "Registry"
  4. When the registry list opens, drag the line between the two windows so you can see which registry hive you need.
  5. Next, open the HKEY_LOCAL_MACHINE, and navigate to the following key:
  6. Now look in the right side pane for two run values that are just random numbers.
  7. Once you have found the value(s), right click it and press "Delete"
  8. Okay the prompt and close IceSword.
Posts Posts : 2685
Joined Joined : 2009-05-05
OS OS : Windows Xp Sp3
Points Points : 31483
Post by Drew_Irons on Tue Jul 28, 2009 10:32 pm
I don't think I made myself clear.
I cannot run any programs. This virus/rogue program has taken over my system. It wont let me run ice sword, malwarebytes, spybot, regedit, task manager, or any other program. Renaming the file to "winlogon.exe" does not work either.
Is there anything I can do? I am seriously about to wipe the had drive.
Drew_Irons
Post by Belahzur on Wed Jul 29, 2009 5:50 pm
Lets try something else that is not an exe file.
Points Points : 245069
